Passive Volume Attenuator Source Selector
This passive volume controller adjusts the signal level without using an active amplification stage, allowing it to be simply placed between a source and an amplifier or another audio device. Its XLR and RCA inputs and outputs ensure compatibility with both balanced and unbalanced connections, while the independent adjustment of the left and right channels allows precise correction of the stereo balance when the two channels present a level difference.
4.0 / 5
Reference : 22457
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 18-11-2026.
Volume Attenuator Source Selector Passive
Volume attenuator : Front view
This passive volume controller adjusts the signal level without using an active amplification stage, allowing it to be simply placed between a source and an amplifier or another audio device. Its XLR and RCA inputs and outputs ensure compatibility with both balanced and unbalanced connections, while the independent adjustment of the left and right channels allows precise correction of the stereo balance when the two channels present a level difference. Beyond this control function, a simple press of a button allows switching the input and output, turning the device into a source selector and thus facilitating the management of several elements within a Hi-Fi system.
Product typeVolume attenuator
Source selector
Inputs1x RCA stereo
1x XLR stereo
Outputs1x RCA stereo
1x XLR stereo
Input impedance10kΩ
Output impedance50kΩ
Dimensions145 x 65 x 42mm
Weight314g
PackageSold individually
InputXLR
ClassN/A
Useful addition
L-R balance controls have just about disappeared from today's audio products. Sometimes they are tugged away somewhere deep in the menu structure. I would like to see them on every preamp with the option to bypass them. But in the case of a preamp like the Topping's PRE90 they typically are non-existent. This passive volume attenuator by Lynepaudio adds L-R balance functionality to an audio set-up. It is not ideal to add a step to your audio chain, but I have noticed no degradation to the sound quality in my configuration. I subtracted a star from the rating as there is no description of the device supplied by Lynepaudio. Neither is there a set-up guide or manual.
This review has been posted for Passive Volume Attenuator Source Selector
This passive volume controller adjusts the signal level without using an active amplification stage, allowing it to be simply placed between a...
