By buying this product you get 97 loyalty points
The SMSL VMV P2 is a high-performance preamplifier - desktop headphone amplifier, capable of delivering high power and extremely accurate sound reproduction. It is based on a carefully designed balanced architecture, enabling it to deliver 2x6W at 32 Ohm or 2x350mW at 600 Ohm. The whole unit is housed in a magnificent aluminum chassis, as robust as it is stylish.
The rear of the SMSL VMV P2 displays three selectors. The first selects the input, the second the output, and the third adjusts the gain level. The latter switch has three positions. Adjusting the gain makes the amplifier particularly versatile, enabling it to adapt to both high-impedance headphones and high-sensitivity earphones.
The SMSL VMV P2 benefits from a totally balanced architecture with an ultra-low distortion 4-way PLFC circuit. No less than 99 low-noise OPAs are integrated in a parallel design. The specially designed volume potentiometer greatly reduces crosstalk. The whole system is powered by a high-efficiency, low-noise power supply, providing a clean electrical signal to all circuits.
1 | Touch button |
2 | LED |
3 | Button |
4 | Jack 4.4mm balanced headphone output |
5 | Jack 6.35mm single-ended headphone output |
6 | XLR 4 pins balanced headphone output |
7 | Single-ended RCA input |
8 | Input selection |
9 | RCA pre-out |
10 | Balanced XLR input |
11 | Gain switch |
12 | Output selection |
13 | XLR pre-out |
The SMSL VMV P2 boasts a sublime CNC-machined aluminum casing, giving it a modern yet luxurious aesthetic. Its front panel features a sturdy tempered glass panel, a high-quality rotary knob and a touch-sensitive ON/OFF button.
Product type | Headphone amplifier |
Inputs | 1* Balanced stereo XLR 1* Single-ended stereo RCA |
Outputs | 1* Balanced Jack 4.4mm headphone output 1* Balanced XLR 4 pins headphone output 1* Single-ended Jack 6.35mm headphone output 1* Balanced XLR pre-out 1* Single-ended RCA pre-out |
Output power | 2x12W @ 16 Ohm 2x6W @ 32 Ohm 2x700mW @ 300 Ohm 2x350mW @ 600 Ohm |
SNR | 133dB |
Dynamic range | 133dB |
THD+N | -123dB, 0.00006% (1kHz, 32 Ohm) |
Input impedance | 47kOhm |
Amplifier output impedance | Near 0 Ohm |
Preamp output impedance | Balanced: 44 Ohm Single-ended: 22 Ohm |
Frequency response | 20Hz - 100kHz (-0.5dB) |
Gain | Single-ended: low = -9dB / mid = 0dB / high = 18dB Balanced: low = -3dB / mid = 6dB / high = 24dB |
Consumption | < 60W |
Dimensions | 280*235.7*51mm |
Weight | 3.25kg |
Color | Black |
Package | 1* SMSL VMV P2 1* Power cable |
Input | RCA |
Input | XLR |
Output | XLR |
Output | Jack 4.4mm |
Output | RCA |
Output | Jack 6.35mm |
Color | Black |
Class | N/A |
Remote Control | No |
