Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Mohammed B.
die
Paulo Fernando A.
TINYSINE TSA6016 Bluetooth 5.0 aptX Receiver Board wih Microphone Input This Bluetooth 5.0 aptX receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this...
Best Bluetooth receiver ever!
I have tried many Bluetooth receivers over the years, this one is the best! The sound quality is as rich as cable quality, and also no interferences during phone calls. Finally I found a prime quality Bluetooth to use in my car.
Pascal M.
Bonne marque
Le câble est très bien fabriqué.
Rachid Z.
XDUOO XC-08 Adapter Cable Female Angled USB-A to Male Angled Micro USB 8.5cm This xDuoo XC-08 adapter/cable has a female USB-A connector and a male Micro USB connector. A particularly practical adapter for connecting a USB-A device or cable to a device...
Erreur de conception !
Dommage que le câble sorte du mauvais côté de la prise micro USB... du coup inutilisable pour connecter mon XDuoo XD-05 avec mon smartphone !
Grzegorz B.
Very good quality, necessary product!
It is necessary product with all screwed connections. I use PEW12 system to crimp and it allow to almost homogeneous material from sleeve and wire.
Grzegorz B.
Grzegorz B.
Grzegorz B.
Grzegorz B.
Grzegorz B.
Very good quality, fast shipping from the shop.
I changed speaker terminal from WBT 0780 (chromed brass) on Mundorf Mconnect (gold plated copper). The sound is much better, more detailed, more opened, with deeper bass. Terminals are more comfortable with big nuts. Thank you Audiophonics for fast shipping.
Laurent T.
Impressionnant !!!
Je suis réellement stupéfait par ce "petit" Ibasso Dc02 , branché sur mon Huawei mate 20 pro qui a une sortie son un peu juste l'apport est impressionnant , c'est nettement plus fort et la qualité s'est nettement améliorée bref le top !
Je pense que le rqp de ce ibasso doit être vraiment difficile à surpasser
Jean-Louis l.
Très bonne qualité
La qualité de ses fiches est véritablement excellente. Elle est au-dessus de mes attentes. C'est une valeur sûre.
Jean-Louis l.
Rien à redire sur la qualité de ce produit qui est conforme à mes attentes.
Pierre F.
Déception
Utilisé à la place d'un TacT RCS, entre une Mutec MC3 Smart Clock USB et deux amplis TacT 2150, reliés en toslink (sans utiliser les DSP, donc), la qualité sonore a nettement reculé : perte de la scène 3D et timbres ferraillant.
La praticité de la télécommande et la facilité des réglages pour un système multivoies sont indéniables, mais ils ne compensent pas la qualité très moyenne du son.
Ce n'est pas un appareil haut de gamme et cela s'entend.
Michel C.
Pied caoutchouc Amortissant
Je suis satisfait de mon achat la hauteur de 30m/m est impeccable
pour mes Audio Researsch Sp9 mk ll et classic 30 !
ils avaient besoin d'air pour les ventiler
Pieds d'origine 20 m/m !
Alan M.
VIBORG VP-1501 Power Cable OFC Copper 4N Copper Shield 6mm² Ø16mm The Viborg VP-1501 is a high quality meter-to-meter power cable. It will allow you to design your own power cables.
VP-1501 POWER CABLE
Incredible value for money..an exceptional build quality cable,
Guillaume V.
mini...
...mais il fait le maximum!
les+;
modulable dans tous les sens:
-utilisation autonome sur batterie.
-gain et basse réglable avec 2 boutons pour s'adapter a toutes les installations.
-resultat global du son trés satisfaisant (transforme le son d'un ordinateur).
les- ;
-en cherchant bien peut être...
pour ma part je ne vois rien a redire.
Anders L.
Superior value
These plugs are very good. They are very well machined, particularly to avoid an excess volume of copper (eddy currents etc). They fit very well in speaker terminals.
The packaging is also excellent with a hexagonal key and four marked shrink sleeves in each box of quality paper.
I would also commend Audiophonics for their speed of service and thoughtful stock. Everything I have bought so far has been exceptional value at their respective price points. Excellence s a rare thing these days, but Audiophonics is a truly excellent trader.
Anders L.
Functional and aesthetic
I used these to add volume to the conductors in a home-made quad type speaker cable. The conductors were Audiophonics 4 sqmm silverplated hookup wire with PTFE insulation. The purpose was to reduce the potential for cross-talk between conductors.
This cotton sheath was perfect for the job. It was easy to insert the conductors and then stretch the sheath to a tight fit. The knots in the weave also made it easy to twitst the conductors together.
The natural cotton also adds a beautiful aesthetic to the cables, so I would recommend using this sheath as often as you can in your builds.
didier s.
Mitigé
Ce DAC est tout à fait correct au niveau de la qualité sonore, par contre l'exemplaire reçu s'est rapidement montré défaillant au niveau de l'affichage OLED, ainsi que par l'apparition d'un bruit parasite sur l'un des canaux à chaque changement de track / chaine tv, …
Un appel au SAV est lancé pour ce produit.
Serge D.
Produit conseillé
J'ai acheté ce produit pour réparer un caisson ELIPSON "HORUS"
Ce module m'a été livré en excellent état. Il me donne entière satisfaction.
Je recommande donc ce module.
Pieter T.
good bitumen, very sticky so be warned
good bitumen, delivered as plate, flexible without being warmed up
it sticks good on sticky side, however the other side is very sticky too when foil is removed, so be warned when you put something on top
Victor S.
Cédric C.
Mr Cédric Chassaing
Bonjour.
C’est bien la première fois que je rédige un commentaire de satisfaction après achat. J’avais cependant déjà possédé des câbles Oyaide au sein de mon système hi-fi. Alors lorsque j’ai constaté que la marque proposait un câble de remplacement pour le fameux HD-650 de Sennheiser, modèle de la marque et référence de très nombreux amateurs du casque ouvert dont je suis, j’ai tout de suite voulu essayer d’ « influer sur ce maillon faible de la chaîne » en remplaçant le câble d’origine de 3.00 m par celui de la marque japonaise réputée, pour la pureté de son cuivre, sa teneur en argent et sa longueur d’1.30 m. A l’époque du test initial, mon casque était branché dans un DAC OPPO HA-2 SE, lui-même branché dans mon iPhone connecté à Qobuz abonnement Hi-Fi Sublime+ (via un câble USB / Lightning Audioquest Cinnamon 15 cm). L’ampli du DAC était muni d’un amplificateur des basses fréquences ; avec le câble d’origine, j’avais pris l’habitude de l’enclencher, (bass + on), bien que généralement je n’utilise de correction de tonalité sur aucun de mes systèmes, afin d’éviter tout risque de filtrage en peigne. Le seul faible défaut imputable aux écouteurs Sennheiser est en effet, un léger manque d’assise dans le grave. Or, une fois l’amplificateur des basses éteint, (bass + off), et le câble Oyaide HPC-35HDX Jack 3.5mm 1.30 m branché, ces basses fréquences sont apparues avec beaucoup plus de définition et de densité. Il délivre à peu de frais ce qui manquait à ce très grand casque de moyenne gamme (moins de € 350,00) fabriqué par l’un des meilleurs constructeurs en la matière. L’association devient donc évidente. Existe en black et silver.
Système d’écoute pour le câble :
OYAIDE HPC-35HDX
Câble Jack 3.5mm : https://www.audiophonics.fr/fr/cables-pour-casques/oyaide-hpc-35hdx-cable-35mm-pour-hd650600580hd-25sp-ii-13m-p-7729.html
pour HD650 : https://fr-fr.sennheiser.com/casque-audiophile-haute-qualite-hd-650
iPhone Xs Max : https://www.audioquest.com/cables/digital-cables/usb-lightning/cinnamon
OPPO HA-2 SE : https://www.oppodigital.com/headphone-amplifier-ha-2SE/
Bastien S.
Très bon ampli, nettement meilleur que le Smsl Ad18...
Après 2 mois d'utilisation quotidienne, voici mon compte-rendu personnel :
Il remplace un Smsl Ad18 que j'ai apprécié pendant 18 mois...
Et l'A8 ne joue pas dans la même catégorie que son petit frère ! Sans non plus ridiculiser l'Ad18, il est évident que l'A8 est (nettement) meilleur à tous les niveaux.
L'Ad18 reste d'un rapport qualité / prix exceptionnel, mais ses connectiques aléatoires et malcommodes, sa compacité et sa puissance modeste le limitent rapidement. C'est en particulier son entrée numérique coaxiale qui m'agaçait ( entrée jack qui réclame un adaptateur jack/rca) ainsi que les entrées analogiques (là aussi en jack)...
Avec l'A8, on dispose de vraies entrées numériques ( 2 optiques + 2 coaxiales) et analogiques en RCA. Seuls les borniers d'enceintes restent inférieurs à la dimension classique, mais ça ne me gène pas trop.
L'Ad18 remplaçait avantageusement un Atoll In80Se. Les seuls points sur lesquels l'Atoll restait meilleur étaient la dynamique et la "tenue" de la musique, grâce à sa réserve de puissance supérieure.
Sur tous les autres points, l'Ad18 était meilleur : à la fois plus détaillé et plus doux, plus musical et expressif, plus riche et vivant. Et je n'ai jamais pu revenir sur l'Atoll (qui est un ampli très honnête dans sa gamme de prix).
Avec l'A8 on retrouve la douceur, la finesse et la musicalité de l'Ad18, associées à la tenue et à la dynamique de l'Atoll, mais un bon niveau au dessus des deux autres !
Sur les entrées numériques spdif, l'A8 est aussi moins chaleureux et plus clair que l'Ad18 (plus smooth).
Je préfère la neutralité de l'A8, qui me semble plus naturel et tendu.
Je l'utilise sur l'entrée coaxiale numérique pour la musique et les films, et sur l'entrée optique pour la télé.
Et il faut souligner qu'écouter des émissions musicales devient intéressant, avec un bon câble optique, ainsi qu'un bon câble d'antenne (ce dernier pouvant nettement jouer sur la qualité du son et de l'image). D'ailleurs simplement écouter la télé peut aussi devenir un plaisir avec cet ampli, car dès que la prise de son est soignée (reportages animaliers et documentaires par exemple), c'est très immersif, vivant.
Je n'ai pas encore testé les entrées analogiques (en principe performantes en classe D), ni l'entrée USB.
Le dac embarqué me semble très bon, précis et équilibré. Mais ceux qui cherchent un son chaud le trouveront sans doute froid !
J'ai 3 reproches à formuler toutefois :
- Il est parfois un peu lent à régir via la télécommande, et il ne faut pas trop s'écarter de l'axe de l'ampli.
- A l'allumage, il arrive qu'il reste muet (en fait il reste en "mute", sans qu'il ait été éteint dans ce mode)... Il faut alors l'éteindre puis le rallumer : un peu agaçant.
- Sur l'écran (déjà petit) le volume s'affiche en minuscule, et pas moyen de l'afficher en information principale...
Alors comment décrire les performances de cet ampli ?
Et bien je dirais simplement que pour la première fois, j'ai l'impression qu'il ne manque rien à la musique : tout y est sans défaut ni excès.
Ce qui devient appréciable avec l'A8, c'est l'intégration évidente de qualités qui ont généralement tendances à s'opposer : douceur et dynamisme, précision et fluidité, richesse des timbres et tenue bien "carrée" de la musique, subtilité et punch, détails et ampleur, etc.
Ce qui me réjouit le plus, c'est sa subtilité dans les détails et les nuances (ambiances de salles, détails sonores d'arrière-plans, extinction de notes...), associée à sa capacité explosive, son équilibre général et sa poigne (très bonne tenue des graves).
Du coup il met clairement en évidence les limites de mes sources et de mes enceintes, (limites déjà perçues avec l'Ad18).
J'ai changé le câble secteur fourni par un câble secteur maison (blindé), et l'A8 apprécie, tout est plus clair et nuancé.
Pour ceux qui apprécient l'Ad18 mais veulent aller (nettement) plus loin en restant compact, l'A8 est un très bon choix.
En espérant qu'il sera fiable dans la durée.
Bonnes écoutes.
Bastien.
Gael J.
Du son et du vrai
J'ai redécouvert des musiques grâce à ce lecteur.Des basses enveloppantes et des aigus pas trop pointus . Une très belle définition. Utilisé en carte son de PC, il vous change tout. Un vrai plaisir. Il chauffe pas mal mais il envoie tellement du lourd que çà va. Heureusement que la batterie est grosse car il dépense de l'énergie, le petit coco. Je suis vraiment content de mon achat .
Emmanuel M.
J'en utilise depuis des années , aussi bien pour l électronique que pour mon caisson velodyne , les méga sont a privilégier même pour des électroniques d env 10kg ,car les petits se déforme avec le temp , et le prix est raisonnable ;-)
jean-michel L.
indispensables
bonne interface entre les pointes et le revêtement de sol, prix modéré, bonne qualité,en complément du support DAYTON
l'ensemble donne un résultat excellent, au delà de celui espéré
jean-michel L.
excellente surprise
acheter pour stabiliser des enceintes MULIDINE ACCORD, non seulement le support a bien rempli son rôle, mais l'équilibre tonal et la spacialisation ont été transformés, inatendu mais parfait
prix minime, esthétique en rapport , mais au vu du résultat , on ferme les yeux pour écouter
jean v.
Après une erreur suite à la lecture d’un forum que le site a géré très professionnellement, j’ai reçu ce produit qui est un condensé de ce qu’un quinquagénaire non frappé d’illectronisme et amateur de musique pouvait espérer.
Ce produit devrait faire partie des « produits de première nécessité »
Sylvain L.
Ronfle
Produit correspondant à la commande mais très bruyant. C'est un problème fréquent avec les toriques mais je ne pensais pas qu'il ferait du bruit à ce point ! Pour un ampli audio ça ne fera pas l'affaire. Je vais rajouter un filtre (vu sur la toile) pour supprimer la composante continu du réseau (non symétrie du 50Hz). À suivre...
gerard P.
Optique
Toujours un rapport qualité prix intéressant cable optique excellent sur 5 mètres
Tomislav G.
Incorrect voltages
This transformers have false secondary voltages , 15V is actually 18.2V on both, and 9v is measured 11V.
No other problems found.
Bernard a.
Très dynamique. Large courbe de réponse.
FDA très dynamique. Large courbe de réponse paraissant plutôt bien droite. Aucune indication de + ou - d'aiguë, de grave ou de volume.
Anders L.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Black This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
Intelligent design.
This cable has an intelligent design. It is made of medium strands that are twined tightly. It is almost like a single core with the added benefits of a greater surface area and flexibility. With the silverplating, large diameter and good dielectric, it's a very good conductor for high level audio signals. Top marks.
Adrian-Marcel O.
No difference
Using this cable on an AV receiver which produced different, better sound with another cable with similar construction yielded absolutely no improvement and no difference to the supplied stock power cable. I will try again with different mains and IEC plugs, but have little hope to achieve something. I'll update this review in case there are any changes.
Antoine C.
Parfait rapport Q/P
Je crois que nous sommes à une bonne cinquantaine d'achats de ce petit pot-vibrant comme on dit !
La qualité audio (bien sûr dépendante de la surface) est bonne, les clients sont toujours étonnés des basses produites et de la bande passante pour un si petit format... et invisible, en plus.
La connectique est pas terrible, il faut souder ou utiliser des cosses mais franchement pas pratique.
Utilisation dans le cadre de projets industriels et scénographiques.
Alain V.
Excellent rendu
Je retrouve tous les caractéres décrits par Sylvain D le 26/5/18 ainsi que les autres avis positifs. Le câble secteur (Nordost) de mon préampli bridait la chaîne.
Après lectures sur les forums j'ai tenté ce câble. Le résultat est au delà de mes attentes, gain sur tous les paramétres. Son prix est justifié. Le rodage est long: 5 jours en fonctionnement.
Minh N.
Complément de mon avis
Pour information : l’entrée optique accepte du DTS 5.1, du AAC mais pas de Dolby Digital 5.1 (pas de son mais un bruissement).
benjamin b.
sans prétention …
Sans prétention ce câble fait le job.
Son défini, clair et précis. Le message est respecté de bas en haut.
Facile à mettre en œuvre, on peut le contraindre un peu sans souci (mémoire de forme) pour du câblage fixe ou interne.
Très hautement recommandable pour du petit budget.
pascal b.
1877PHONO OCC Silver Dart Modulation Cable RCA-RCA 1.5m (Pair) The 1877 Phono RCA cable is a major advance in the design of analog cables. Taking all the mechanical, electrical and magnetic criteria influencing the final result, the Silver...
Musicalement ce câble est parfait il ne manque rien
Par contre j’ai un gros doute sur la robustesse des fiches RCA
Surtout le poids est conséquent
Dommage
le bon choix
très belle fabrication avec du matériel de qualité dont les prises RJ45 qui sont top, bravo
utilisation en hifi entre un switch et un lecteur réseau, ce câble me semble supérieur à quelques grandes marques testées de même
pour le reste, l'information et la livraison sont efficaces comme toujours, c'est un plaisir d'acheter chez Audiophonics, bravo
Alain j.
Ecouteurs de bonne facture
Bonne sonorité dans l'ensemble avec un grand choix d'embouts,
a recommander.
Alain j.
Produit de style
Enfin un lecteur de qualité, bonne prise en main et superbe sonorité dans les basses. bref a recommander au éventuels acheteurs.
Jean Claude L.
Effet indiscutable et immédiat. Utilisation en bypass.
Apporte juste ce qu'il faut de lumière d'ouverture et de précision au son.
Gilles H.
DAYTON AUDIO APA150 Class A/B Amplifier 2x75W 4 Ohm Black The DAYTON AUDIO APA150 from 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it offers a real solution that is very...
Un OVNI HIFI
Alors , et bien c'est la main de fer dans un gant de velours, très puissant et charpenté, le médium aigu est bien là aussi.
Un Nad 316 bee mk2 est largué par cet ampli deux fois moins chère.
Impossible de mettre le bouton de volume au tiers, sinon les voisins vous tue !!!! (enceintes Mission 733 pro MK2 , Klipsch référence)
Musical, et bien foutus bravo, c'est adopté !!!
Recommandé !!!
Gilles
Attention vendu à l'unité. Commandez en deux !
Et oui c'est écrit mais je me suis fait avoir. Si vous en avez besoin de deux commandez en deux. Pour le reste beau produit trés (trop) bien emballé. Fait le job; Doit certainement pouvoir servir à d'autres marques d'enceintes qui ont un insert filté de diam 6mm.
Réglable dans tous les sens.
Câble neutre
Belle présentation. Câble neutre. N'apporte rien de particulier, mais c'est ce qu'on demande.
Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 10m This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low...
Parfait à résolu mes problèmes de jitter
J'ai acheté ce câble pour remplacer un classique belkin de 10 m.
J'ai un emotiva UMC 10 et un vieux panasonic full HD (HFDMI 1.4 sans doute).
J'avais des mouches blanche sur les images sombres.
Maintenant c'est nickel.
Ce câble m'a été conseillé par Audiophonics par échage de mail.
Le signal transite par fibre optiques. les convertisseurs sont dans les prises. il est fin, bien présenté.
Bon achat.
Excellent rapport Qualité prix
Ampli vivant et dynamique.
Un peu déroutant au départ il ne pardonne pas les défaut de la source.
Le son et précis tenu et dynamique. C'est attachant.
Je l'utilise avec des enceinte que je ne connais pas bien et qui me semble limitées dans les aigus (Qaccoustic 3020).
Les basse sont bien définie et on perçoit les nuances de grave même avec des enceinte bibliothèque.
Avec le rodage le son c'est adouci, ou je me suis habitué ?
C'est minimal (une entrée, on/off, bouton de volume) mais l'essentiel y est et surtout l'alimentation est soignée.
Il y a ce qu'il faut pour une écoute audiophile pas plus.
Bon achat.
Attention pas très bien emballé, il y a des efforts à faire de ce côté. La face avant est arrivée très légèrement écornée.
Eric A.
Furutech FT-212
A l'ouverture de la boîte, on sent que l'on n'est face à quelque chose.
"Couplé" avec le câble Oyade Across 3000, après une journée de rodage, on est vraiment face à quelque chose.
Du très bon.
Pourtant l'ampli est quasi de base. Yamaha AS 701.
