Comme je l'écris...
Rachid C.
J'en rachète, donc très bon produit.
Rachid C.
Petit mais costaud
Petit ampli, 2x50W, DSP. Très versatile. Rapport qualité/prix des plus intéressant. Je l'ai acheté pour expérimenter avec...
Customers reviews - There are 19539 reviews.
Anastasios D.
ATAUDIO L-4E6S Male USB-A to Male USB-B Cable Gold Plated OFC Copper 0.75m This ATAUDIO USB cable offers both high quality and luxurious design. It consists of a four conductor structure made of braided OFC 6N copper with excellent conductivity,...
Nice quality cable!
Nice quality cable!
Anastasios D.
Nice quality cable!
Nice quality cable!
Anastasios D.
Quality build!
Nice quality build PSU with good connectors. Packed nicely and shipped fast!
Anastasios D.
AIYIMA A07 Class D Amplifier TPA3255 2x225W 4 Ohm The Aiyima A07 is a small, simple, powerful, efficient and affordable Class D amplifier, ideal for setting up an audio system that requires a lot of power input. It embeds a...
Surpisingly good!!
I was looking to buy something cheap to replace my meridian 556 amp until it's fixed. I have the B&W 685 speakers (first edition) and this amp sounds so clear and detailed. I think it lucks some power compared to the meridian even with the "Switched Mode Power Supply 100-240V AC to 48V 7A DC". It is loud but I think it cannot drive the speakers with power compared to a transistor amp. But it is loud and clear, so I give it 5 stars for the money!
The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
Jean-Pascal H.
Filtre secteur
Mes appareils sont enfin protégés le wattmètre est très pratique pour connaitre la consommation réel de chaque appareil , merci top
Jean-Pascal H.
Cable Secteur
Câble d'alimentation très bien réalisé à un prix qui me convient merci Audiophonics
Anastasios D.
Nice sound!
Very good device. I am connecting it through Coax, Toshlink and USB to my old AudioGD DAC19MK3 and it sounds beautiful. Unfortunately I cannot test the I2S yet, but I might modify my DAC to accept it. The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
David T.
Après neuf mois d écoute, aucun changement. Amplificateur de premier choix
Kentarou T.
IAN CANADA HDMIpi MKII Transmitter I2S / DSD / DoP to HDMI This module allows you to recover the outgoing digital audio stream of the GPIO port of a Raspberry Pi (or one of its HATs) and send it to the balanced LVDS format on an HDMI port.
Great Product
I am using HDMIpiMkII (RaspberryPi5 GentooPlayer) and Musician Draco with i2s transmission. I have used Topping and RME products in the $200 to $1,000 range, but the sound quality is completely different from those. It is very smooth and has high resolution, and I want to listen to it forever. It took a little effort to get the sound to come out, so I will summarize the settings.
(1) HDMIpiMkII: Jumper Switch S1 settings
DIP1: ON DIP2: ON DIP3: ON DIP4: OFF (master clock is not output)
The initial state is all OFF, and i2s signals are not output from the HDMI terminal, so you must set it.
(2) Musician Draco: Set i2s mode to Mode5
The lamps [1X] and [4X] at the bottom right of the front panel should be lit. The mode setting method is described in the user's manual (i2s PIN configuration of DRACO).
(3) Connecting HDMIpiMkII to Musician Draco
I use ECDH-HD14SS03BK (made by ELECOM).
équilibre parfait
Salut ,comme j ai changé d enceintes et platine vinyle , je trouve le cable ludic d un realisme incroyable! Le couteau suisse des cables HP pour moi ,franchement pour faire mieux faudra mettre tres cher! recommander vivement
la reine de la rapidité ,finesse!!!
Bonsoir , j ai testé ma schuko 004 sur mon ampli nuprime , vondita oyaide ,iec 004 , a la place d une FI38r ,resultat plus de vitesse,precision, transparence ,finesse, super aigu! petit bémol elle degraisse un peu . Franck
Paul M.
Compact, XLR out and balanced sound: all I need!
I use this DAC for conversion duties between my TV and active speakers. Happy to say that it ticks all the boxes for me. XLR out, solid build, foolproof and logical operation and most importantly: a detailed and balanced sound. It does not outperform the dac in my audio set (and it shouldn't at just 10% (!) of the price of the audio dac), but it would make me rethink the audio dac should I have to purchase that now. Recommended!
joel p.
TONEWINNER TY-1CD CD Player DAC ES9028 The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as...
lecteur cd tonewinner ty-1cd, surpris !
colis reçu rapidement et bien emballé, merci d'avoir respecté ma recommandation sur ce point particulier.
Je suis agréablement surpris par la qualité de fabrication et la finition de ce lecteur.
A l'écoute, je redécoudre mes cd du point de vue de la musicalité, très analytique, procure un espace sonore en 3d encore amélioré par rapport à mon ancien lecteur british.
Avec des cd de bonne facture (qualité audiophile) j'apprécie tout son potentiel et qui pourra que s'améliorer après une période de rodage.
Bref, pour l'instant je suis très satisfait de cet achat ! très très bon rapport qualité prix !
Josep s.
XDUOO XD05 PRO Portable Headphone Amplifier DAC ES9039SPRO XMOS XU316 32bit 768kHz DSD512 MQA 8x With the XD05 Pro, xDuoo unveils a high-performance, robust and versatile portable DAC / headphone amplifier. It features high-quality components such as an ESS ES9039SPRO DAC...
XDUOO XD05 PRO
Envio rapido,muy bien empaquetado,web seria y muy de fiar.
El amplificador/dac,excelente en construccion,prestaciones,conectividad y gran calidad de sonido,es una maravilla en relacion calidad/precio!
Alain S.
DAC TOPPING DX3 PRO+
excellent DAC, correspond a mes attentes, HI RES enfin disponible sur mon installation HI-FI.
Son de très bonne qualité.
Uwe G.
Topp Kabel
Ein Kabel ohne Kompromisse.
Konfektioniert mit Kupfer vergoldeten Steckern ein Muss.
Alexandre L.
Cable de très haute volée
Acheté en remplacement du câble de ma multiprise Furutech TP60E (Audiophonics Stealth excellent cable pour 100E).
La clarté apportée est incroyable j'ai l'impression d'avoir un nouveau DAC ! Neutralité conservé avec plus d'extension des aigues, très cohérente et aucunement agressive ni incisive.
Pas d'extension dans les basses mais plus de précision et de slam. Pour le médium il était déjà incroyable dû au rhodium des prises mais il vient le rationaliser et pousser encore la barre pour atteindre une justesse jamais entendu !
Monté avec IEC Oyaide C004 et Schuko Furutech FI-E38(R).
Au passage le câble est balèze mais est suffisamment flexible pour une installation correcte. J'en rachèterai sans hésitation pour un cable d'ampli dans le futur !
David S.
What an awesome surprise. This is just great.
I was completely caught off guard by this. I bought it more out of curiosity than anything else, quite certain of a return. Well, the Digirescue is not going anywhere. With a 5v IfI IPower 2 power supply, the sound of out of the reclocked coax tap was much improved compared to the sound obtained from my Elac ds s101g previously. But after connecting the Digirescue to my Keces P3 lps upgraded with a SR Orange fuse, the sound coming out of of my Rotel 1592 mk ii just exploded…it is way above anything I could expect. For me the lps is a must do upgrade. The imaging, the depth and width of the soundstage, the dynamics, and musicality, have just gone from adequate to really, really good. I know it probably sounds silly to use such an expensive lps with a component at this price point, but if you already have a power supply and are thinking about upgrading your streamer, just give this a go, you might have a surprise. I was not expecting anything given there weren’t many reviews, but I’d give this a 6/5. Well done audiophonics! I guess Ian Canada stuff is really that good. I’d recommend using good cables as well, totally deserving of them.
Pedro Jose T.
A 10 for Audiophonics logistics
In less than 36 hours my order was at home (Palma de Mallorca), a record. So congratulations to the Audiophonics logistics team.
I'm not going to talk about the sound characteristics, or the finishes, since other buyers have already done so and I fully agree with their observations, a fully recommendable amplifier if you are looking for quality-price and with a small footprint for your desk.
I just want to comment on how nice it looks with that red LED light that comes out from the inside through the ventilation slots and that I don't think anyone has mentioned. I also want to comment that I thought it would get hotter, but it has been working for about 4 hours (volume at 40%) and it is practically cold and moves my 84.5 db sensitivity speakers without problems.
Rainer E.
Top !!
Nachdem ich bereits mehrere andere DACs ( Gustard x26 Gustard R26 und einen Questyle) ausgiebig in meiner Kette getestet hatte und die Firma Gustard fast ausgeklammert hätte, bin ich mit dem Gustard A26 hochzufrieden.
Dieses Gerät liefert eine sehr natürliche, authentische Wiedergabe mit ebensolchen Klangfarben, sehr guter Auflöung und einem ganzheitlich überzeugenden Gesamteindruck.
Klanglich habe ich nichts zu bemängeln. Ich kann damit Musik hören, ohne ständig da und dort mehr oder weniger Defizite verbessern zu wollen. Zuhören ohne Stress ohne in verrundeten Wohlklang abzugleiten.
Den Streamer habe ich nicht ausprobiert, da ich direkt über Macbook Pro und Audirvana höre.
Ich habe eine Hifi - Tuning Feinsicherung in der Gold Ausführung installiert, bzw. gegen die serienmäßige Feinsicherung ausgetauscht. Netzkabel ist das Furutech FP-3TS20. Auch dieses ist sehr empfehlenswert. Leider - wie so vieles - deutlich im Preis gestiegen.
Zurück zum DAC: Dieses Gerät ist in dieser Preisklasse absolut empfehlenswert und vielen anderen - auch R2R DACs überlegen.
Hätte ich den A26 nicht, würde ich wahrscheinlich den A26 schauen, oder dem Gustard X30.
Aber......die Nachfolge der aktuellerern Geräte ist noch lange kein Grund unzufrieden zu sein.
Hören Sie sich den A26 an, wenn sie die Gelegenheit dazu haben!
Die eingangs erwähnten Geräte lässt er locker hinter sich. auch den vielerorts hochgelobten RME DAC.. Ganz zu schweigen von allem was günstiger als Fertiggerät erhältlich ist.
Dimitar M.
SMSL PL100 CD Player CS43131 Silver The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound...
Excellent!
Great little CD player!
Very nice looks, decent remote control and superb sound quality! I first tried it with the optical out into my Aune X8 DAC with Sparcos Op-Amp. Sounded great.
After that I decided to try the onboard DAC and it sounds almost as good as my external DAC, that costs 4 times the whole CD player!
Overall, I am very pleased with it!
Murat D.
Génial
Je les utilise au lieu des J&J EL34s sur mon ampli intégré. Je suis totalement satisfaite de cet achat. Un grand merci à Audiophonics.
FURUTECH NCF BOOSTER-SIGNAL-L Flat Support for Cables and Connectors Furutech's NCF Booster Signal L, a version of NCF Booster Signal, is a cable and connector holder designed to improve cable and connector performance. Having been a real success...
Le son se modifie mais est il meilleur ? rqp élevé
Ma chaine dispose de plusieurs câbles secteur stealth audio . Essayé sous le câble de l'ampli puis sous la prise du câble d'alimentation général . Je constate un son lissé et plus propre mais moins impliquant qu'avec les supports que j' ai fabriqué avec des supports de manche à balai muraux surmontés d'absorbants acheté sur ce même site . Cependant le son reste bon avec ce booster signal mais il s'agit sur mon système d'un autre type d'écoute plus rectiligne et avec moins de relief . Mon avis n'engage que moi mais ne justifie pas ce prix qui me semble élevé pour le résultat . A voir selon les systèmes .
Jean-Jacques R.
Gain trop important
Testé sur un ampli à transistor en remplacement de son préampli.
Le + :
- Le son à l'air déjà bon avec ses tubes d'origine,
- pas de ronflette,
- punch
le moins :
inutilisable sur mon ampli (Roksan kandy KII) du fait du gain élevé qui arrive dès le début de la course du potentiomètre de volume.
Le volume est trop fort alors que je ne suis même pas au quart et n'est pas gérable sur mon installation. Dommage.
Mais peut-être qu'un remplacement du potar serait une solution ?
Armin w.
It's Ok
After some fiddling with minor issues, I will correct my former review and give the case 4 stars for the price is fair.
Armin w.
Good quality
and works flawless. Recommended!
Szabó Z.
quality product as usual
Xavier B.
Mauvaise connexion
Bonjour, j'ai branché ce câble ATAUDIO KING WOLF sur ma platine Marantz et les connecteurs de chaque câble ne serrent pas assez du tout ; en tirant légèrement, les câbles se retirent assez facilement sans faire bouger la platine. Les connecteurs se serrent/desserrent un peu mais cela ne change rien à la force de serrage.
David O.
Easy to install - works well
DC 9V Jack Filter with Supercapacitor to Jack DC This DC 9V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 5F - 3.0V and an...
Pratique et efficace
Apport évident dans la plupart des configuration.
J'en ai plusieurs et l'ajout d'une forte valeur capacitive de 4 à 5 Farad ( 4/5 millions de uF) apporte un vrai plus en matière de musicalité !
Très qualitatif et précis dans son utilisation. Le serrage inspire confiance et la fiche la qualité.
Etonnant
A la réception, j' ai été surpris par la qualité au toucher. Côté serrage, la aussi, c' est parfait. Une vraie pièce de précision !
Theodoros A.
MiniDSP MCHStreamer
Have been working with its previous version since 2013 without a single hitch. I integrated the new one in a multitrack interface setup (24ch) and is working flawlessly from day one. Albeit not really cheap, it' s worth its price..Audiophonics service prompt as always.
Rick H.
Wow - Great amp
The amp arrived in 3 days to the US! Very fast. Packaged well and I got it hooked up and it impressed me from the start. Smooth and musical - I could really see this amp as an end game. Gobs of power and control over my tower speakers. I am really impressed with how seamless the sound is. Nothing stands out - in a good way. Highly recommended!
Denis K.
SMSL B200 DAC USB CS43131 Bluetooth 5.1 Receiver aptX HD LDAC 24bit 48kHz The SMSL B200 offers both USB DAC and Bluetooth receiver functions. It benefits from a Cirrus Logic CS43131 chip, enabling it to support sampling rates up to PCM 24bit 48kHz via...
performant.
Acheté pour remplacer un Audiophonics U sabre , il tient bien la comparaison, son très clair et ciselé dans les médium et les aigus.
Mise en route rapide après avoir installé les pilotes ( lien fourni par l'assistance Audiophonics, merci ...) ça fonctionne direct en USB,
Apparié en Bluetooth en un éclair, pour écouter via le téléphone, à l'occasion.
J'ai utilisé les sorties RCA en analogique donc pas de retour concernant les sorties numériques,
En résumé très bon achat pour moi, en espérant une durée de vie aussi longue que le Sabre (8 ans!).
Très bon rapport qualité-prix pour ce DAC compact!
Dominique O.
12AT7-S
Tube comportant une finition excellente ;
montés sur un ampli Octave , ils ont une excellent définition, en particulier sur les médium / aigus
Rumen S.
Simple and reliable!
They are no nasty surprises with Neutrik XLRs.
The assembly is firm and tight and cable is ready for a heavy duty applications.
Rumen S.
Rumen S.
Very good product
This skin is easy to work with and has very good appearance.
I used it on OYAIDE TUNAMI V2 Ø15mm cable and it fitted perfectly.
Excellent value for money!
Pino M.
excellent cable!!
I own a Chord digital system that requires BNC SPDIF cables to express it's best: this cable makes the system to sound really well, better than any other I tried, great value for it's cost.
Impressionnant pour le prix
Comment dire...mes préjugés sur les amplificateur en classe D sont tombés...exceptionnel de transparence,sur des enceintes de rendement correcte (92 db) aucun tassement de dynamique ni de saturation même à niveau sonore déraisonnable
Comment vous faites pour moins de 300 euros ??
Petit aparté : je le trouve plus équilibré, moins brillant dans l'aigu que le AO 200 mk2
DAC INTÉGRÉ de qualité tres moyenne, mérite un dac externe
Gulnara G.
Beautiful player, love it!!!
Beautiful player, thoughtful retro design, and great quality. Packaging also looks nice.
THIERRY D.
gaine
la gaine est épaisse, très solide, idéale pour un travail propre et efficace...
THIERRY D.
gaines
les gaines sont épaisses, très solides, idéales pour un travail propre et efficace...
THIERRY D.
Banana Plugs Gold Plated Ø4mm (Pair) These low-cost banana plugs allow for quick and easy design of speaker cables. The assembly is done by means of a screwing system, effectively holding the conductor in the...
Bananes
fiches bananes d'excellente qualité, le contact avec les borniers est parfait. Montage facile !!!
Sanjin S.
ISOACOUSTICS APERTA Speaker Stands 155x190x76mm 15.9kg Black (Pair) IsoAcoustics Aperta isolators provide excellent energy management for your speakers to reduce vibrations resonating through the support surface and eliminate dissonant sounds...
Great speaker stands.
I am very pleased with the improvement in the sound of my bookshelf speakers. If you have bookshelf speakers, I definitely recommend purchasing these stands.
Emmanuel L.
Mieux qu'un DC06 mais ça n'est pas le miracle
Ce petit DAC rend bien mieux qu'un iBasso DC06 ou même qu'un iFi Hip Dac 3 (sans la puissance). Il est plus précis et plus détaillé. La scène est plus large et les instruments bien séparés mais la largeur de la scène n'est pas envoutante.
Je l'ai testé avec un Hifiman, le FiiO FT1 et un Audiotechnica MSR7. S'il drive le Hifiman mieux que le iBasso DC06 qui menance de flamber tellement le casque en demande, ce n'est pas non plus ce que j'ai lu ici et là. Il se débrouille bien avec le FiiO et l'Audiotechnica mais un bon setting est nécessaire sans quoi la les basses et les aigus s'envollent.
La molette est gènante, elle s'active dans la poche et n'est pas manipulable aisément avec une seule main.
L'écran affiche trop d'informations en même temps, ce qui rend les caractères trop petits.
Sur un smartphone Android (Nexus 7a) c'est une calamité, beaucoup plus "picky" que le DC06 ou le Hip Dac. A la moindre perte de signal, le driver audio est désactivé. Au démarrage de l'application, il faut parfois plug-unplug plusieurs fois pour que le driver se load correctement; un peu comme avec les Questyle, qui, eux, m'ont carrément rendu dingue.
Bref, c'est bien, c'est petit mais je le trouve surcoté dans les reviews. Il y a des inconvéniants et il faut le dire
Emmanuel L.
Bon casque mais quelques défauts casse-pieds
Dans l'ensemble, pour 150€, on ne peut pas reprocher grand chose à ce casque, il est précis et la séparation des voies est bonne.
La scène sonore est par contre moyenne, peu ample ; les basses bien présentes mais peu détaillées.
Le pire est la rigidité du câble. Si vous utilisez un DAC portable, il engendre une contrainte folle sur l'USB.
Enfin, sur la tête, il ne montre pas une tenue très travaillée. Je n'ai pas une petite tête et pourtant, réglé au minimum il tombe presque si je gigote trop.
Johan G.
LT3045 Linear Voltage Regulator 5V The LT3045 linear voltage regulator offers excellent performance and is ideal for HiFi integrations, providing a clean electrical signal to the audio circuits. It can be used to...
Johan
These regs have a favourable price level but there is a distinct lower level quality on the boards compared to ldovr variants. The soldering is quite sloppy with some of the regulators having an excess of solder on the connection pins.
The component values differ from that of the TI manual recommendation. The for noise critical Cset is 20x (0,47uF) to small so the advertised noise figures here cant actually be met. So these are not 0,8uV. The 2 other caps is however 10x bigger (47uF) than the smallest value recommended. Did someone mix up the values... Go figure...
These would be very nice if Cset vas altered to 10uF and the soldering and cleanliness of the product could be improved.
Christian T.
TOPPING L70 Balanced NFCA Headphone Amplifier / Preamplifier Black With the L70, Topping offers a highly engineered balanced NFCA headphone amplifier and preamplifier combo that delivers excellent sonic performance and is suitable for a wide...
Topping L70
Very fine pre amp...
