Nikolaus S.
Einstieg bei den HighEnd Stromkabeln
Kombiniere die VE/VF512S mit dem "Supra Cables LoRad 2.5 SPC Silver Anniversary Edition", ergänze das ganze mit einem...
Philippe B.
Parfait sur un bureau
Je confirme les qualités évoquées lors des messages précédents : rapport qualité/prix exceptionnel, avec 3 entrées (BT, aux...
MICHAEL K.
Recommended
It does its job well. I paired it with a BST300 bass shaker and it's able to drive it quite nicely. Pretty significant...
TOPPING D90 III DISCRETE Balanced Discrete DAC Bluetooth 5.1 32bit 768kHz DSD512 Black - reviews - There are 2 reviews.
Sandu T.
Super !
Super DAC, looks identical, but they don't do the same thing :) It sounds very good, it's worth it! This company has made me a fan forever. Bravo to the engineers! With love from Romania!
Poul T.
This one is different!
This is not an audiophile DAC, but a mastering DAC that opens a window into the mix. Used with USB it is extremely transparant and resolving and that is definitely both good and bad as I have found out. It simply cannot be compared to other DAC´s at the pricepoint, because you get a much different experience of hearing the music.
Some records sound much worse, some flat sounding records are brought to life and many records have spookely lifelike timbre.
I am not sure I can recommend it in general, but I am definitely keeping mine :-)
 (3)
The D90 III Discrete balanced DAC from Topping is the parallel to the D90III using a 100% discrete digital/analogue conversion module. Here,...
