POWERGRIP YG-1 V2 Power Filter Distributor 11 schuko surcharge overload protection
The Powergrip YG-1, powerful distributor and mains filter with its 11 Schuko sockets is the essential element for all enthusiasts wishing to protect its Hifi Home Cinema.
By buying this product you get 159 loyalty points
Reference : 11404
1 595,00 €tax incl.
1 329,17 € tax excl.
This product has been replaced by the new version, the POWERGRIP YG-3 Power Filter Distributor 12 Sockets 16A.
Powergrip YG-1V2
11-outlet mains filter with overload protection
Powergrip YG-1
The Powergrip YG-1, powerful distributor and mains filter with its 11 Schuko sockets is the essential element for all enthusiasts wishing to protect its Hifi Home Cinema. Featuring advanced phase detection and overload protection capabilities, the YG-1 has many advantages. Moreover, thanks to a filtering system of very high quality, it allows a noticeable noise reduction (ripple) concerning the electrical installations deficient. Much more than an accessory, it brings readability of the sound message, a reduction of video noise on video projectors.
An audiophile filtering system on 3 levels
Level 1, high level of filtering:
The filtering system of the YG-1 mains distributor detects and removes even the smallestnoises on power lines that can ruin your listening experience. The filtering will also extend the life cycle of your equipment by providing clean energy. The Powergrip YG-1 has 4 filter sockets for the original digital devices (DAC, CD players, FDA flat panel displays) to back up digital background noise, an essential element for true high-definition audio.
Level 2, large current:
the Powergrip YG-1 has 4 sockets with dedicated filtering for analog devices (preamplifiers, vinyl turntables) allowing an adaptation that does not degrade the sound performance but on the contrary participating in a better precision and an increased dynamic microphone. It also offers interference suppression and lightning protection on 2 gold-plated connectors, a standard antenna plug for your tuners, satellite boxes, flat screens.
Level 3, High current:
End of the end the YG-1 has two sockets designed specifically for power amplifiers. With its 2 HIGH CURRENT power outlets, the Powergrip YG-1 filter does not have the problems of dynamic settlement on high-power amplifiers typical of poorly designed AC power solutions.
A programmable automation of the mains plugs and two triggers:
The Powergrip YG-1 dispdocking system to select the start order of your devices. So you can trigger your digital and analog sources first, followed by preamplifiers to finish on the amplifiers. The YG-1 can itself be triggered by an IN trigger and trigger any compatible device via a trigger OUT (video projectors, flat panel displays).
<! - PICTURE LEFT / TEXT RIGHT ->
Powergrip YG-1
Surge protection and intelligent protection:
Of course the YG-1 has all the modern surge protections with an intelligent shut-off system to protect your appliances from the dangers of mains power. This intelligent distribution system incorporates effective protection coupled with a noticeable improvement in the reproduction of the audio video signal.
Warning :the Powergrip YG-1 power distribution console must be connected to a mains power supply with a viable ground to benefit from mains protection and its advanced filtering system.
It has a separate terminal on gold-plated screw allowing to connect it to a viable ground.
Technical Features
Connectors
Number of programmable Schuko sockets10 on the rear panel divided into 6 groups
USB sockets2x for 5V 2A load
IN / OUT aerial socket1x
Grounded gold plated socket1x
Trigger IN / OUT jack1x
Capacity Joule6220 J
Front Voltmeter240V
Maximum tensile stress187000 A
Overload protection190V +/- 4V / 256V +/- 4V
Maximum power3520W 16A
Input Voltage220V / 240V
Dimensions, weights and accessories
Support rack 19 "Included
Power cable 1.50mSection of 3.3mm² 16A with plug C19
Total dimensions440 x 150 x 405 mm
Weight10kg
A description in English in PDF demonstrates the scope of the Powergrip YG-1 in the "Download" tab.
Schuko dedicated analogue and high current sector sockets:
Powergrip YG-1 prises analogiques et haut courant
Dedicated Schuko sector sockets Digital and low current:
Powergrip YG-1 prises digital et fainle courant
Powergrip YG-1
Number of sockets11
FilteringYes
2 reviews
Excellent
Multiprise qui protège vos électroniques des surtensions ou sous tensions du secteur: coupure. Réarmement manuel qui permet de se rendre compte que ce genre de mésaventure n'est pas si rare! Filtrage efficace contre les appareils pollueurs. Pas donné mais c'est le prix de la qualité et de l'efficacité.
This review has been posted for POWERGRIP YG-1 V2 Power Filter Distributor 11 schuko surcharge overload protection
POWERGRIP YG-1 V2
Produit très bien présenté, la qualité semble être au rendez vous. Appareil assez lourd. L’expédition est sans problème, l’appareil est super protégé. Manque la notice en Français, mais on la trouve sans difficulté sur internet
The Powergrip YG-1, powerful distributor and mains filter with its 11 Schuko sockets is the essential element for all enthusiasts wishing to...
