FURUTECH AC-1501 (R) IEC Base C13 Rhodium Plated EMI noise filter 230V 15A
FURUTECH AC-1501(R) IEC Base Rhodium Plated noise filter/ EMI 230V 1A
11143
64,00 €tax incl.
53,33 € tax excl.
Accessories
This basesector IEC FURUTECH AC-1501 Rwithnon-magnetic treatment Alpha answers the problems related to pollution sector with the technological processes that have made the success of the Japanese brand.
The nylon and fiberglass body (Piezo Epoxy), andplated connectors Rhodium guarantee internal immunity, a significant reduction in parasitic noise,strong>electromagnetic interference EMI and EFI .
This filter is most effective for filtering disturbances when the capacitors prove to be insufficient
An excellent choice to transform the sound of a CD player, a DAC and devices with low current consumption like preamplifiers for example.
This FURUTECH IEC filter will be especially effective in hostile environments surrounded by bad quality AC adapters rejecting the harmful sector pollution for audio fidelity: (internet box, games console, smartphone 5V USB, house lighting).
This versionplated Rhodium ensured stability over time against corrosion without detracting from the electrical qualities of this mains filter.
The result is immediately recognizable with a limpid sound, a calm, and a better rendering of the higher harmonics.
This filter is imperative to be connected to ground to operate at its highest potential.
This socket is compatible with the lugsFURUTECH FT-210.
Specifications:
  • Type: IEC C13
  • Outputs on Rhodium plated lugs with cryogenic processing Alpha
  • IEC Plated Rhodium Pin with Cryogenic Alpha Treatment
  • Internal Fiberglass Body, Zinc Epoxy and Nylon
  • Metal outer body
  • Two pines plus ground
  • Operating Voltage: 115V / 250V Max 50 / 60Hz
  • Current 15A
Dimensions and weight:
  • Dimensions: 57x28x20.8mm
  • Weight: 40g
MaterialCuivre
PlatingRhodium
ConnectionScrew
ConnecticMale
ConnecteurC20
Porte FusibleNon
Colissimo - TNT - SoColissimo
