Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Giovanni G.
LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 1m The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher...
a bit disappointed
it looks amazing, but when i connected to my electronics i was a bit disappointed. with my preamp pass labs xp12 or with my integrated amp vitus audio ri-101 the result was not so good ... it was clearly worste than other cables that i own (like Oyaide SSC, furutech, bcd). the sound was confused and muffled compared to the others power cables.
nicolas H.
super fiche Banane
Montée avec du RAMM Audio Amadeus 5 , le top... super serrage, j'ai masqué avec de la gaine thermo pour une belle finition, pleinement satisfait de la qualité de ces fiches
Robert G.
ES9038Q2M DAC
First I had the old I-SABRE V4 DAC ES9023 TCXO. I t was ok, but I have added Kali reclocker. That was a nice improvement in clarity. Then I added battery power and again it was noticeably better, cleaner. Then I replaced the DAC with the new I-Sabre ES9038Q2M and it is another clearly audible improvement. There is nothing more in the sound, I'd say it's the opposite. There is less bloat. Everything is more controlled and precise, bass is less boomy, the overall presentation is more clear and there is more audible detail on top, but everything is still smooth without any harshness. Nice DAC!
Giovanni G.
stunning !!
it's a wonderful cable .. neutral.. rich.. armonic sound without harsness .. i made one rca and another xlr version and both are simply wonderdul.. i use the xlr version between pass xp12 and x350.8 and the rca version between a msb analog dac and vitus ri101 integrated amp...
Giovanni G.
very good
i think these are the best rca connection for the price. really good for sonic and materials
Giovanni G.
wonderful cable
i have bought this cable.. and made one rca and another one xlr.. in both cases i think the result it's stunning... neutral, rich, armonich without harsness ..
"Longueur des pâtes : 25mm"
Des pâtes, oui, mais des Panzani...
Des pattes s'il vous plaît !
C'est corrigé, merci à vous !
Pas mal mais...
Construction allemande, bof. Qualité en dessous d elecaudio. Plastique cheap. Mais fait l affaire pour brancher un Ifi purifi sur prise triple mural. Ne pouvant installer une vrais prise audio en chuko. J ai pris une rallonge du commerce avec prise triple ch. Fils trois fois 2mm2.a vingt centimertres environ pour pouvoir y fixer les trois fils.a cause de la longueur entre l entrée des fils et les borniers. Qui accepte max le 2.5mm2.la fixation et plutôt legere, il faut etre doux sinon sa casse. Le resultat, j ai d'abord brancher sur la prise juste a côté de la pride alimentant mon systeme. Bof rien ne sais passé. J ai ensuite branché en dessous. Apres qq minutes d ecoute. Resultat.. Ecoute plus fluide et plus de calme dans la musique. Resultat final exelent. J ai pus resservir se filtre qui ne fonctionnait pas a cause de mon conditionneur secteur dont le principe etait un dephasage en mode commun somme toute exelent mais que mon ifi purify n aimais pas du tout. Mdr. Si sa peut aider sais un resultat exelent en vus du prix prise et filtre max 150 fr ch. Car un filtre dedié coute bc plus cher. Service audiophonics exelent comme dab.
volker d.
Klingt sehr Gut
J'ai reçu l'appareil aujourd'hui.
L'installation sous Windows 10 ne pose aucun problème.
Le son est nettement meilleur que celui de ma petite carte son USB.
Bonne résolution via Toslink.
Un gain pour pas grand chose.
Salutations
Volker
Übersetzt mit DeepL https://www.deepl.com/app/?utm_medium=android-share
Lorenzo C.
Full-bodied sound
Honestly I wasn't expecting big performances, I was more intrigued by the peculiar circuitry of this little amplifier.
The workmanship is pleasant and substantial, and with the exception of a few sharp edges the quality of the materials is above all suspicion.
Like any amplifier of this type, the sound is full-bodied and well extended, with good dynamics and adequate damping which makes it not very sensitive to the types of speakers to which it is connected.
Very detailed in the mid-high range, with a great soundstage reconstruction and a bass that could appear to some as too controlled, it is excellent for those like me who prefer the classic jazz of C. Mingus, it gives great breath to the vocal pieces of D. Krall, and also gives Fripp's "pizzicati" that warmth and dimension that I usually find with SET and SEP amps.
As per description, the hum of the transformer becomes audible after an hour of listening but is very subdued, all in all in tune with the construction type.
Nothing to say about the silence of the circuit, however.
The amplifier is very quiet, even if you put your ear to the tweeter you can't hear any noises.
Definitely an EXCELLENT starting point for those who know and want to customize it, it represents a great investment for the asking price, and satisfaction is guaranteed.
My compliments go to the Audiophonics team for the quality of the transport box which is absolutely - flawless -.
The amplifier is enclosed in a solid polyurethane foam shell wrapped in expanded cardboard fillings, all enclosed in an external box whose solidity is guaranteed "courier proof"!
Thanks to the Team also for the speed in managing my order.
Have a good listening!
superbe petit ampli
très belle sonorité pour ce petit ampli
associé à des enceintes focal de 8 ohm le son est excellent le coté puissance est époustouflant car, utilisé dans une pièce de 16 mètres carrés, le bouton de volume est réglé quasiment au minimum pour une écoute très confortable
Manolis A.
Excellent communication and value for money product
Good quality of the product. I noticed immediately the good quality of the sound. I believe it is a vey good purchase and I highly recommend it.Very satisfying customer service.
Boris T.
Great DAC
This DAC represents great value for the money. In my system, it replaced Topping E50 that has the same ES9068A chip, only single one. Differences are easy to be heard as better sound stage, additional fine details in the reproduction and better separation of multiple voices or instruments.
Only let down is display. It’s very dim, even at max. brightness, with too small characters.
From the moment of order to delivered it took only 25 hours, from France to Croatia, using TNT service. Bravo Audiophonics!
Igor K.
AUNE X7S 2021 EDITION Headphone Class A amplifier Variable Out Balanced Out Silver The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the...
Amazing, smooth, detailed, dark background
I'm using Sennheiser HD6xx and Audeze LCD-1 headphones. I also have the B1S from Aune. The headphone amp sounds "liquidy". It's easy to place instruments in space. The background is very dark. I would not call class A warm, just pleasant / sweet sounding. Excellent for long listening sessions. For comparison, I have Hegel H95 and I tried Woo Audio WA7 3rd gen, and I prefer this amp.
Fabien M.
rien à dire. C'est simple et bien fait
Fabien M.
pas ce que j'attendais
Tout d'abord... j'admets être un peu maniaque.
Je voulais remplacer mon ampli 70's par un ampli plus simple (pas de réglage aigu/grave/balance qui à mon sens n'ont rien à faire dans un ampli).
Le côté positif, le schéma électronique est TRES bien... c'est pour cela que je l'ai acheté.
Malheureusement le son n'arrive pas à la cheville de mon vieil ampli (HK505).
Je pense que les condensateurs ne suivent pas. J'aurais pu tout dé-souder et remplacer par des condos haut de gamme (MKT / Électrolytes) pour multiplier la qualité du son par 10... mais bon.
Le jour où il y aura une version 2.0 de cet ampli avec des condos haut de gamme je serai prêt à payer 100 Euro de plus avec grand plaisir.
Sami K.
Rigid cable
Excellent quality cable as such, but maybe not be the best choice for headphone use as the cable itself is pretty thick and stiff.
Fabien M.
Très bien (voir mesures ci-dessous)
Boudonnement mesuré sur le haut parleur:
50Hz passé de -45dB à -75dB!
100Hz passé de -60dB à -90dB
128Hz passé de -62dB à -74dB
Eric P.
TOP
Acheté en remplacement d’un autre sélecteur de sources/ enceintes qui me jouait des tours.. celui ci est parfait.
Il remplit son rôle sans faiblir ( je l’ai testé «  à mort »)
Il semble bien robuste avec ses grosses bornes et je sens qu’on va se plaire tous les deux.
Merci à audiophonics pour le conseil.
Excellentes fiches bananes
Excellentes fiches bananes. Elles sont très faciles à installer.
Ne dénaturent pas le son et tiennent fermement sur la fiche HP femelle.
Il faut simplement mieux repérer le Plus et Moins.
Je recommande vivement ces fiches avec le câble triangle.
Envoi rapide comme d'habitude par l'équipe.
Marian M.
noise activity
Great capacitors
fits Yamaha DSP A-592.
Great sound, they gave my amplifier (1997) a new life.
Extremely fast delivery, thank you.
Changement
Je reviens sur ma première analyse qualifiant ce câble de pas terrible.
Il n’en est rien en réalité, car après 1 mois de fonctionnement il révèle aujourd’hui tout son potentiel. Il est passé par différentes étapes, de très claire a très sombre.
J’ai bien fait d’insister car aujourd’hui c’est un vrai bonheur et je retrouve toutes ses qualités qui m’avaient bluffées en modulation.
Beaucoup de matière avec un registre grave profond et détaillé. Le reste du spectre sonore est riche de détails et la justesse des timbres est superbe.
Bref, vous l’aurez compris, ce câble a besoin de temps pour s’exprimer à sa juste valeur.
Alors avec un peu de patience vous aurez une petite merveille
Et si vous le jumeler à une paire de modulation (oui, je sais qu’il n’est pas vendu pour ça) vous entendrez vos CD sous un autre jour.
Par ailleurs je confirme que leur diamètre est bien de 6.4 mm et non de 4.6 mm comme annoncé sur le site.
Ç’est important pour commander les bonnes prises.
Faites vous plaisir sans plus attendre.
Mathieu W.
MERVEILLEUX
Ce Dac est une incroyable surprise - ce qui n'est pas toujours le cas de mes acquisitions. Mon système (enceintes atlantis labs AT31 + LUXMAN L 509X) a été transfiguré. Pour plus de détails je renvoie a la REVIEW de SOUNDNEWS : vous aurez exactement ce que ce testeur y décrit (au millimètre). J'avoue avoir été sur la réserve à la commande pour le médium et la musicalité mais c'est superbe. C'est plein de matière et de technique. ET LE PLUS IMPORTANT et je ne m'y attendait pas : IL EST EXCEPTIONNEL en préampli et j'attaque directement le bloc du LUXMAN avec un meilleur résultat que le préamplificateur Luxman (Si!). Jusque la tout mes DAC étaient un peu décharnés en branchement direct : perte signal, timbres etc. La c'est le rêve et avec un grave d'un autre niveau pour la rapidité et les impacts. J'envisage d'acheter des blocs de puissances plus conséquents vu la synergie. Quelle transparence, quel niveau de détails et ce fond noir de la scène. Bref conquis.
Enfin le changement de la phase en façade est génial et la qualité en Bluetooth est également bluffante. J'espère qu'il durera dans le temps car vraiment très bon a ce prix. Ce n'est pas un DCS BARTOK mais pour écouter beaucoup de DAC dans ce créneau de prix et au delà c'est très fort. Impossible de se tromper.
Peter L.
Quality product
Very nice soldering. Refurbed ic's look like new. All test ok (4 units).
I have replaced 2 opa2134's in my preamp with the 627's. 2134's remain in the balanced receiver. In short the 627 are better: smooth, far more balanced tonally, defined rich bass. Mellow but all the texture and detail is there.
Patrick K.
Very good and soilid build quality! Very good sounding and lots of power!
The sound quality is very good, but the production in China is not flawless, because the stereo RCA channels are internally inverted! Therefor only 4 stars worthy.
Greetings
Jean-François S.
Bon HP large bande à prix démocratique
Donne de bons résultats monté dans une enceinte de 5 litres accordée à 60 Hz pour un usage de monitoring en MAO et d'écoute de proximité. Au début les aigües étaient un peu timides, défaut disparu après quelques heures d'utilisation (rodage ?). Ecoute très "analytique" et neutre, c'était le but visé, mais les graves sont tout de même bien présents malgré la petite taille des enceintes.
David S.
à recommander !
Je manque surement d’expérience dans le domaine des câbles phonos, mais le rendu est tout à fait conforme à mes attentes et les dépassent largement. Je me suis fié aux retours d’utilisateurs lus sur des forums anglophones.
Il me fallait un câble qualitativement plus en adéquation avec ma cellule MC bas niveau pour remplacer mon câble pro-ject. C’est chose faite : une image stéréo renforcée avec énormément de micro détails sur tout le spectre sonore avec beaucoup de poids et dynamisme, tout en restant naturel.
Pour 155 Euro, on en a largement plus que pour son argent.
Le seul petit moins : les pinces pour le fil de masse ne sont pas très pratiques, du moins sur mon installation.
Le petit plus superflu mais agréable au déballage : un superbe packaging.
Merci à Audiophonics de mettre à disposition cette marque méconnue en France sur son site.
Igor K.
Amazing, holds its own against much higher priced units
Tried with Audeze LCD-1 and Sennheiser HD 6xx. I only had Woo Audio WA7 gen3 and Hegel H95 to compare with side by side. Aune has darker background than WA7 and is a touch more dynamic and a bit more resolving. There is greater separation of instruments and the soundstage is deeper (again, a bit). Considering the price, this is an amazing accomplishment. Hegel H95 throws a wider sound stage, but I'm not sure if it's more accurate. Overall, very pleased with the unit. I normally don't buy lower priced units, but this is the only portable class A unit I could find under 1k. This unit holds its own against much higher priced desktop amps.
Luis V.
Audio Isolation Transformer Ground Loop RCA This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be...
Excelent
Solves ground loops without the compromise of sound quality
Florian G.
SMSL HO200 Balanced Headphone Amplifier / Preamplifier Compact and elegant headphone amplifier & preamplifier with output stage capable of delivering up to 6W under 16Ω (3W @ 32Ω). Constitutes an ideal solution to...
Très satisfaisant
Associé temporairement avec un M300 de la même marque, rien à redire sur le son ; c'est très propre.
Gain très correct avec des casques monitoring 250 ohms ; largement de quoi se rendre sourd. (-:
N'ayant plus d'ampli disponible, je n'ai pas testé les sorties préampli.
arnaud g.
c'est beau, c'est très mauvais
pourquoi vendre des cables comme cela sur un site audiophile, je ne sais pas.
Cable de faible qualité, tient à peine, n'enserre pas, bref je l'ai rangé dans la caisse de suite
Iulian M.
The best 24v smps I have ever owned.
60-80mV is NOT ultra low noise/ripple but with more filtering i could get it to 2-3mV and that is the best result i ever had with a smps.
Powering a Burson Funk, it really makes a difference. It's like the Burson SuperCharger but without the background noise and without the exagerated price. A minor issue is the input filtering choke that is flapping around and it really needs a bit of glue.
Srboljub S.
Very happy
This sleeve is both beautiful and high quality. Will buy again.
Pastorelli g.
Impressionnant
Un superbe subwoofer, très bien construit et qualitatif. Monté dans un caisson clos de 8,5l fitlré à 60hz ....le résultat est terrible, rapide et une très belle frappe, aucun trainage. Un excellent choix.
Service Audiophonics parfait !
David O.
Formidable
Viens en remplacement d'un Micromega MyDac car il datait un peu.
Après quelques recherches j'ai lu que ce DAC avait des revues objectives sur sa transparence. Le résultat à l'ecoute est incroyable.
Laurent F.
Très bon produit, montage facile , vis type Allen avec clef fournie
Prise lourde et solide 5 * avec plaisir
Laurent F.
Les produits Pangea sont excellents
Laurent F.
PANGEA PREMIER Cat7 RJ45 Ethernet Cable Silver Plated Copper Triple Shielding 0.129mm² 3m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
Très bon et beau câble , excellente finition , je recommande
Johan Å.
AUDIOPHONICS HPA-Q250NC Power Amplifier Class D 4 Channel NCore NC252MP 4x250W 4 Ohm The Audiophonics HPA-Q250NC is a four-channel amplifier based on two Hypex Ncore NC252MP.
Insane value and perfermance
As the title says, insane value and perfermance! Compared to my much more expensive Emotiva amplifier this one sounds smoother which I didn't expect. In fact this Audiophonics amplifier sounds so good I placed an order for the 3-channel Purifi amplifier.
Regarding build quallity; one of best built amps I have held in my hands - built like a tank!!
maarten v.
Nice looking and stable for this price
Angelo B.
SABAJ A10H Headphone Amplifier Class AB 1W 32 Ohm Sabaj completes its A10 range with the A10h headphone amplifier, a high quality model based on an optimized architecture using carefully selected audio components. The amplifier...
Sabaj A10h
This neutral sounding amplifier surprised me incredibly with its open soundstage and very good separation of musical instruments. Also surprised by the sound quality with my HD650 and HD58X (incredible musical definition). The volume returned was more than enough to appreciate the perfect compatibility and goodness of the Sabaj A10h and HD650.
Comparisons made with:
-Violectric HPA V200.
-OTL MegaHertz.
-Schiit modi Multibit.
-Khadas Tone Board.
-Austrian Audio Hi-X65.
-Avantone Planar.
-Equalizer APO.
Thank you very much David Aubert who always very professional in recommending the products.
Ioannis S.
Coaxial not operate properly
Is a good DAC but the coax input operate with with continuous breaks when i connect a CD player !
Thierry A.
Très bon niveau en terme de qualité prix
Différence perceptible en utilisant ce câble par rapport au câble d'origine sur une source OPPO 203. Un peu plus de définitions.
Très bonne qualité de fabrication. Très bon rapport qualité prix. Je conseille de le tester.
Ce câble ne détériore pas la qualité du son en privilégiant un registre par rapport à un autre comme certains câbles secteurs peuvent le faire ce qui est un très bon point.
Bien pour le prix
Fait le job pour alimenter un caisson de basse équipé Dayton. A noter que le ventilateur se met en route...pour ne plus jamais s'arrêter...
Philippe K.
Excellent accessoire
Encore un excellent accessoire pratique de Dynavox. Pèse efficacement la cellule et permet un réglage fin et précis du contre-poids permettant une lecture optimisée. Excellent rapport qualité/prix.
Philippe K.
Excellent produit très bien usiné. Apporte stabilité à la lecture et réduit efficacement bruits et distorsions. Un accessoire indispensable pour tous possesseurs de platine vinyle.
parfait .
dans l esprit de rester tout cuivre j ai acheté cette fiche .
rien à redire.
bonne qualitée apparente meme si je doute que le corps de la fiche resiste à plusieurs chutes ou choques ?
accepte du câble plus gros que 2,5 mm .
montage sans difficulté et prix acceptable .
bravo .
besoin de plus ?
cette barette fait parti des premiers prix de la catégorie , comment la critiqueur ?
mon choix c est porté sur le nombres de prises bien sur , mais aussi par la presence du rail en laiton de forte epaisseur qui relie les schuko et garant d une bonne restitution du courant entre les fiches .
pour la qualité c est du très très bon .
les fiches secteurs mal s emboitent avec resistance dans la barette gage d un bon maintien.
seul hic l assemblage !
je n ai jamais rien vue de si peu pratique .
pour un meilleur contact pensez à étamé le bout de vos câbles c est toujours meilleur et ca tient mieux au serrage .
un tres bon choix .
Jean-Claude T.
Produit Ok
Superbe produit et reçu très rapidement!
Jérôme L.
au top
La carte est géniale, le rendu est vraiment bon. J'ai déjà un raspdac mini qui est équipé avec celle-ci je commande donc les yeux fermés
Juste dommage qu'il n'y ai pas les entretoises vendu avec.
