POWERGRIP YG-2 Power Distributor Conditioner Filtered 6 schuko surcharge overload protection
For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format. Like its big brother the YG1-V2, it is capable of operating at very high power (3520 watts, 16 amps).
4.7 / 5
By buying this product you get 98 loyalty points
Reference : 12885
985,00 €tax incl.
820,83 € tax excl.
POWERGRIP YG-2
3x2 filtering power distributor with overload protection
Powergrip YG 2 Audiophonics
For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format. Like its big brother the YG1-V2, it is capable of operating at very high power (3520 watts, 16 amps). Huge efficiency capable of powering a massive complex audio system wanting great power supply, or even a complete home theater.
YG 2 distributor is designed for audiophile facilities with an integration in limited space. This version was deliberately shortened on height (80 mm) and depth (185 mm) to be easily integrated into most environments lacking space.
Level 1, High filtering level:
mains filter for digital camera and decoder
The device operates a hyper accurate filtering system, capable of detecting and removing the smallest noise from your power lines. As a result, the value from having high-quality component in your devices becomes way more perceivable (especially when it comes to reading files, decoding and converting sampling rates). Clocks, in particular, benefit from accurate and filtered power supply, which greatly limits the jitter and decoding error that can be heard.
The sector filter will also enhance the life cycle of your equipment thanks to clean energy (without unecessary constraint when operating).
YG 2 has 2  filtering sockets dedicated to digital source devices (DAC, CD players, flat screens amp FDA) which allows for a deepening of the digital background, which is fundamental for true high-quality audio.
Level 2, mainstream:
sector HIFI analog filter element
YG-2 Powergrip has 2 plug with dedicated filter for analog devices (preamplifiers, turntables). This adjustment stabilizes the incoming stream, which improves the micro-dynamic by reducing background noise depth.
The device also offers a suppression of unwanted noise filtering and protection against effective against current peaks.
Level 3, High current:
Filter power amp for sector
Ultimate YG-2 has two sockets specifically designed for power amplifiers. With 2 taken HIGH CURRENT sectors, the YG-2 Powergrip filter ignores the typical dynamic compaction problems of high power without processing sector amplifications.
Trigger and ignition automation
Powergrip YG2 trigger
YG 2 Powergrip has a trigger system taken ignition to choose the boot order of your devices. It can therefore be set so that the digital and analog sources light up first, followed by the pre-amplifiers and power amplifiers. YG 2 can itself be triggered by an IN trigger and triggered any compatible device via a trigger OUT (video projectors, flat screens).
Peripherals and intelligent protection:
Powergrip YG-2 protection
Naturally the YG-2 has all the modern protections against overvoltage with a clever cut-off system to immunize your appliances against power ridges that could damage components. Besides a really significant improvement in the reproduction of audio video signal, smart distribution system also provides effective protection to your installatio.
Warning: YG-2 Powergrip power distribution console must imperatively be connected to a mains with a viable land to benefit from the sector protection and its advanced filtering system.
It has a separate terminal on plated Gold screw to be connected to a clean ground connection.
Typefilter distributor sector
Number of Schuko sockets programmable Filteredx6
Voltage190 - 256V
Capacity3680W @ 230V
Ampere16A
FilteringFort (DAC, CD player, FDA, screens)
Grand current (preamp, turntables)
High current (Power Amplifiers)
Manual commandfront panel
Enabling and disabling autoConfiguration of delays between outlet groups
Trigger12V
Entrance
Exit
Integration interfaces supportedControl4, Creston, AMX ...
Protectionemergency limit: ≤ 190 ± 4V / ≥ 256 ± 4V
Current crest65.000A
Dimensions440 x 80 x 185 mm
Weight4.8kg
Panel materialBrushed aluminum 4 mm
Parts suppliedPower cable 1,5m (Section de 1.5mm² avec prise C19)
Support Rack 19 inches
Number of sockets6
FilteringYes
Download
3 reviews
Après plusieurs mois d'utilisation
Je complète mon avis après deux ou trois ans d'utilisation., J'ai maintenant deux Powergrip sur mon système principal, ce qui est parfait compte tenu de la multitude d'appareils à alimenter (TV, Lecteur BR, Pré-Pré vinyle, Platine TD, Pré-ampli stéréo, Pré-ampli AV, Caisson de basses, deux amplis de puissance entre autres).
Je vis dans un pays tropical ou l'alimentation en électricité est souvent perturbée. Ce système protège mes appareils en commutant lors des incidents les plus brutaux.
Le fonctionnement est sans problème après plusieurs mois, l'aspect reste très bon et le fait de pouvoir tout éteindre en appuyant sur deux boutons en façade est particulièrement pratique.
Tout cela pour dire : une étoile en plus.
This review has been posted for POWERGRIP YG-2 Power Distributor Conditioner Filtered 6 schuko surcharge overload protection
Une multiprise hors de prix ?
Sur un système « résolvant », (JMR Offrandes - 2 Pass Aleph 5 - Primare Pré 35 -Pré Pré Clearaudio Balance - Cellule Clearaudio Stadivardi) et en remplacement d’un Dynavox x6000 je n’entends aucune différence.
En revanche l’appareil est très joli, bien fabriqué, assez ergonomique avec un interrupteur en face avant.
Attention si vous comptez utiliser un câble secteur plus en rapport avec les prétentions et le prix du Powergrip, il vous faut une terminaison en IEC C19. Par chance J’avais un Shunyata de bonne qualité à ce format.
Mon installation étant entièrement symétrique j’envisage l’achat d’un deuxième Powergrip en remplacement d’un deuxième Dynavox. Je pense aussi monter deux câbles secteurs basés Viablue.
L’addition est très élevée. C’est mon seul reproche sur ce produit dont la valeur que je perçois est inférieure à 500 euros.
Alors une multiprise hors de prix : oui
Bon investissement
Effet très net sur la clarté générale,les aigus et l’ouverture de la scène sonore et tout cela avec les câbles secteur « basiques ».Je ne regrette pas mon achat.
For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format....
