LITE MV06 Passive volume control module Motorized 2 Channels + 5.1
Reference : 5040
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 08-05-2026.
2 Channel RCA + 5.1 Input Power Controller with Remote Control
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_1.jpg
A stereo volume controller with 6-way motorized ALPS potentiometer and which makes it possible to vary a stereo or 5.1 signal
This module allows to vary 4 RCA inputs or 3 RCA inputs + one 5.1 input
Selecting the sources and adjusting the sound level can be operated via the potentiometer and the selector but also by remote control remote control and an infrared receiver supplied .
Installation ofLEDs assignableto the different entries and informing about the nature of the source in activity.
Integrated power supply: requires only one power transformer between 9 and 12Vto work.
Connection table included in the kit.
Audio scheme 100% passive, no component in the signal path.
Specifications :
  • Number of RCA Stereo Inputs: 3 or 4
  • Number of Inputs 5.1 Stereo:1 or 0
  • Number of Outputs:1 (stereo or 5.1)
  • Power Supply Voltage:AC 9 ~ 12V
  • Potentiometer Drilling Diameters: Selection of Sources: 9,50mm
    Volume Control: 9.0mm
  • Dimensions:Motherboard: 120 x 54 x 28mm (L x W x H)br>Girl Card: 90 x 44 x 15mm (L x W x H)
  • Total weight :200g
Configurations possible via resistors:
  • R18 Absent:
    When switched on, the potentiometer cycles to 0
  • R18 Presents (10ohm):
    The volume is not changed when the ignition is switched on
  • R17 Absent:
    Changing the source does not vary the volume
  • R17 Presents (10ohm):
    At each change of source the volume returns to 0
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_2.jpg
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_3.jpg
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_4.jpg
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_5.jpg
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_7.jpg
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_6.jpg
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_8.jpg
Mounting diagram:
https://www.audiophonics.fr/images2/4764_LITE_CONTROLEUR-VOLUME-4CH_SCHEMA.jpg
InputPCB Connector
InputSolder pad
OutputPCB Connector
Channel2 (Stereo)
Channel5.1
4 reviews
Arnaque ...
J'ai acheté , il y a quelques années des modules LITE MV06, quer je n'ai jamais eu le temps de tester, ni même de monter, m'étant heurté tout de suite au schéma qui me semblait incohérent. N'ayant, à l'époque , pas eu le temps de le faire, je m'y suis mis récemment, ayant un besion urgent depréampli sélecteur de source !
Ce module LITE MV06 vendu par audiophonics est une arnaque en ce qui concerne le 5.1 ! En effet, la carte de motorisation qui contient l'arrivée des signaux d'entrée (certains les appellent de modulation) et qui est livrée dans ce kit audiophonics n'est pas la bonne .
1) elle ne relaye pas tous les circuits commutés par la carte de sélection(5.1) [ 7 connecteurs sur carte vers 6 sur carte motorisation, cf. câbles livrés]
2) la carte de motorisation et de sortie, ne permet pas de sortir tous les signaux comme le montre le schéma joint à cette carte. Si vous suivez ce schéma , impossible de sélectionner 1 entrée en 5.1
3) sur l'arrivée du potentiomètre, en suivant les pistes il y a 5 entrées repérables facilement et 4 en sortie ...il faut m'expliquer comment sélectionner une source 5.1 !!!...
4) J'ai triouvé, sur internet et eBay pour ne pas les nommer le kit qui fonctionne effectivement en sélecteur de source 5.1 et la carte de motorisation volume correspond bien, cette fois-ci, au schéma fourni par audiophonics sur la page LITE MV06
Il y adonc bien plus que des adaptations à faire à cette carte . Tout devrait focntionner si l'on n'essaye pas de sélectionner une source en 5.1 !!!
Malheureusement cette carte est annoncée comme pouvant le faire ... Hors ... il n'en est rien, car la carte de motorisation du volume n'est pas la carte adéquate !!!
This review has been posted for LITE MV06 Passive volume control module Motorized 2 Channels + 5.1
Suite de mon avis précédent...
Étonné par le manque de qualité audio, j'ai suivi les circuits et le fautif était le câble audio de liaison entre la platine maître et celle des relais dont une prise est câblée à l'envers.
Donc au moins pour cette liaison, ne vous servez pas des détrompeurs dessiné en blanc sur le circuit imprimé mais suivez les fils en fonction des marquages sur le cicuit (SGND-_ SGND etc...) .
Attention au décalage possible, ce câble a 8 fils pour seulement 7 pins (idem pour la sortie audio).
Depuis ces corrections, plus aucune ronflette, même en touchant le circuit audio !!
Donc super produit que je conseille.
Résistances de configuration : Je confirme qu'il faut s'en tenir aux valeurs sérigraphiées sur le circuit imprimé (2x 10 ohm).
Ces 2 résistances devraient être livrées dans le kit car je pense qu'elles sont nécessaires à la configuration la plus couramment utilisée.
Les valeurs données pour R17 et R18 sont fausses :
R17=10R --_ pas de reset du volume à chaque changement de canal!
R18=10R --_ pas de reset du volume à la mise sous tension!
Nécessiterait des liaisons blindées pour les parties modulation!
