claudio c.
claudio c.
YANN P.
Excellente barette secteur
Dimitar C.
Tornado blows expensive ones
Second time purchase this product, first time implementation was in system for 100000Euro the result was amazing, more definition,better separation and wider sound scene(replacement was only for monoblocks).Now expect delivery from Audiophonics to implement on system for 500000Euro and above for all sources, pre amp,phono and monoblocks.For those who are sceptical about power cords, pleace try and then share the experience .Also on system let me say" low quality "it doesn't matter what kind of power cable you are using .
On the second system I and my friend who is the owner started with replacing power cords of Halcro dm10 pre and Halcro dm58 monos, just for the experiment .Amazing result,he confirm that this replacement change the sound entirely with the same performance as in my first atempt.
As soon as I finish with the project, I will post results!
Thanks again Audiophonics!
Brice D.
Du tout bon
Câble qui alimente une barrette secteur ,ce qui a eu pour effet de booster l ensemble du système.
Mais il faut tout de même quelques jours de rodage.
David T.
RaspDIGI LTE DigiOne digital network player Raspberry Pi & SPDIF A high quality network player based on Raspberry Pi 3 B+ and the Allo DigiOne audio interface. Great performance, low for high definition digital and performance that adapts to...
Avis Raspdigi LTE
Bonne construction, solide, la finition est appréciable.
La carte Allodigione est agréable à l'écoute.
Je voulais signaler un problème avec la nappe d'extension de la carte SD. Celle-ci génère des i/o errors sur le file system.
J'ai testé en flashant 4 SD cards différentes (sandisk, intenso fournie) avec les systèmes Volumio, Moode, RuneAudio, M2P, Libreelec, à chaque fois des I/O errors survenaient tôt ou tard.
Plus aucun problème en branchant directement la SD card sur le slot du Raspberry.
Peut-être un problème d'interférences sur la nappe, je ne sais pas.
Mis à part ce souci qui m'a pris du temps je suis satisfait du produit.
Philippe A.
Adapter Male XLR to Female RCA This adapter features a male 3-pin XLR connector and a female RCA connector. Robust, it has a metal body.
produit correct
fais ce qu'on lui demande et pour un prix accessible.
Philippe A.
super ampli
écoute très détaillée et neutre. super ampli de puissance, ne prend pas trop de place et design très sobre. en fait une super acquisition.
Philippe A.
livraison rapide, produit simple et convivial à utiliser. sera très pratique pour mes tests de haut parleurs.
Franck R.
J'ai acheté ce bloc de puissance afin de remplacer un FDA Alientek D8 dont je me lassait un peu. Il est connecté à un preampli Rotel rc 980 pour alimenter des Elipson planet L associées à leur caisson de basse dédié. En amont la source principale provient de fichiers flac lus par un PC via un Dac usb sabre es 9023.
Je suis très surpris et enthousiasmé par cette association qui me convient en tout point. C'est puissant, très puissant, dynamique, détaillé, et en même temps musical, pas fatiguant pour un sou. On se situe à un niveau ou ce système est capable de rivaliser avec des ensembles beaucoup plus honereux.
Bref, vous l'aurez compris, ces blocs Ncore sont une excellente alternative à partir du moment où vous prenez soin de les associer à des sources se situant à leur niveau.
A ce prix Je recommande chaudement !
David d.
XDUOO XD05 BASIC Portable Headphone Amplifier DAC ES90108K2M XMOS 32bit 384kHz DSD256 xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means...
Parfait, impossible de charger la batterie et de l'utiliser en même temps sans brancher 2 cables
Malgré que ça ne soit pas annoncé il fonctionne parfaitement avec GNU/Linux, il est par contre nécessaire de modifier les fichiers de configuration de pulseaudio ou pipewire pour que l'échantillonage change selon le fichier source. Une fois modifié on voit bien le petit écran afficher l'échantillonage du fichier qu'on lit.
Aucune diférence audible entre PCM1 et PCM2.
Pas pris pour le bass boost, c'est au final une bonne surprise qui est bien utile selon le genre de musique et les casques audio.
Seul petit bémol le port USB pour les données sert uniquement aux données, il ne peut pas alimenter l'appareil, il faut donc aussi connecter le port d'alimentation si l'on ne veut pas décharger la batterie.
Autrement le son est très propre et même 600 ohms ne sont pas un problème.
Testé aussi avec une OP Amp TI LME49720NA/NOPB, pas vraiment de différence audible mais ça fonctionne aussi bien.
Avec un Surfans F20 en USB il y malheurement de petits artefactes, mais c'est le Surfans qui est en cause.
David d.
Très facile à souder mais très fragile et sans bouchon en sortie de cable
D'autre plug du mëme genre ont un embout qui tient le cable, là non, on peut observer les soudures à volonté en regardant le trou à l'arrière du plug. Mais surtout beaucoup trop fragile, le jack n'avait plus aucune rétention après la soudre ...
Dommage, le plus simple a souder autrement.
Ce produit est bien doté d'un système de rétention.
Il suffit de faire un nœud sur le câble avant le réducteur métallique intégré a la lamelle de masse.
David d.
Female Stereo Jack 3.5mm Connector Gold Plated Ø6mm This female Jack 3.5mm connector of good quality benefits from gold plated contacts, ensuring a good transmission quality and an excellent resistance to oxidation. It...
Pas facile a souder, parfait autrement
Difficile à souder par rapport à d'autre plug du genre, la base en plastic peut se mettre à fondre, mais autrement parfait.
David d.
Rien a dire, fait ce qu'on lui demande.
Superb value for money
I have these coupled to Oyaide Tunami cables and they are every bit as good as far more expensive connectors. Sound is very neutral and the connector does the job of passing the signal as cleanly as it can.
The clamping mechanism is also a lot more cable friendly than other manufacturers who charge a lot more for phosphor bronze than pure copper! Shame Viborg didn't apply the same clamping mechanism to the IEC version of this connector.
Sergey B.
TPA3255 Inside
Voici un très bon ampli, super compris à un Hypex NC122 avec des mesures ASR qui ne mentent pas.
Pour éviter le "reverse ingeniering" topping a pris soin de gommer les références sur les inducteurs, puce TPA3255, mais un démontage montre bien un TPA3255 avec des composants de bonnes factures autour. Je pense qu'il s'agit d'un classe D monté sur une typologie composite avec des OP amps masqués par la marque, mais de type probablement différentiels et un PFFB activé pour atteindre un aussi bas THD.
Je conseille de changer l'alimentation donnée à 38V / 4A = 152W. Preferez une alimentation DIY de type Connex SMPS300R ou une Meanwell, dont les ripple sont meilleurs et surtout la puissance = 300W, pour gagner en patate )
Je recommande cet ampli pour un usage Audiophile dans une pièce de taille modérée, il donne environ 2X50W / 8R en puissance réelle.
Ville E.
KHADAS TONE2 PRO DAC Headphone Amp ES9038Q2M 768kHz DSD512 MQA Full Decoder Black Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768 kHz and native DSD512 and even MQA. New headphone...
Excellent DAC, good headphone amp
This little box sounded wider and more detailed than old rega dac. I've played it to my friends and colleagues, some who are really into audio, and everyone agrees that this is a gem. The headphone amplifier is a little bit on the weaker side but will work well for balanced IEM's. I'm using ikko oh10 with great results.
Henri C.
SHANLING UP4 Portable Headphone Amplifier DAC Balanced 2x ES9218P Bluetooth 5.0 CSR8675 Compact, affordable, yet high-performance, the Shanling UP4 is a DAC combo and portable symmetrical headset amplifier with Bluetooth 5.0 connectivity. It will accompany your...
Ultra pratique
Cela fait maintenant quelque mois que j'utilise ce produit. Principalement connecté sur un système d'enceinte portable et via la prise jack simple. Je précise du coup, car je l'utilise pas vraiment dans son usage principal d'écoute au casque. Mais du coup premier point super, c'est la porté. Elle est vraiment excellente en comparaison à d'autre produit que j'ai pu testé, pour moi c'est important car je peux aller d'un bout à l'autre du jardin, ou de la maison sans que cela déconnecte, très agréable à l'usage. L'autonomie est bonne aussi. L'ergonomie est chouette, notamment la connexion rapide, il va même démarrer automatiquement la musique qu'on était en train d'écouter. Moi j'apprécie. La molette très agréable aussi. L'application s'avère utile, un égaliseur de disponible pour un réglage fin, c'est pas un égaliseur de bourrin, et c'est bien comme ça. Sélection de type de traitement (filtre) des haut fréquence, je ne pensais pas que ça me serait utile au départ, j'ai appris à les utiliser selon les besoins des système et il s'avère bien de les avoir quand on bricole, ou change de système régulièrement. Mode de gain intéressant, pareil j'ai eu des périodes high gain qui a la plus grand dynamique à mon sens, le dual dac boost qui peut être utile en soirée quand on recherche un son un peu compressé, et le low gain, je l'utilise actuellement quand je recherche vraiment à faire ressortir les basses. Comme j'écoute surtout sur un système d'enceinte amplifié, je ne peux pas juger de la puissance pour driver les casques, mais du peu que j'ai testé, y'a de quoi faire. En ce qui concerne la qualité de son, je l'utilise en LDAC, je dois avouer que le son a la pêche, c'est dynamique c'est sûr, c'est très bon pour le prix, mais dans la même gamme de prix, le topping BC3 m'a paru meilleurs en terme de scène sonore et de naturel, que ce soit au casque et sur un système d'enceinte. après une note importante à préciser, j'ai testé uniquement sur la prise jack standard en high gain. Je n'ai pas actuellement de quoi testé la prise TSR, donc peut être que cela vient améliorer justement la perception de la scène sonore. Mais bon avec l'application, la compacité, la fiabilité de construction et de connexion, je suis très satisfait, je recommande.
Excellent cable
Excellent câble pour un prix correct.
On peut le comparer au triangle OFC 2x2.5mm².
Meme approche de son plus que satisfaisant sur mon système.
À recommander dans cette gamme Cuivre/Argent.
Merci audiophonics, envoi parfait comme d'habitude.
Oleg K.
Oleg
The new PME-2 is very good sounding. Despite the fact that it is made on a syabr chip, it does not have the wildness and brightness of the sound at high frequencies.The sound concept is different from Chinese DACs - smsl m500, smsl su-9/9n and the like.probably they wanted to make the sound similar to ak4393. It is more restrained at high frequencies and a little fatter.But if you put the output filter - Sharp, then it looks a little more like ess dac. The containment of bright sounds allows you to listen at high volume without fatigue. also you will not have irritability with "bright" acoustics. The DAC has great functionality. - parametric equalizer, tone controls, adjustable loudness - this allows you to equalize the sound for any acoustics or headphones according to your personal desire.However, with the neutral sound of the PME-2, it has no problems with detail, it has a very wide stereo base, it has well-defined instruments and vocalists like on a stage... And the reverberation and echo of the hall where it was made is also well transmitted. The RME-2 works well with any type of headphone and has separate settings for all headphones and a separate line-out with saved presets.
Xavier T.
Remarquable !
J'ai pu comparer cet ampli avec un Topping A30 Pro, qui a excellente presse et qui coûte le double. Vous voulez savoir ?
Cet Audiophonics HA-B6120 offre tellement plus de relief à la restitution musicale ! La scène sonore est étendue en largeur et profondeur, rendant l'image bien plus réaliste. Les basses sont plus présentes, sans démesure, offrant une tonalité plus chaude que le Topping.
Il est plus puissant aussi. Je suis resté au plus bas niveau de gain avec le Sennheiser HD650 qui fait pourtant entre 350 Ohms et 500 Ohms selon les fréquences. Sur le Topping, je devais utiliser le gain maximum pour une écoute un tant soit peu musicale avec ce casque.
Il s'accorde également parfaitement bien avec le Focal Clear, le Grado SR225i, l'Hifiman Sundara.
Ne vous laissez pas rebuter par l'absence de reviews ou le peu d'informations disponibles à son égard, ni par son prix entrée de gamme cet ampli est remarquable de qualité ! Il écrase la concurrence, même au double du prix ! Difficile à croire et pourtant, c'est sans appel.
Je dis bravo et merci à Audiophonics de sortir des sentiers battus pour nous proposer de telles perles !
Bonnes écoutes à vous.
boîtier avec dissipateur
Très bien pour réaliser un ampli à transistors
Je recommande de prendre également un fond de boîtier perforé
Indispensable pour boîtier à dissipateur, permet de fixer les PCBs, transfos etc...
Rigidifie bien l'ensemble
interrupteur
Les pins sont assez rapprochées, pour la partie secteur câbles en 0,75mm2 + gaine thermo
La diode verte est assez lumineuse
Bon produit dans l'ensemble
Olivier g.
Bluffant
Je ne cache pas que j'ai longtemps hésité avant de commander ce câble compte tenu de son prix. Mais franchement, couplé à des connecteurs furutech NCF rhodium, c'est simplement impressionnant. Le câble n'est pas encore rodé au moment où j'écris ces lignes mais sur mon préampli il a tout simplement pulvérisé mon câble HMS à 3 fois le prix. Bref, vivement recommandable mais je pense qu'il ne fait pas faire l'économie de connecteurs qualitatifs qui révéleront toutes ses qualités. Et a ce jeu les connecteurs NCF sont vraiment au dessus du lot. Bravo Furutech. C'est pas donné mais le résultat est vraiment à la hauteur.
Ce qui frappe à l'écoute c'est l'impressionnante ouverture de la scène, l'aération et le contrôle. Les voix sont à tomber, gros gros silence et ça c'est fabuleux pour révéler une miriades de détails que je n'avais pas soupçonné sur des enregistrements que je connais depuis des années. Et je pousse le potard 2 cran plus loin sans que rien ne bouge, c'est vraiment impressionnant, très beau, très naturel, un excellent câble assurément.
Bruno l.
MUNDORF BS140 Copper Wire Ferron Core Coil 3mH Mundorf BS140 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal...
excelent produit
Monté sur un focal audium 15VX, c'est très musical.
C'est bien meilleur que la self sur air de 20/10 que j'avais avant et qui donnait un son criard.
J'ai largement gagné en resistivité puisque malgré le fil plus fin, je suis passé de 0.4 Ohms à seulement 0.18 Ohms.
Ludovic M.
MOGAMI W3103
Très bon câble de bonne qualité facile à dénudé
Autrement livraison rapide très bonne communication avec audiophonics toujours près a trouvé des solutions pour satisfaire le client Au top Merci
Pierre T.
BLUESOUND NODE 3 (2021) Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA Black The BlueSound Node 3 opens up the world of remote control, network playback, streaming and multi-room. Easily integrated into an existing HiFi system, it will allow you to...
Très bon lecteur réseau
Commandé le lundi, reçu le jeudi bien protégé dans son carton d'expédition.
Installation facile et rapide grâce à l'application BluOs. Montage de mon NAS Synology un peu plus laborieux, il faut bien donner les autorisations nécessaires sur le compte "invité" du Synology.
Application BluOs bien conçue, conviviale et intuitive, bien mieux que Volumio que j'utilisais auparavant sur un Rapsdac Mini.
Superbe qualité sonore, les aigus sont très fins et précis, les médiums bien définis, les graves un peu en retrait surtout à bas volume. À volume plus élevé, aucune fatigue ne se fait sentir, la scène musicale est très bien définie et aérée. C'est superbe.
Maxime D.
Perspicace !
Eh oui, Perspicace, c'est le mot qui décrira au mieux ce petit ampli de chez Loxjie que je ne peux que conseiller. 2 semaines d'essai et vraiment pas déçu de mon achat. Pour ceux qui veulent se créer un petit 2.0 / 2.1, pour le prix, foncez ! Me concernant il est couplé à une paire d' Klipsch RB-81 II et le rendu sonore est vraiment très très bon, j'ai joué un peu avec le treble pour régler et le tour est joué. Bref, rien à redire pour le moment, à voir dans le temps !
Etien K.
AUDIOPHONICS STEALTH Stereo Cinch XLR Interconnect Cable OFC Copper ELECAUDIO 0.75m (Pair) This XLR modulation cable STEALTH was assembled by us in the Audiophonics workshops. The choice of materials has been carefully studied and every detail or finish is checked to...
Un bon achat
Je me suis procuré cette semaine un nouvel amplificateur de puissance pour l’utiliser avec mon préamplificateur, Audio-GD Master 19, que j’avais acheté chez Audiophonics.
J’ai aussitôt commandé sur le site un jeu de ces XLR qui m'avaient donné satisfaction dans mon dispositif. En attendant leur livraison, j’ai utilisé pendant quelques jours d'autres câbles que j’avais à la maison.
Ils sont arrivés ce matin et l’amélioration du rendu sonore était immédiate. Plus de clarté et plus de dynamique.
Bravo Audiophonics pour ces produits, bien meilleurs que certaines références plus coûteuses. Made in France de surcroit.
Nikos K.
Tout simplement génial pour l'argent. Quant au magasin AUDIOPHONICS, expédition incroyablement rapide et service impeccable.
Imrich R.
Fantastic !!!
The most transparent speaker cable I've ever heard, no matter the price. Mogami lets the music breathe, has no natural dynamics, unlimited coloring of instruments and textures, paints rich and detailed details and at the same time sounds easy and nimble. It's as if the cable has given way to music, and it's not just trying to use it to excel on its own. It lacks the feeling of listening to a component - it simply moves you closer to the source. Definitely beats very expensive products.
Thank you Audiophonics for the fast delivery of goods.
Iulian M.
Verry nice
I have to wait for burn-in but it sounds good from the start. Of axis also has great sound.
Excellentissime !
Dans l'ensemble je rejoins les avis précédents sur les grandes qualités de ce petit câble d'apparence modeste et tout riquiqui. Je vous assure qu'il envoie : des timbres magnifiques et doux et avec de l'impact, définition. Seule remarque à prendre en compte pour ne pas être déçu, il dégraisse pas mal l'extrême grave. Du coup je l'ai exploité pour oprimiser des grosses monitor diy montées avec un bon 30cm peerless et un pavillon klipsch, grosse clasque c'est juste magique les graves sont maintenant bien tenus et les médiums présents sans agressivité. Mêmes prestations sur mes mulidines accord de 1995 dont le grave un chouilla pneumatique se voit mieux maîtrisé sans nuire à la profondeur.
Merci Audiophonice pour nous proposer de tels produits à un prix vraiment intéressant. Vous m'en mettrez bien une bobine de 100m...
Claudio c.
HIDIZS AP80 PRO-X Digital Audio Player DAP Balanced 2x ES9219C Bluetooth 32bit 384kHz DSD256 MQA Black The AP80 Pro-X from Hidizs is a compact and powerful digital music player, benefiting from both a neat design and quality components. Behind a 2.45" IPS touch screen are two ESS...
Incroyable petit lecteur.
En quelques mots, incroyable lecteur pour le prix. Son , ergonomie prise en main facile.
Belle qualité !
Mon câble (diamètre 6mm) avait du mal à glisser dedans , astuce : fixer solidement avec du ruban adhésif le corps d'un stylo Bic à l’extrémité du câble , et faire glisser la gaine le long du stylo : gain de temps assuré !
Merci Audiophonics pour tous ces produits qui permettent de se livrer aux joies du DIY !!
Bambos P.
Top quality
Very high-quality connectors, easy to use with your thicker cable, good clamping system too. Highly recommended.
Bambos P.
Amazing
This is an amazing sounding cable, far better than the really good stock cable that is supplied with the Sennheiser HD 650, definitely worth every penny.
Very soft and playable. Highly recommended.
CHINDA A.
Very good 48V external power supply. It's a switch mode power supply (SMPS) but if well implemented can be as good as a linear power supply.
Like the other reviewer I also bought the power supply to use with the AIYIMA A07 (Audiophonics unbranded version) amplifier that measured well on Audio Science Review.
Using the amp to power 2 surround speakers. So the amp isn't working nearly as hard than if it was powering the front left & right speakers.
Very pleased with the 48V external power supply. Seems very clean uncoloured with plenty of power. Plus the pictures don't do it justice, it's well built nice aesthetics.
Definitely recommend!
jerome F.
WONDOM PS-BC12113 BCPB4 Battery Manager Module 5x26650 Charge Management Module for 5x Accumulators 26650. Safe charging and discharging. Delivers 21V at full charge, degressive
mitigé
La sortie 12v n'est pas régulée et en fonction du niveau de charge des batteries, le voltage en sortie est très très vite en dessous de 12v. Curieux aussi de voir à l'usage comment se comporte le module qui dans l'état n'as aucun ventilateur.. à suivre
NICK P.
Best dac under €200 easy
Very nicely made and finished, feels and looks solid. Wow, crystal clear and highly resolving, but, neutral sound. Creates incisive soundstage, makes my Wharfedale diamond 12.1's sing...! Used in combination with smsl A100 amplifier. Great pairing.
NICK P.
SMSL A100 Amplifier Class D Infineon MA12070 Bluetooth 5.0 2x80W 4 Ohm SMSL offers with the A100 a compact and affordable but nevertheless powerful Class D amplifier, based on an Infineon MA12070 chip allowing it to develop 2x80W under 4Ω....
Wow...!
Nicely made and finished, feels and looks solid. 40w per channel drives my Wharfedale 12.1 speakers very well, plenty loud enough...! In combination with the smsl su6 dac, a great system, just add a source.
Philippe H.
Surprenant d'efficacité
A peine installé, je constate la disparition des ronflements mécaniques (Atoll IN 400, 2 transfos de 500VA chacun), notamment lors d'utilisation d'autres appareils domestiques. C'est le rôle du DC Blocker, nickel.
Au fil des écoutes, avec la confirmation d'une 2ème paire d'oreilles averties qui connaît bien mon système, on est très agréablement surpris par l'apport sur le caractère global : posé, fluide, davantage de poids sur les notes, de variété sur les nuances … Zéro tassement dynamique, au contraire, timing encore plus évident et une mise en place au cordeau. Honnêtement, le rapport qualité/prix me semble excellent …
Noël C.
Avis DAC ES9018K2M
Je souhaitais faire évoluer le déjà bon DAC Sabre ES923, avec une version simplifiée du I-Sabre ES9038Q2M, ce DAC Sabre ES9018 répond à mon attente.
Mise en oeuvre avec un Raspberry pi et Moode audio version 7.61, la première impression subjective et qu'il est sensiblement plus détaillé, les plans plus précis, les basses plus profondes et plus fermes, avec une bonne dynamique.
Bonne carte DAC.
Penser à retirer le jumper J3 pour accéder à l'I2S.
Guillaume B.
Bonne qualité.
Un peu raide et doit être dompté au début.
Guillaume B.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Satisfait de cet achat
Utilisé pour lire la musique de ma tablette, via la sortie USB, sur un casque Meze 99 Classics.
A la hauteur de mes attentes.
Produit compact et de bonne facture.
Guillaume B.
Joli support de casque
Produit parfaitement conforme.
Se marie bien avec un Meze 99 Classics
Benjamin G.
Multi-Strand Litz Wire PU Insulated 90x0.01mm 0,71mm² Litz wire is a conductor whose strands are insulated from each other by a layer of varnish to eliminate the skin effect. This copper conductor also provides excellent electrical...
Attention à la description
Êtes-vous sûr que les brins soient de 0.01mm? JE pense que c'est plutôt 0.1mm
Stefanos S.
NEOTECH NEI-1002 Interconnect Cable UP-OCC Silver Triple Shielding Ø11.5mm The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE...
Great cable
Although i am a fun from the copper cables ,i did try the Neotech nei-1002 occ silver.
Absolutely top quality from Neotech, it sounds Crystal clear,with a large soundstage.
Audiophonics fast shipping as usual ,good package .
My only complaint is that Audiophonics sale cables only 1 meter size.
They should begin to sale cable's in 0,50 cm ,it wil be better for the customers and for the business.
 (10)
David S.
Mon premier vrai câble d'enceinte audiophile en remplacement d'un câble Norstone W250.
Suite à une montée en gamme de mon amplificateur (classe D remplacé par un ampli hybride lampes/transistors Lector audio) je songeait à remplacer mes enceintes Davis accoustic Balthus. Et bien non, ce câble furutech a révélé la capacité de tout mon système: le son délivré est précis et clair, des basses puissantes mais équilibrés, tous les instruments sont bien bien présents. Je partage les commentaires sur les aigus, mais impression qui s’estompe complètement si la source de l'enregistrement est propre.
Mécaniquement, je n'ai pas beaucoup d'expérience sur ce type de câble, mais l'isolation est très solide, il est blindé et l'âme en cuivre OFC est de très bonne qualité avec une petite rigidité à considérer pour disposer d'un rayon pour la connexion. (J'ai utilisé les connecteurs banane PANGEA XTREME)
David S.
validées
Débutant en en matière de tubes, je cherchait à remplacer les tubes electro harmonix montés d'origine sur mon pré-ampli phono qui commençaient à ronfler après environ 300h d'utilisation et qui n'étaient pas toujours précis dans les graves et aigus.
Je ne regrette pas le changement: tout est plus précis dès la première minute avec une dynamique améliorée et se bonifie à fur et à mesure du rodage.
Ces psvanes valent largement plus que leur prix.
Moyennement satisfait
Sur mon système, le DAC intégré au lecteur CD Shanling Tempo eC1B me donne plus de satisfaction auditive que ce DAC.
Essayé tous les filtres sans succès.
Cependant l'audition de chacun est différente ainsi que le système hifi.
Il n'y a qu'en comparant que l'on trouve son bonheur.
