IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V
Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality. The PurePi integrates a 5V supercapacitor power supply and a second isolated 3.3V LifePO4 battery rail. Thanks to the use of spring contacts, it is very easy to install a Raspberry Pi or other audio HAT on top of the PurePi, without the need for an additional power supply connector.
Reference : 18200
125,00 €tax incl.
104,17 € tax excl.
Shipping date: 08-05-2025.
Ian Canada PurePi II
The PurePi is from a functional point of view equivalent to a ConditionerPi 5V associated with a LifePO4Mini 3.3V.
Version II
This new version of the PUREPI offers a number of significant improvements.
Version II improvements and new features :
  • [New feature] SYNC charging function added. This allows the battery to be re-loaded when the music stops, prolonging usage time while avoiding voltage drops and triggering the protection mode. Perfect for long listening sessions.
  • [New feature] Also works for Pi free applications.
  • [Upgrade] Support USB-C PD (power delivery) protocol. This enables the use of high-speed USB-C cables.
  • [Upgrade] No longer locks SD card, ON/OFF control connector has been moved.
Key features:
  • 5V supercapacitor power supply with two 100F-2.7V supercapacitors pre-installed. ESR less than 10mΩ.
  • Isolated 3.3V power supply on LifePO4 battery, with pre-installed battery cradle for two 18650 cells. ESR below 6mΩ.
  • Gold-plated spring contacts to power a Raspberry Pi directly via the GPIO, without adding a connector.
  • Works as a stand for a complete audio project. Spikes can be installed, as well as rubber rings, to limit vibrations.
  • Only a 5V 2.5A power supply required as input, via USB-C.
  • Integrated ON/OFF button. Can be deported to have an external switch.
  • ON/OFF control signal for integration into a multi-power supply system as a master ON/OFF control.
  • Integrated protection system to prevent battery wear and maintain an adequate electrical signal.
  • Ultra-low noise and high dynamic range passive power supply.
  • Ultra low ESR MOSFETs controlled by optical isolators to eliminate current leakage.
Product typePower supply module for Raspberry Pi
Input voltage5V 2.5A
Output voltageUltracapacitor power supply: 5V
Batteries power supply: 3.3V
Dimensions141*108mm
Mouting holes spacing127*94mm
InputScrew terminals
OutputPCB Connector
2 reviews
Excellent system
Along with a RaspberryPi 4 and the other Ian Canada products, FIFOPi Q7 II, TransportPi AES, this makes an excellent streamer. Very detailed and rich, balanced sound across the frequency range. It is easy to assemble and programming the Raspberry Pi with Ropieee is straightforward. The YouTube Gabster channel helps with this and this video is a good place to start: https://youtu.be/Tc_QfRTbb6U?si=dLAMcCxoA9bha-cP
This review has been posted for IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V
IAN CANADA PUREPI
Incredible power system for Raspberry PI and for ES9038 + FIFO Q7 II. Allows you to obtain a very clean power supply. Great work at a low cost. I am very satisfied
Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality....
