Relay Volume Control Input Selector Board 50K
This handy volume control module uses a series of relays, allowing precise adjustment of the sound level. Control is via an ALPS 27 potentiometer. The volume controller comes with a source selection volume on which 4 pairs of RCA connectors.
Reference : 15007
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 14-10-2025.
 Volume Control / Input Selector Board
Module de contrôle de volume sélection de source
This handy volume control module uses a series of relays, allowing precise adjustment of the sound level. Control is via an ALPS 27 potentiometer. The volume controller comes with a source selection volume on which 4 pairs of RCA connectors (sold separately) can be installed. The power supply ground, as well as those of the left and right channels are independent. All functions can be controlled remotely using the supplied remote control.
Product typeVolume control / input selection boards
PotentiometerALPS27
Number of slots for RCA connectors (sold separately)8
Potentiometer shaft diameterØ6mm
Potentiomater shaft typeNotched
IR Receiver LED
Remote control(AAA 1.5V batteries sold separately)
Power supply5V DC 1A (sold separately)
Boards dimensions100 x 65mm
InputSolder pad
OutputSolder pad
Channel2 (Stereo)
Les bonnes cartes!
Installées dans deux préamplis maison à tubes : un sacré coup de jeune! les cartes sont très bien étudiées, pas encombrantes, donc facilement intégrables. Cerise sur le gâteau: la commutation du volume par résistances pilotées par relais , offre une écoute stable, linéaire avec une belle plénitude et un beau recule du bruit de fond.
This review has been posted for Relay Volume Control Input Selector Board 50K
This handy volume control module uses a series of relays, allowing precise adjustment of the sound level. Control is via an ALPS 27 potentiometer....
