IFI AUDIO IPOWER X Low Noise Switched Mode Power Supply 12V 2A
iFi Audio offers with its iPower X power adapter a very low noise power supply, designed to cleanly power your HiFi modules and devices, contributing greatly to the quality of audio playback of a system. This model delivers a voltage of 12VDC for a current of 2A.
Reference : 14433
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 19-05-2026.
iFi Audio iPower X
iFi Audio iPower X Adaptateur Secteur Alimentation Faible Bruit 5V 3A
iFi Audio offers with its iPower X power adapter a very low noise power supply, designed to cleanly power your HiFi modules and devices, contributing greatly to the quality of audio playback of a system. This model delivers a voltage of 12VDC for a current of 2A (3A max). The power supply incorporates advanced technologies and features to deliver excellent performance. The AC adapter also comes with a variety of DC jack adapters in different formats to fit most devices.
A white 5.5/2.5mm DC jack adapter with reverse polarity is supplied with this power supply.
Active Noise Cancellation 2
Proprietary Active Noise Cancellation 2 technology generates an opposite-phase signal to cancel power supply noise, similar to noise-cancelling headphones.
Key points :
  • Active Noise Cancellation 2 to cancel the incoming noise.
  • Input capacitance 50% larger for more filtration and dynamics.
  • Output capacitance 150% larger
  • Solid organic capacitors for better suppression of high-frequency noise
  • Leakage capacitance < 20x. Less than normal SMPS (100pF vs 2200pF)
  • 20% more power
Product typeSwitching mode power supply
Input voltage / current100-240VAC 1.5A 50/60Hz
Output voltage / current12V 2A continuous
12V 3A maximum
Output connectorJack DC 5.5/2.1mm (different adapters included, see package)
Noise floor~1uV
Dimensions95 x 80 x 43mm
Weight195g
ColorWhite and beige
Package1x iFi Audio iPower X 12V 2A
1x Jack DC 5.5/2.5mm adapter
1x Jack DC 4.8/1.7mm adapter
1x Jack DC 4.0/1.7mm adapter
1x Jack DC 3.5/1.35mm adapter
1x Jack DC 5.5/2.5mm reverse polarity adapter (white adapter)
Output voltage (V)12.0
7 reviews
Belle amélioration
Sur un switch ethernet en amont du streamer, les instruments sont plus intégrés et plus en place avec une dynamique accrue sans aucune agressivité.
Un petit reproche : il manque un adaptateur pour les appareils ayant une prise d’alimentation USB à acheter séparément
This review has been posted for IFI AUDIO IPOWER X Low Noise Switched Mode Power Supply 12V 2A
Que demander de plus ?
Placé derrière un petit DAC Geshelli à la place de l'adaptateur d'origine, l'iPowerX apporte immédiatement un grave plus percutant, une scène sonore plus profonde et quelque chose de plus "moelleux", de plus "posé" dans le médium… un régal à l'oreille. A noter qu'il fournit plus du double en puissance de l'adaptateur d'origine. Une optimisation essentielle pour redécouvrir son DAC !
bon matos
très bonne alimentation, très silencieuse, dommage les leds blanches qui s'allument en permanence en utilisation. je ne regrette absolument pas mon achat.
Toute la différence avec un découpage basique
Cela fonctionne parfaitement bien; On a de la finesse en plus vu le recul phénoménal du bruit ! Bien supérieure à une alimentation à découpage à résonance qui sont très puissantes mais n'atteignent pas la finesse réalisée par la marque Ifi sur ses Power alimentions audio.
Placé en amont d'un système dématérialisé utilisant le streaming (donc sur une Livebox).
Les voix sont plus présentes et les instruments plus détourés (par rapport au transformateur 12V livré d'origine).
D'autres essais avec une alimentation linéaire basique de la box et même un conditionneur de courant étaient restés infructueux!
la box semble se comporter comme une source de meilleure qualité : le célèbre switch venu de Mariposa en Californie à l'autre bout d'un Câble ordinaire Ethernet cat 6 de 10 mètres ne manque pas de faire encore mieux son travail!
iFi Audio offers with its iPower X power adapter a very low noise power supply, designed to cleanly power your HiFi modules and devices,...
