ATAUDIO AT-K005 Interconnect Cable 4.4mm Jack to 2x RCA Male 75cm
The ATAudio AT-K005 interconnect cable is a high-quality cable featuring a balanced 4.4mm stereo jack connector (TRRRS) on one end and a pair of RCA connectors on the other. This unique design is only compatible with some particular devices.
Reference : 21345
24,81 €tax incl.
20,67 € tax excl.
Shipping date: 01-12-2026.
ATAudio AT-K005 Interconnect Cable 4.4mm Jack to 2x RCA Male 75cm
Photo du ATAUDIO AT-K005
The ATAudio AT-K005 interconnect cable is a high-quality cable featuring a balanced 4.4mm stereo jack connector (TRRRS) on one end and a pair of RCA connectors on the other. This unique design is only compatible with some particular devices. The AT-K005 consists of a 6N OFC copper conductor for increased conductivity and copper shielding to protect the signal from interference. The connectors feature gold-plated copper contacts. Robust and elegant, this cable is durable and reliable.
Be sure to check that your devices are compatible with this type of cable before use, otherwise you risk causing serious damage to your device.
ATAUDIO AT-K005 Interconnect Cable Structure
1Spiral conductors
26N OFC copper
3Transparent PVC insulation
4Copper braided shielding
5PVC Insulation
6Filling cotton
7Outer sheath
8Cotton braided sheath
Product typeInterconnect cable
Connectors1x 4.4mm stereo balanced jack (TRRRS)
2x RCA
Conductors6N OFC Copper
ShieldingCopper braid
InsulationPVC sheath
Cable diameterØ6.5mm
Outer sheathCotton braid
Connector contact materialsCopper
Connector contact plating24K gold
Length75cm
Package1x ATAudio AT-K005 interconnect cable
Length (m)0.75
ShieldingYes
Section (mm²)N/A
ConnectorRCA
ConnectorJack 4.4mm
The ATAudio AT-K005 interconnect cable is a high-quality cable featuring a balanced 4.4mm stereo jack connector (TRRRS) on one end and a pair of...
