David m.
une super prise hifi
Jochen M.
Tout n'est pas parfait
Richard M.
Customers reviews - There are 19552 reviews.
Laurent L.
Belle amélioration générale
Achetée vu les avis très positifs et parce que chaque achat Furutech à apporté une amélioration très nette à mon système.
Ici, j'ai été vraiment étonné d'entendre une amélioration si importante, profondeur et précision de la scène sonore, timbres.
J’étais sceptique, comme pour les câbles, mais je ne reviendrais pas en arrière, tant pis pour le grincheux du coin....
Attention, à ce niveau, la chaîne doit être très transparente, pas sur qu'on entende quelquechose sur des Triangle achetées chez carrouf.
Pour info, j'ai un pass labs x0, un ML-3 et des Apogée Caliper refaite.
Merci à Audiophonics pour la rapidité et la qualité des envois.
Laurent.
SA R.
a solid choice
If you have an active subwoofer, the best thing you can do is to replace the stock interconnect cable. For bass, accurate and clean signal transmission is critical, as lower frequencies are reflected and multiplied within the room; therefore any defects, impurities or losses in the transmitted signal can easily result in uncontrolled and muffled sound, and the longer distance of cable that is common in this case, is not helping.
When I purchased my subwoofer (paradigm servo 15), almost immediately, I changed interconnect from stock, with a simple (lets say level 1 cable) upgrade (under half the price of this), with the additional shielding, I was really impressed and satisfied, so I did not prioritize this upgrade. I purchased this interconnect as simple level upgrade, without checking reviews and doing deep research, as I only anticipated small improvements from my already shielded cable; boy I was wrong, I cannot in the life of me believe the transformation - mostly because now the link with my speakers (bw 603s2) is even more fluid and the bass way more natural, as if coming from the main speakers, rather than the sub! (and the cable not even burned-in yet)! I think that the increased accuracy and control was indeed needed and the final result impressive.
I have no benchmark in the price range, nor knowledge from reviews to share any comparisons from my findings. All I can say is, that it works great for me and definitely I feel that it sounds the price (or higher) - as noted in the title I feel it is a solid choice for the price and that I believe you cannot go wrong by choosing this cable for your sub.
As it is with all hi-fi equipment and accessories, spending and return in listening experience is always the case, but it is almost never a proportional relationship. From my experience on this item, I recommend that, if you haven't already, revisit your subwoofer interconnect; and if in doubt, buy this cable, I don't believe that you will regret it.
Michel P.
Réfection
Excellent HP pour remplacement de caisson de basse
Serge V.
efficace et prix justifié par sa qualité
Excellent produit : placage or de bonne qualité car il ne s’écaille pas comme sur certaines autres marques asiatiques, les pas de visse sont sans jeux, visses sans tête en acier de bonne qualité. Bref un produit parfaitement recommandable. Je les ai montées sur du câble ELECAUDIO SC-221SPOFC dont chaque brin a une section de 0.12mm. Toutefois, pour visser les câbles, il faut avoir une clé Allen (6 pans) type 82H de 1.3mm, disponible au rayon bricolage ou chez les marchands de cigarettes électroniques ou de modélisme et chez votre voisin « Vapoteur », car elle fait partie du nécessaire de montage des réservoirs DTA et RDTA.
Bon DIY...
Gregory K.
Good opa
Hello,
I bought it and tested it on the Fostex Hp A3.
It was better than the chip I used.
The sound stays warm, more midrange and defined bass, I found it better than the Au 627, it was more fun to play and the resolution and detail was excellent.
I found it better than the new generation Vivid models, because it is simply more authentic in the reproduction. compared to the Vivid the Red Opa was too bright in the treble.
Definitely worth it if you have the opportunity to replace the Opa.
Gregory K.
Good
Hello,
The sound stays warm, more midrange and defined bass.
All in all quite good, you have to pay attention to the crescent when you install it.
There is also one painted on the board.
Pål K.
Fast shipment
6 days after i ordered there was a phone call from TNT Express. Very happy with everything!
Jordi M.
Très bon product
Service excellent. et meilleur rapport qualité / prix.
Hubert D.
Au TOP
Doré et sans bavure, correspond bien à la description.
Déjà en application sur mon DAC
A recommander
HD
István P.
Almost perfect
The amplifier is great, but the power supply is very loud. At first I thought there was a problem with the earthing. I isolated it, but the fault did not go away. I ordered an another power supply, I hope the new one will be good! The Audiophonics support team was helpfully and kind! Thank you!
Louis C.
Stratos pour phono
C'est le deuxième montage liaison platine phono que je réalise avec ce câble. Silencieux, parfait du moins dans cette configuration de montage où il redonne un peu de chaleur à certains vinyles qui pourraient en manquer.
jean jacques m.
très bon produit.Excellent couplé avec un smsl sanscrit.
et ampli classe d.
Sonorité transparente.
jean jacques m.
jean jacques m.
jean jacques m.
Tomas C.
Fast and good
Sparkos ss3602 gave a better sound in my dac and the delivery was smooth and fast.
Patrick R.
Balanced Male TRRS Jack 2.5mm to Single-Ended Female Jack 3.5mm Adapter This adapter consists of a balanced 2.5mm TRRS male jack and a single-ended 3.5mm female jack. The 2.5mm jack therefore has 4 poles, particularly practical for connection to...
Ce n'est pas un avis mais une remarque sur l'avis précédent
J'ai écrit à iBasso pour leur poser la question à propos du dac DC01 (que je possède aussi). Leur réponse: "The DC01 is balanced output. You can't use it with a single ended headphone. It would short the DC01."
Ce qui a du sens, électriquement parlant, coupler les sorties d'un ampli casque symétrique pour en faire une sortie asymétrique, ne peut pas fonctionner correctement.
JEAN PIERRE D.
Bien pour le prix
Fonctionne parfaitement, borniers à vis fragile mais accessible pour être ressoudé. Couverture des fréquences incomplète : chute rapidement en dessous de 80 Hz
Guy P.
Utilisé pour créer des câbles reliant des appareils Heed. Malgré que je ne sois pas un pro de la soudure, le résultat est nickel.
István B.
István B.
István B.
István B.
Guy P.
Finition impeccable
J'ai acheté ces fiches banane pour connecter ensemble des enceintes et un sub REL sur les sorties haut-parleur d'un ampli Naim. Les sorties haut-parleur de l'ampli Naim ne permettent pas de mettre des fiches de type fourche ou du câble nu. Utiliser ce type de fiche est idéal car il permet de loger 2 câbles d'origines différentes sur une même sortie. De plus la finition est vraiment superbe et le système de serrage garantie une tenue sans faille même aves des câble un peu lourds. Un vrai plus par rapport aux fiches de même type utilisées précédemment, mais d'un prix nettement inférieur. Rapport qualité-prix au top.
laurent S.
RQP imbattable
Commande de L'IEC ainsi que de la Schuko pour réalisation d'un câble reliant le secteur à ma barrette. Les prises sont d'une qualité incroyable, la qualité des fiches, des serrages ainsi que des finitions n'a pas d'égal au tarif proposé. Et en plus elles m'ont apporté un surcroît de définition de la musique et du poids dans les premières octaves. (qualité des conducteurs ?) Le leader des connectiques secteur mais moins bien pour plus cher. Pour ma part c'est tout vu !
OPA1612 Dual OPA DIP8 (Unit) The TI OPA1612 dual operational amplifier benefits from excellent technical characteristics, allowing very good electrical and audio performance. It ensures a very low noise...
OPA1612
Super OP amps. J'ai tout testé de l OPA1612, OPA627, Genuine NE5532, OPA1611, OPA1622, Burson V5i, MC33272 etc etc
Avec les OPA1656 = la crème de la crème, les OPA1612 restent mes préférés. Ils apportent du micro détails, améliorent grandement la scène sonore, et subliment le hut du spectre.
Ma config :
Ampli TPA3255 by DrMordor.
OPA1612
PSU LLC SMPS 500W
GAUTIER P.
Fonctionne très bien
Utiliser avec un ampli de puissance Vincent à tubes. Fonctionne avec un câble stéréo
Jérôme F.
Jérôme F.
Superbe DAC
Je l'ai pris pour servir de DAC via RJ54 et surtout pour améliorer ma platine CD en sortant en coaxial.
L'amélioration est nette au niveau de la spatialisation et aussi du rendu de grave !
Cerise sur le gâteau, les web radio via moode et je commence à mettre les mains de le cambouis avec DietPi qui offre plein de possibilités.
Aleksandr U.
That's a higher level of sound reproduction...
Few weeks ago received R-8 after a year of looking at it on audiophonics web page. I noticed that there is sufficient difference with DA-8 modules based hand made DAC after several minutes of listening it, but what happened after three weeks of burn in process is hard to put into words. The sound has just came out from the speakers and all the instruments took their own places how they say =)
I have never ever heard such a spacious sound stage. All the sounds are in the air. They don't link to each other.
All this was happening after I switch the input to ACSS on my Audio-gd Master 10 amp. In RCA mode the sound stage was totally flat like there is no difference what type of DAC you're listening.
Master 10 I've got a almost a year ago. I left my feedback under it.
R-8 and Master 10 will reveal all what is hiding behind regular multi bit DACs.
No really... summarizing - you will never get anything better for this money. 4k Eur for the set but it worth much more.
Audio-GD team understand what the sound should be.
Yves A.
Excellent résultat
J'en ai assemblé 4 pour faire un DAC 8 canaux I2S et j'en suis très satisfait, surtout avec l'ampli op DEXA DISCRETE AUDIO OPAMP...
(Dommage qu'il ne soit plus en stock)
Largement au dessous du lot
J'avais envie de m'offrir un set casque et ampli, en complement de ma chaine.
Sur les bons conseils de David Aubert, j'ai acheté ce casque, ainsi qu'un ampli casque AUDIO GD AUDIO-GD NFB-1AMP.
Mariage Heureux.
La finition de ce casque est époustouflante, surtout pour ce prix.
Il est très confortable et ne chauffe pas les oreilles comme on peut lire parfois...c'est comique.
A la 1ere écoute, il est vrai que ce casque a trop de basses, mais j'étais averti qu'il fallait attendre un bon rodage.
Je l'ai laissé fonctionner jour et nuit pendant une semaine.
A présent, mais quelle merveille, je prends autant de plaisir qu'a l'écoute de mes enceintes Tannoy + Tube....avec en plus le coté immersif propre à l'écoute au casque.
Il y tout, des graves et sub grave , des aigus et médiums qui filent très haut....le tout très proprement et franchement même à un volume proche du déraisonnable, il encaisse.
J'ai eu en prêt un Sennheiser hd 800 (1200€)...et franchement je ne l'échangerai pas contre ce MEZE.
Systeme d'ecoute
Qobuz + Audirvana
Interface numérique AUDIO GD DI20
Dac AUDIO GD R8
Ampli casque AUDIO-GD NFB-1AMP
Yannick A.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
lampe préampli
reçu très rapidement pour upgrader un préampli à lampe, avec une gamme militaire de très bonne qualité
Laurent t.
Simple et efficace
Je suis bluffé par la qualité de restitution - utilisé en BT avec des cables Atohm zef et des enceintes Triangle Comète EX : vraiment un achat sans regret.
Seuls bémols : les réglages ne sont pas mis en mémoire (mais la simplicité est telle que leur restauration à l'allumage est très rapide) et la connectique enceintes un peu sous-dimensionnée pour connecter les câbles Atohm de 2,5mm2.
Mais quel son !
Teddy T.
CYK Stereo Cable XLR-3 Female / RCA Male Gold plated 24K OFC Copper 2m This affordable RCA male to XLR female CYK cable is ideal for ensuring good conductivity to your signal with its OFC copper conductor.
Bonne qualité !
Pour le prix rien à dire, c'est un très bon cable, inutile d'acheter plus chère il fait parfaitement son boulot.
Teddy T.
Simple efficace !
Première impression à l'écoute, très doux adapter je dirais pour un casque de 120 ohms max, le volume est amplement suffisant, on sent l'ampli class A.
Je recommande !
Teddy T.
Bluffant pour le prix
Je cherchais un ampli casque capable de driver mon sennheiser hd 660s pour un prix "normal" je suis entièrement satisfait au première note on sent que l'ampli en a dans le ventre, des basses propre sans manque particulier sur le haut spectre, je l'ai brancher sur mon dac Smsl SU-8 V2, très bon je recommande !
Antoine S.
Perfectissime !!!
Extérieurement, il a un look sobre, et une connectique de qualité.
Dés la 1ère écoute on constate que la séparation des canaux est parfaite. La scène sonore est fluide, aérée, ample, riche en détails, et dune grande précision. L'image 3D et la dynamique sont parfaites.
Il est taillé pour l'écoute haute résolution, aucune fatigue à l'écoute, sa justesse procure un réel plaisir à l'écoute des titres, et les musiciens et chanteurs semblent prendre place dans le salon.
Le plaisir qu'il rend vaut bien plus que son prix.
Olivier J.
Alim compacte de qualité
Très compacte et légère, tension de sortie réglable. Dommage que les vis courtes ne soient pas fournies avec.
Olivier J.
Beau et fonctionnel
Bouton en plastique mais de bonne facture, éclairage doux.
Olivier J.
Francis P.
DIY Case 100% Aluminium 430x330x80mm This large 100% Aluminium DIY box with rounded corners over a 35mm radius will allow you to integrate the components of an amplifier, pre-amplifier, DAC, or any other audio...
Magnifique boitier, très, très massif.
Les 4 côtés font 8mm d'épaisseur, donc attention aux usinages.
Un potentiomètre normal, par exemple, ne peut pas être vissé le filetage est trop court.
Pour les bons bricoleurs, super qualité.
Bruno C.
Utilisé pour alimenter des Cabasse Egea3 + caisson de base avec un ampli Pié Audio ms380se, le résultat est saisissant, les basses sont beaucoup plus sèches et les médiums plus précis.
Je recommande ce câble avec un excellent rapport qualité/ prix.
Bruno C.
Belle qualité d'outil pour un prix mini
Bruno C.
Livraison rapide, produit correspondant parfaitement à lin attente.
Je recommande.
Phillip F.
upgrading to 5-star
I bought one of these for my stereo rig. It performs beautifully and reliably.
I like it so much that I've ordered 2 more to update my 4.1 surround system to an efficient, powerful class D setup.
Other class D modules from Hypex and Purifi might measure better but I doubt that I could hear the difference.
Jiri S.
Jiri Sobas
First impressions are very positive. Listening to Beyerdynamic headphones is really great. Use as a preamplifier for a power amplifier and speakers is also very good. I recommend!
David G.
meme avis que Valery H.
Meme avis que Valery H ! pret a le revendre !
je vais essayer les settings recommendes ici et voir si mon jusgement change mais de base il n'y a rien de bien sauf si usage avec un caisson de basse ....
Bonjour, nous pensons que le problème est ailleurs ...
Le produit en lui même est exceptionnellement bon dans cette gamme de prix :
https://www.audiosciencereview.com/forum/index.php?threads/loxjie-a30-amplifier-review.17547/
Vincent L.
SOMMERCABLE SINUS Single-ended Modulation Cable 3x0,35mm² Ø6mm The Sommercable Sinus can also be used in a home HiFi system or for Car Audio. This one enjoys an excellent reputation from connoisseurs for its unbeatable quality/price ratio....
Un peu rigide
Utilisé pour recabler des platines vinyles, un peu rigide mais d'excellente qualité !
Hervé P.
Ampli fonctionnel
Bonjour.
Module monté dans un caisson de basses JVC à la place de l'ampli d'origine, alimenté par une alimentation d'ordinateur portable de 110W réglée sur 18V. Débite sur 3 haut-parleurs de 4 ohms.
Le son est très bon, très “propre”, assez puissant pour mes synthés !
Cordialement.
Pierre L.
pratique pour relier au reste du réseau
Déjà détenteur de plusieurs Audiocats, j'ai renouvelé l'achat car je m'en sers pour mettre tous les équipements non DLNA dans mon réseau musique multiroom basé sur un serveur LMS (Logitech) hébergé sur mon NAS. Le boitier AudioCast permet fort bien de transformer en enceinte connectée DLNA tout appareil pourvu d'une sortie audio.
Pour l'installation en effet on peut passer par le WPS mais dans mon cas il m'a suffit fort simplement de connecter ma tablette au Wifi (hotspot) de l'audiocats pour ensuite indiquer la clé Wifi et laisser l'application tout faire. A noter que pour l'upgrade Firmware, on est guidé et que l'audiocast vocalise (en anglais) les étapes ce qui est rudement pratique pour éviter le trou durant les 2 ou 3 mn de la mise à jour (il y a de mémoire 3 messages vocaux confirmant que ca avance bien). Bref pour le prix c'est très pratique et me permet d'envoyer de la musique ou histoires pour les enfants n'importe où.
jean michel G.
Est-ce un cablage audio ?
Je lis de tres bon retour concernant ce cable.
Amerais savoir si le cablage est fait que pour l'audio ?, a savoir 4 fils au lieu des 8.
Ce produit est basé sur le VIABLUE EP-7S Câble.
Un câble réseau CAT7 8 conducteurs.
Nous n'avons jamais entendu parlé de câble réseau 4 fils et voyons mal comment cela pourrait fonctionner.
