Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Customers reviews - There are 19585 reviews.
Grzegorz B.
Very good quality
I use them after crimp on cables for mount cables in power plug with gold coatings. You have to use carefully, because the FP-209 are long and you can have about 0,5 cm of free cable (with inner isolation) to mount them in Furutech IEC power plugs. With longer free cable you can't holding whole cable in plug jaws. There limitation is only for IEC, for Schuko you have more space in power plug.
Grzegorz B.
Very good quality product
I use them after crimp on cables for mount cables in power plug with rodium coatings. You have to use carefully, because the FP-209 are long and you can have about 0,5 cm of free cable (with inner isolation) to mount them in Furutech IEC power plugs. With longer free cable you can't holding whole cable in plug jaws. There limitation is only for IEC, for Schuko you have more space in power plug.
Grzegorz B.
Good quality but you can't use in power plugs
I use Dayton Spade 2,5mm for mount power cables in power plugs, but this products is only for speaker cables.
Grzegorz B.
Good quaility
I use them with CANARE L-4E6S Star Quad High performance Microphone cable shielded Ø6mm for supply switches, router, NAS, etc. There is exactly space to use heat shrinkable sleeve that defend before break cable and is good matched in size with this cable, that all looks like from manufacture.
Grzegorz B.
Good quaility
Grzegorz B.
Good quaility
This is one of the best cables for power supply connection with small load, f.e. 12V /5V power supply for NAS, routers, switches etc., full recommendation.
Yvon C.
Belle découverte
Un petit câble à classer dans les meilleurs R.Q.P. Belle vivacité, bel équilibre des registres (le grave est un peu moins bon que le médium/aigu, mais à ce prix difficile de trouver mieux), bon respect des timbres. Chapeau à V.D.H. pour cette réalisation. A conseiller sans réserves pour chaînes musicales de milieu de gamme.
Gunnar B.
Good for the money
Only had it for a couple of days . Let’s see if it opens up à bit norr after à weekend or so.
Yvon C.
Idéale ?
Pourquoi dépenser plus ? Ces fiches présentent à mon avis, le meilleur RQP possible. Bien conçues, faible masse des conducteurs, gros diamètres de câbles possible. Quoi de mieux à ce prix ?
Jean Paul L.
Parfaites
RQP imbattable, elles sont solides et le câble est bien tenu.
Jean Paul L.
Pour le tarif rien à redire, banane et poussoir.
Gérard C.
MUNDORF MLYTIC AG Capacitor 63V 4700µF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
QUAD 306
Remplacement des condensateurs sur un amplificateur QUAD 306 qui date des années 80 dont l'écoute a été complètement rajeunie , je redécouvre C.D. et vinyles .
Rapidité de réception, sous 3 jours . merci !
frederic P.
TINYSINE TSA2210 Kit Class D Amplifier Module TPA3110D2 Bluetooth 2x8W + Volume Controller + LED This small Class D amplifier module based on a TPA3110D2 chip capable of developing a power of 2x8W. It can be used with speakers with an impedance of 4Ω or 8Ω.
TINYSINE TSA2210
C'est mon deuxième ! Utilisés pour redonner une vie moderne à 2 vieux postes de radio TSF irrécupérables , le bouton en plastique de controle de volume ne s'enlève pas de son axe ce qui aurait permis de cacher le circuit imprimé !
frederic P.
DAYTON AUDIO DTA-2
Utilisé pour moderniser/marabouter un vieux poste radio tsf de 1957 :
Seul reproche , des borniers vis pour brancher les haut parleurs auraient été plus facile , un concurrent du tinysine tsa2210 qui possedent un bouton de mise en marche/réglage de volume déporté
Jean-Francois B.
Déçu!
J'ai acheté cette carte DAC pour changer une carte XMOS XU208, en pensant que cela allait m'apporter une amélioration au niveau du son.
Ben non! La carte fonctionne bien sûr mais, reliée à mon streamer SOtM SMS-200 et le tout correctement paramétré, la carte ne reconnais que péniblement le DSD64 en provenance d'Audirvana, aussi bien en natif qu'en Dop. A chaque changements de morceaux, un clac se fait entendre dans les enceintes et les morceaux ne s'enchainent pas. Le DSD 128, on oublie! Le son est parasité par un bruit blanc assez faible mais audible.
Par contre la carte fonctionne parfaitement avec du PCM et le résultat est bien sûr correct.
Je regrette un peu mon investissement et j'ai donc réinstallé ma carte XMOS qui elle fonctionne parfaitement, surtout depuis qu'elle est connectée sur un streamer SOtM.
Jean-Francois B.
Excellent!
Je viens de tester ces AOP et vraiment il sont TOP. Comme j'ai pu le lire ailleurs, ils sont très musicaux, un peu "chaud" et en ce moment ils remplacent des AOP de chez JRC qui à côté, sont franchement brouillon. Une fois un rodage de quelques heures effectué, l'image stéréo devient plus ample et les enceintes se font oublier. Une impression de vérité caractérise les voix que j'ai écouté. Les basses sont présentes et bien tendues.
Bref en duo avec des OPA1611 sur mon dac double AKM4497eq, ça change TOUT...
Bastien S.
Amélioration évidente.
Cette embase IEC apporte des améliorations similaires à l'embase schuko cuivre rhodium de la même marque...
Timbres riches et nuancés, extension et beauté des graves, scène sonore étendue et mieux organisée, silence et douceur, plus de détails sur tout le spectre sonore.
Dommage que sa grande soeur l'IEC fi-09 soit si chère car elle va probablement plus loin encore.
Franck B.
finition
Toujours sympa pour la finition des câbles!
Franck B.
Bonne accroche
Pourquoi mettre plus cher dans du scratch. Elles font très bien le job!
Franck B.
Yarbo quoi!
J'ai toujours aimé cette marque pour le sérieux et le "potentiel" cuivre qu'il pourrait y avoir dans leur produits à défaut du laiton ou autre des concurrents.
Là Yarbo met encore la barre plus haut! De la vis au système de serrage tout respire le sérieux et la qualité, aucun jeu et un état de surface miroir.
Merci Yarbo et Audiophonics
Franck B.
Yarbo quoi!
J'ai toujours aimé cette marque pour le sérieux et le "potentiel" cuivre qu'il pourrait y avoir dans leur produits comme le dit Michel, à défaut du laiton ou autre des concurrents.
Merci Yarbo et Audiophonics.
Eric C.
Utilisé en complement des produits HP dayton PC105 & DC28 et d'un filtre monacor 3 voie, j'ai refait pour 200 euros mes enceintes Jamo studio 170 de 25 ans qui étaient devenues "plates" et donc l'écoute été fatigantes à la longue. Un peu de de laine, une charge close et de l'huile de coude. Le poid des enceintes à doubler et la qualité du son aussi : précis et dynamique. Parfait pour les budgets restreints.
Bastien S.
Beau câble très musical
J'ai utilisé ce câble pour relier l'embase IEC (furutech ncf) de mon ampli Smsl A8 à son module d'amplification Ice Power, donc sur seulement 15 cm de recâblage interne...
Il n'est donc pas évident de dissocier précisément l'apport du câble 1877 de celui de l'IEC... Mais connaissant déjà la gamme NCF de Furutech (embase schuko), je peux quand même discerner l'apport du 1877.
Le monobrin central en cuivre occ apporte de très beaux graves et médiums/graves, profonds et généreux, mais surtout pleins de nuances et de noblesse, avec une impression de silence et de calme, très agréable.
Les monobrins de 0.3 mm en cuivre et cu/ag entourent ce grave d'un beau bouquet d'aigus et médiums expressifs et détaillés, avec une belle scène sonore, propre et bien organisée.
Globalement c'est très agréable, musical et détaillé, très expressif, la musique vivante se déploie avec naturel, belle dynamique sans agressivité.
Je perçois pourtant un léger manque entre les médiums et les médiums/ graves , donc un manque de "matière" et d'incarnation de certaines voix, ce qui semble logique en considérant les sections utilisées, puisque les 0.3 mm correspondent aux aigus et le 1.3 mm aux graves, la jonction de ces 2 sections créant donc un médium "composite"...
Je serais curieux que 1877 tente un câble identique, mais avec en plus une section intermédiaire (0.8 ou 0.6 mm) de façon à établir un médium encore meilleur.
Il reste que ce câble me semble très bon, et même sur 15 cm son effet se fait sentir.
Il est assez rigide mais se dénude bien.
Je l'utiliserai bientôt pour le recâblage interne de mes enceintes, mais en dissociant les sections (donc après l'avoir éventré, le pauvre ) de 1.3 pour les hp de grave et les 0.3 mm pour les aigus, et associés à d'autres sections (en fil de litz) pour chaque hp.
Ce câble n'est pas donné, mais l'expérience prouve que même une petite longueur peut apporter sa part.
Dans un système chaque maillon faible va brider voire étouffer les maillons de qualité optimale, il faut donc porter attention à tous les composants traversés par le signal.
Pierre S.
OK
Thermo retractée en dessus d'un grille-pain, parfait :-)
Pierre S.
Assez fragile
Je n'ai pas d'expérience avec les gaines, c'est la première fois que j'en posais une, une fois trouvé "le coup" c'est assez facile à faire passer sur un cable de 16mm... * 6m. Pour le contre, elle semble très fragile et se troue facilement au moment de la pose. A voir comment elle va tenir sur la durée. Mais bel effet sur le câble.
Pierre S.
Belle finition
Ce n'est que des pointes, mais c'est classe, usinage et finition au top. Très franchement excellent.
Pierre S.
Taille trop petite pour un cable de 16mm
Après de longues minutes d'essai, impossible de faire passer un câble 16mm dans le Joint d'entrée de la prise, même dans gaine. Impossible également de fixer la bride intérieur sur ce câble.
J'ai pu finalement la monter sans le joint ni la bride, et très "plastoc"... bof bof
Vous avez du rater la mention de la fiche :
"Ø16mm sans manchon / Ø13mm avec manchon"
Luis V.
Outstanding Heatsink
I ordered a pair of these heatsinks to cool out an amplifier, by glueing them to the sides, and was worried about the finishing and looks of the pruduct, well it is much more prety than the photos, the fins are waved and rounded edges, the amplifier looks much more prety now.
Christophe v.
Audiophonics k214 v2
Christophe v.
Ibasso dc02
Olivier b.
SUPER PRODUIT
aucun bruit residuel.
Toon N.
Installation was easy.
++ AptX support
++ line in
Konstantinos D.
Great class D Amp
Rudolphe D.
Moyen
Pierre F.
très content d mon achat
Hubert B.
Efficace !
Denis Gabriel G.
Un meilleur son pour 30€
Herve C.
Hervé
Alain G.
JOLIE SURPRISE
alain d.
SMSL SU V2 DAC
Daniel V.
Amazing
Daniel V.
Very nice cable
Good build quality with good connectors, very pliable, nice to hold and connect to your devices.
Joao L.
jean michel G.
Bon ou juste comme tant d'autres
Après avoir lu les différents retours, me demande si j'aurais un plus avec mon phase linear 400 accouplé à un marantz 1060 en Préampli, sur des JBL et du mogami 3103.
J'attends vos retours.
Florent G.
Toujours excellent
Second avis après mise en place du module dans un caisson DIY avec un HP Focal 25A4 chargé dans 58L clos. J'ai laissé le X-guard au niveau 1 et ai laissé le module en mode "linéaire" (QTC à 0.707).
Concrètement, c'est le meilleur caisson que j'ai eu entre les mains pour un tarif très abordable. Le module Athom S250 s'adapte à toutes les situations grâce à ses nombreux réglages et est largement suffisant en Hifi. En prenant le temps de faire les bon réglages (en lisant bien le manuel), le résultat est redoutable de précision.
J'étais très satisfait lors de mon premier commentaire et le suis toujours : un très bon module d'ampli.
Bertrand B.
Achetés en complément de mes IT04, ces intras sont très confortables et ne tombent pas. Je les ai associé à un câble Ibasso CB13 et le rendu (après +- 70h de rodage) est vraiment excellent. Les basses sont rapides et précises sans être envahissantes. Les voix féminines sont superbes. Écouteurs parfait pour tous les jours. Qualité de fabrication au top
Jean-Louis S.
Matériel sérieux et conforme à mes attentes.
Merci à Audiophonics pour leur rapidité et leur sérieux.
Vaclav S.
OK
Vaclav S.
Comme Hugo je les trouvent très bien construites, j'en aurais acheté 8 de plus pour mon câble Kimber.
