WONDOM AA-AS43112 GAU4 Amplifier Module
The Wondom AA-AS43112 GAU4 is an amplifier module designed for integrators looking for a compact and versatile multi-channel amplification solution. Initially designed for gaming and arcade applications, this 4.1 module based on several Texas Instruments TPA3116s is also suitable for compact home cinema setups, sim racing installations or monitoring systems requiring separate bass management.
Reference : 21362
89,90 €tax incl.
74,92 € tax excl.
Wondom AA-AS43112 GAU4 Amplifier Module TPA3116 4x50W 4 Ohm + 1x100W 2 Ohm
Wondom AA-AS43112 GAU4 : Front view
The Wondom AA-AS43112 GAU4 is an amplifier module designed for integrators looking for a compact and versatile multi-channel amplification solution. Initially designed for gaming and arcade applications, this 4.1 module based on several Texas Instruments TPA3116s is also suitable for compact home cinema setups, sim racing installations or monitoring systems requiring separate bass management. The combination of comprehensive connectivity, a programmable DSP and lockable physical controls makes it an amplification platform that can be adapted to the varied constraints of professional environments and demanding DIY projects.
Wondom AA-AS43112 GAU4: Output power of 4x50W + 100W
The GAU4 benefits from a 4.1 architecture based on several Texas Instruments TPA3116 chips, delivering 4×50W under 4Ω for the mid-high channels, while the subwoofer output reaches 100W under 2Ω with a 24V DC power supply, creating a particularly immersive sound spatialisation.
Wondom AA-AS43112 GAU4 : Amplificateur 4.1
Wondom AA-AS43112 GAU4: Comprehensive connectivity
The module directly integrates a 3.5mm analogue jack input, USB and digital optical input, eliminating the need for external switches. Beyond this convenience, the digital inputs effectively isolate the signal from parasitic ground loops, preserving sound clarity in multi-equipment installations. This design allows direct connections to consoles, motherboards, smartphones, or televisions without complex rewiring.
Wondom AA-AS43112 GAU4 : presentation of the connectors
Wondom AA-AS43112 GAU4: Physical controls and secure locking
Four onboard potentiometers independently adjust the stereo/subwoofer balance, bass, mid-treble tone, and overall volume. This hardware approach offers instant, latency-free manipulation, while screen-printed markings ensure repeatability of settings. A switch deactivates the potentiometers after calibration, preventing accidental changes during operation, which is particularly useful in public spaces.
Wondom AA-AS43112 GAU4: Programmable DSP
The integrated digital signal processor, accessible via the ICP5 programmer, allows real-time adjustment of equalisation, cut-off filters, inter-channel delays and bass boost during playback. This iterative approach significantly speeds up acoustic tuning. Saving and importing DSP profiles allows for the deployment of an optimal sound signature across multiple installations, ensuring perceptual consistency regardless of room variations.
Wondom AA-AS43112 GAU4 : DSP programmable
Wondom AA-AS43112 GAU4: Heat dissipation and protection
The aluminium chassis ensures effective passive heat dissipation during continuous full-power operation, while also acting as electromagnetic shielding. On-board active protection monitors overvoltage, undervoltage, temperature, parasitic current and short circuits, ensuring rock-solid reliability.
Wondom AA-AS43112 GAU4 : dimensions
Wondom AA-AS43112 GAU4: Simplified installation
Self-locking terminals eliminate accidental disconnections, while differentiated Micro-Fit and Mini-Fit connectors physically prevent polarity reversal. Integrated aluminium fins with pre-drilled mounting points allow direct mounting on the chassis without intermediate brackets, optimising space in applications with limited space.
Product typeAmplifier module
Imputs1x Jack 3.5mm
1x USB-C
1x Optical Toslink
Outputs5x Molex
Output power4x50W @ 4Ω + 100W @ 2Ω
GainJack 3.5 input, stereo : 26.8dB
Entrée Jack 3.5, mono : 35.4dB
Optical input, stereo : +34.1dB(Vrms/FS)
USB input, stereo : 12.8 Vrms/FS
Input sensitivityJack 3.5 input, stereo : 775mVrms
Optical input, stereo : -11dBFS
Signal-to-noise ratio (SNR)Jack 3.5 input, stereo : 94.9dB
Entrée Jack 3.5, mono : 91.2dB
Optical input, stereo : 95dB
USB input, stereo : 93.8dB
Total harmonic distortion more noise (THD+N)Jack 3.5 input, stereo : 0.24%
Entrée Jack 3.5, mono : 0.01%
Optical input, stereo : 0.21%
USB input, stereo : 0.20%
Noise levelJack 3.5 input, stereo : 237.4µVrms
Entrée Jack 3.5, mono : 460.9µVrms
Optical input, stereo : 233.6µVrms
USB input, stereo : 262.5µVrms
Dimensions190 x 116 x 37mm
Package1x Wondom AA-AS43112 GAU4
InputJack 3.5mm
OutputMolex
Channel4.1
Amplifier chipTPA3116
Power (W)100.0
Power (W)50.0
WONDOM AA-AS43112 GAU4 Amplifier Module TPA3116 4x50W 4 Ohm + 1x100W 2 Ohm
The Wondom AA-AS43112 GAU4 is an amplifier module designed for integrators looking for a compact and versatile multi-channel amplification...
