Laurent B.
Bonne upgrade
Hans B.
Patrice L.
Un produit bien conçu.
Customers reviews - There are 19358 reviews.
Jacques B.
DIY Case Aluminum 320x308x70mm Silver Front Panel This DIY case, ideal for the manufacture of a HiFi device such as an amplifier, is made of Aluminum. It is delivered with an IEC base, feet and screws.
boitier électronique
Reçu le boitier dans un temps très cour, produit bien emballé , mécanique très soigné , très précise , et une belle esthétique , un bon rapport qualité prix , en fait j'ai pas trouver de défaut ! parfait .
Adam S.
very nice quality
prefect transformer for the grounded grid preamp
its dead silent ,no noise ,imo it works better than the toroidy audio range transformers ,replaced a faulty toroidy transformer with this and got to my surprise an upgrade in sound
Corneliu S.
Listening Musica Nuda
Before posting this review I used the amplifier for a week, listening every day.
Indeed, the musica nuda of the two from Musica Nuda, the voice of Petra Magoni and the double bass of Ferruccio Spinetti in Live a Fio. I continued with Laura Fygi, The Latin Touch, finished with Chantal Chamberland, Soiree.
The amplifier is a "purist", it does not add colors or shades to the sound, it plays exactly what the source senis feeds in .
It is a quality product, its industrial look may or may not please you ... it depends on everyone. It's certainly not to showoff to your audiophile friends with branded gear, but if you do then you really don't have to feel inferior to them, the end of the day, the sound matters and in this case yes, it matters.
A Big Bravo to Audiophonics for this product and for the sales & logistics services!
By the way Audiophonics, I love the Gran Torino, the French version by Chantal Chamberland, sounds .... terribly good on this amplifier.
Keep your good work and thanks,
Corneliu
Rien à dire
Très bon câble, plutôt neutre sans duretés, câblé en symétrique avec des xlr neutrick, entre mon DAC et l'intégré.Je le préfère au Galileo 236+ que je trouve un peu bouché et de moins bonne facture.Il est facile a travailler et plus solide que l' albédo, plus cher et plus fatiguant par manque d'assise dans le grave.Un câble de qualité, et musical, à 3 euros le mètre...Excellent RQP, je recommande.
Remus Andrei S.
Recommended, looks great.
- made in Lichtenstein
- easy to solder for a beginner
Remus Andrei S.
Great amplifier for the price
I was convinced of getting a Hypex nCore NC252Mp after reading the review of Archimago about it and the reviews on Audio Science Review of the hypex ncore amp. Audiophonics provided the a great build and less expensive in comparison with builds by other companies.
They power the Elac DBR-62 in my system. I cannot hear any noise coming from it, not even when I put my ear against it. It's also just slightly warm and doesn't seem to run hot.
The only things that is not clear from the pictures is how large this thing is. it's length is close to the height of the DBR-62. And from what I've seen of people who opened it, there's mostly open space in there.
Can something be done to make this more compact without sacrificing anything? I hope they consider this for future products.
Nicolas M.
Petit mais costaud !
Première fois que j'achète ce type de matériel. Branché en direct sur les CMS65 Focal en lecture de mon PC du boulot ou de mon téléphone Sony Xperia (son meilleur avec le PC) le son est excellent. Idem en passant par ma table de mixage Behringer X1204USB. Facilité d'utilisation parfaite. Un petit interrupteur pour l'arrêter aurait été top mais il est sur une multiprise avec un bouton ON/OFF du coup pas de souci. Je crois même pouvoir le brancher via USB sur la table... Au vu de la taille et du poids quand on le sort du carton, on s'attend à être déçu...et bien non ;-)
Gérard R.
Déçu
Concernant la sortie Analogique FL/FR je m' attendais à minimum à l' obtention d' un son stéréo quelque soit la nature du signal porté.
Dans mon cas le signal peut parfois être de type Dolby (5.1).
Ce qui m' oblige à couper l' émission Dolby , pour l' obtention , d'un son stéréo (FL/FR)
Ce décodeur, semble t'il ne sais que reconnaître que du "pur LPCM "
Pour ce qui est de l' extraction du signal HDMI et sa conversion vers SPDIF optique le système fait son job., à priori sans altération majeur
Donc 2 étoiles.
Claude C.
Complément avis du 14/01
Je précise à le suite de la réponse d'Audiophonics que la connectivité utilisée est un réseau filaire Gigabit.
Alors en effet votre problème est ailleurs.
Mais pas du coté du Streamer en lui même.
C'est un Best seller depuis plusieurs années qui utilise une technologie éprouvée (linkplay) et reprise depuis par des marques mass market. Ce problème est inconnu.
réponse tardive à Jean b.
Je viens seulement de voir votre message, j'ai remplacé le condensateur électrochimique 16V 2200 uF par 2 Nichicon 16V 1000 uF FG (Fine Gold) bien meilleurs en terme de dynamique et de musicalité. Cordialement !
Joanna D.
Oyaide explorer v2 speaker cable102 ssc copper 2x1.25mm
I am a bit disappointed about this product because I have already IC rca made in this technology 102 ssc and it’s very good. Compared to my Chord Clearway speaker cable, soundstage has lost its depth and the treble lost its sparkle. In my opinion this speaker cable may sound better in dark sounding systems. Anyway I’m very happy with the customer service at this store and it’s definitely not my last order.
Dmitri K.
Great product and service
The UMIK-1 is most popular mic for measurement. Very easy and friendly to set up and operate.
The delivery is fast. I'm very satisfied with audiophonics's customer service.
NE DEPENSEZ PAS PLUS...
Très beaux timbres, d'une densité plaisante. Image stéréo tridimensionnelle, très bonne transparence, dynamique sans compression et sans agressivité, spectre retranscrit dans son intégralié. Un rapport musicalité/prix exceptionnel. L'orbit 225 est dans la même veine, excellent lui aussi.
Angelo P.
bien
quelque difficulté pour integrer cet ampli dans mon systeme, mais ça vaut le coup le son est vraiment bon. merci au sav d'audiophonics
très efficace
Je suis très étonné par l'efficacité de petit filtre secteur qui se défend plus que bien.
Sur le plan sonore, en Hifi on gagne nettement en silence et fluidité
En bref: super rapport qualité/prix.
A recommander chaudement !
MICHEL B.
Excellent câble 110 Ohm
Les câbles AES EBU « Audiophonics Canare » et « Mogami 3080 » sont à égalité dans l’excellence. Un grand merci à Audiophonics pour avoir constitué ce câble qui respecte parfaitement la norme 110 Ohm.
Ci-dessous le résultat de mes tests d’écoute.
Les timbres sont ceux des vrais instruments de musique avec de la matière et de la présence. Donc pas de décalage d’effet jitter, c’est quasiment de l’holographie acoustique. Le médium est superbe. On se délecte de la quintessence des instruments. Les violons d’époque J.S. Bach ont leur acidité naturelle sans aucune agressivité. Les graves sortent sans effort, nets et sans atténuation.
L’espace sonore est grandiose, totalement libéré en trois dimensions. On perçoit l’acoustique de la salle d’enregistrement. Parfait respect des plans sonores. Sur de l’orgue (œuvre pour orgue de J.S Bach interprété par André ISOIR chez CALLIOPE, enregistrement magnifique), on perçoit l’ambiance de l’abbaye, les registres, les tuyaux, l’organiste, etc.
Ecoute relaxante, absolument pas fatigante quel que soit le volume. Quand c’est fini, on en redemande. On est transporté par la musique. Il n’y a aucune agressivité. On perçoit le corps, la résonnance et les harmoniques des instruments. On entend la respiration des chanteurs. Le son est naturel. Les fins de notes se prolongent. L’émotion passe (critère très important).
Dynamique intégrale avec des transitoires très rapides, sans excès. La musique est très vivante, l’enchaînement des phrases musicales coule comme de l’eau pure.
Le plaisir d’écoute est fantastique, ce n’est plus une chaîne Hi-Fi, c’est de la musique réelle, rien que du bonheur !
Vous pouvez acheter ce câble les yeux fermé, qualité au top et prix très honnête !
Mehdi M.
Très bon ampli
Le HPA-S400ET est une belle bête. Sobre, bien réalisé, il n'a pas à rougir face à une concurrence bien plus chère en terme de fabrication / finition. Les borniers sont impressionnants. A l'écoute, je ne sais pas encore si c'est mieux - je manque de recul - mais c'est en tout cas assez différent de mon Audio Analogue. Les graves vont plus bas et sont plus tendus, mieux définis. A l'inverse, le haut du spectre est moins dynamique mais a priori tout aussi précis. Parfait pour être associé avec mes enceintes Dynarex qui ont des aigus très agressifs. Avec des Klipsch Cornwall iii qui ont un naturel assez "sombre", l'association n'est pas idéale. En revanche je trouve que la scène stéréo manque un peu de largeur, peut être n'ai je pas encore trouvé le bon placement des enceintes, mais face à l'Audio Analogue, la différence est assez fragrante. Je suis un peu plus réservé sur l'alimentation. En effet à chaque fois que j'éteins l'ampli - volume à zéro - j'ai un "clac" dans les enceintes assez désagréable. Cet ampli me fait l'effet d'une loupe : il amplifie le moindre bruit, signal ... qui provient de la source voire du pré-ampli. Dans l'ensemble je prends plaisir à écouter mes disques et rien que pour cela, le HPA-S400ET est bien recommandable vu son prix.
Frederic L.
Très bon produit, facile à installer, extrêmement polyvalent et d'une bonne qualité sonore.
Seul bémol: je ne peux plus régler le volume à partir de l'émetteur (un Sony NW-ZX507), alors que c'était possible sur mon ancien récepteur (en BT 4.0).
Côté service: livraison rapide et emballage soigné... je recommande sans réserve.
Jean-Charles g.
SHANLING MW200 Bluetooth 5.0 Receiver DAC Headphone Amplifier AK4377 CSR8675 MMCX The Shanling MW200 is both a Bluetooth receiver, a DAC and a headphone amplifier in neckband format. It benefits from a very nice design quality in order to offer you a great...
Récepteur bluetooth Shanling
Tour de cou malin, pratique et efficace. Marié avec des intras tinfi P1exigeant en terme de puissance, la bête s'en sort correctement.
Jean-Charles g.
SHANLING M6 PRO HiFi DAP Compact Music Player DAC 2x AK4497 32bit 768kHz DSD128 Titanium Shanling's M6PRO is a DAP with dual AKM4497 and exceptional audio performance. It uses a version of Android OS specifically customized to maximize audio performance and offer...
Shanling M6 Pro
Matériel véritablement audio offrant une scène sonore large et une dynamique de premier plan. Peux driver n'importe quel casque exigeant.
Le système Android utilisé est simple mais efficace. Petit bémol concernant la puce Wifi utilisée qui est correct mais pas aussi performante que celle d'un iphone par exemple, ce n'est pas rédhibitoire et l'expérience générale d'utilisation reste géniale.
Jean-Charles g.
Casque sundara
Un casque véritablement audio avec un une dynamique intéressante et un bel équilibre général. L'ergonomie, la qualité de fabrication et le confort sont très correct. Peut être driver avec un DAP de milieu de gamme, nécessite un rodage pour le "libérer". Excellent rapport qualité prix plaisir
Martin S.
Surprisingly good
Used to replace the inbuilt TOSlink on motherboard. Everything sounded clearer and bass had more slam
Davide S.
Finition top
Un produit presque indispensable pour construire des câbles de grande niveau
Davide S.
Solide
J'ai testé cette câble sur conseil de technicien Audiophonics, et je doit dir que est un super produit surtout qualité prix. Avec des RCA de qualité c'est tout la différence.
Edwin P.
Borniers très pratiques et qualitatifs
Ces borniers sont très pratiques car ils se serrent simplement en relâchant le ressort.
Le contact est bon, le pois et le matériau sont satisfaisants.
Les câbles de 4mm² de section auront du mal à entrer, mais aucun problème au dessous
Edwin P.
ELECAUDIO BP-206 Gold Plated Binding Post Acrylic Isolated Ø19mm x 47mm Red This high quality Elecaudio BP-206 terminal block uses gold-plated copper alloy as conductor, ensuring excellent conductivity and resistance to oxidation.
Excellente embase
Ces embases respirent réellement la qualité, elles ont un beau volume et poids et sont bien conçues d'une façon générale. J'ai vu des amplis haut de gamme être bien moins dotés que ces borniers.
Le serrage des câbles est très bien pensé car en plus de la partie extérieure à visser, un anneau interne mobile va éviter de "frotter" les brins du câble, et va assurer un serrage bien ferme.
La soudure à l'argent n'est pas évidente, veillez à bien retirer toute la plastiquerie avant de vous mettre aux soudures, car vous devrez chauffer FORT et LONGTEMPS.
Edwin P.
Excellente embase
Edwin P.
Excellent câble interne
J'avais utilisé la version argentée de 1.6mm² de ce câble (FT116TS) sur un autre ampli de puissance, avec des résultats corrects.
Après avoir fait l'ânerie d'utiliser des SC Orbit 225 en câble interne pour relier mon ampli de puissance aux borniers (en remplacement des câbles constructeur), j'ai tenté ma chance avec ce modèle là.
Et bingo : les Orbit commencaient à sonner convenablement après un long rodage, mais ce câble a instantanément amélioré la sonorité avant même d'avoir passé le rodage.
Mon système a non seulement retrouvé son détail et sa dynamique, mais a aussi nettement surpassé les câbles d'origine.
Et oui, la sonorité peut être très influencée par les premiers 8cm de câble
Il est fin et relativement rigide, ce qui facilite le placement, mais attention lors de la soudure il peut y avoir de la brasure qui se glisse le long du câble et rigidifie le début. Cela m'a sensiblement compliqué la tâche vu la très faible longueur
Edwin P.
VH 3.96mm Male Socket 2 Channels Gold-Plated White (Unit) This straight connector in 3.96mm VH male / male format has 2 channels (2 pins) and will allow you to make quick connections between the modules of your DIY project. Each...
Très bon choix de matériaux
Rien de particulier à dire sur cette embase, elle fait son job et propose un matériau qui a de bonnes propriétés.
Ca a demandé un peu de travail de toutes les remplacer dans mon ampli de puissance, mais je suis certain que cette partie (entrée et sorties) ne limitera pas le son
Edwin P.
VH 3.96mm Male Socket 3 Channels Gold-Plated White (Unit) This straight connector in 3.96mm VH male / male format has 3 channels (3 pins) and will allow you to make quick connections between the modules of your DIY project. Each...
Edwin P.
Module satisfaisant et versatile
J'en ai équipé mon ampli de puissance, pour qu'il s'allume via une entrée déclencheur 12V.
Le *clic* est très audible mais bizarrement satisfaisant, on sait quand il s'allume ou s'éteint. Il pourrait être étouffé avec un montage sur amortisseurs, le mien est sur des entretoises laiton dans un boitier aluminium.
Edwin P.
VH 3.96mm Female Contact Terminal Gold Plated (x10) These VH3.96 connectors ensure a reliable and secure connection for all your DIY circuits wiring.
Le meilleur choix de matériaux
Je n'ai trouvé nulle part ailleurs de contacts de ce type plaqués or, ce qui en fait automatiquement le meilleur.
Tout mon ampli de puissance en est équipé désormais, côté entrée secteur et sur les sorties d'enceintes.
Je ne suis pas convaincu que cela a rendu mon son significativement meilleur, mais j'ai la certitude qu'il n'est pas pire et que ca durera dans le temps.
Par curiosité j'aurais aimé connaitre l'alliage à l'intérieur.
Michel R.
Qualité et tranquilité au rendez vous
Destiné a un usage Home studio sur une base de carte mère Asus de 2012
et une carte son externe Apollo.
cette fameuse carte a résolue mes problèmes de parasites EMI générés par le processeur de type I7 Intel (bruit typique de travail lors d'ouverture de programmes ou déplacement de la souris). Mais pas que car sa a aussi amélioré le temps de latence a moins de 2 millisecondes avec a la clef une net amélioration au niveau de la spatialisation sonore et clarté des timbres.
un investissement sert élevé pour cette petite carte mais le prix de la tranquillité et de la qualité sonore.
cy f.
Très bons conseils d'Audiophonics, excellent câble.
Thomas B.
Excellent transmetteur BT LDAC
Petit boitier très complet et très efficace avec de belles finitions ! Je l'ai branché en optique sur la TV pour pour transmettre en bluetooth LDAC sur mon casque Sony WH-1000XM4 et ca fonctionne très bien !
Laurent C.
Transformer R-CORE 60VA 20-0-20V This R-Core transformer is ideal for creating the power supply stage of a DAC or preamplifier for example. It is also equipped with a magnetic screen and an electrostatic screen.
Produit de qualité et service impeccable
Ces transformateurs sont de bonne facture apparente (non encore testés, je pars de l'hypothèse qu'ils tiennent les caractéristiques annoncées) et sont conformes à la description.
Ils sont bien protégés pour le transport et l'emballage complémentaire Audiophonics est sérieux.
Pour avoir déjà utilisé ce type de transformateur dans des montages audio vraiment musicaux (j'ai enfin entendu des détails insoupsonnés de mes sources audio high def, y compris en comparaison avec des système hifi vraiment sérieux) je confirme qu'ils sont adaptés à ce type de destination de haute transparence et musicalité (naturellement ils ne font pas tout et le reste de la conception audio doit aussi être à la hauteur).
Je recommande ce produit.
Julien M.
DAYTON AUDIO ND25FA-4 Speaker Driver Dome Tweeter Neodymium 20W 4 Ohm 90dB 2500Hz - 20kHz Ø2.5cm This 25mm dome tweeter with neodymium magnet offers in a compact format a quality impulse response and a flat response from 3000 Hz onwards. Easy to filter, thanks to its round...
Avis sur ND25FA-4
Je me demandais bien ce que je pouvais avoir comme rendu avec ce tweeter à moins de 13€.
Après l'avoir associé avec une paire de Dayton Audio ND91-4, ce petit tweeter va au delà de ce que je pouvais attendre. Finesse de l'aigu, linéarité en fréquence dans l'axe et hors axe, jamais agressif même à fort niveau.
Un excellent choix pour vos petits projets d'enceintes 2 voies. Filtré pour ma part à 3.2kHz en 3ème ordre à -3dB, le résultat est au rendez-vous.
N'hésitez pas, très bon rapport qualité prix.
Julien M.
Avis sur ND91-4
Dayton Audio propose un driver de très bonne fabrication, capable de délivrer une basse homogène et un très beau médium, jusqu'à 3kHz environs. Vous y retrouverez un timbre assez typique dû à la membrane en aluminium par rapport à d'autres matériaux, cela dit cela reste agréable à l'écoute.
Proposé comme large bande, ce dernier ne me paraît pas si approprié que cela pour cet usage, car passé 9kHz, la réponse en fréquence chute de près 10dB jusqu'à 14kHz pour après remonter de 5dB et rechuter vers les 16kHz.
J'ai effectué plusieurs essais avec un filtre RC afin de faire baisser la courbe d'impédance dans la zone des 10-16kHz. Un léger mieux est apparu dans la mesure et l'écoute sans que cela soit très convaincant.
Pour qui recherche une certaine clarté en utilisation full range, prévoir de l'associer avec un petit tweeter de la même marque, dans la série ND25 par exemple, qui donne un résultat très convenable.
Leur préférer un filtre passe bas et passe haut d'ordre impaire, 1 ou 3 donnent de bons résultats, à affiner selon les goûts et les oreilles de tout un chacun!
Michel D.
Livraison rapide. produit conforme.
Thierry B.
Très efficace
Utilisé pour diffuser Qobuz sur ampli HK et enceintes BW - impressionné par le rendu sonore en utilisant l Aptx HD ce en couplant un tel huawey (les deux reposent sur des processeurs Qualcomm)
Alexandre S.
Très bien !
Relie un minidsp shd à un master 10, j’ ai opté pour cette paire de câbles, viablue ne m’ ayant jamais déçu, le gain comparé à la connexion RCA (furutech OCC) est gigantesque, je ne peux pas comparer cette paire à une autre, mais je ne peux que conseiller d’ utiliser ces XLR avec ces 2 appareils.
Antonio S.
Buen DAC
Después de unos días probándolo, quiero decir, que en con mis componentes musicales, mis altavoces y en la sala donde lo escucho; suena muy bien: sonido transparente, nítido, gran amplitud en el estéreo; muy contento por la compra. Lo tengo unido, por óptico, a un reproductor Cd Onkyo, por cable coaxial al reproductor Node 2i y de vez en cuando por USB a un ordenador portátil. En todos ellos la reproducción es muy buena. (para mi y mi sala y equipo).
La transsación con AUDOPHONICS, también ha sido muy buena. Gracias
Erwan C.
BT60W étonnant pour sa taille et son prix !
A l'origine, je cherchais à un ampli sous 12 v pour pour constituer une petite chaine autonome.
J'ai été bluffé par la qualité de cet ampli qui, testé sur des bonnes enceintes de salon, n'a presque pas montré ses limites !!
j'en reprend un autre pour remplacer une mini chaine HS.
Jean-Marie G.
Pourquoi dépenser plus ?
J'en ai acheté d'abord un, puis deux autres reçu cette semaine. Le commentaire pourrait presque s'arrêter là !
Mais bon d'abord explication du titre: on peut dépenser plus par passion bien sûr, mais la règle et que pour avoir sensiblement mieux il faut mettre dix fois le prix, c'est loi logarythmique concernant le rapport gain qualitatif/prix ou effort consenti...car on peut aussi faire soi-même si on a les compétences bien sûr.
Pourquoi j'en ai 3 de ces amplis ? Pour de la bi-amplification active, le troisième en remplacement au cas où.
L'ampli aigu est sur des moteurs 1.4 pouce NSD1480n, aucun souci de souffle il n'y en a quasiment pas l'oreille collée ! Les timbres sont beaux, c'est vraiment bon, grosse image stéréo.
J'avais demandé un bon emballage à cause du poids de deux amplis dans un colis, ça été le cas, merci.
Et encore merci pour cette qualité de son à ce prix.
Francois C.
Traitement commande et livraison très rapide. Produit parfait, fonctionnement avec télécommande One for All URC7955, compatibilité totale (STB, code 3455) seule particularité le bouton power n'est pas actif, celui qui assure cette fonction est LIST.
Alex B.
Very high quality!
This wall bracket mount for Furutech FI-E30 fits perfectly and is of very high quality. I prefer Black version, but sadly those weren't in stock anymore. Silver one looks great too. Have pictures but can't send them here. Would buy again for sure!
tim c.
Neotech Silver
Was bought to build some phono cables from my Systemdek turntable and also make some interconnects between phono stage and amp, truly outstanding results, recommended.
tim c.
Neotech solid core
Was used for Avr system, excellent cable for center speaker, usual Neotech characteristics, a natural relaxed sound but packing a punch when needed, seems to be a bit of a hidden gem in the world of top end speaker cables
tim c.
Neotech
Very solid plugs, NEOTECH NEI-2001 Interconnect Cable UP-OCC Silver cable fits nicely inside which some plugs can't manage
tim c.
Top notch
Very well made, solid connection
