By buying this product you get 123 loyalty points
With the Hestia 12Th, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure Class A to deliver unprecedented sound quality. Its microprocessor-controlled 60-step attenuator with precision-tuned resistors ensures perfect balance between channels and an incredibly low harmonic distortion level of just 0.000230%, giving you the most crystal-clear sound possible.
The power supply stage has also received special attention. The Hestia 12TH benefits from a O-Core copper OCC transformer with shielding to protect it from any external electromagnetic interference. Furthermore, the power supply has been fitted with a host of low-noise linear power capacitors to ensure that the power supply is both stable and perfectly silent.
With its two balanced inputs and one balanced output, the Hestia integrates perfectly into any audio installation, whether it's a professional studio or an audiophile-quality setup. Its adaptive nature and compatibility ensure seamless integration into your existing setup, enhancing overall performance and delivering an incredibly wide and immersive soundstage.
Product type | Discrete balanced preamplifier |
Architecture | Pure classe A |
Attenuator | Microprocessor-controlled 60-step relay attenuator |
Inputs | 2x Balanced stereo XLR 1x Single-ended stereo RCA |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Input impedance | Balanced : 60kΩ Single-ended : 12.2kΩ |
Output level | RCA : 2Vrms XLR : 4Vrms |
Output impedance | Balanced : 400kΩ Single-ended : 200Ω |
Gain | Unity gain, 0dB |
Frequency response | 10Hz - 80kHz (-0.3dB) |
Total harmonic distortion more noise (THD+N) | 0,000230% |
Signal-to-noise ratio (SNR) | 120dB |
Dynamic range | >121dB |
Crosstalk | -110dB |
Supply voltage | 100-240V AC 50/60Hz |
Consumption | 20W |
Color | Black |
Dimensions | 320 x 330 x 60mm |
Weight | 6.5kg |
Package | 1x Denafrips Hestia 12TH 1x Remote control |
