By buying this product you get 284 loyalty points
This Topping pack, comprising the D900 DAC, the A900 headphone amplifier and preamplifier, and a pair of 25cm TCX1 XLR cables, will enable you to enjoy exceptional sound quality, both on headphones and in classic integration with a power amplifier.
The Topping D900 pushes the boundaries of audio fidelity with an exclusive 32-phase DSM (Discrete Sigma Modulation) architecture. A true showcase of Topping's technological know-how, this top-of-the-range DAC combines digital precision, organic musicality and total flexibility to sublimate all your sources. It supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. Its digital-to-analog conversion stage is supported by an Altera Max II CPLD and Accusilicon 45MHz/49MHz clocks, guaranteeing perfect synchronization.
Numerous features are available, such as Bluetooth 5.1 supporting LDAC and a 10-band parametric equalizer accessible via the Topping Tune application. As far as connectivity is concerned, the Topping D900 is very complete, with numerous digital inputs enabling it to adapt to a wide range of configurations. Outputs include two balanced XLR outputs: a line output and a preamplifier output, offering versatility for integration into your audio system.
Find out more about Topping D900The Topping A900 is a high-end headphone amplifier and preamplifier, combining power, performance and design. It benefits from T'ang-ku-la's proprietary symmetrical amplification architecture, enabling it to develop significant power, making it capable of accompanying the vast majority of audio headphones. What's more, in addition to its exceptional measurements, the A900 boasts a particularly comprehensive connectivity package to meet a wide range of needs.
Learn more about Topping A900Topping's TCX1 cables are high-quality XLR male/female cables. They feature 6N copper and 6N silver-plated copper conductors for perfect signal transmission. Each conductor has a cross-section of 0.533mm² (19AWG). Connector contacts are gold-plated for excellent conductivity and resistance to oxidation. Each cable is covered by a robust black and red braided nylon sheath.
Learn more about Topping TCX1Technical characteristics
Products type | DAC + Headphone amplifier / Preamplifier + XLR cables |
Pack content | 1x Topping D900 1x Topping A900 1x Topping TCX1 XLR cables pair 25cm |
Topping D900 general specifications | |
DAC chip | PSRM |
Bluetooth chip | QCC5125 |
CPLD | Altera Max II |
Inputs | 1x USB-C 1x USB-B 2x Coaxial 2x Optical 1x AES/EBU 1x I2S via HDMI Bluetooth |
Outputs | 1x XLR line out 1x XLR preamp out |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
Color | Silver |
Accessories | 1x Bluetooth remote control 1x Bluetooth antenna 1x Power cable |
Topping A900 general specifications | |
Inputs | 3x Combo XLR (balanced) / Jack 6.35mm (single-ended) |
Outputs | 2x Combo XLR (balanced) / Jack 6.35mm (single-ended) headphone output 2x Balanced XLR 4 pins headphone output 2x Balanced Jack 4.4mm headphone output 1x Balanced XLR pre-out |
Headphone output power (single-ended output) | 2x 6000mW @ 16Ω, THD+N <0.1% 2x 3000mW @ 32Ω, THD+N <0.1% 2x 1550mW @ 64Ω, THD+N <0.1% 2x 660mW @ 150Ω, THD+N <0.1% 2x 330mW @ 300Ω, THD+N <0.1% 2x 165mW @ 600Ω, THD+N <0.1% |
Headphone output power (Balanced output) | 2x 22000mW @ 16Ω, THD+N <0.1% 2x 14000mW @ 32Ω, THD+N <0.1% 2x 7000mW @ 64Ω, THD+N <0.1% 2x 3000mW @ 150Ω, THD+N <0.1% 2x 1500mW @ 300Ω, THD+N <0.1% 2x 750mW @ 600Ω, THD+N <0.1% |
Color | Silver |
Accessories | 1x Remote control 1x Power cable |
Topping TCX1 general specifications | |
Connectors | 1x Male XLR 3 poles 1x Female XLR 3 poles |
Length | 25cm |
Cable outer diameter | Ø8mm |
Conductors material | Copper Silver plated copper |
Conductors section | 0.533mm² (19AWG) |
Contacts plating | Gold |
Outer sheath | Braided nylon |
Color | Black and red |
Quantity | Pair |
