PANGEA AC-14 C7-IEC Power Cable 1m
The power cable Pangea AC-14 is specifically designed for source components, which do not require the same current levels as receivers and amplifiers. The AC-14 delivers more current while offering multiple layers of shielding and other features that ensure extremely clean and noise-free power to your equipment.
Reference : 22051
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 20-11-2026.
Pangea AC-14 C7-IEC Power Cable Schuko IEC C7 Triple Shielding OFC Copper Gold-Plated 3x2mm² 1m
Thumbnail of the Pangea AC-14 C7 IEC
The power cable Pangea AC-14 is specifically designed for source components, which do not require the same current levels as receivers and amplifiers. The AC-14 delivers higher current while incorporating multiple shielding layers, enabling an extremely clean and noise-free power supply for your equipment.
Pangea designed the AC-14 specifically for powering AV components. It allows optimization of the performance of preamplifiers, CD players, DVD/Blu-ray players, DACs and other line-level components.
The AC-14 uses 99.99% OFC copper conductors, ensuring maximum conductivity.
Spiral counter-conductors provide enhanced noise protection, while the triple shielding ensures effective protection against RFI and EMI interference while improving isolation for sensitive source components.
The AC-14 connector contacts are 24k gold-plated, ensuring improved conductivity and strong resistance to oxidation.
Cross-section diagram of the Pangea AC-14 C7 IEC
Technical specifications
Product typeAC power cable
Connectors1x 24k gold-plated Schuko
1x 24k gold-plated IEC-C7
Conductor materialOFC copper (99.99%)
Cross-section14AWG (2.08mm²)
Triple shielding
Outer diameter12mm
Cable length1m
Package contents1x Pangea AC-14 C7 IEC 1m
Length (m)1.0
ShieldingYes
Section (mm²)2.00
ConnectorSchuko
An exceptional cable
An exceptional power cable — robust and compact. Tight passages and sharp angles during routing could potentially be an issue. The sound of the HiFi system (Bluesound Node Icon, Rotel A11mk2, Focal Aria Evo X N°1) is extremely clear.
This review has been posted for PANGEA AC-14 C7-IEC Power Cable Schuko IEC C7 Triple Shielding OFC Copper Gold Plated 3x2mm² 1m
The power cable Pangea AC-14 is specifically designed for source components, which do not require the same...
