AUDIOPHONICS CS3318 6 Channel Arduino Volume Control Module
AUDIOPHONICS CS3318 - Module contrôle de volume 6Ch Arduino
7943
49,00 €tax incl.
40,83 € tax excl.
This product is no longer in stock
AUDIOPHONICS CS3318 - 6-Channel Volume Controller Module
We offer here for lovers of electronics a volume control module to mount yourself.
This can be integrated into one of your projects or serve as a basis for a specific development.
The CS3318 has a zero crossing detection function with programmable assignment time allowing volume change without audible "plocks" or "clicks".
Characteristics:
  • Possibility of chaining the assemblies (ENOut output) on the same control bus.
  • Addressing is possible individually and by group, simplifying the simultaneous configuration of the level of several channels with several controllers.
  • Up to 3 configurable Master Volume and volume control per channel.
  • 2 possible digital communication modes: I2c & SPI .: I2C: Max Clock Frequency: 100kHz / SPI: Max Clock Frequency: 6MHz
  • THD + N: -112dB (0.00025%)
  • Output noise at 0dB: 1.8uVrms
  • Dynamic: + 127dB
  • Crosstalk: -120dB
  • Volume control range: -96dB to + 22dB in steps of up to ¼ dB
  • Mute function available (software and hardware), up to 3 Master Mute and one per channel
  • 2 free connections on the card to allow connection to an external switch for a Mute function on the front panel
  • Function Reset disponible (software and hardware)
  • Analogue power supply: + -8V to + -9V
  • Power consumption: 36mA per rail
  • Digital power supply: + 3V3
  • Power consumption: 1mA
Possibility of control via PC via USB (by adding a USB controller), "FlexGUI" software availablehref = "http://www.cirrus.com/en/support/software/msaudio.html" target = "_ blank">RIGHT HERE
#datasheet
#Evalution board
We provide on the forum aArduino CODEallowing it to be operated with a rotary encoder
Product delivered
https://www.audiophonics.fr/images2/7943/7943_kit_controleur_volume_CS3318_1.jpg
The complete module once mounted:
https://www.audiophonics.fr/images2/7943/7943_kit_controleur_volume_CS3318_2.jpg
https://www.audiophonics.fr/images2/7943/7943_kit_controleur_volume_CS3318_3.jpg
Example of implementation (control via rotary encoder with Arduino)
https://www.audiophonics.fr/images2/7943/7943_kit_controleur_volume_CS3318_4.jpg
Colissimo - TNT - SoColissimo
Volume Controls mal exploité
Seulement 6 canaux alors qu'il a la capacité d'en piloter jusqu'à 8 !
This review has been posted for AUDIOPHONICS CS3318 6 Channel Arduino Volume Control Module
