Krzysztof K.
Good HDMI Cable, indeed!
Hey, folks!
Urtsua R.
Fine
Ruben P.
Audiophile grade +
Customers reviews - There are 19424 reviews.
Ioannis K.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Excellent DAC/head phone pre-amp
Today, after the ultra fast shipping from audiophionics, i had the pleasure of experiencing the Topping DX3Pro+, and let me tell you, it's a game-changer. As someone who values both sound quality and versatility, this DAC truly impressed me. For the money it costs, its superb.
Hachadourian F.
Knob Aluminium Notched Shaft 25x13mm Ø6mm Black This black aluminium knob with a diameter of 25mm and a depth of 13mm has a 6mm diameter notched pin. A perfect button for mounting on a DIY project or as a replacement for a...
excellente qualité et esthétique à un prix très correct !
Cao Hai N.
Excellent RQP
Excellent! Du gain et de la musicalité. Qualité/Prix imbattable!
Henry G.
Automatic Power Suplpy Switching Module This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV.
Remplit parfaitement sa fonction, compact. Dommage que la modification de la tempo ne puisse se faire que par un changement de capa d'un condensateur.
JULIUS L.
I LOVE THIS AMP
I have also the LD1+ but MKIV SE is just so much better at everything.
The amount of bass,midbass and midrange is surprising great pairing with my Grado RS1x razor sharp neutron star dense bass pure audio bliss. There is plenty of power that I will probably never need this much but good to have it just in case.
There is slight microphonics but proper placement away from electromagnetic fields from other electronics helps.
Those tubes improved after 60 hour so much better separation of layers, better details everything.
Delivery and sent was fast and reliable highly recommended audiophonics is GREAT.
I will be back in the future for sure!
Pratique
Comme son jumeau en iec, ce connecteur est super pratique pour les câble de grosse section et pour gagner de la place sans abîmer le matos. Bonne restitution .
Pratique
Pratique pour gagner de la place derrière un meuble et bon accueil pour un elecaudio cs361 de 17 mm de diamètre.
Bonne restitution du signal.
DDHifi TC07S USB-C Cable Pure Silver / OFC Copper OTG 50cm The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to...
sous des cables
LAURENT G.
ETI KRYO Silver Plated Tellurium Copper Binding Post Ø17mm x 52mm (Set x4) The ETI Kryo are top of the range terminal blocks designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity and...
Excellents borniers
LAURENT G.
Pratique et bonne qualité
Bonne qualité pour le prix.
Je conseille vivement.
LAURENT G.
Guillaume F.
SHANLING M0 PRO Compact HiFi Digital Audio Player DAP DAC 2xES9219C Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD Green Shanling offers with the M0 Pro a technical and aesthetic evolution of the M0 high fidelity digital player. This Pro version benefits from an improved digital/analog conversion...
DAP Shanling M0 Pro
Laurent M.
Très très bon câble H.P
Sur ma config;
les connecteurs :
Le résultat est magnifique !
C'est beau !
très bon
très bon
toujours content
ca dépends du système
Anton N.
Excellent bornier.
Excellente fiche banane
Emmanuel A.
Haut de gamme
Joris J.
Loose physically connected
Joris J.
Superb reclocker
Eugen M.
TSP facile
Eugen M.
Très surpris en bien
Joris J.
Exceptional value
Almost for free.
Philippe K.
ASTELL&KERN KANN MAX Digital Audio Player DAP HiFi 4x ES9038Q2M Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Gray The KANN series is a line of portable digital music players, particularly popular with audiophiles for their performance focused on high output and clear sound. The KANN MAX,...
Erik J.
naturel
Thierry V.
Surprenant!
Rimantas S.
Nice little DAC
Nothing to complain about.
Jean L.
Très bon RQP
Gregory F.
Impressionnant
bernard T.
fiche bananes
Très belle fabrication, dommage que les vis soient un peu courtes car même avec un câble de 4mm2, elles peuvent tomber dans le corps du connecteur à la fin du serrage.
TAD ECC803S Tube Twin Triode (Unité) The TAD ECC803S tube is a double triode with a long plate, based on the Telefunken ECC803S design. It has a 1dB lower gain than the ECC83-Cz but offers a much more detailed and...
En rodage
Première impressions face aux tungsol qualité standard que je viens remplacer.
Plus de présence et de définition dans les basses fréquences.
Pas vraiment plus de details mais il n'ont que 3 ou 4 h d' exercice.
De prime abord, tien de fou face au tungsol.
On verra dans le temps...
Cela reste de bons tubes.
ARYLIC B50 Amplifier Two-Way Bluetooth 5.2 aptX HD HDMI ARC 2x50W 4Ω The Arylic B50 is an extremely versatile and practical Bluetooth 5.2 amplifier, endowed in addition to its wireless connectivity with a wide panel of connectors allowing it to...
Très très bon ampl avec l hdmi parfait pour un televiseur
Excellent ampl très étonnant pour sa gamme de prix. Il fonctionne à merveille pour épauler une TV avec l hdmi arc et l aptx hd s entend c est étonnamment bon quand les appareils connectés supportent le même code pour un système d'appoint ou du quotidien sans prise de tête tv et musique de qualité c'est parfait. En plus l appli est très bien faite franchement super pratique et Son qualitatif.
Didier G.
NEOTECH NEET-3008 Ethernet RJ45 Cable UP-OCC Copper 3m Neotech offers with its NEET-3008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It integrates four UP-OCC Copper conductors with a cross-section...
Didier G.
Patrice L.
Excellent choix
Cette nouveauté chez AudioPhonics est excellente .
Du connecteur cuivre doré dans des proportions minimalistes afin de ne pas perdre le signal dans des masses métalliques inutiles ( sauf pour l'égo de certains ... ) .
La coque est également en cuivre qui lui confère une bonne rigidité pour un poids assez léger.
L'accès à la soudure est déjà vue , hyper pratique, l'isolant tient bien la chaleur.
Je ne me perdrai pas dans la critique de la concurrence, mais à conception équivalente et à très exactement 4 x le prix, chacun se fera son opinion.
Cette fiche n'est pas blocable mais perso je ne m'en sers pas dans une régie/son , donc ....
Dans les ratios prix/matériaux/conception/fabrication, je ne chercherai pas plus loin.
Merci Audiophonics pour cette excellente initiative.
Bonnes soudures à tous
Alan S.
Très belle et bonne barrette secteur
je souhaitais refaire un peu mon setup home cinéma et il restait une partie à ne pas trop négliger l'alimentation de ce dernier (TV ampli HC platine Blueray, Console, PC multimedia, décodeur TV ) .
J'ai opté pour cette barrette 8 prises afin de disposer d'assez de prise en tenant compte du placement d'un filtre IFI AUDIO AC iPurifier pour la partie vidéo. J'ai associé des câble secteur de chez PANGEA AC-14SE MKII et franchement ça match bien. Il faudrait que je permute afin de voir si tous les bénéfice sont là mais en tout cas pas de bruit parasite ou de neige à l'écran ni au niveau du système sonore. Ça respire la qualité. Alors est-ce un effet placebo ? En tout cas quand j'écoute une bonne source ( FLAC ) sur mon système je le fais avec un grand plaisir :D
Alan S.
Indispensable pour écoute nomade sur Smartphone
Ayant deux casques de qualité, je voulais pouvoir les utiliser sans souci sur n'importe quel smartphone. Après un moment de recherche, je me suis arrêté sur le Fiio KA3. Et franchement je ne le regrette pas le moins du monde.
Je peux maintenant profiter en mode "nomade" de mes casques ( Hifiman Sundara & Denon AH-D5200 ) sans le moindre souci de performances ( tant puissance que qualité ). ce DAC rikiki permet de les "driver" sans aucun problème. De plus ayant changer de smartphone, le Samsung A53 ne dispose plus de port 3.5mm jack. je me balade donc en permanence avec mon DAC. Ecoute de fichiers lossless ( FLAC ) et streaming via abonnement Qobuz et vrai régal.
J'ai fait écouter le combo à plusieurs collègues et franchement ils étaient stupéfaits de la qualité de rendu.
Je ne peux que recommander ce produit. ( livraison rapide et soignée comme toujours avec audiophonics)
PS : non, je ne suis pas sponsorisé ^^ mais quand un produit est bien il faut le dire. Quand il est mauvais aussi ^^
François R.
efficaces
beau produit protègeant bien le parquet!Il eut été plus confortable qu'elles soient livrées avec la rondelle de caoutchouc déjà installée car cela est fastidieux à mettre
Richard Ö.
This amplifier sounds fantastic !
Having heard many different highend amplifiers the last 20 years, Im very impressed by the sound quality from this amplifier. It is very clean, neutral and powerful, and the spatial qualities and resolution are stellar.
The sound from this amplifier is an upgrade from the otherwise very good sounding Fosi V3 and Aiyima a07.
M A.
IAN CANADA GPIO 40PIN Extension Kit for Raspberry Pi Ian Canada offers a GPIO extension kit for Raspberry Pi, allowing to make an off-set of this connector, especially useful for a box integration of some modules.
another beautiful product from ian canada.
exactly what I was looking for, this way it is easy to expand the gpio of a raspberry pi.
a minus point is that the product is quite pricey ..... something cheaper would have been nice, Other than that it's worth 5 stars.
M A.
LHY AUDIO Triple Linear Power Supply Module LT1963A 5V / +/-5V This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal....
Build quality is good and easy to adjust.
It would be even better if it could deliver higher amps.
all in all a perfect product.
M A.
good quality for a reasonable price.
build quality is good and looks nice.
M A.
nice quality and works fine
already bought several ian canada products and just like this one it really adds something and a very good quality.
use this in combination ian canada PurePi to 3.3 volt input FifiPi MA.
