ARMATURE ELECTRA F8 V2 Filtered Power Distributor 8 Sockets Aluminium Black
ARMATURE ELECTRA Filtered Power Distributor 8 Sockets Aluminium Black
-13%
The Armature Electra F8 V2 is a high quality filtered mains distributor, integrating two direct sockets and four filtered sockets which will give your music back its real color.
KEY POINTS :
  • OCC Copper
  • CLC filter
  • 2500W 10A
  • Gold plated contacts
  • 2 Direct taps without filtering
  • 6 CLC EMI / RFI filtered outlets
Reduced price!
Reference : 12358
Limited special offer
229,00 €tax incl.
-13%
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Filtered power mains distributor 8 outlets
Armature Electra Distributeur Secteur Multiprise filtrée 8 prises
An essential hifi element
The mains power is the first link in your Hifi system. It is essential to offer for your Hifi system a stable and clean voltage devoid of any harmonic distortions. It is in this sense that Armature has developed Electra, a range of innovative sector distributors offering two modes of operation.
Filtered Mode and Direct Mode
To suit all needs and systems, this Electra F8 V2 integrates 2 outlets in Direct mode for your power amplifiers. These 2 gold-plated sockets respects the rhythm of the music without the effects of dynamic compression. The Electra F8 also has 6 CLC filtered outlets that effectively lower the potential interference (RFI, EMI) that could affect the sound reproduction of your audio system. The result is convincing : your system widens its dynamic range to assert itself in the bass and treble mediums become more accurate, more natural and offering a great respect of harmonics.
Armature Electra Distributeur Secteur Multiprise Mode Direct et Mode Filtré
Reference picture : Armature Electra F6 V2
A high quality filter
To achieve this feature, the Armature Electra F8 mains distributor incorporates an oversized CLC-type power filter, consisting of WIMA film capacitors and a custom Tore Ferrite choke, to divide AC mains distortion by 8 (dependent on the quality of your mains installation). In addition, all contacts are Gold plated to ensure excellent signal conductivity. All wire is in OCC copper wire 2.5mm² section.
Armature Electra Distributeur Secteur Multiprise de Grande Qualité
A secure system
The Electra Power Distributor is capable of supporting up to 2500W over 10A and features a resettable circuit breaker to protect your HiFi system.
Armature Electra Distributeur Secteur Multiprise sécurisé
TypeFiltered mains distributor wired in OCC copper 2.5mm² section
Connectors number8 (2 direct + 6 filtered CLC)
Type of filterCLC (WIMA capacitors and ferrite tore)
Maximum power2500W 10A
ContactsGold plated
Box materialAluminium + rubber feet
Dimensions39.7 x 15.5 x 6.8cm
Weight1.8kg
Accessories1x IEC cable 1.5m
Number of sockets8
FilteringYes
3 reviews
Multiprise de qualité.
Je viens de brancher cette multiprise, ampli de puissance X2 sur direct et streamer, dac sur filtrée.
J' obtiens un son plus propre, une bande passante bien plus étendue de bas en haut, des détails supplémentaire et des basses bien détourées et tendues. Elle n' est pas encore " rodée" et donne déjà un gain important comparé à mon ancienne barrette, certe moins aboutie mais déjà audiophile. Je recommande sans hésitation.
This review has been posted for ARMATURE ELECTRA F8 V2 Filtered Power Distributor 8 Sockets Aluminium Black
a
Très content de cette acquisition. Produit de qualité avec une belle finition. Je l'ai mis en évidence sur mon meuble Hi Fi NORDOST tel un élément de mon système puisqu'il apporte une réelle valeur ajoutée:
Définition, qualité des timbres, aération de la scène sonore
Super Multiprises
Distributeur de grande qualité de fabrication, juste un peu encombrant mais tellement pratique avec les 8 prises, dont 6 filtrées, dédiées à mon ensemble musical. il me semble que la musique a gagnée en clarté. C'est un bon investissement.
The Armature Electra F8 V2 is a high quality filtered mains distributor, integrating two direct sockets and four filtered sockets which will give...
