FX-AUDIO TUBE-05 Preamplifier
-80%
The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It features an innovative appearance and form factor, as well as quality components such as WIMA and Nichicon capacitors and a JRC NJW1194 volume control chip with output selector and tone control.
3.0 / 5
Reduced price!
Reference : 18573
99,00 €tax incl.
-80%
20,00 €tax incl.
16,67 € tax excl.
FX-AUDIO Tube-05 Preamplifier with ECC82 Tube / Headphone amplifier
FX-AUDIO TUBE-05 picture
The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It is part of the brand's "GOOD TIME" series. This range is represented by products with demanding aesthetics and choice of components. Indeed, the Tube-05 features an innovative appearance and form factor, as well as quality components such as WIMA and Nichicon capacitors and a JRC NJW1194 volume control chip with output selector and tone control. The front panel features a knob/potentiometer and is supplied with a remote control for a more pleasant user experience. In terms of connectivity, the TUBE-05 features a stereo RCA input, a stereo RCA line output and two single-ended headphone outputs: 3.5mm jack and 6.35mm jack.
FX-AUDIO Tube-05 : Tube ECC82
The Tube-05 comes with a PSVANE ECC82 tubeUsing this tube in the audio signal path will bring roundness and warmth to the sound reproduction of the Tube-05 headphone amplifier/preamplifier. You can, of course, choose a different tube for a different sound. Many tube models are compatible: ECC82,12AU7, 6N10, 7316, CV4003, 5814, B749 and 6189.
Photo of PSVANE ECC82 tube
Photo of JRC NJW1194 volume controller
FX AUDIO Tube-05 : JRC NJW1194 digital volume control
FX Audio has chosen to integrate a stereo digital volume control with output selector and tone control into its headphone amplifier/preamplifier. This volume controller features low-noise, low-distortion characteristics thanks to a resistor network circuit (R2R).
Preamplifier
Tube1x ECC82
Inputs1x Stereo RCA input
Outputs1x Stereo RCA output
1x 3.5mm headphone output
1x 6.35mm headphone jack output
Output power (headphones)960mW @ 32Ω
750mW @ 64Ω
430mW @ 150Ω
245mW @ 300Ω
125mW @ 600Ω
THD+N (headphones)Tube mode: 0.6%
Direct mode: 0.1%
SNRLine output: 105dB (tube mode) / 113dB (direct mode)
Frequency response20Hz-40KHz
Line output level2Vrms (Volume 90)
3.5Vrms (Volume 99)
Output impedance< 0.1Ω
Noise floor1mW
Power supply12V DC 2A via DC jack connector 5.5/2.1mm
Standby power consumption< 0.1mW
Dimensions78 x 70.55 x 141.4mm
Weight396g
Package1x FX-Audio Tube-05
1x Tube ECC82 PSVANE
1x Mains adapter
1x Remote control
OutputJack 3.5mm
OutputJack 6.35mm
ClassTube amp
Remote ControlYes
plutôt décevant
Pour le prix c'est sans doute bien. Mais je l'ai utilisé avec une bonne alimentation 12 volts et un bon dac et j'en attendais plus.
Avec un sennheiser hd650 c'était assez mou, pas assez de grave et d'impact.
J'ai upgradé le tube (gold lion genalex) pour voir. C'était un peu mieux, mais toujours pas ça.
This review has been posted for FX-AUDIO TUBE-05 Preamplifier with ECC82 Tube / Headphone amplifier
The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It features an...
