François G.
Samuel A.
What a surprise!!!
Frederic A.
3E AUDIO 260-2-29A PFFB
Fonctionne...
Konstantinos A.
Very good dac
Clean and quiet dac with spacious performance and good analysis. Easy to connect in both Windows 10 (with SMSL drivers) and Linux Ubuntu (no drivers needed).
Quick and professional communication and postage from Audiophonics.
Neil M.
a Game changer
I've been a fan of Bruno Putyz and his designs for many years and consider him a pioneer of Class D. Hypex, N-core have been adopted by so many high end manufacturers NAD, Bel Canto etc etc. I was very excited when Purifi announced eigentakt. Even more so when audiophonics packaged it so attractively and affordably for the enthusiast with the well proven Hypex SMPS power supply. An immediate buy. I love building but dont have the machinery or time for nice casework.
Comments. Excellent build quality in and out. If you want pretty spend another 5k.
initially disappointed with sound compared to Nord n core monblocks with hardy discrete amps.
Immediately looked at lm4652 (see other reviews) and replaced with sparkos discrete dual opamps. A revelation. up there with the very best. This is super audiophile at bargain basement prices.
Tres bien. Merci beaucoup.
NM
Neil M.
AUDIOPHONICS HPA-Q400ET 4-channel Class D amplifier Purifi 4x400W 4 Ohm We are proud to present AUDIOPHONICS HPA-SQ00ET, a class D 4 way power amplifier based on 4x PURIFI 1ET400A modules.
a potential game changer
NM
Neil M.
NM
Michel b.
Excellent produit rigide et bien doublé. Par contre la découpe est vraie ment difficile même avec de bon outils. La colle auto adhésive encrasse très vite la lame du cutter ou les ciseaux.
Le moins compliqué est de couper au cutter la partie tissée et aux ciseaux le reste tout en prévoyant d’éliminer régulièrement les résidus de colle.
La colle adhère vraiment bien et la plaque est quasiment impossible à repositionner ou à plier pour la passer par des ouvertures étroites.
jean michel G.
J'utilisais une soudure avec qui je n'étais pas vraiment satisfait. Avec celui la, c'est propre et pas besoin de chauffer éternellement.
Produit à recommander.
Olivier M.
trés bien
voir les autres avis, rien redire.
Installation facile et trés bon son
Christophe V.
Une Tuerie!
Pour avoir eu l’ancienne prise version rhodium sans le traitement NCF pendant plusieurs années, j’ai décidé de passer sur cette version NCF qui je dois dire l’enterre littéralement sur les points de référence telle que la finesse,la clarté sur les voix font un bon en avant de façon considérable, écoute beaucoup plus naturel sans aucune sensation de coloration qui pouvait être un peu la critique de l’ancienne version...
Le grave est plus détouré avec une belle extension sans caricature.
Petit conseil, tout amélioration d’un système haute fidélité devrait déjà commencer par cette prise avant de toucher à autre chose
Une référence !!
François L.
Mitigé
L'histoire des câbles de liaison est trop complexe pour en donner un vrai avis objectif, pour ma part sur mon système, grave trop mou, médium plus doux, aigu en retrait, ah si le saint graal Audio existait ,serions nous un peu moins "idiotphile" ?
Par contre Audiophonics, toujours au top pour leur réactivité et
des réponses SAV avec intérêt.
François L.
bien
Le service Audiophonics au top de réactivité, pour l'article en lui même, rien à dire en particulier, conforme au attente.
Serge P.
PTFE Sheath AWG14 Ø1.5mm Transparent This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1.5mm diameter maximum. Transparent, it leaves the conductor visible.
Sert aussi de liner cable
En plus de l'usage en électronique , c'est top aussi comme liner cable pour le dérailleur arrière où le trou de passage sur la base est vraiment petit sur le Wilier GTR Team ;-)
Ludovic L.
Je ne suis pas un pro de la soudure et j’ai réussi à monter mes câbles. C’est plus simple que sur les REAN NEUTRIK. Elles sembles solides et les matériaux de qualité, elles tiennent bien une fois branchée, parfait avec le câble CANARE S G6.
Ludovic L.
J’avoue avoir acheter ce câble par curiosité. J’avais un câble enceintes audio-pro en 2x4mm qui convenait bien à mon ancien ampli (Yamaha A-s 701), j’ai récemment acheté un NAD c368, j’étais alors un peu déçu du résultat et je pensais que l’ampli était la caïques du problème. Après le montage des câbles, c’est un changement intégral du son, complètement débouché....beaucoup plus transparent, clair et ça descend plus bas et les aigus plus cristallin sans fatigue. Top quoi...
gilbert d.
Potentiomètre mono
Produit de qualité correspond à mes besoins
gilbert d.
Récepteur audio bluetooth
Produit conforme mes attentes très bon son sur chaîne hifi ainsi qu'une très bonne transaction
Cable très neutre (testé avec Audio-GD R1). Kingwa est vraiment très fort pour proposer d'excellents produits à des tarifs raisonnables. Je recommande ce cable.
Jon H.
Great build quality and sound performance
Great cable with great build quality. Improved my sound with a smooth and warm sound, without loosing details. Improved foundation with a lot of more and better bass!
Stretchy Sheath Extensible Nylon (PET) 30-50mm Black This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of...
Pas mal pour une simple gaine de protection
Facile d'utilisation et bonne qualité de protection générale, j'aurais aimé une bi colore mais ne semble pas exister dans ces dimensions.
Elle protège mes câbles secteurs réalisés sur la base de conducteurs Néotech acheté sur ce même fournisseur.
J'achète depuis de nombreuses années chez Audiophonics et je suis très satisfait de nos échanges et de leur rapidité d'exécution.
NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm² Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver...
Excellent pour un Diy Modulation
Utilisé pour réaliser un Diy modulation en RCA, le résultat est absolument sublime, attention la fragilité du conducteur oblige de trouver des solutions pour limiter la casse du fil, mais le résultat vaut qu'on se penche sur le problème.
J A B.
ALPS 50KA2 Stereo Potentiometer High Quality 50kΩ The ALPS 50KA2 is a high quality stereo potentiometer with a resistance of 50kΩ and a logarithmic progression curve. Its smooth shaft has a diameter of Ø6mm and a length of 25mm.
j brouwer
Perfect.
But a tiny item like this would be received easier if sent in an package flat enough to fit into a standard letterbox opening. That could save time for the postman and the receiver.
Hordur T.
Amazing
Yes, this works as advertised, the sound becomes smoother and more detailed. I am not sure if this is true but I have a feeling that this affects all the electricity in my house. A computer screen that sometimes flickered off does not do that any more. A light that flickered has stopped doing it. My wifi seems better. I am not sure if I am imagining those things but just the improvement in sound quality is very significant. This optimizer is a work of genius, recommended.
Pascal M.
Alles bestens, schönes Gerät.
Und danke für die schnelle Lieferung...
Jean-Pascal F.
Après avoir hésité, j'ai acheté le micro de mesures UMIK-1 et j'ai testé Dirac live en direct sur le site de l'éditeur avec Audirvana. Le choix était soit Dirac live (environ 350 €) avec audirvana ou le SHD studio avec son lecteur Volumio intégré !! J'ai choisi le lecteur car j'ai le choix des entrées et plusieurs sorties. Au final, dans mon bureau ou je suis installé de manière assymétrique (pas le choix à cause des portes fenêtres et radiateur), j'ai un son d'une qualité exceptionnelle, je n'ai plus les ronflements dus aux modes (ondes stationnaires), la musique respire, le son est équilibré, je peux écouter plus fort et quelle que soit la musique, je prends du plaisir. Je redécouvre mes albums et qobuz !! Arrêtez d'acheter du matériel hors de prix et commencez par nettoyer le son, vous entendrez la différence !! Croyez-moi, le retour arrière est impossible !!
Jonas S.
VIBORG RC-101 RCA Plugs Pure Copper (Set x4) The RC-101 from Viborg are very good RCA subbases, ideal for quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal...
Very nice and great quality Rca plugs.
Jonas S.
VIBORG BP-603 Pure Copper Speaker Terminals Plug Ø4.5mm (Set x4) With its BP-603, Viborg offers exceptional terminal blocks for speakers, thanks to a design using particularly high-end materials.
Very nice and good quality speaker terminals.
Pascal M.
AUNE XP3 Linear Power Supply 9VDC 1A / 2x 13.5VAC 0.8A for Aune X1s Pro / X8 / T1s / X5s / X7s / T1se Black The XP3 is part of the second generation of XP power supplies adapted to Aune's X/T products. It is a high-end power supply capable of providing a clean and stable electrical...
Petit produit, grand effet...
La différence avec l'alimentation de série est très significative. Le son est plus aéré, plus dynamique...
Un très bon achat !
Bernard B.
Surprenant de qualité pour son prix et sa taille
Voilà quelques jours que j'ai reçu et essayé cet ampli entièrement numérique. En le commandant je pensais que tout l'engouement fait autour était une blague. Et bien non; il est véritablement un élément clé maintenant dans mon plaisir d'écouter de la musique.
Le son est précis et équilibré. Je l'ai testé et un peu poussé sur du jazz (Miles Davis, Brad Mehldau), du classique (Requiem de Mozart) et sur le dernier opus rock indies de Tash Sultana (formidable).
Il est couplé sur des enceintes Triangle Lunn de 1999 que je n'avais pas encore entendu sonner de la sorte. Je pense même qu'il mérite aussi de monter en gamme et je vais investiguer sur des Dynaudio Special Forty (certains ont essayé ?).
En tout cas, c'est un achat sûr et fiable.
MATHIEU B.
Super facile
Acheté pour capter le wifi sur un système Volumio-Raspberri Pi enfermé dans un boîtier hi-fi métallique. Un petit câble de rallonge USB et cette antenne et hop, le signal wifi est de retour (et meilleur qu’avec l’antenne du RPi) et tout cela en plug and play (pas besoin d’installer de driver).
Arnaud L.
Marcel J.
Boitier parfait à ce niveau de prix
Ce boitier est parfait à ce niveau de prix et permet une réalisation très professionnelle. Les vis de fixation sont un peu longues pour la face avant. Il faut ajouter des rondelles sous les têtes pour qu'elles serrent bien. Il est vrai que les 2 boutons sont un peu "cheap". Je les ai remplacés par 2 boutons de meilleure qualité d'un diamètre de 30 x 15 avec vis de serrage, ce qui ne m'a couté que 6 € de plus. Par contre, il faut savoir qu'il y a des lamages dans la face avant de diamètre 37 et 4 de profondeur au niveau des boutons, ce qui est du plus bel effet, mais qui posera problème à ceux qui veulent ajouter un boutons supplémentaire si besoin était. Dans ce cas, il faudra mettre des boutons de diamètre 38 mini pour recouvrir les lamages existants. Pour le reste des accessoires fournis, RAS.
Marian S.
Dac de très bon qualité.
Je l'ai acheté pour pouvoir partir plus tard sur des éléments séparés, ampli casque et dac. Je possède momentanément un Fiio K5 pro qui fais les deux. Lui aussi est de très bon qualité .
J'ai le associé au smsl q5 pro (acheté aussi de chez vous) Je constat que le son et encore mieux.
J'ai gagné donc un dac qui va me servir pour casque et pour l'ampli salon.
Merci Audiophonics pour votre réactivité et votre professionnalisme. Vous êtes au top.
françois t.
retenir que c'est un des rares modèles quatre broches
un des rares modèles quatre broches à point milieu (en général utilisé pour le muting), et donc à retenir pour le remplacement dans des amplis plutôt anciens
albert l.
BRUNO B.
FIIO Q3 Balanced DAC Headphone Amplifier THX AAA-28 AK4462 XMOS XUF208 32bit 768kHz DSD512 FiiO's Q3 is a high-performance, portable balanced headphone amplifier and DAC combo. Featuring a meticulous design using high-end components, it offers excellent performance...
parfait!
reçu rapidement, merci encore a vous !
après avoir eu le Q1, je ne regrette pas le Q3,il apporte plus de détail définition, précision, c'est chirurgicale ! couplé a mon baladeur Fiio M7 le couple fait des merveilles !
Gilles D.
Super cable!
grâce à lui tout est rentré dans l'ordre, beaucoup plus efficace que l'audioquest cinnamon, et bien moins cher!
François C.
Parfait pour un cable 2P+T
Si vous n'avez pas la place sur votre boitier pour intégrer une prise châssis IEC 2P+T (ça prend de la place...) cette traversée de cloison est idéale. Après serrage, vous pouvez tirer sans crainte sur le câble. Je pensais remettre un collier sur la gaine du câble dans le boitier, mais je n'en ai vraiment pas eu besoin. C'est du costaud ! Je recommande, surtout pour ce prix...
François C.
Excellente qualité
Qualité de fabrication irréprochable. Je l'ai intégré dans un boitier avec un RPi 3B et une alimentation linéaire de ma fabrication. Le DAC et le RPi sont cote à cote, reliés entre eux par les 3 fils du bus I²S. Mon alimentation est connectée directement au DAC, qui alimente à son tour le RPi, grâce à deux pins du GPIO. Le RPi embarque Volumio. Branché sur mon ampli, je profite de toute la musique qui est sur mon NAS (CD rippés en FLAC) avec une excellente restitution. Testé en aveugle, c'est impossible de faire la différence avec ma platine CD. Excellente carte que je recommande à tous les bidouilleurs et fans du DIY.
Valentin S.
Un régal pour les oreilles et le portefeuille
E-30 : superb clarity and finesse, even has decent op-amp for an entry level system (OPA1612).
audiophonics: fast shipping, newest factory charge (2102XXX), ordered in march.
tres bien overall.
Byron P.
ALLO Acrylic Case for Raspberry Pi 4 + Allo DigiOne Signature Black This acrylic case designed by Allo is perfectly adapted to receive the Raspberry Pi 4 and Allo DigiOne Signature combo, while maintaining access to the different connectors of...
Simple easy to assemble case
A simple cheap acrylic case for the DigiOne Signature kit and RPI 4. If there were an aluminum/metal case I would have bought that instead.
Byron P.
Excellent sounding and looking network streaming device
This is an excellent Raspberry based network streaming kit that sounds like a high-end component. The aluminum case makes this look like a manufactured product and not a DYI.
I have mine hooked up to separates (preamp and multi-channel amp) and the dynamics, soundstage, and high-end are nicely presented.
In the download section you will find instructions for assembly and usage. Thankfully for me there is an English version as I do not speak French. The assembly instruction should be slightly updated as it shows an older version component for the display unit which has been updated to an LCD display but easy enough to figure out.
I think you will not be disappointed in the sound coming from this device or the convenience of having all your music or web based music stations at your fingertips. My music was accessed by both a solid state drive directly connected to the RPI unit and via NAS.
Lastly I was impressed how quickly I got the unit within 6 days from France to the USA and it was nicely packaged.
Damien M.
Aussi performantes que leurs grandes soeurs
Elles se présentent comme un copié collé de leurs soeurs , hormis le fait que sous le plaqué argent , ce n'est pas de cuivre dont elles sont constituées , rien n'est précisé , une lacune d'ailleurs dans le descriptif ;Je suppose qu'i s'agit d'un alliage de nickel ou de laiton.
Comme leurs aînés , leur ergonomie facilite l'accès au soudage, la vis de blocage du câble par le biais d'un manchon de plastique protège bien la soudure d'éventuelles contraintes mécaniques. Enfichées , le maintient de la connexion est exemplaire , rien à redire sinon que pour un prix inférieur de moitié , elles se révèlent aussi performantes (comparatif effectué entre deux cordons , chacun équipé de l'un des deux modèles).
Si c'était à refaire je m'équiperais exclusivement de ces dernières.
un grand classique
Attention à ce que les résistances, par ailleurs bien alignées, bien soudées, ne touchent pas les deux vis et écrous du carter, les écarter un peu si nécessaire. La rotation est un peu dure (rodage ?), c'est le prix à payer pour des contacts de qualité. Remplace avantageusement les modèles à pistes, mais on ne pourra le motoriser, trop de force pour faire tourner.
Parfait, on a tout d'avance
Toutes les tailles, prix raisonnable.
Cable Male USB-C 3.1 to Male USB-C 3.1 Super Speed 5A 10Gbps 0.5m This USB cable has a USB-C 3.1 connector on both sides and allows you to connect two devices with this connection, such as a smartphone and a recent laptop or tablet. The cable...
Cinq ampères, on prend !
Le câble USB 3.1 que l'on attendait, rapide, et du débit, enfin.
Enfin un filtre secteur deux pôles.
Difficile à trouver, et pourtant, bien utile ! Souvent le troisième pôle, la terre, amène plus d'inconvénients que d'avantages. Donc le format IEC C7 est très bien dans la plupart des cas. Indispensable.
Bien, mais usage domestique
Fabrication un peu légère, à déconseiller en usage professionnel. Qualité suffisante dans les autres cas.
VIBORG VE01R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A The Schuko Viborg VE01R uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of...
Belle fabrication, et de vraies vis, et peut accueillir des câbles de 6 mm. Indispensable.
DAYTON AUDIO H812 Horn for compression chamber 800 Hz Dayton Audio horns are designed to operate smoothly until the lowest possible crossover frequency. whIt maintains consistent and predictable dispersion throughout the intended...
Pas cher, mais franchement mal fini
Prenez vos limes douces, les trompes arrivent, mal démoulées.
Les ébavurages, on s'en fiche, sauf quand c'est la gorge !
Les 25,4 mm (un pouce) de diamètre ne sont pas respectés, ce n'est même pas rond, c'est fâcheux, c'était le point important. La partie plane qui reçoit le moteur... n'est pas plane. Oui, ça fait des vagues, donc il y a des fuites là où c'est le plus critique. Il faut aplanir les bosses, reboucher les creux, à la résine, puis poncer. Pour quelques dollars de plus, à peine, on pouvait faire nettement mieux. Ce n'est pas cher, mais avoir tiré la qualité vers le bas à ce point, c'est incompréhensible. Alors, à vos outils ! Sinon, la coupure basse (moins de 1000 Hertz) est intéressante et elles sont solides.
chiostri g.
KHADAS TONE2 PRO DAC Headphone Amp ES9038Q2M 768kHz DSD512 MQA Full Decoder Red Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768 kHz and native DSD512 and even MQA. New headphone...
Khadas tone 2
Very good. Not so easy to use. Next I will buy the special balanced cables and the new Topping pre90
Denis f.
Parfaite
Pas encore installer, mais acheté pour une fabrication subwoofer en 38.
Poids final 45kg mais vu l'aspect des pointes je me fais aucun soucis elles sont très robuste et respire la qualité
