ARYLIC LP100 Streamer
-15%
The Arylic LP100 is a network player that uses high-quality components to provide access to various audio streaming protocols and platforms.
Reduced price!
Reference : 21334
Limited time offer:
449,00 €tax incl.
-15%
381,65 €tax incl.
318,04 € tax excl.
Shipping date: 01-12-2026.
Arylic LP100 Streamer AK4493SEQ WiFi Bluetooth 5.4 Roon Airplay 2 Google Cast DLNA UPnP 24bit 192kHz
ARYLIC LP100 picture
The Arylic LP100 is a streamer that uses high-quality components to provide access to various audio streaming protocols and platforms. Its architecture includes an AKM AK4493 SEQ DAC chip combined with a CT5302SL chip and an AK7735 ADC/DSP. The combination of these three chips offers superior high-resolution stream processing quality up to 24bit 192kHz PCM. Compatible streaming protocols including WiFi, AirPlay 2, Google Cast, Spotify Connect, Tidal Connect, Roon Ready, DLNA, and UPnP provide access to numerous sources. In addition, it features Bluetooth 5.4 and support for SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, and LC3 codecs. The LP100 can also be controlled in a number of ways, including via an infrared remote control, a dedicated mobile app, or voice control via Siri or Google Assistant. Its sleek design and extensive connectivity make it a device of choice.
A high-performance streamer
Arylic LP100: High-quality components
The trio of AK4493SEQ DAC chips for high-resolution playback, SRC CT5302SL for refined conversion, and AKM7735 ADC/DSP for precise signal processing delivers a high-quality musical experience with support for up to 24bit 192kHz PCM.
The components of Arylic BP100
The streaming protocols of the Arylic LP100
Airplay 2
AirPlay 2
Stream music directly from your iPhone, iPad, or MacBook, and listen to it with other AirPlay 2-compatible devices. You can also add LP100 to the Apple Home app and easily control it with your voice via HomePod.
Google Cast
Google Cast
Stream music directly from your Android device, YouTube, or any other Cast-compatible app. The LP100 works seamlessly with other Google Cast speakers for multi-room playback, voice control with Google Assistant, and supports high-resolution streaming up to 24bit 96kHz via Google Cast.
Spotify Connect
Spotify Connect
Listen to your playlists and collections directly from the Spotify app. With Spotify Connect, LP100 streams your music over WiFi for superior quality and stable playback. Even free accounts can enjoy it, without interruption from phone calls.
Tidal Connect
Tidal Connect
Stream high-resolution music directly from the TIDAL app to the LP100 via Wi-Fi. Enjoy your personalized playlists and lossless sound with exceptional clarity, and continue listening to your music even when you receive calls.
Arylic LP100: Bidirectional Bluetooth 5.4
The Arylic LP100 streamer's Bluetooth 5.4 supports wireless connection streaming reception and transmission, allowing for many different configurations. In addition, it supports many high-resolution codecs such as SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, and LC3, as well as Auracast and LE Audio features.
Bluetooth function of the Arylic LP100
Arylic LP100: EQ via the GO CONTROL APP
The Go Control App offers numerous features, including an equalization system to adjust the sound output according to the type of music being played or the user's preferences.
EQ function via the GO CONTROL APP
Arylic LP100: An easy-to-use streamer
GO CONTROl APP
Go Control App
Take full control and customize your personal settings.
BLE Remote Control
BLE Remote control
Quick reading, equalizer, access to preset content with remote control.
Voice Control
Voice control
Convenient voice control with Siri and Google Assistant.
Arylic LP100 overview
1Reset
2GND Phono terminal
3Trigger 12V output
4USB-B input
5RJ45 Ethernet LAN port
6USB-A Host input
7HDMI eARC CEC input
8RCA phono input
9RCA input
10Coaxial SPDIF input
11Toslink optical input
12RCA output
13Subwoofer ouput
14Toslink optical output
155V 2A power supply via USB-C
Contrôle via HDMI CEC
Arylic LP100: Control via HDMI CEC
Thanks to HDMI CEC technology, the LP100 integrates seamlessly with your TV. Turn on your TV and the LP100 will automatically start up. You can control the volume and playback using your TV remote control.
Product typeAudio streamer
ChipsetDAC AK4493SEQ + SRC CT5302SL + ADC/DSP AKM7735
Inputs1x USB-B
1x RCA
1x RCA phono input
1x HDMI eARC input
1x Coaxial input
1x Toslink optical
1x USB-A host
Bluetooth
Outputs1x RCA line output
1x Subwoofer output
1x Toslink optical output
Bluetooth
Other connectorsTrigger out 12V
Port Ethernet RJ45 (LAN 10/100M)
Supported sample ratesPCM up to 24bit 192kHz
WiFiIEEE802.11 b/g/n 2.4GHz, 5GHz
Bluetooth5.4
Supported Bluetooth CodecsSBC, AAC, aptX, aptX HD, aptX AD, LDAC, LC3
Supported streaming protocolsWiFi, AirPlay 2, Google Cast, Spotify Connect, Tidal Connect, Roon Ready, DLNA, UPnP
BroadcastAuracast 10m
Frequency response20Hz-20kHz ±1dB
THD+N≤ 0.001%
SNR≥ 80dB
Crosstalk≥ 80dB
Phono compatibilityMM / MC, RIAA EQ built-in
Supported USB Host FormatsFAT16, FAT32, exFAT, up to 128GB
MP3, WMA, M4A, AAC, FLAC
ApplicationGo Control App
Compatible voice assistantsSiri, Google Assistant
Power supply5V 2A via USB-C
Dimensions167 x 167 x 43.5mm
Weight550g
Package1x Arylic LP100
1x RCA cable
1x USB-A to USB-B cable
1x USB-C cable
1x AC adapter
1x IR remote control
InputWiFi
InputPhono
InputHDMI eARC
OutputOptical Toslink
OutputSubwoofer
OutputBluetooth
DAC / ADC ChipAK4493SEQ
Max sampling rate192kHz
Remote ControlYes
Remote ControlControl app
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsUpnP
ARYLIC LP100 Streamer AK4493SEQ WiFi Bluetooth 5.4 Roon Airplay 2 Google Cast DLNA UPnP 24bit 192kHz
