Preamplifier 5.1 / 2.0 Module with Tone Control 7x AOP NE5532 DIP8
20%
This really complete preamplifier module has the particularity of offering a choice of connecting a 2.0 system or a 5.1 system, via a remote module (supplied, with its connection cable). So whether you have a classic system or a home theater system, this preamplifier will blend perfectly with your hardware.
Reduced price!
Reference : 12802
Limited time offer:
32,90 €tax incl.
-20%
26,32 €tax incl.
21,93 € tax excl.
Last items in stock !
Shipping date: 06-05-2026.
Preamplifier & Volume/Tone Control
7x AOP NE5532 - 5.1 / 2.0
Préamplificateur et contrôle de volume 5.1 / 2.0
A complete preamplifier module
7x AOP NE5532 and quality components
This tone controlled preamplifier is based on a series of 7 operational amplifier TI NE5532, one per channel plus another for the filter, combining excellent DC and AC characteristics. They offer very low noise and distortion ensuring a clean signal.
Also on the board are 2x1000µF Ercon Japanese capacitors for the main filter or 1A rectifier bridges to obtain a stable continuous signal. On the resistors side, these offer an accuracy of +-1% allowing to obtain a very good Signal/Noise Ratio. There are also Siemens 1µF capacitors from Germany, ensuring soft highs and deep bass.
Accurate volume/tone control
This module integrates no less than 6 potentiometers allowing you to precisely adjust each element of your system. So you can change the sound of your surround speakers, headphones, center speaker and subwoofer separately. It is also possible to adjust the low frequencies in order to obtain a more homogeneous, more coherent reproduction. Finally, once these adjustments have been made, a potentiometer is used to adjust the overall volume for greater simplicity.
There is also a small switch on the module to invert the subwoofer phase to match the phase rotation of your speakers. So your speakers and subwoofer will work in perfect harmony.
Preamplifier board diagram
schema preamplificateur
1Power Supply AC 15V-0-15V
2Low frequency filter
3Subwoofer volume
4Center speaker volume
5Surround speaker volume
6Front speaker volume
7Main volume
8Outputs
9Inputs
10Subwoofer phase reversal switch
Input board diagram
entrées module préamplificateur
1MR = Front right speaker
2ML = Front left speaker
3Subwoofer
4CEN = Center speaker
5SR = Right Surround
6SL = Left Surround
7Left AUX
8Right AUX
Channels5.1 or 2.0
Available controlsMain volume
Subwoofer volume
AOP7x NE5532P (on DIP8)
Subwoofer phase switchYes - 180°
Power supplyAC 15V-0-15V
Preamplifier board dimensions201 x 49 x 29mm
Preamplifier board fixation holes spacing194mm /42mm
Inputs board dimensions76 x 32 x 31mm
Weight155g
Package1x Preamplifier module
1x Inputs board
1x Connection ribbon cable
InputPCB Connector
OutputScrew terminals
Channel6
This really complete preamplifier module has the particularity of offering a choice of connecting a 2.0 system or a 5.1 system, via a remote module...
