Nicolas B.
Steve D.
Dayton spa300-D
Genalex
Nicolas M.
Faible qualité
L'initiative de proposer des transfo sur mesure est bonne mais la qualité de fabrication de ceux-ci est vraiment très basse (Europe de l'est voir Chine). Les enroulements ne sont pas forcément bien empilés (fait à la main?). L'isolant est de très mauvaise qualité et les tours ne se chevauche pas suffisamment. Le support SF01 est absent, à la place de celui-ci un résinage bleu au centre du torique. Celui-ci dispose d'un perçage de 5mm non centré, et insuffisant en diamètre au vu du poids! L'application n'est pas très exigeante (amplificateur classe D), il doit-être plus difficile de mettre un tel transformateur en œuvre pour de l'analogique (couplage, ronflette, etc). Il est loin d'une qualité audio. Je ne parle pas du délais de livraison de 2 mois et demis (repoussé 2 fois).
Nicola G.
Good but could be better
I bought this DAC and a Linear Power Supply, initially I had some trouble with the power supply but now it works well. I had to pay the assistance, Audiophonics team said that everything was ok, but I sent a non-working things and received back a working one... But all's well that ends well, as the old boot said.
The main problem is that the Pi isn't shutdown well.
I bought this to substitute a Cocktail Audio, looking for a better sound.
The usability feature on the cocktail audio are better, the touchscreen and the interface are very well made. I hoped that this could be like the Cambridge Audio but the only way to use Raspberry with Volumio is through another interface.
The remote control and the knob aren't useless to navigate inside the library.
The sound of the DAC is good, better than Cocktail Audio.
The unclean poweroff of the Pi is the biggest minus.
I didn't understand if there is one or more pin of Raspberry GPIO available for custom usage.
Raphaël M.
ELECAUDIO ADIACIUM GR Extensible PET braided sleeve Nylon 4-11mm Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique PET...
Durabilité, qualité, simplicité.
Bientôt 5 ans que cette gaine protège mes câble d'alimentation pour un amplificateur dans ma voiture, ainsi que mes câbles HP et RCA (dans dans dimensions plus resserrées)
La gaine est simple à mettre en place autour du câble, c'est même très satisfaisant à faire !
Ensuite je doit dire que la longévité sans faille ne me surprend pas vu la qualité perçue lors de la mise en œuvre, mais force est de constater qu'après 5 ans aucun signe de faiblesse. Les parties dont j'ai un accès visuel n'ont pas changé d'aspect notamment sous le capot moteur près de la batterie qui est un environnement plutôt engageant, la gaine traverse le temps sans aucun problème.
J'en suis évidement hyper content.
Merci Audiophonics de proposer du matériel d'une aussi belle qualité.
Alan D.
Super satisfied!
This is the first DAC I have ever purchased for a Pi, so I didn't know what to expect. I am totally impressed with this little jewel! I have paired it with a Raspberry Pi 3B+, an ELV 38W amp and a pair of Focal LS RSE-130 speakers and installed all of this in a custom made wood enclosure. The sound has beaten absolutely all of my expectations for such a price point. I am particularly impressed with the clarity and stage/depth of the music. I highly, highly recommend it!
Valentin R.
Toogle Switch with Red Light ON-OFF 250V 3A Ø 21mm Black This is an ON / OFF toggle switch 250V 3A. Connection via 4.5 mm flat connector. Black case with I/O label.
Attention la temperature
ça bloque en position on sur un ampli de classe A qui chauffe bien le switch, donc un changement
Vous devez certainement lui faire passer plus des 3A pour lesquels il a été conçu.
Très bien sur pc portable
Venant d'acquérir un pc portable,j'utilise foobar règle sur Wasapi:c'est juste parfait...vraiment étonnant ce petit dac
Hasni Z.
Très bon produit et livraison ultra rapide!
Merci à l’équipe d’Audiophonics :)
Hasni Z.
Très bonne qualité de fabrication pour isoler un câble DYI
Un immense mini DAC à prix doux
La qualité sonore est vraiment bluffante (parfaite?), les sorties symétriques (4V) apportent aussi un vrai gain en qualité sonore car elle permettent de faire fonctionner l'amplificateur dans sa zone de confort.
Le D10B fonctionne aussi très bien alimenté en USB avec un RI4 et il s'arrête et s'éteind avec le Raspberry ce qui est un petit confort appréciable.
En revanche les adaptateurs XLR/jack 6.35 sont juste monstrueux, il pèsent plus lourd que le DAC ! (attention à l'équilibre...)
Alain c.
SHANLING M3X Digital Audio Player DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256 The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm Snapdragon 430 processor, an Open...
mediocre produit !
ce produit n'est pas dans l'exellence pour le prix vendu !
plans sonore plat, aucune precision, mon Cowon plenue V est nettement et facilement au dessus quand a la qualité sonore !
la partie android est quand a elle souq alimenté par une ram rachetique de 2 GO, et audroid quand a lui utilise en moyenne
960 mo !
si l'on a comme beaucoup d'usager du materiel audio avec des fiches en 3.5 et 2.5 l'on se trouve dans l'obligation d'acheter un adaptateur
4.4 vers 3. ou 2.5 .... ce qui augemente l'enconbrement et les possible problemes de connectiques !!
donc retour a Audiphonic pour tout ces élements !
Marc B.
IFI AUDIO SUPANOVA Power Cable OFHC Copper Gold Plated Shielded with Active Noise Cancellation Technology 1.8m The impressive iFi Audio SupaNova power cable delivers incredible performance to provide your audio system with a clean and stable electrical signal. The cable features Active...
L'effet est là
Installé en amont de la multiprise sur laquelle sont branchés mon préampli et mon ampli, le son est plus propre, plus précis.
En revanche sur mon DAC Denafrips Venus II je n'ai ressenti aucune amélioration. A voir avec d'autres DACs peut-être.
Frank j.
gustard u18 very low jitter, sound the best i have heard.
at 48khz the jitter is down at -185db
ACCUSILICON AS338 110db at 10hz
where the ACCUSILICON AS318 is down 99db at 10hz
clock is important what gives the sound
crystal clear sound, all details are included, as well as 3d sound
on the neumann 310a studio monitor, one of the best, studio monitor in the world.
best dcc i have to date
have tried singxer su1 -su2 su6 as well as sotm dX-USB HD
but dcc gustard u18 beats them all
and only driven 2 hours gustard u18
gets better at 50hours
Jean-René N.
Bien mais compatibilité avec Windows 11 perfectible.
J’ai passé ma commande, le produit était en rupture de stock, je l’ai reçu 10 jours plus tard, un peu plus tôt que convenu. Emballage impeccable, comme d’habitude chez Audiophonics.
Il n’y a qu’une notice succincte en anglais, mais l’appareil est très intuitif : deux boutons, l’un on/off, l’autre pour sélectionner la source. Un potentiomètre pour le niveau de son et les basses/aigues quand on l’enfonce. J’ai essayé de connecter un caisson de basses issu d’un home-cinema, mais aucun son n’en sort. Effectivement la notice parle de caisson de basses actif, alors que le mien est passif.
Je me sers de l’ampli pour sonoriser mon bureau à partir de mon ordinateur que j’ai passé en Windows 11 à la fin de l’année 2021.
A la première connexion en USB, les derniers drivers Microsoft sont installés. Mais là, je déchante, aléatoirement, la sortie son « USB Audio-Hi-Fi » n’existe plus, il faut rebooter pour la retrouver. L’ampli n’y est probablement pour rien, mais c’est très désagréable.
Autre bizarrerie : quand je suis en visioconférence, au bout de 2-3 minutes, je suis déconnecté avec le message suivant : nouvelle caméra USB détectée. J’ai débranché à tour de rôle tous mes accessoires USB avant de me rendre compte que Windows 11 prenait l’ampli pour … une caméra. Très gênant.
Je me suis donc connecté en entrée optique où tout fonctionne correctement, mais sans avoir la profondeur des sons en basse qu’il y avait en USB.
En conclusion, un bon appareil avec un son tout à fait correct pour le prix, mais il faudra revoir la connexion en USB avec W11.
kg s.
Surprisingly good
It sounded too good when reading the specs and all comments around the web, but I couldn´t resist although I already have a good dac from Nuforce. The main reason was to be able to play DSD-files. From start I was convinced that it did sound as good as my old dac (did cost about ten times the price of Sanskrit 10th, several years ago) and it does play all DSD up to 256 without problems. Playing 512 is not possible yet, but it is a MacOS issue. And it does it great! I had a few questions and got prompt answers from audiophonics, cudos! I did change the tiny USB-cable to something mor sturdy and a bit longer. I use external power although it worked well without it. I made a blind-test to the Nuforce DAC-9 and it was impossible to hear any difference playing 24/192 or lower resolutions (DAC-9 doesn´t handle DSD). Really great sound for peanuts!
Do I recommend it? Yes
Do I recommend Audiophonics? Yes
Jerome t.
Gustard x 16
J ai acheté ce dac et il est parfait. Je l ai connecté à ma box en forçant la prise coax de celle-ci (pas aux normes) le son sort neutre mais pas froid, comme dans le réel, époustouflant !! J ai aussi relié le dac en optique a mon lecteur DVD Samsung de base avec le cordon viablue vendu sur ce site et ça m évite de payer un coax a 200 euros. Le son vaut un lecteur cd a 500 euros, que du bon. En plus je peux commander le volume vers l ampli. Franchement super.
Ludovic M.
RSS315HF-4 Impressionnant !!!
J'ai utilisé ce haut parleurs pour faire un caisson de basse reflex de 71l pour une fréquence de 23 Hz j'ai fait le svs pb 2000 pro
avec un amplis sledge sta 500d et je dois dire que le son des basses est impressionnant pour le home cinéma les explosions sont extraordinaires très puissantes que du bonheur
Jean Claude D.
Musicalité, définition, transparence.
J’utilise ce câble en bicablage et il remplace pour mon plus grand plaisir des VIARD AUDIO HD silver. Cela me donne un rendu plus favorable que des Nordost frey 2 que j’ai essayés sur mon système.
(Mac intosh D150/MC352/Audio research LS27/Klipsch forte 3)
Contrairement au schéma de la spécification, j’ai raccordé les 6 câbles à l’amplificateur ; Rouge/blanc/bleu pour le + et noir/jaune/vert pour le -, dont 2 câbles (rouge/vert) pour les médium/ tweeter et 4 câbles pour le grave.
Le résultat est une spatialisation plus accrue, le son est plus limpide, plus dynamique et plus de détail sans être fatiguant après de longues heures d’écoutes. Je découvre toute une gamme de nuance dans les graves et percussions. Les voix sont présentes et charnelles.
Avec ces câbles je redécouvre mon système et ma discothèque.
Jürg E.
Top quality Plug
Outstanding build quality and good construction. This is the best sounding Schuko plug i have tested so far. It sounds smooth, natural and organic with a lot of bass power. No harshness or edgy sibilants like some silver or rhodium plated plugs of other brands. Excellent combination with the Yarbo cable.
Jürg E.
Top Cable
This is a very balanced sounding cable. Smooth, natural, detailed and a big soundstage, Excellent cable for preamp and source components. Because of its smaller diameter, it fits all Plugs very well. Even it contains some silver as plating, it is still smooth and natural. The litz wires are sensitve bacause of its thin strands. When removing the insulation, a lot of care is needed.
Holger B.
LAN-Kabel Audiophonics, 5 m
J'utilise le câble comme connexion de la prise murale TAE au routeur comme câble DSL ! L'effet par rapport à un câble DSL normal est écrasant ! Tous les appareils de mon réseau profitent énormément de la transmission ! Acoustiquement, le câble améliore le son de mon streamer, bien numérique !
L'image sur ma TV est nettement meilleure (connexion TV via Internet !) !
Tout simplement génial...!
Yann J.
Kit intégré dans une petite enceinte passive pour créer une paire d'enceintes autonomes (1 active + 1 passive), se monte facilement, le rendu est très correct, pour l'instant l'autonomie a l'air conforme, la puissance est correcte, la portée bluetooth est d'une dizaine de mètres. Attention pour avoir un kit complet vous devez prendre 2 supports métallique (1 pour l'ampli et 1 pour la carte d'accus). De plus il vous faudra un interrupteur bistable NF (normalement fermé) car si vous ne câblez pas l'interrupteur le module reste allumé. Dommage que le prix ne soit pas un peu plus attractif.
Stephen J.
Meilleur rapport qualité / prix ?
J'ai d'abord acheté ces haut-parleurs un peu par hasard (les large bande que je voulais n'étais pas dispos, et ceux-ci semblaient intéressants). J'ai calculé de petites enceintes bass reflex en agglo de récupération, ceci avec l'objectif de remplacer les enceintes pourries dont ma fille avait hérité avec une micro chaîne. Elle pensait que c'était une lubie de ma part, mais quand je les ai branchées, elle a juste dit "Ah, d'accord...". L'ensemble n'est pas vraiment de la hifi, mais c'est agréable à écouter, un bon investissement.
Ensuite j'ai lu le commentaire de Kolja Z., que je remercie vivement ! J'ai commandé une deuxième paire de haut-parleurs, et j'ai fabriqué les Needle, en suivant les plans qu'on trouve facilement sur le net. J'ai encore utilisé de l'agglo de 15mmm (la construction était un peu sportive !), et j'ai connecté les baffles à mon ordi avec un DAC et un petit ampli classe D. Le résultat est franchement surprenant, surtout au niveau des graves compte tenu de la taille de ce tout petit haut-parleur. Il a fallu trouver un peu de place au sol, mais le son est agréable et précis avec une gamme étendue. Je sens que je vais me régaler. Ça doit être difficile de faire mieux à ce prix.
Jean-Marie M.
excellent préampli Class A
acquis sur la baie en occaz mais comme neuf... emballage au Top ! superbe équilibre, la matière est au rendez-vous doté d'une très bonne dynamique. la finition est également parfaite; merci Audiophonics pour ce produit rapport/qualité prix difficile à battre ... couplé avec un bloc de puissance Sony TA-3130F
François G.
Un très bon ampli
Dès réception, déballage et attente que l'appareil soit a la température ambiante avant la mise sous tension. Le coffret est d'une très belle fabrication. Après quelques heures d'attente, mise sous tension et puis fonctionnement pendant quelques dizaines d'heures avec de la musique avant de faire une écoute objective.
Essai avec des enceintes bibliothèque équipées d'un 13cm + tweeter Dayton, le rendement de ces enceintes est de 85dB/W/m. L'ensemble est homogène, bonne tenue dans le grave, clarté, dynamique, tout est là.
Essai avec des enceintes très haut de gamme avec des 38cm qui ont une bobine mobile de 100mm et des tweeters Heil AMT et dont le rendement est de 100 dB/W/m. Premier constat, le rapport signal bruit est excellent, il faut approcher son oreille a quelques centimètres du tweeter pour deviner un très léger souffle. J'ai été bluffé par la tenue du grave de cet ampli, il montre une petite "faiblesse" lorsque il y a de l'infra, mais c'est beaucoup lui demander. Sur le reste du spectre, un léger manque de "chaleur" sur les voix et une très légère brillance sur l'aigu. Cette comparaison a été faite avec des électroniques "haut de gamme".
Conclusion: Un excellent petit ampli que je recommande.
Un petit plus serait d'avoir une notice sur la télécommande, certaines touches ne correspondent pas aux indication, il suffit de quelques minutes avant de découvrir toutes les fonctions.
Bylna D.
Tube rolling
J'ai commandé un quartet de 6CA7 Electro Harmonix pour un ampli Line Magnetic LM211IA, ce dernier avait encore ses tubes de puissance EL34 d'origine(Shuguang rebadgés Line Magnetic) qui fonctionnaient très bien avec une belle sonorité.
J'avais commencé par changé les tubes de préamplification 12au7 et 12ax7 d'origine par des Psvane 12au7S et 12ax7S, le bon qualitatif avait été énorme....!
Avec les 6CA7 l'ampli a conservé son fruité et son coté délié, détaillé et profond avec en plus le coté impact...! Et la sonorité riche du Live...!
Ces tubes de puissance comme tous tubes neufs doivent être montés, réglage du bias, laisser chauffer à vide volume à zéro environ 30mn.... vérifier le bias, réglage si nécéssaire et écouté.... Vérification plusieurs fois du bias(au bout d'une heure avec ajustage très très léger), puis le réglage ne bouge plus du tout.
Ne pas s'inquiéter, au bout d'une demie heure ça avait un peu bougé... C'est un rodage....
J'ai même eu une toute toute petite sifflante sur une voie qui a disparu après la première heure.... Rodage.. rodage, je ne sais pas si c'est pour tout le monde pareil mais pour moi ça c'est passé comme ça.....
Après 5 heures d'écoute(en 2 fois) le résultat est franchement à la hauteur, il y a sans aucun doute sûrement mieux mais ce ne sera plus le même budget et pour quelle différence ?
Sinon merci encore à Audiophonics pour son sérieux et sa rapidité même en période de Noël pour satisfaire les commandes, produits conformes et emballage au top comme d'habitude, Bravo...!
Jérôme L.
IFI AUDIO IDEFENDER+ Anti Ground Loop Filter Male USB-A to Female USB-A The iFi Audio iDefender+ allows you to cancel noise originating from a ground loop in your audio system. Indeed, the inevitable use of several plugs and cables within your HiFi...
Ne change rien sur ma config
Toujours autant de bruits parasites même avec le idefender+ :/
Ludovic A.
FURUTECH LAN-8 NCF Ethernet RJ45 Cat8 Cable S/FTP 1.2m Furutech LAN-8 NCF is a beautifully designed Category 8 RJ45 Ethernet cable with S/FTP shielding for high-speed signal transfer.
Cable Impressionnant
J’ai hésité pendants de longue année à changer de rj45, un 600mhz en Cat7 entre mon drive Denon A11 et pré-ampli Avpa1hda / liaison Denon Link dans le sens où mon RJ d’origine m’allait très bien mais là on passe vraiment dans une autre dimension et perso dans mon système pas qu’un peu à tel point que ce câble révèle totalement les capacités drivepré-Ampli
Les avantages :
Micro et Macro détail ultra fouillé
Message audio holographique
Stéréo et séparation des Canaux optimal
Basse modulée et dynamique énorme
Médium super ouvert
Aigu qui file sans aucune duretés
Les notes s’estompent en silence de fin sans aucune détection de bruit numérique en fin de traitement...hallucinant
Je suis plutôt septique de nature mais j’ai l’oreille absolu et ce cable à été la révélation pour en réveiller mon système !
Mes écoutes comparatives ont été réalisées en 1ère Écoute sur : CD BO film Elysium, SACD 5.1 film Matrix, CD Solar Fields Réflectives Frequencies Remixed
Yoan S.
XDUOO XQ-50s Bluetooth 5.1 Receiver QCC3034 ES9018K2M aptX-HD The xDuoo XQ-50s Bluetooth 5.1 Receiver is the perfect ally to give an existing audio system wireless reception functionality and allow you to stream your music remotely,...
Top mais...
La puce à l'intérieur est bien une QCC3031 et non une ACC3034.
Le site de Qualcomm se trompe peut-être sur les spécifications de ses puces (...) par contre Xduoo et Audiophonics trompent leurs clients sur ce qui leurs est vendu (photo de la carte du XQ-50s à l'appui) et ça je trouve que c'est moyen.
Le produit reste de bonne facture.
Décevant... Pas convaincu... Avis pour les audiophiles
... Superbe petit ampli au niveau de la finition et de la restitution sonore...
Pourtant s'il invite à la sortie casque 4,4mm symétrique le souffle est prédominant à bas volume. D'autant qu'aucun gain ne soit audible///
Sans compromis / Du Tout Lampes / De la chaleur / Du soyeux
Du 'Tout tubes' de qualité sans dépenser une fortune ? oui ça existe ! Même les adeptes forcenés de l'hybride ne pourraient renier cette 'Jekyll' expérience. Je recommande l'utilisation de ce 'Tout Lampes' en pré-ampli de salon au sein d'une chaîne numérique ; bien qu'en ampli casque l'expérience demeure magnifiquement concluante (à relatif volume moyen (pas pour les ultra sensibles)). En conseil je me permettrais de préciser qu'il faut travailler un peu sur les volumes injectés tout au long de la chaîne (de la source DAC, Pré-ampli, Ampli) afin de profiter soudainement de l'apport chaleureux de ces lampes !
Le tube imposant de puissance est soyeux autoritaire (en attente de recevoir de nouveaux tubes à tester...) et accentue une orientation V shape (basses et aiguës un peu en avant sans toutefois être piquants).
La lampe pré-ampli d'origine même si elle génère des nuances 'tubesques' colorées, gagne à être changée (récemment mis une Electro Harmonix Gold, l'injection gagne en médium sans masquer l'amplitude colorée du spectre).
Conclusion, avec des manipulations je reste bluffé par l'apport soyeux que cet ampli est capable d'insuffler au final (rien de comparable avec le tout numérique), certes vous faudra t'il jongler avec les volumes des étages montés.. et soudainement vous atteindrez un nirvana pour sûr, non moins mélomane. Garanti !
A vos oreilles de Spock ! Silence intersidéral... Plaisir incroyable
Sceptique réjouissez vous l'homme capable du pire... miracle.., est prodigieux de fulgurances ! Et cet ampli (à mon humble avis d'audiophile) est un ovni; du silence cosmique aux douceurs pigmentées de l'arc en ciel sonore. Même avec un DAC ampli casque dédié 'haut de gamme' comme le Teac UD-505 (désolé pour les plus fortunés) ce petit Topping A90, à la finition irréprochable, me plonge indéniablement plus loin dans le système 'sonolaire'.. La sphère du spectre ne déborde jamais dans l'explosion liquéfaction, et tout y est ! Posséder plusieurs casques selon la musique devient une prodigieuse réalité nécéssaire. Cet ampli est tout simplement du bonheur supplémentaire
MONOLITH THX AAA-788 Balanced Headphone Amplifier DAC 2x AKM 4493 2x THX AAA-788 32bit 192kHz DSD128 The Monolith THX AAA-788 is a symmetrical headphone and DAC amplifier combo benefiting from a particularly well thought-out architecture and embedding high quality components...
L'excellence ! Dédiée à l'écoute au casque. Whaou !
Un DAC tout en clarté dynamisme précision douceur avec sa fonction d'égalisation ultra jouissive qui offre enfin les réglages parfaits à l'audiophile du casque.
J'écoute en sortie Mac logiciel Audirvana avec les Hifiman Arya et Audio Technica ap2000ti (deux merveilleux casques ici magnifiés) un vrai bonheur!
Merci à Audiophonics
Charles M.
Le parfait binôme pour RaspeberryPI
A la recherche depuis plusieurs semaines d'un FDA ou d'une carte son pour mon raspberryPI, j'ai écouté les conseils judicieux de David pour finalement acheter cet ampli que j'ai connecté via le port USB à une RaspberryPI et des enceintes Tangent X4 Spectrum. Quel bonheur que de profiter de ce son HiFI d'excellente qualité, de retrouver des sensations acoustiques qui me manquaient depuis plusieurs années. Un tout grand merci pour les conseils et ce choix :-)
Jonathan D.
Connecteur de bonne qualité, j'ai pu y soudé et passé 2 câbles JANTZEN AUDIO HEW-PTFE Fil de Câblage Cuivre/Argent 2.5mm², l'isolant tient très bien à la soudure et en passant un petit coup de toile emeri sur le corp du connecteur j'ai aussi pu y soudé une tresse de blindage. C'était pour y faire passé au max du 24V et 6,5a.
Etien K.
Un bon achat
C'est un amplificateur de fabrication robuste qui me donne entière satisfaction.
Je l'utilise avec un DAC R-2R, Pegasus, et un streamer, l'Allo USBridge Signature. Je branche à sa sortie symétrique une variété de casques.
Master 19 est un amplificateur puissant et il drive aisément des casques d'impédance élevée et des planars.
C'est aussi un bon préamplificateur. Sa télécommande est très pratique à l'usage.
Je remercie M. David Aubert pour ses bons conseils lors de l'achat.
Etien K.
E.
Ce DAC est remarquable.
Le fabricant préconise un rodage de 300 heures pour ce produit. Et je confirme que cela est nécessaire. Je l'ai laissé en marche pendant deux semaines, mais Pegasus s'est révélé déjà au bout de 2-3 jours. Ensuite il n'a fait que se bonifier.
La scène sonore est large. La précision de la restitution sonore est excellente tout en étant musicale. Ayant toujours utilisé des DACs Delta-Sigma, c'était un bonheur de découvrir les avantages d'un bon DAC R-2R.
Je remercie M. David Aubert pour la pertinence de ses conseils son professionnalisme.
Aziz A.
Très bien qualité / prix
J’ai remplacer mon ampli smsl ad-18 pas cet ampli et je suis très content les basse sont plus profonde accouplée à un DAC RME adi-2 et des enceintes Dali obéron 3 le rendu est vraiment bon
Grégory O.
Boitier correct pour bricoleur
Généralement, le dernier achat lors du montage DIY. A usiner à la "MC Gyver" mais un passage obligé pour un modèle à cout réduit. La qualité du "Acier+Alu" est correcte. Tout bon bricoleur c'est du tout bon. En passant, je tiens a féliciter toute l'équipe d'AudioPhonics pour le bon travail, "disponibilité de produits d'ici et la souvent galère à trouver ailleurs", "La qualité de la livraison dispo dans les temps" Le SAV ???? Pas encore passé par la donc c'est du tout bon je pense.
Ryad B.
Décevant et très fragile
Le fil en cuivre se rétrécit à l'intérieur de la fiche, si bien que la section se réduit fortement, du coup l'une des fiches a rompu sous le poids seul du câble pourtant posé sur le sol sur la quasi totalité de sa longueur. Résultat le set est inutilisable et le service client n'a pas donné suite à ma réclamation.
Dommage
Bruno G.
Musical !
Dès les premières minutes d'écoute d'Andres Segovia, j'ai été captivé par la restitution naturelle de ce dac. Sans pouvoir le comparer à un dac du même prix, je peux simplement dire qu'il est très musical. Mes vénérables Kef 105 en sont encore toutes émoustillées. Tout à fait recommandable.
Yoan S.
Top mais...
Fonctionnement facile, fabrication de qualité.
Une étoile en moins pour le marketing mytho à la chinoise : il s'agit bien du XQ-50 en bluetooth 5.0 re-nommé XQ-50s (mais sans le bluetooth 5.1).
Arnauld D.
Merci Audiophonics.
J'ai reçu mon streamer Shanling EM5 dans les délais. très joli petit streamer ampli casque, à la finition remarquable, configuré en 3 minutes et qualité audio remarquable pour un tel prix .
alain g.
IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black iBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS...
Superbe produit
J'ai eu plusieurs DAP ibasso (DX-50,, DX-90, DX-150 ) et comme je m'y attendais un peu ce modèle surpasse mon precedent DX-150.
La qualité de fabrication est excellente, la réactivité et la qualité de l'écran est superbe et bien entendu pour la restitution de la musique que je croyais pas que l'on puisse faire mieux que mon DX-150.
Produit que je conseille... pour la fiabilité le temps le dira..
Hervé C.
Très très bon DAC !
Je sortais d’un SMSL Sanskrit 10th que je trouvais déjà très bon. Là, on gagne tout : définition, équilibre tonal, scène sonore… Beaucoup plus droit que le Sanskrit (qui garde beaucoup de charme et reste un rapport Q/P imbattable).
Les filtres jouent de manière très légère sur le son. C’est parfois honnêtement inaudible.
Le Bluetooth est excellent ! Dommage que l’association ne puisse se faire que lorsque l’entrée Bluetooth est sélectionnée. Et puis toujours cette télécommande très cheap et un peu capricieuse..,
Aucun regret en tout cas !
Hervé C.
Très bon streamer. De la matière, du détail et une très belle scène sonore. Le mien tourne sous Picoreplayer, qui permet pas mal de paramétrage et se commande très bien avec l’application iPeng. Connecté à un DAC Smsl SU9, miam ! Alimentation Shanti bien sûr mais le résultat est aussi très bon nourri par une bonne power tank (attention avec courant mini de 2 à 3A).
Aucun regret !
Szilard M.
White SPI / IIC 256x64 OLED 3.12" screen Here is a very elegant 3.12 "256x64 OLED screen with superb brightness and excellent readability. It is already mounted on its PCB with a soldered connector.
Top quality, great display
Great display, after some hours of struggling (I'm a beginner) I managed to drive this display with my NodeMCU microcontroller, from Arduino IDE, using the u8g2 graphics library. Amazing, it's using the fast mode (hardware SPI), with 3 wires only (4 is optional) + GND + 3v3.
You can see the library's example here, doing a demo:
https://www.youtube.com/watch?v=VX7gFL9v1qo
Amazing little display and very nice, refined screen. Top quality.
Please Audiophonics, keep this on stock, a lot of them, as long as you can. Really easy to work with.
Highly recommended.
Ce câble a très avantageusement remplacé un câble DIY fait d'un fil d'argent gainé de coton et utilisant une prise RCA Eichmann. Le son est maintenant beaucoup plus équilibré entre le grave, le medium et l'aigu alors que le câble argent était très ascendant et criard. De plus, cela s’est fait sans aucune perte de définition. Bilan : un résultat bien meilleur pour un prix bien plus faible. Je l’utilise entre un drive AM-Audio Design CD1000 et un sur-échantillonneur Behringer SRC2496. Pour l’anecdote, ce dernier est ensuite relié (RCA-RCA), là encore avec un câble numérique Canare 75 ohms, à un filtre numérique Behringer DEQ2496 modifié dont j’utilise le convertisseur N/A.
Jean-François T.
Extrêmement efficaces.
Montées sous les supports d'une paire d'enceintes de 20kg de part et d'autre de l'écran, sur du parquet dans une maison ancienne. Plus aucune vibration n'est transmise au parquet. (les résonances étaient énormes, au point d'interdire la lecture de vinyles voire même de CD à volume même moyen)
Mais du coup, c'en est presque décevant : les films à effets spéciaux ont nettement perdu de leur ampleur.
4 pieds de 20x24 pour une enceinte de 20 kg est vraiment limite. Mais la structure des supports (en tube carré de 20x20) ne permettait pas d'en mettre de plus gros sans compromettre l'esthétique de l'ensemble.
Jean-François T.
MONACOR SG-165 Speaker Protection Grille Ø174mm This Monacor SG-165 metal protection grille has an outer diameter of 174mm and an internal diameter of 140mm. It has been designed to fit many speaker models.
Bien, mais...
Acheté (en croisant les doigts) en complément d'un petit sub woofer (Dayton DCS165-4), pour un petit caisson "down firing". Donc, sans préoccupation esthétique (look auto radio de l'accessoire). Juste en prévention de possibles dégâts lors du passage à l'aveugle de l'aspirateur.
Adaptation parfaite, excepté le nombre de trous : 4, alors que beaucoup de woofers comportent 8 trous... Pas très grave, mais ballot tout de même !
On pourra toujours en percer 4 de plus, mais pas très facile de percer propre dans de la tôle de 0.9mm à raz d'un congé sur une surface qui est en l'air ; nécessite quelques astuces et un foret adapté. En même temps, ça ne sera jamais visible...
Passages de vis de diamètre 4.5mm sur un cercle de 155mm. S'adapte parfaitement au Dayton DCS165-4 grâce aux trous oblongs de ce dernier ; pour ce HP, faire les avant trous en fonction du cerclage de la grille et non des côtes fournies par Dayton.
Prévoir également un joint entre cerclage et enceinte (non fourni). En dépannage, il est possible d'en réaliser un en cinq minutes chrono avec du carton et une paire de ciseaux. La forme du cerclage est prévue pour un joint, ET pour que le joint soit invisible.
Jean-François T.
Attention ! Cotes comportant ds erreurs.
Acheté par flemme d'en imprimer un...
Tout bidouilleur le sait, on ne coupe/taille/fraise/perce rien avant d'avoir l'accessoire en main. Le schéma fourni comporte des erreurs. Par exemple, sur l'exemplaire reçu, pour un montage en feuillure, l'épaisseur du flasque n'est pas 2.5mm mais 3mm ; le diamètre du cercle sur lequel se trouvent les trous de fixation n'est pas 65mm mais 66.5mm, les trous de fixation ne font pas 4.3mm mais 4.5 à 4.8mm.
Aspect positif : cette épaisseur de 3mm permettra la fixation par des vis tête fraisée de 4 ou 4.5mm moyennant un petit coup de fraise à chanfreiner afin d'obtenir un montage 100% affleurant. Pour un montage propre, des cotes exactes sont indispensables !
Malheureusement, ce schéma erroné ou obsolète se retrouve partout sur le web, Monacor ayant probablement jugé inutile de mettre à jour la documentation après avoir changé de sous traitant.
A part ça, friction très insuffisante des deux parties sur la deuxième moitié de la course utile. Du coup, ça ne tient plus au delà de 230mm. Prévoir un bout de scotch pour augmenter un peu le diamètre et donc la friction (astuce connue).
Naturellement rien de bien grave, mais ça mérite d'être signalé.
Measure twice, cut once !
