jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
Kieron R.
Great project Ground Pole.
I purchased & used this ground pole when fitting RCA jack sockets to a Thorens TD-160 mkII. It is very good quality & super conductive. Will definitely accommodate a substantial ground lead to be fitted to the turntable. Highly recommend for project work. Great service as usual through Audiophonics.
Kieron R.
Super Valve
I recently changed out the stock valves on my Douk Audio phono preamp with the GE5654 and still can't believe the difference its made. The stock valves were 6A2 and although they worked ok they just didn't bring any life to the music.
The preamp is a Douk Audio T3 ( budget pre amp ) and I am using a Shure Hi-Trac cartridge on a Thorens TD-160 mkII.
The GE5654 added a whole new dimension to the sound stage with vocal clarity, highs & midrange improving drastically. Instruments are much more defined and overall the playback is much more realistic and livelier.
They have being burning in now for about 40hrs and are still improving.
They have turned a budget preamp into something much more resembling an expensive preamp. Not quite as good as the Schiit Mani but definitely on the same racecourse. Very definitely a worthwhile change. Great service also from Audiophonics who always ship promptly.
Pierre-Yves C.
Bon cable, souple et bien fini
Pour ce qui est de la qualité mécanique / physique, je suis très satisfait. Il est étonnamment souple pour un tel diamètre. Attention à bien choisir vos connecteurs, j'ai un peu galèré avec les miens (1,5 mm de marge seulement, sans compter la gaine thermo). Pour ce qui est de la qualité "sonore", Je ne suis pas "câblo-septique" mais quand il s'agit d'un câble secteur, je sais un peu dubitatif quant aux effets qu'on lui prétend. Pour l'instant je n'ai pas encore testé assidûment mais quand on sait ce que l'on a derrière nos murs, j'ai du mal de comprendre comment 1m de câble peut faire de la magie. Je suis à l'essai pour le moment.
Pierre-Yves C.
Conforme et sans surprise
Première fois que j'achète ce type de produit et c'était exactement ce à quoi je m'attendais. La gaine semble de bonne qualité, à voir avec le temps. Pour le moment, A+ :-)
Pierre-Yves C.
Bon embout
A rempli sa mission avec brio (pas le tube des années 90's hein !). Il se coupe très bien (j'avais une bonne pince aussi...) et n'a pas perdu son revêtement lors du sertissage. Que dire de plus sur un embout...
Pierre-Yves C.
Prévoir de la marge pour le diamètre du câble
Semble très solide et bien fini. Toutefois, choisissez un diamètre de câble avec suffisamment de marge au niveau diamètre. Le ELECAUDIO CS-331B que j'ai choisi rentre au chausse pied (j'ai savonné la gaine...). Je ne suis pas sûr de pouvoir juger d'un quelconque ressenti spécifique, qu'il soit positif ou négatif, sur le rendu sonore. Je ferai un test plus tard en revenant au cordon type "appareil à raclette", mais le test sera d'autant plus biaisé qu'il dépendra du câble et du connecteur C15 également...
Mario S.
Good product
Solid connector for fair price.
Mario S.
Good product
Excellente interface usb!
Je l'utilise depuis quelque temps déjà et je confirme l'excellente musicalité de cette Matrix élément H! La scène sonore est large,
profonde,précise et aérée.Les timbres sont nuancés et naturels.
Pas de crispation mais une restitution fine,plutôt douce et sans
coloration excessive. La musique s'écoule avec fluidité,un certain
raffinement,tout en procurant une agréable sensation de réalisme
et de naturel. C'est donc un excellent produit!
Patrick
Alexandre S.
Possédant un drive Audiolab raccordé à un Naim Superuniti, j’ai essayé plusieurs raccordements avec différents câbles (optique, coax...), mais systématiquement le son était trop « montant » et du coup fatiguant. Je regardais pour changer mon drive par un lecteur cd plus doux et je me suis dis: pour 35 euros, je vais essayer ce câble quand même, pour ne pas mourir idiot. Et bien dis donc... il a tout ré-équilibré! Oui, il semble moins détaillé que ma liaison optique, mais bien bien cohérent sur l’ensemble. Les dureté dans les aiguës ont disparues, en gardant tous les détails des enregistrements, mon drive me parait désormais formidable. C’est un excellent câble pour le prix, il ne met rien en avant et est très équilibré. A tester absolument!
Marcin W.
Great sound!
SUperb sound, no issues with connectivity, tidal connect
Pascal M.
Ein sehr gutes und schönes Kabel. Top verarbeitet super Qualität. Der Klang meines Volumio Primo hat sich auch verbessert.
Super Leistung von Audiophonics besten Dank an das Team.
Frederic H.
Parfait pour du 2.5mm2
Pour moi , ce connecteur a un excellent rapport qualité/prix
Le câble est bien serré , on peut aller jusqu' a 3 mm2 sans soucis
La prise n'est pas lourde et pas encombrante , elle s'insère fermement . D'ailleurs les fabricants de câble l'utilise très souvent :
J'ai un Mélodika et un MPC qui ont la même prise !
Très apprécié
Suite à mon 1er avis, les 12au7wa TAD sont meilleurs, je suis resté dessus.
J'ai beaucoup utilisé le HE-6 dessus, n'écoutant pas à des niveaux sonores très élevés.
Essai d'un HD800s c'est fantastique. Aucun autre ampli chez moi n'arrive à le faire s'exprimer comme ce xDuoo! ce casque est capable du meilleur comme du pire selon l'ampli.
Volkan A.
Best price
Just add it to your order. You know you need it
Volkan A.
RASPBERRY PI 4 MODEL B RAM 2Gb Micro HDMI Ethernet Gigabit WiFi Bluetooth 5.0 4x USB 1.5GHz The Raspberry Pi 4 Model B is the latest product in the SBC Raspberry Pi range. It offers an unprecedented increase in processor power, multimedia performance, memory and...
Best price
Fast and communicative service with approachable product.
Volkan A.
Easy
Easy to use with a wonderful and clever display. Totally recommend it
Volkan A.
AUDIOPHONICS COBALT Banana Speaker Cable OFC Copper Gold Plated 2x4mm² 3m (Pair) The Audiophonics Cobalt speaker cable has been designed and assembled in our workshops to offer a high-performance product at an affordable price. It thus integrates a Elbac...
Amazing
Heavy weight with a good structure. More than expected
Patrick D.
filtre audio
Excellent POUR LES BOOMERS SONO OU HIFI et donnent d'excellents résultats je recommande ...
michel M.
michel M.
michel M.
Paul L.
Premier essai très satisfaisant
Je commence dans la mesure de ma pièce après un déménagement. J'avais déjà un microphone mais pas aussi adapté à la prise de mesure. L'utilisation avec REW est parfaitement satisfaisante.
Pascal H.
Très beau câble
Très beau câble d'un diamètre qui donne confiance et des connecteurs premium. EN plus il est fabriqué en France.
Je ne suis pas capable de vous confirmer que j'entends la différence sur mon système hifi de bon niveau. Mais il ne perturbe plus le décodeur TV sur le même switch.
Pascal H.
Très beau cable
Très beau câble de bon diamètre et avec des connecteurs qui font premium.
Difficile de dire que j'ai perçu la différence pour l'écoute musique démat mais j'avais un pb d'images qui se figeaient avec mon décodeur TV branché sur le switch avec les appareils hifi. Ce cable en amont du switch a fait disparaitre le pb. Ce que j'esperais. Super !
dominique M.
Snap-Fit GX16 Plug 10 Pin Silver Plated Copper 200V 4A Ø7.5mm This Aviation GX16 type connector offers you the possibility to create cables whose connections will be particularly robust and resistant. They are suitable for all types of...
Très bon connecteur au niveau réalisation et solide
dominique M.
bon câble
fait bien ce que l'on lui demande
dominique M.
boitier bien réalisé
Bon déclencheur 12V boitier sérieux .
dominique M.
bon câble
Parfait pour mon utilisation
Marcel T.
Mooie degelijke pluggen en klinkt in combinatie met m'n van damme silver series lo-cap 55 erg mooi
daniel n.
ELECTRO HARMONIX EL34 Amplification Tubes (Matched Quad) The Electro Harmonix EL34 tubes contribute to offering a sound reproduction of great musicality and richness. These are perfect models to replace unsuccessful units on vintage...
Expédition rapide, son homogène et transparent Je suis satisfait . Merci
Vyacheslav K.
MiniDSP UMIK-1
Many thanks to all the store staff for a very good job. The order was shipped very quickly. Delivery to Russia took only a week.
René I.
Omnimic V2
Très bon produit, mesures faciles avec le CD test.
Par contre :
- la notice mériterait d'être traduite en français
- l'explication concernant le calage temporelle des HP est un peu courte... car trop idéalisée par rapport à la vraie vie.
- les explications indiquant comment et surtout pourquoi une carte son additionnelle serait utile manquent cruellement.
Sinon l'un dans l'autre fait très bien le job.
Max W.
Excellent!
Très satisfait de cet article. Il est plus petit qu'on ne le pense mais semble très bien fait. Mon téléphone Android l'a reconnu immédiatement et je peux maintenant écouter mes fichiers audio HiRes sans aucun problème.
Je le recommande vivement !
Amaury C.
Fait le job !
Cette interface m'a permis de récupérer le signal DSD des SACD sur la sortie HDMI 2 de mon Oppo 105 pour l'envoyer sur un Gustard DAC-X16. Il en est de même du signal PCM 16 bits/44.1 kHz des CD. Liaison donc en HDMI (avec du 1.4 ou même du 1.3 ça fonctionne sans souci) entre l'Oppo et l'interface, puis un autre câble HDMI entre la sortie HDMI/I2S de l'interface et l'entrée HDMI/I2S du Gustard.
Alors, attention, car au début cela ne fonctionnait pas. J'avais en effet branché une alimentation secteur sur cette interface (4,5 V / 600 mA) et la diode rouge de mise sous tension s'était allumée normalement. Cependant, une fois les câbles HDMI branchés et un SACD mis en lecture je n'avais aucun signal. J'ai fini par me dire que ça ne marche pas et j'ai donc commencé par débrancher l'alimentation. J'ai alors constaté que la diode rouge restait allumée. En éteignant l'Oppo 105 elle s'éteignait aussi. Ce qui signifie que l'interface est alimentée via le câble HDMI et que l'alimentation secteur n'est pas nécessaire dans ce cas de figure. J'ai donc refait jouer un SACD et là j'ai vu s'afficher sur l'écran du Gustard "DSD 2.82 Mhz" et la musique bien sûr dans les HP. En espérant que ces précisions vous seront utiles. En tout cas, le résultat d'écoute est nettement meilleurs aussi pour la lecture des CD via l'HDMI/I2S plutôt qu'en coax, plus équilibré et "analogique" dans le haut-médium/aigu, basses plus profondes.
Benjamin D.
IFI AUDIO HIP DAC Portable Balanced Headphone DAC Amplifier 32bit 384kHz DSD256 MQA iFi Audio presents the HIP DAC, a DAC combo and nomadic symmetrical headphone amplifier, both compact to accompany you in all your travels or on your desk, but also benefiting...
un réel gain de qualité !
A la base j'écoutais de la musique avec un Xiaomi redmi note 7 ou un macbook air fin 2020, le son était était déjà bon avec mais ça manquait de présence, j'utilise le casque Focal Elégia, je souhaitais avoir un ampli-dac à moins de 200 euros de qualité, il y a beaucoup plus de présence avec cet ampli-dac, bien meilleur spacialisation, plus de graves , le son est moins acide, pour le moment je ne l'ai pas réussi à l'utilisé sur mon mac, je vais peut-être trouvé une solution d'ici là mais je suis satisfait de cet achat.
eric b.
ARYLIC VOLUME KNOB BOARD Volume Control Module This Arylic Volume Knob Board module is designed as an extension of other Arylic DIY modules. It allows to have a volume control knob. Used with an Arylic Up2Stream Mini V3...
nécessaire pour switcher d'une entrée Bluetooth , wifi ou dac d'un arylic , mais pas terrible au niveau réactivité quand on veut changer le volume
eric b.
MONACOR SMC-1 Stereo to Dual Mono Adapter Converter RCA This small converter takes a stereo audio signal as input and outputs a dual mono signal. Interconnections are made on RCA connectors. The input impedance of the converter is 4.7Ω.
un peu cher pour ce que ça fait , mais en même temps c'est plus propre que 3 résistances qui se promènent... On perd un peu de niveau
, mais à priori pas de dégradation du signal.
eric b.
très propre pour alimenter un module Bluetooth ou wifi type arylic
eric b.
ARYLIC UP2STREAM MINI V3 Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device. Practical, it allows you to limit...
très simple , plein de sorties possibles , numérique et analogiques.
eric b.
ARYLIC DAC BOARD ES9023 DAC Module I2S RCA 24bit 192kHz for Up2Stream V3 This tiny Arylic DAC Board digital-to-analog conversion module takes an I2S signal input and outputs it to stereo RCA. It is based on an ESS ES9023 chip, supporting PCM streams...
joli son
Jean Philippe L.
Nice product
Comparing the price it is a very good cable, nice definition comparing with expensive cable its worth to buy.
Jean Philippe L.
Very nice product
Well if you think for the price is worth and good definition overall, silver and copper combination very nice!
Mark G.
Well worth the investment
Definitely an improvement with my Chord Qutest when using with a linear power supply over the power from my iMac. Smoother mids & highs and no hash or artefacts. The Qutest requires constant 5V power to its USB port.
If your DAC only requires power for the initial USB handshake like my Topping D70, you can use any outside power source to make the connection then disconnect the power to this adapter after startup and leave the adapter in place, it will then only get data from your computer or other source.
Highly recommended!
Associées à de la soudure mundorff a 10% d’argent ces fiches sont sans concurrence.
Une petite gaine thermo pour renforcer et embellir le tout et vous avez un ensemble au RQP imbattable.
Je recommande sans limite
Bien mais
C’est vrai que pour le prix vous avez un bon câble qui fait le job.
Maintenant si on le compare avec des câbles haut de gamme, il ne peut pas rivaliser.
Naïvement, je me suis fié aux commentaires élogieux qui mettait ce câble sur un piédestal, écrasant la concurrence à plat de couture et j’ai eu tort.
Après un rodage de 30 heures il ne sait pas bonifié.
Je l’utilise en mono câblage avec des bananes cuivre argent comme recommandé dans les avis utilisateurs.
Il est agressif dans les aigus
Un médium pâlichon
Des basses correctes. sans plus.
Bref, Il ne tient pas la comparaison avec des câbles à 10/15€ le ml voir moins cher acheté sur ce site.
Je vais attendre encore 20/30 heures pour voir si ils se libèrent, mais j’ai un gros doute.
Par contre en modulation les câbles Canare sont excellent.
anael g.
DAYTON AUDIO PS220-8 Speaker Driver Full Range Paper 40W 8 Ohm 96dB 40Hz - 25kHz Ø22cm The Fountek PS220 full-range loudspeaker has the particularity of producing both bass and articulate, balanced midrange, as well as extended highs. The full-range concept...
belle surprise
achetai pour une 2 vois DIY se dayton ps 220 et une alternative intéressante à une compression 1.4 pouce !
le but étant de concevoir une enceintes simple en 2 vois avec le moins de composant possible .
grave 38 cm 18 sound
medium & haute fréquences dayton audio ps 220
coupure 380 / 12 db grave 6 DB large bande .
volume grave 160 litres bass reflex volume ps 220 25 litres clos .
autre large bande en ma possessions ( pour comparé au dayton ps 220 )
fostex fe 206 médium plus chaleureux mai plus compliquer à mètre en ouvre sonorité asses marquer .
supravox 215 version sans bicone !! médium bien en place sonorité naturel nécessite un tweeter ou un moteur 1 pouce !!
dayton audio ps 220 médium naturel bien en places un vrais large bande capable de travailler sans tweeter !! je le mesure jusque à 20 000 hz chez moi !! je le qualifierai de polyvalent même si je considère qu'il et presque indispensable de rajouter un renfort de grave comme moi avec un 38 cm à haut rendement pour relevé la coube en bas . ou l'utiliser tout seul avec un filtre bouchon et indispensable pour atténuer la monter de la courbe ! pour ma part je préfère l'option n 1 avec un 38 cm .
bref pour conclure se large bande et une belle surprise sa construction et sérieuse et de qualité la mesure et vraiment propre et il à rien à envier à un 215 ou fe 206 de fostex !!
le medium et propre en place rien et mie en avant ont peu se passer sans problème de tweeter au final se large bande me permet de construire une enceintes simple et vraiment audiophile à haut rendement avec un prix contenue !!
Philippe S.
Bluffant !
Très satisfait de mon achat ; utilisé avec un Nad c316bee et des enceintes Cabasse Chaloupe et transport cd avec sortie coax sur le sud et un PC en Linux audiophile
Les oreilles ouvertes
Sans soucis.
Apparemment c'est moi qui ai eu le dernier bout !
y'en a plus pour le moment et ça se comprend. Je ne sais pas si ça améliore le son ; en tout cas ça respecte totalement. Il faut bien 290° pour souder et la soudure est mate... comme l'argent ! J'ai soudé en XLR un SommerCable ABEDO et j'ai bien le résultat promis, clarté Détails et douceur. Pour moi c'est la meilleure soudure pour le son.
Fred F.
Comme toujours, merci à M. David Aubert pour ses précieux conseils : cet ampli remplit toutes les cases de ce que je recherchais. Fonctionnalités, son, tout est bon dans ce petit (vraiment petit) appareil pour un rapport qualité/prix extraordinaire.
