Marcus L.
Michael M.
Worth every penny!
mathieu l.
Patrick H.
DAC Board for Raspberry Pi 2x ES9023 24bit 192kHz This DAC HAT module will allow you to transform your Raspberry Pi into a real high quality audio system, without breaking the bank. It includes a balanced digital to analog...
Bass for a bargain.
I'd almost forgotten what bass sounds like and feels like. Electronic music sound especially good. I think it's a massive improvement on the onboard sound from a Raspberry Pi 4. I can't do an A/B test easily because you have to disable the onboard audio which isn't difficult once you know what to do but it isn't easy to find out what to do if you're not a real nerd. Like the other review says there are zero instruction for this product. I'm still using (and want to continue using) Raspberry Pi OS. If anyone wants to know, this is what you need to do (maybe there are other ways but this worked for me) Open the terminal (the black box on the taskbar) and type sudo nano /boot/config.txt press "enter" then using the arrow keys find the line "#dtparam=i2s=on" and delete the #. Next find and delete the line "dtparam=audio=on" and replace with dtoverlay=hifiberry-dac Then find the line dtoverlay=vc4-kms-v3d and add ,noaudio (note the comma - no spaces). Finally press control and x (together) then "y" for yes to save the changes then reboot.
I have no complaints about the service from Audiophoniics. I picked it up from the post office a couple of days after ordering. I chose this DAC because it was the cheapest that has RCA outs and mini-jack for headphones. The RCAs aren't disabled when you plug headphones in (which suits me). The best slightly less than 40€ including shipping I've spent for a long time.
Laurent M.
IEAST OLIO Receiver WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz Black With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission...
Cette minus boite qui fait tout est simplement incroyable
Je viens de recevoir mon iEAST OLIO (Alim Bloc 5V USB C iFi) que j'ai branché via Fibre Optique sur mon DAC SMSL M8A avec son alimentation séparée dédiée. Connecté sur mon abonnement QoBuz HiRes directement via le WiFi, le résultat est excellent pour un prix très contenu. L'application de pilotage IEAST intallée sur mon iPhone est très conviviale. Bravo!!!
Ce système qui me sert dans mon bureau est composé ensuite de l'interface Tube Musical Fidelity X10D refaite entièrement par Rock Grotto, un Pioneer A757 de mon adolescence, et une paire de Tannoy Devon de 1973 équipée du HPD 315alnico.
Yannick M.
alimentation très efficace
sur un couple Raspberry + Allo Boss, ça fonctionne vraiment très bien.
Quel dommage que Allo ne la propose plus !
Mais bizarrement, elle est toujours apparemment disponible ici
https://www.allo.com/sparky/shanti.html
mais pas là
https://www.allo.com/sparky-eu/shanti.html
Question à Audiophonics :
pourra-t-on espérer une nouvelle disponibilité sur ce produit dans l'avenir ?
ou alors un produit de remplacement (éventuellement développé par vous-mêmes) ?
cdt
Cette alimentation est vraisemblablement définitivement arrêtée ...
Jean-Pierre D.
SOMMERCABLE EPILOGUE RCA Modulation Cable Gold Plated OFC Copper Shielded 2m (Pair) Sommercable's Epilogue RCA modulation cable has been designed to contribute to a neutral and faithful sound reproduction, favouring a wide sound image thanks to excellent signal...
Modèle sonore très neutre, sans décoloration et spatialisation respectée pour une reproduction à la fois détaillée et musicale
Ce câble est globalement neutre, équilibré et linéaire, avec des basses de qualité et un aigu présent mais non envahissant, le médium pourrait être un peu plus "fruité", en tout cas pour la musique classique ou Jazz, sinon très bon pour le rock, la pop. Point particulier : le temps de rodage est étonnement assez long, ensuite le son semble continuer à s'améliorer très longtemps, pour finalement atteindre un très bon niveau de qualité :
- large bande passante.
- grave bien présent mais bien contrôlé
- équilibre global non spectaculaire mais de qualité.
En conclusion, des câbles neutres, transparents et détaillés qui donnent du corps au son et ne diminuent pas la chaleur de ma configuration. Rapport prix et qualité du son très bon, à ce prix, je ne vois rien d’autre. J’utilise le Neotec 3220 qui est un câble assez différent, un peu plus d’ouverture, plus doux, aigu plus défini et cristallin, tendance à être lumineux sur la pop et le rock, voire le Jazz. Dans cette tranche de prix entre 100 et 250 euros, les deux meilleurs rapport qualité sonore et prix.
Yannick M.
VIBORG VR106AG Male RCA Connectors Pure Silver PTFE Ø11mm (Set x4) Viborg's VR106AG are premium male RCA connectors, using pure silver contacts to provide maximum conductivity. They also feature PTFE insulation and a rugged aluminum body with...
mes préférées !
J'ai eu l'occasion de me servir de ces connecteurs plusieurs fois, et je les trouve à la fois excellents et très bien fabriqués.
Je n'ai pas rencontré le pb cité dans le précédent commentaire.
Question qualité sonore, c'est le top :
matière, transparence, équilibre, c'est vraiment de très haut niveau
Mieux
Après avoir dénudé les 4 ou 3 fils sur 7 ca chante d'un grand naturel par contre il n'a pas de profondeur
j'ai branché le cable nu aux borniers avec les bonnes bananes sont devrait arriver a quelque chose de bon voir très bon
Roberto G.
Belle sonorité équilibrée
Câble d’excellente qualité. Belle sonorité, présence des graves, beaux médiums, aigus détaillés sans aucune agressivité. J’aurais tendance à le préférer au Canare Star Quad L-4E6S que je trouve aussi excellent. Le Canare L-4E6S à des graves, peut-être, légèrement plus amples et des aigus un peu plus doux avec un lecteur CD. Est-ce en en raison des soudures et des connecteurs? La signature sonore me fait penser aux câbles Mogami, Atlas Element ou Equator. Difficile de se tromper avec ce câble, il sonnera de toute manière très bien et il est certainement capable de rivaliser avec des câbles plus onéreux.
Kerem N.
nice
arrived today and it has a real quality perception
Marcos Pérez J.
No words!
First of all, I put a single clock on Ian Canada's dualxo board, with a very good linear feed and Ian Canada's ADM715X regulator. The result was very good: the scene was clearly going forward and upwards, more air between the instruments and more detail, the reverberations of the recording were especially noticeable.
After improving the feeding with Ian Cada Lifepo4 and UCconditioner MKII the change has been even more spectacular, highlighting that there is still more clarity in the recordings, and my system is already very transparent, but what stands out the most is the considerable increase in bass. I have a system with coxial speakers and ripol subwoofer, the theory says that I should not have a seismic bass, typical of closed boxes, but surprisingly and inexplicably it has appeared with the change of power. I have to say that my system is very good and I have some amazing speaker cables, I don't know if the effect on more modest systems can be just as good.
Marcos Pérez J.
No words!
Marcos Pérez J.
No words!
Jean Philippe L.
Very nice cable superbe
I live in Hong Kong, this is a reliable in wall power cable, I brought 10 meters last year in Tokyo Japan as it is so stiff I have to fix it on the wall from my main power distributor to my HiFi power Cryo distributor box . Sound fantastic solid bass and full of details.
Very good products in Europe buy with Audiophonics.
Michel G.
Une merveille
La vérité, rien que la vérité, je le jure !...
J'ai l'impression d'avoir ouvert une porte sur un autre espace. ce n'est pas seulement le fait de retrouver un son analogique, c'est juste le meilleur de l'analogique et du numérique...
(Et pourtant je n'ai pas encore l'amplificateur qui permet de driver mes casques sensibles)
En plus la qualité de fabrication est absolument sublime, quelle merveille...
Pour info entre la sortie USB (depuis un PC avec iPurifier) et la coaxiale via M2Tech Hiface, la sortie USB est bien meilleure, plus douce et équilibrée.
Des heures d'écoute sans aucune fatigue. Clairement un saut dans un nouveau monde.
Et merci Audiphonics pour le contact et les conseils.
MG
Christophe L.
Tout simplement génial
Je suis passé du furutech fs alpha au dss installation focal Diva Utopia, audio GD master 10 , he7 r2r ladder dac, auralic Ariès g2 , alim full dps , full furutech. Première heures tout de suite grosses amélioration mais c'est brouillon après 50h le dss commence à donner le meilleur de lui même. Pour faire simple c'est de la folie grave de dingue médium idem mais pour moi le top c'est les aigus d'une beautés les instruments sonne différemment il y a beaucoup plus de détails on monte le volume ça ne fait pas mal au oreilles on gagne en 3d les essais sur le net sont très élogieux et c'est vraiment mérité le seul IQ c'est le prix bien sûr et c'est vraiment dommage car si vous avez les moyens de vous l'offrir les yeux fermés. Pour moi c'est ridicule de s'acheter ce câble si l'on a pas Qobuz ou une source hires . Les spliteur en Alu 18 mn du site passe j'ai coupé la gaine tissu gaine thermo et on fait des économies. Bonne écoute cordialement
Emmanuel A.
Vraiment très bien
Difficile de trouver mieux à ce prix. Le manque de marque ne pose aucun problème. Bien au contraire, cela permet d’avoir des articles à des prix très abordables nettement au-dessus de certaines marques très cher.
Emmanuel A.
Très bon rca
Pas besoin de mettre 100€ pour avoir des connecteurs de qualité ceci en est la preuve
RENE R.
FURUTECH
Très bon cable, plutot souple ce qui est un avantage, placé entre un I BASSO 150 et un ampli casque audiophonics le son est excellent et neutre sans privilégier le moindre registreL
La note de 5 est conforme à sa qualité.
Roberto G.
Sonorité ample et équilibrée
Belle sonorité de manière générale, aérée et équilibrée. Apport important sur un lecteur CD, plus de densité et de présence, ampleur des graves, aigus plus doux, bien entendu avec un bon câble secteur mais qui s’est révélé encore meilleur avec ce distributeur. Par contre, l’ampli intégré perd nettement en dynamique, donc, retour sur une prise non filtrée. Une prise non filtrée aurait été la bienvenue. Les détails sont soignés, deux interrupteurs souples, vumètre éclairé. Ce distributeur est très bien réalisé.
deception
Cable utilise en mono cablage
l'image est retrecis il est brouillion
bonne attaque du medium a par ca bref une *
Pierre-Jean T.
Solo
Un son ouvert, aéré qui emplit l’espace. Je suis satisfait d’avoir choisi ce lecteur si pratique et musical. Il ne peut que s’améliorer avec les futures mises à jour.
Richard Z.
Pas grand chose à dire...
Fini enfin de recaler mes enceintes DIY Dynaudio. Les anciens fils étaient visiblement oxydés . Après avoir lu certains avis, j'ai sauté le pas . Je n'ai malheureusement pas l'oreille audiophile et ne puis juger du résultat de cette opération.( Certains parlent " d'ouverture", de " spécialisation", de " voile enlevé ", de "rodage"). Il faut pour entendre tout ça avoir eu l'oreille éduquée de longue date
Marc T.
Ce serait simple de faire mieux !
Elecaudio a fendu en trois les embouts, ce qui les rend trop fragiles pour des câbles H.P un peu lourds.
Pourquoi ne pas faire comme les autres avec une seule fente en zig-zag qui assure l'effet ressort ???
Dommage, le métal employé inspire confiance, est un bon conducteur, et le prix est très raisonnable.
marc g.
marche toujours bien au bout d'un an
Depuis plus d'un an que j'utilise ce petit ampli, je tenais à exprimer tout le bien que j'en pense. Pour ce prix, c'est imbattable, et en plus, je trouve le son agréable: il est branché avec des bibliothèques de qualité (HP SEAS, DIY) et sonne sur mon bureau tous les jours. Seul bémol: l'entrée minijack est pas très pratique ni très utile à cet endroit pour l'intégration dans un boitier.
Patrick R.
En remplacement des Netpoint SCC 300 sous mes Living Voices. L'amélioration n'est pas non plus transcendentale, mais il y a du mieux dans le contrôle du grave. Très content du résultat. J'ai pu placer les SCC sous mes électro et ça c'est bien aussi.
Très bien !
Agréable à manipuler, efficace, en tous cas plus efficace et solide que la pompe premier prix.
Pied caoutchouc très solide.
Solide et parfait pour mon caisson de basses diy.
CP-2015 Desoldering braid 1.5m Coil Ø2mm This desoldering braid greatly facilitates the removal of welded components. She mechanically absorbs the solder material to make changes / clean and sustainable equipment repairs.
Super pour pcb.
Très bonne tresse pour circuit imprimé, fine et étroite.
Se visse facilement dans le bois MDF avec une clé allen de 8 mm, information manquante sur la fiche, bonne tenue une fois rentré.
Gilles M.
Je cherchais un dac pour remplacer mon vieil Atol et après recherches le D400EX est sorti du chapeau.
Il fait de la musique, détendu, chaleureux, sans agressivité et avec du détail, bref je suis parti pour le garder longtemps.
Merci aussi pour le service express Audiophonics
Emmanuel A.
Pour des rca au top
Après de nombreux tests ce modèle de câble a été choisi en lieux et place de mes Viard monté par un professionnel pour l’ensemble de mon installation ampli accuphase
Dac chord
Ce ne sont pas les plus cher mais il sont vraiment très bon
TAD 5751 HIGHGRADE Twin Triode Tube High-Mu (Unit) The TAD 5751 HIGHGRADE is a high-gain, dual-triode tube offering a smooth, clear sound. When used in a HiFi preamplifier, the TAD 5751 will provide a lower noise floor and a...
La TAD 5751 est certainement la lampe la plus musicale que j'ai essayer ..un son clair et bien défini sur tout le spectre harmonique. L'essayer c'est l'adopter ..
Cyril T.
Une horreur à monter
La bague qui tient les connecteurs à souder s'ouvre et c'est un galère sans nom une fois soudé pour tout remonter... Les pires fiches que j'ai pu utiliser !
Leur structure est en effet complexe mais elle est au service de la qualité de conductivité et connexion. Un schéma et un éclaté complet sont visibles sur la fiche permettant de juger de la complexité de mise en œuvre.
DIDIER S.
Parfait produit conforme à mes attentes emballage bien fait, protection tout autour du produit pas que sur un côté comme je vois trop souvent lors de mes achats sur d'autres sites de VPC.
J'avais posé une question au sujet de ce module j'ai eu une réponse ultra rapidement ca aussi ca fait plaisir à voir.
Marcel R.
Allo Digione
Bona millora sobre Raspberry PI 4, so més net i sensació d'amplitud sonora millorada. En tot cas, veient el que es paga per un streamer és una compra molt assumible.
L'enviament va trigar 5 dies en arribar a casa.
Tot correcte,
Vincent L.
TANCHJIM SPACE LITE Portable USB DAC CS43131 32bit 384kHz DSD256 The Tanchjim Space Lite is an ultra-compact and efficient portable DAC. It adopts a premium finish with a CNC machined one-piece aluminum alloy frame. The aluminum chassis...
Pour le prix foncez
Testé, niveau son, identique au Space.
La différence se trouve sur les boutons du Space.
Bien meilleur que les DAC de mon S23 et de ma TAB S9+ et celui de mon PC. Coté design, il est tout pititoumignon et robuste.
Il est pas overkill mais franchement pour une écoute nomade, il n'y a pas mieux et compact.
Par contre comme son grand frère des petit bugs sonores lorsque plug - deplug de temps à autre.
Vincent L.
Mmmmwouaiiiiiiiii
Définitivement, il est meilleur que le DAC de mon téléphone, de ma tablette ou encore du PC.
Mais de 1, la différence entre le light et le space, ... il n'y en a pas au niveau du son.
De 2, je ne suis pas transcendé par des bass plus basses et des aigues plus aigres ou même des voix plus voisses (je déconnes c'est pour la blague) malgré les stats améliorés par rapport au lite.
L'avantage est sur les boutons, et il ne faut pas se mentir sur le style aussi.
Je ne dis surtout pas que le son est mauvais mais il sera au niveau CD niveau retranscription sonore pour les i audiophiles et niveau salsa/dance des canards pour ceux qui cherchent le fun dans la musique coté mélomane.
Donc il y a mieux mais plus cher, sur cette échelle de prix, le Lite et le space dominent. A savoir si cela est suffisant pour votre écoute. Perso j'ai testé avec 3 casques :
Sennheiser HD 400S (bof),
Sennheiser - HD 569 (Brrrrrr bof),
Beyerdynamic DT 770 PRO (ah! Manque un truc...),
Focal Elegia (un peu gluant mais appetissant),
Focal Celestee (ca va ya les infos sur le DAC, c'est les casques qui sont nuls).
Richard P.
Étonnant !
Câbles de 2 mm...
Il n'y aura pas de basses...
Quelle surprise dès la première écoute.
Un médium/aigu superbe, ultra détaillé et chaud quand même.
Quant à mon doute sur les basses et bien ils ont été balayé. Bien présente, sèche et profonde comme j'aime. Un peu moins présente il est vrai qu'avec mon ancien câble. Mais le gain de précision est tel que c'est parfait pour moi.
Cet avis n'est valable que pour mon système bien évidemment, mais au vu des avis positifs je ne doute pas que ce câble Mogami W3082 réjouira beaucoup d'audiophiles.
Source platine CD Rega Planet, platine vinyle Rega Planar 3 et cellule Denon DL 103 avec un petit transfo Anzaĩ et pré pré Talisman T6F
Lecture en dématérialisée sur ordi fait maison, lecture fichiers audio en Flac.
DAC Audiomat Tango 2.
Ampli musical fidelity M2si.
Enceintes Kit Focal 350 des années 1980.
EFFICACE
Je possède déjà des filtres secteurs quiet line et audio tools sur mon système qui m'apportent une belle musicalité ; ce ifi audio complémente le tout en entrée de ligne . Au final un gain audible en propreté et netteté indéniable sans aucune dureté . Le prix est correct vu le résultat . Cependant je n'ai pas écouté ce filtre en supprimant les autres . idéal pour une personne qui ne veut pas trop se ruiner et obtenir un résultat satisfaisant .
SUPERBE CÂBLE
Câble que j'ai utilisé pour le recâblage interne d'enceintes DAVIS Hera 250. Le Jentzen 6N a transformé un grave épais et imprécis en un grave superbement tenu, quel contrôle! Je n'ai pas moins de basses mais elles sont maîtrisées de belle manière. Le médium a aussi bénéficié de ce superbe câble: plus de densité et de limpidité. Un câble merveilleux capable de dompter les enceintes indisciplinées dans le bas du spectre.
SHANLING M0 PRO Compact HiFi Digital Audio Player DAP DAC 2xES9219C Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD Black Shanling offers with the M0 Pro a technical and aesthetic evolution of the M0 high fidelity digital player. This Pro version benefits from an improved digital/analog conversion...
Léger, compact mais très musicale
J'utilise le M0 Pro depuis quelques mois dans les transports en commun avec un casque Sennheiser HD 569 (28 ohms) en mode asymétrique. Je n'ai pas de problème côté niveau sonore, je vais très rarement au-delà de 60/100. Le logiciel répond parfois trop vite parfois trop lentement mais je m'y suis fait. Il faut dire aussi que j'ai une carte SD de 1 To avec environ 20 000 titres ... donc grosse base de données.
Juste 2 petits bémols :
- attention au choix de la carte SD, j'avais une Toshiba qui n'a pas fonctionnée. J'ai donc acheté la carte de référence SanDisk 1 To Ultra microSDXC UHS-I.
- lorsqu'on choisit GENRE les chansons du même genre apparaissent toutes par ordre alphabétique. J'aurais apprécié un classement par artiste, i.e. un sous-filtre par artiste dans genre.
Edoardo I.
Acquistato ad agosto assieme ad alimentatore AUDIOPHONICS LPSU25 migliorato audio lettore pioneer BDP-LX71 che uso per cd audio con uscita coassiale collegato al dac smsl le cui uscite RCA sono collegate ad ingresso RCA amplificatore Roksan K3. Grazie audiophonics.
Edoardo I.
Ottimo
Acquistato ad agosto sono riuscito a collocarlo nella sua corretta disposizione, sostituito al cavo della viborg v80, alla quale sono collegati tutti i dispositiv:i tv amplificatore e dac.. migliorato di molto qualità video ed audio. Grazie a David di audiophonics per l'ottimo consiglio, vi terrò sempre a mente per futuri acquisti.
istvan f.
NEOTECH SOCP-14 Wiring Cable UP-OCC Copper PVC 14AWG Ø 3.5mm The Neotech SOCP-14 cable is a high quality 14AWG UP-OCC copper cable with PVC insulation. Its design makes it an ideal cable for audio.
speaker cable live wire
Very good cable, I removed the PVC insulation and insert it in teflon tube AWG10 and closed it both end . Air has the best dialectic 1.0.
I used in double run for live , gently twisted together every 10cm gap between twist. Than inserted in Helix geometry (coil shape) negative wire ( silver plated twisted 12AWG milspec) and terminated in banana plug. Results Wider sound stage, clear background, No noise from speakers,better instrument separation. Worth the price.
BRUNO G.
Le kit idéal pour transformer une ancienne radio
Le seul kit Bluetooth qui vaille vraimenr le coup. Certes le budget peut paraître plus élevé qu’ailleurs mais la qualité des produits est au rdv. Étant novice j’ai sollicité plusieurs fois leurs conseils et j’ai toujours une réponse rapide soir pour commander les bonnes enceintes soit pour la phase de montage. Et le service c’est super important !
J’ajoute qu’un interrupteur devrait être proposé en option car le kit reste actif sans cela. Je recommande
Magnifique produit avec un bemol
Excellent produit à ce prix.
Plaisir gâché car sur quatre boites commandées un total de 4 vis serre câble sont absentes donc une seule vis par fiche banane au lieu de deux.
Dommage
Lászlo T.
Frequency accuracy
I bought two of them.
The nominal frequency was 45.1584 MHz.
The measured frequency of one of them was 45.158230 MHz,
the other measured frequency swam slowly to the desired value : 45.1584000 MHz
Obviously, after a while it slowly drifted away from here, but how much was the error of the measurement or the oscillator could only be told by a frequency meter with an atomic clock .
Excellent oscillator with very little jitter.
Très bien.
AIYIMA T8 Tube Preamplifier 6N3 Headphone Amplifier MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier stage uses a 6N3 tube, which...
Fait très bien le Job. Excellent.
MONOLITH M1060 Over Ear Open Back Planar Magnetic Headphone 96dB 50 Ohm 10Hz - 50kHz The Monolith M1060 headphones are the ideal listening solution to get the most out of your music. Featuring large 106mm Planar Magnetic drivers, the M1060 delivers a precise and...
Très bon produit conforme à toutes mes attentes. Merci Audiophonics.
Regis s.
Acheté pour remplacer des tubes EH kt 88 un peu en fin de vie les TAD font plus que le boulot c’est tendue, c’est chaud , c’est charnelle en un mot magnifique et Audiophonics toujours au top Merci
