AUDIOPHONICS MPC6 V2 Aluminum Distributor 6 ports SILVER
4.2 / 5
Reference : 11575
119,00 €tax incl.
99,17 € tax excl.
The Audiophonics MPC6 V2 represents the next generation of high-end power strips. The Audiophonics MPC6 V2, with a revised and corrected finish with rounded fingernails and improved mechanical strength, offers great possibilities for optimization.
This bare box to assemble allows you to express your creativity by choosing according to your needs the different components among the bases and cabling that we distribute.
This new generation MPC6 V2 includes a new aluminum finish with increased electromechanical performance.
Throughout the process of creating this product the emphasis has been placed on the choice of materials so as to obtain one of the best possible interconnections sector.
To complete your bare MPC6V2 distributor, we recommend the following IEC and SCHUKO connectors, selected by the Audiophonics team:
Sockets Schuko:
IEC sockets:
Wiring:
Thickness chassis:
  • Facades: 3.5 mm
  • Sides: 3.5 mm
  • Top: 8mm
  • Bottom: 3 mm
Features:
  • Number of slots compatible Schuko imprint: 6
  • 1 slot for IEC plug (Furutech FI-Inlet compatible)
  • Anti-sleep rubber feet
  • Dimensions (in mm): 340 x 123 x 75 (W x W x H)
  • Weight: 1.770kg
Warning ! This Audiophonics MPC6 V2 mains socket is to be mounted. It comes with all necessary hardware.
audiophonics MPC6 V2 silver
ColorSilver
MaterialAluminium
FilteringN/A
Internal widthN/A
Internal depthN/A
Internal heightN/A
5 reviews
un boitier solide
Beau boitier une fois monté, comptez 2 heures de montage pour un bon résultat...mon boitier était plein de copeaux d'alu qui obstruaient les emplacements de vissage, pensez à vous munir de clés Allen coudées de différents diamètres. Coté musique grosse amélioration surement due aux prises schuko Furutech Rodium, j'ai réalisé un câblage en étoiles avec du câble cuivre de 2,5mm . Pas de connecteur IEC mais un passe-câble elecaudio pour amener un câble prisonnier de gros diamètre
This review has been posted for AUDIOPHONICS MPC6 V2 Aluminum Distributor 6 ports SILVER
Great!
Surprisingly more than my expectations. Order in Silver color but look luxuries, shiny, and elegant, has all screws and they fit perfectly. Very easy and straight forward to set up, but the quality and build look very high end. Its worth feed high end resolution gears.
Special thanks to CS, and more more to David.
Great base for a DIY distributor
Nice surface, perfect fit. If you want to build your own distributor, this case is a good base to start.
Fabrication top
bon produit avec matériaux de qualité mais à assembler soi même, il faut compter environ 4h de boulot pour concevoir ce boitier avec embases et cablages, Une * de moins juste pour ce côté à faire soi même (monter et visser la boite
Meglio prima,MA MOLTO MEGLIO PRIMA.
Sempre di ottima fattura,ma l'aumento del prezzo non è nelle aspettative, prima l'alluminio era lucido,ora è trattato e opaco,esteticamente piu' bella prima e piu' pesante dando l'impressione di robustezza,Togliendo materiale + guadagno -peso, prima la iec la davano gratuitamente e i piedini in gomma da avvitare sono stati sostituiti con 4 adesivi in silicone. 10€ in piu' per avere meno,Complimenti!!!
 (5)
