Pack Topping A70 PRO Headphone Amplifier + D70 PRO DAC + TCX1 XLR Cables 25cm Black
This Topping pack consists of the A70 PRO headphone amplifier, the D70 PRO DAC and the TCX1 XLR cables. It's a perfect combo to enjoy a headphone listening solution of exceptional quality, ensuring notably an extremely low level of distortion and noise. The result is a sound reproduction of a sublime richness, precision and musicality. The set is thought, both in its technical conception but also by its design, for a complementary use. The D70 PRO can also be used as a preamplifier in a home HiFi system, thanks to its RCA and XLR outputs.
By buying this product you get 118 loyalty points
Reference : 17755
1 184,00 €tax incl.
986,67 € tax excl.
Pack content
Pack Topping A70 PRO + D70 PRO + TCX1
Headphone amplifier + DAC + XLR cables black
This Topping pack consists of the A70 Pro headphone amplifier, the D70 Pro DAC and the TCX1 XLR cables. It's a perfect combo to enjoy a headphone listening solution of exceptional quality, ensuring notably an extremely low level of distortion and noise. The result is a sound reproduction of a sublime richness, precision and musicality. The set is thought, both in its technical conception but also by its design, for a complementary use. The D70 PRO can also be used as a preamplifier in a home HiFi system, thanks to its RCA and XLR outputs.
Topping A70 PRO headphone amplifier
The Topping A70 Pro is an efficient and affordable headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear headphone listening. The amplifier is Hi-Res certified, a label guaranteeing a very good quality of sound reproduction.
Key features:
  • Headphone amplifier / preamplifier
  • T'ang-ku-la modules
  • EXT coupling socket & LIFT/GND switch for ground noise suppression
  • 12V trigger option
  • High precision relay volume control
  • Headphone outputs: Balanced XLR 4 pins / Balanced Jack 4.4mm / Single-ended Jack 6.35mm
  • Outputs: Single-ended stereo RCA / Balanced stereo XLR
  • Color screen
  • THD+N: 0.000055% (0.000055%)
  • Dynamic range: 147dB
  • Power: 17000mW
View more informations on Topping A70 PRO
Topping D70 PRO DAC
The Topping D70 Pro DAC embeds many refinements typical of a high-end audio product. With its high-performance chips, ultra-low jitter clocks, latest generation interfaces and great versatility, this converter offers exceptional audio reproduction, characterized by a magnificent transparency and a beautiful sound richness while proposing practical and useful features.
Key features:
  • ESS ES9039SPro DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.0 receiver with aptX, aptX HD and LDAC codecs support
  • Support sample rates up to PCM 32bit 768kHz and DSD512
  • THD+N: 0.00006%
  • Balanced and single-ended outputs
  • IR remotre control
View more informations on Topping D70 PRO
Topping TCX1 XLR cables
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
  • Length: 25cm
  • 6N copper and silver plated 6N copper
  • Gold plated connectors
View more informations on Topping TCX1
Topping A70 PRO specification
Preamplifier
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
Outputs1* Single-ended stereo RCA
1* Balanced 4 pins XRL headphone output
1* Balanced Jack 4.4mm headphone output
1* Single-ended Jack 6.35mm headphone output
Supply voltage100-240VAC 50/60Hz
Dimensions222*176*48mm
Topping D70 PRO specification
Product typeDAC
Inputs1* Optical Toslink
1* USB-B
1* Coaxial SPDIF
1* AES/EBU
Bluetooth
Outputs1* Balanced stereo XLR
DAC chipESS ES9039SPro
USB interfaceXMOS XU316
Supported Bluetooth CodecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Supported sampling ratesUSB: PCM up to 32bit 768kHz / Native DSD up to DSD512 / DSD DoP up to DSD256
Coaxial, Optical, AES: PCM up to 24bit 192kHz
Topping TCX1 specifications
Product typeMale/female XLR cables
Length25cm
Conductors material6N copper
Silver plated 6N copper
Conductors section0.533mm² (19AWG)
Cable outer diameterØ8mm
Connectors contacts platingGold
Outer sheathBraided nylon
Cable colorBlack and red
This Topping pack consists of the A70 PRO headphone amplifier, the D70 PRO DAC and the TCX1 XLR cables. It's a perfect combo to enjoy a...
