Jochen M.
Tout n'est pas parfait
Richard M.
Bernard g.
Excellente Interface
Customers reviews - There are 19551 reviews.
TECCE V.
Ottimo
TECCE V.
Ottimo
Jose Vicente C.
Good cable
Michel B.
Michel B.
Les plus:
-Montage simple
Les moins:
Michel B.
Très bien !
Les plus:
Les moins:
Michel B.
Les plus:
-Pas cher.
Les moins:
Michel B.
Très bien !
Les plus:
Les moins:
Serdar C.
Fantastic!
I was stuck with my mainboard's soundchip before and I thought that was already good, but the Khadas Tone Board slaps me in the face and showed me what really good sound is. It's like as if an additional layer of detail appeared out of nowhere in the music I normally listen to on a daily basis. I use a DT990 (600 Ohm) with the Schiit Magni Heresy for my listening experiences, the KTB completed my humble setup. If this DAC were a car, it would pass easily as a sleeper.
Serdar C.
Compact goodness!
This small aluminium case is compact, well-machined and not distracting, the way a DAC should be.
However, the screws that came along the generic version of the KTB (also bought from here) don't fit between the case and the board. You can have it "hover" inside, the screw-rings of the RCA ports are sufficient enough to keep the board in place.
I like this product regardless, thanks Audiophonics for the lightning-fast delivery!
pratique
J'ai commandé ces cosses "no name" en même temps que les MUNDORF de même taille et de même prix. J'ai préféré utiliser les premières qui permettent un double serrage alors que les MUNDORF n'en ont qu'un seul ...
Petite pince nécessaire dans tous les cas bien sûr.
Patrice R.
sang c.
very good....
sang c.
GD280 Thermal Paste Syringe 3g
very good.....
sang c.
very good....
Jean-Pierre P.
Serge S.
excellent produit
PATRICK F.
PATRICK F.
PATRICK F.
PATRICK F.
sandy o.
yes it does sound better but?
Jean Pierre G.
Michel E.
Insert de qualité
Robin A.
Fonctionne parfaitement
Circuit très propre, belles soudures, matos de qualité. Le bluetooth fonctionne parfaitement, connexion très rapide.
Par contre manque d'infos sur les watts RMS, c'est la puissance MAX qui est indiquée, donc il faut diviser par 2 en moyenne.
La sortie Sub fait donc en réalité 100W RMS mais sous 2 ohms ! Donc 50W RMS sous 4 ohms. Les deux autres sorties font 50W RMS sous 4 ohms. La puissance est suffisante pour une grosse enceinte nomade.
Attention, la sortie Sub n'est pas filtrée, donc il vaut mieux prévoir un filtre passe-bas pour optimiser les fréquences.
La livraison a été plutôt rapide et le colis bien emballé.
Satisfait de ma commande.
Michel E.
Pointe et contrepointe idéale
Ce système de découplage est parfait sur le rendu sonore en particulier sur de grosses enceintes avec un grave dégraissé clair dynamique. De plus ces pointes permettent de déplacer les enceintes sans efforts et sans risques de rayures. Le prix est justifié.
Philippe R.
Mais...
Produit de bonne qualité, parfait pour mettre sur un appareil qui doit être posé. Pour un appareil un peu lourd (ampli..) qui doit être glissé sur une étagère, les boudins en caoutchouc ne glissent pas et sortent de leur emplacement.
Roberto C.
Fully satisfied
Excellent and fast service, and the quality I expected from an nCore amplifier
Jean-Claude E.
Pourrait mieux faire
Pour une question de vis trop courtes.
En effet les 8 vis 3 mm tête fraisée du capot et du dessous ne prennent que quelques tours sur les écrous noyés et si on serre trop fort, ça foire. J'ai du commander des vis 2 mm plus longues. Dommage, car ce coffret est bien fini.
Christian A.
Attention, le cordon secteur (embase en trèfle) n'est pas livré avec le boitier
Laurent l.
Correction de mon 1er avis (version KIT)
Attention, souffle constant généré par le mini DSP lui même ainsi que du bruit (click et autre fuzz synchronisé en fréquence avec la led de la carte).
Il n'y a pas de solution pour le stopper: Ni une alim de course, ni Les entrées en court circuit (moins pratique pour écouter de la Musique).
Dès que vous insérer ce PROC dans la chaine du son, les souffles & bruits divers sont clairement audibles.
Pour peu que votre système ait un haut rendement...
Le forum MiniDSP a jeté l'éponge. Il s'agit visiblement d'une erreur de conception ou masse analogique
est commune avec la masse numérique.
Comme le dit le forum MINIDSP, une fois que la Musique joue, on entend plus le souffle...
Il semble que seul le procsymétrique soit incriminé. La version non symétrique RCA n'a parait-il pas ce problème. Ma carte date d'il y a 3 ans.
Claudio c.
IBASSO IT01S In-Ear Monitor Dynamic Driver Nanotube Diaphragm Ø10mm 16 Ohm Blue iBasso reinvents its range of mid-range in-ear headphones with the IT01s, specially designed for audiophiles looking for exceptional playback. Using an assembly of high-end...
UN SANS FAUTE BRAVO IBASSO
Cet paire d'intra est vraiment formidable , beau packaging rien ne manque surtout pour son rapport qualité prix imbattable.
Confort design au top et le son tout simplement bon dans tout les registre, c'est du ibasso quoi qui vous offre une qualité sonore audiophile à un bon prix. Je possède des campfire audio qui coutent dans les 800 à 1200 euro et sérieusement cet écouteur n'a pas ç rougir devant eux surtout pour son prix.
Bravo à l"équipe audiophonic pour leur professionnalisme et rapidité dans leur traitement des commandes.
C'est mon deuxième
Câble qui vous révèle le contenu de vos fichiers numériques et révéle la richesse de vos CD ,le mauvais son numérique c'est le jitter,je pense que la qualité des connecteurs est pour beaucoup dans les bons résultats de ce cable qui en diminuant le jitter de la chaine numérique du système en améliore le réalisme de l'écoute .
Jean Luc C.
Beau connecteur
Connecteur qui présente un excellent rapport qualité /prix. Compte tenu de la qualité de fabrication. A associer au connecteur shucko assorti. Achat hautement recommandable
Jean Luc C.
Beau connecteur
Belle qualité de fabrication, montage réalisé sans trop de difficultés, la clef nécessaire pour le serrage des câbles est fournie c'est un détail, mais il faut le dire.
Mais le plus surprenant est bien la qualité du connecteur, celle des fiches en cuivres, et de leur systèmes de serrages notamment. Un rapport qualité/prix très surprenant.
Un achat a recommander vivement.
Bastien S.
Complément à mon avis précédent...
Sur mon avis précédent j'ai oublié de préciser que le son de ma TV est retranscrit par ma chaîne hifi (d'un assez bon niveau) via un câble optique Viablue H-Flex...
La combinaison d'un bon câble d'antenne et d'un bon câble optique permet d'obtenir un son de très bonne qualité.
Evidemment si l'on utilise les HP intégrés de la TV, le son sera peut-être un peu meilleur mais restera forcément quelconque !
Avec un bon câble d'antenne et une bon équipement audio, on réalise que le son de la TNT est excellent, nettement supérieur à la qualité CD...
Mais du coup, on regrette d'avoir si peu de bonnes émissions musicales.
Qualité
La qualité est là, ces bornes sont belles et pratiques, bien que j'aurais aimé avoir un écrou de serrage 6 pans à la place de moleté, pour un serrage à la clé.
Appareil d'apparence qualitative, tout est bien assemblé, fonctionnement correct, très pratique, semble costaud. Reste à l'éprouver dans le temps pour voir s'il est aussi fiable que son aspect respire la solidité.
Jean-Claude B.
VIABLUE TRI SILVER
Excellent produit, j'ai testé ces pointes de découplage pour des enceintes
Harbeth, j'avais testé d'autres pointes de couplage (une pointe sous chaque côté de l'enceinte, mais ce système (trois pontes) est nettement supérieur, la qualité sonore est nettement améliorée dans le registre
bas médium, qui a gagné en clarté.
ghislain g.
Siflement
Un sifflement est audible et très gênant en l'absence de son, il est couvert par la musique lorsque cela joue mais cela est pour moi insupportable et bien loin des avis ou essais présentés (Qobuz, catalogue commercial ?!!).
En tous cas je suis bien déçu.
Encore une ou 2 tentatives et j'abandonnerais la classe D qui semble très bien pour du MP3 sur enceinte bluetooth mais certainement pas pour de la HIFI.
Accessoirement, la puissance réelle semble être assez limitée (l'ampli était pour piloter un boomer de 21cm de 50w en multiamplification avec un ampli à tube el34 de 40w pour le médium - aigue).... Le FX devait jouer "au max" pour être au niveau du médium aigue à peine au quart de la puissance du push-pull el34... (rendement 90db pour le boomer, 91 pour le médium et l'aigue). Et ce alors que les branchement des transfo de sortie sont cablés en 4ohm pour du 8ohm... Puissance des el34 de l'ordre de 20/25w !!!
Bref, c'est un ampli de 10w sur 8hm qui siffle !.. Pas mieux que de la classe AB pour le poids !
Ce sifflement est anormal.
Si vous avez essayé une autre source et une autre connectique, contactez le SAV.
Vladan J.
King!
Very good phono contact. Best reccomedetion!!
Roger D.
Preamplifier with Tone Control OPA LM4562 In addition to a volume control by rotary potentiometer, this preamplifier offers a triple tone control. Its possibilities are based on a series of components that allow to...
Compact et efficace
Tout juste reçu et branché entre un DAC et un ampli Heed pour avoir une possibilité de réglage des basses et aigus. A l’air de bien faire le job sans trop dénaturer la signature sonore. L’appareil a l’air bien construit mais il chauffe aussi pas mal. A voir dans le temps.
Façade trop épaisse ATTENTION !
Boitier intéressant mais quais inutilisable.... La façade de 1cm d'épaisseur empêche l'installation de la majorité des interrupteur et led dont la majorité des pas de vis font moins de 1cm...
D'autre part, le montage du capot est absolument fastidieux, il faut aligner 4 écrous au mm pour pouvoir la visser : ils font de bons yeux..... Made in Italy mais au final, mes boîtiers chinois font mieux )
M Christine L.
La qualité de fabrication du SMSL B1 inspire confiance.
Reçu depuis peu, j'ai été bluffée par la qualité sonore de l'ampli casque (DAP, fichiers FLAC et WAV , mode APTX )
J'ai essayé plusieurs casques dont mon vieux Koss Porta Pro et un Grado RS2e. Le son est vivant, équilibré,naturel, fluide,précis ,avec une bonne spatialisation et une bonne aération sonore.
Parfait pour ajouter la réception bluetooth à une chaine HIFI analogique.
La liaison bluetooth est rapide et stable.
Pourquoi ne pas l'avoir acheté avant?
M Christine L.
Pratique et efficace.
Pratique pour relier un casque filière à un DAP en mode bluetooth
et, dans mon cas, un casque bluetooth dont le mode APTX coupe sans arrêt.
Fait son travail, le résultat sonore est très correct.
hs au bout d'un an
Suite à ma critique du 12/08/19 mon modèle m'a laché à moins d'un an. Décevant.
Caroline B.
En fait je suis agréablement surpris , par cet HP de dépannage.
