François G.
Samuel A.
What a surprise!!!
Frederic A.
3E AUDIO 260-2-29A PFFB
Fonctionne...
Zeferino I.
Oled display
A very good oled display in a nice size
Zeferino I.
Very good amplifier ..
The amplifier was installed in a large room ..
I am very satisfied with the small part .....
Thanks to the Audiophonics team
Zeferino I.
Casing.....
Very nice housing. the build worked well
ANTONIO M.
la mejor etapa de mi vida
He tenido hibridas clase A, valvulas, Emotiva, pero esta Audiophonics Hypex Ncore basada en NC500MP doble monofonica se las come a todas con un previo pasivo a transformadores, cajas Focal o Dynaudio, fuente Arcam y cableado todo en cobre chapado en plata. Lo que decian en los foros de la ncore era como lo que decian de los previos TVC, todo verdad!
https://youtu.be/uec9Uyr0I9E
Limpieza, potencia, detalle... estoy asimilandolo aun no me lo creo
Marco P.
DIfferent from the one illustrated
Once received the item, it seems "old" and a bit rusty and with different components than the ones in the website photos. A 10k resistance was cracked (not a grat problem, substituted). The most great difference (or problem) is in the capacitors bank. the PCB reports "10000uF", but in web photo we have 2200 uF x4 x Channel (quite near) and mounted I founded 1500 uF x4 xChannel, which is quite half than declared. Volt for capacitor is also different (35V instead of the illustrated 25V and that could be better). Also diodes are not the illustrated one (they are Motorola MBR1645 in a TO220 package).
I know these items are not produced by Audiphonic, but a more deep control of conformity may be in result of a better service. It's functional but I'm not so satisfacted. Sufficient but not more.
Marco
Jean Claude G.
Alimente mes NAS et routeur
Améliore notablement l'écoute, beaucoup de détails et de piqué.
Acheté avec câble DIY.
Livraison très rapide.
Très satisfait.
Jean-Jacques M.
Super!
Ce DAC très bon marché m'a été livré en 2 jours. Il s 'est installé sans le moindre problème et fonctionne comme i faut.
Les 3 LEDs de débit sont extrêmement précieuses. Elles m'ont permis de comprendre comment fonctionne le resampling de Windows.
Appareil sans concurrence an niveau du prix.
Alexander S.
Very good DAC unit
Very easy to assemble (although was missing 2 of the bolts V1)
Sound as expected - very good and detailed. Have other two Pi DACs with ES9023 and PCM5122.
Compare to them ES9038 seems to me reproduce more detailed highs / mid highs. RaspDAC mini main advantages:
- remote control and info screen
- Moode customs image
Moode seems to me much more easy to use and no lags (as volumio).
Reccomend!
Bernard M.
Satisfait du produit
Bernard M.
Genial
J'ai découvert le site en cherchant du matériel et des accessoires audio de qualité Je suis très satisfait des borniers et du prix,
satisfait également de la rapidité de la livraison .
İsmail Afşin M.
Thank you for your speed!
Very quality cable, thank you!
Transparence
Utilisée en capa d’entrée sur un ampli à tubes ..superbe musicalité ,aucune coloration...un très bon produit
Guy L.
super produit , je conseille ce produit
Jack Z.
A high-end DAC for low-end price
This DAC is the best audio investment I've ever done. It measures as well as products costing ten times the price. All you need is a chassis, maybe 3D print like I did. Sounds incredible and measures well.
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-wesiontek-khadas-tone-board-dac.4823/
Highly recommended!
J-C- P.
Multiprise de belle facture qui mériterait cinq étoile si le câblage interne était monté avec du 2,5 mm2 en lieu et place du 1,6 mm2 (vu la très faible différence de prix entre les deux câble). De surcroît, il serait judicieux aussi de pouvoir permuter à sa guise le montage interne, c'est à dire de pouvoir visser directement le câble de son choix sur les barres en laiton massif d'un côté (diamètre supérieur à 2,5 mm2) afin d'améliorer la conductivité et de l'autre côté, pouvoir utiliser l'embase fournie (de belle qualité) si besoin. A méditer donc.
Marian S.
livraison rapide et produit conforme
Très facile a installer.Un dac amplificateur casque de bon qualité.Sur un pc bureau avec un casque Plantronics back beat pro que de bonheur.Par contre câble usb micro usb fourni est de mauvaise qualité et ne permet pas a windows 7 de reconnaître le périphérique et de installer le driver. Après le changement de câble tout est rentré en ordre. Merci AUDIOPHONICS.
Robert E.
Heureux possesseur d'un Fiio X3 III et des intras Fiio F9 Pro (excellents à tous points de vue), je voulais compléter cet équipement par un bon casque circumaural.
Après lecture de pas mal d'articles, de bancs d'essai et de forums, j'ai choisi l'Audio-Technica ATH-MSR7 (coïncidence, c'est aussi le cas de Laurent D.). Le rendu du câble d'origine (sans télécommande) est plutôt correct mais j'ai immédiatement pensé que ce très bon casque méritait mieux.
J'ai tout d'abord opté pour un Audioquest Evergreen, ouvert et musical mais beaucoup trop rigide pour permettre une utilisation nomade ou simplement confortable. Je l'ai donc remplacé par ce Furutech ADL iHP-35 II et ne regrette pas mon investissement (il est en effet deux fois plus cher que l'Evergreen). Techniquement, câble souple avec brins en cuivre désoxygéné parfaitement isolés et plaqués argent, connecteurs de très bonne qualité, qui inspirent toute confiance. Musicalement, vaste scène sonore, grande aération, focalisation des instruments rigoureuse (il est très facile de les situer dans l’espace) et registres qui ne bavent pas les uns sur les autres, même sur les tutti orchestraux ou choraux (j'écoute essentiellement du classique en FLAC HD). Les cordes, les cuivres et les voix sont magnifiques de naturel et le piano, saisissant de puissance ou de velouté, lorsque l'enregistrement suit, bien entendu.
Le rendu général est à la fois précis sans être chirurgical et pêchu lorsqu'il le faut mais aucune agressivité ou empâtement du message ne se fait sentir (il vaut mieux ne pas écouter du MP3 à 32 ou 64 kbps avec ce genre de matériel).
En résumé, un excellent achat pour qui souhaite exploiter tout le potentiel de son casque à cordon détachable.
Robert D.
Matériel conforme, envoi rapide.
Etienne B.
J'avais précédemment acheté une interface Phiree U2SX qui fonctionnait très mal sur mon MBP 13" 2016 avec Touch Bar sous Mac OS Mojave (l'interface sortait un son complètement saccadé & périphérique détecté comme un USB 1.1).
Cette interface est parfaitement compatible en revanche avec les dernières versions de Mac OS et sonne particulièrement bien en 24bits et 192kHz via le sac intégré de mon Marrantz PM 6005.
Je recommande chaudement !
Benoit J.
mm
en ce qui concerne le module il est super je vais en prendre un 2 e mais trouve pas un bon boitier
Marc M.
Superbe boitier pour ampli à lampes
Ce boitier est très bien adapté à la réalisation d'amplificateurs avec les lampes et les transformateurs sur le dessus alors que l'électronique est à l'intérieur... Voir les photos sur www.diyaudio.com le sujet est EL34 Baby Huey dans la section ampli à tubes !
Dommage que Audiophonics ne le mette pas en stock et qu'il faille attendre 5 mois lorsqu'on le commande !
Marc
MINIDSP WI-DG Network to USB Interface for miniDSP Alexa Voice Control Black This accessory adds an additional layer of control for your MiniDSP devices. This interface now allows you to control your MiniDSP hardware via the network (Ethernet or WiFi).
Produit pratique
Facile à installer, permet de supprimer du câble lorsqu'on intervient sur son système (mise au point haut parleur par exemple). On peut faire tout ce que l'on fait avec l'application habituelle.
Boîtier très correct solide malheureusement petit donc léger et facilement entraîné par le poids et la raideur des câbles. Peut être je l'integrerai à un appareil.
Je n'utilise pas Alexandre et donc un peu cher pour mon usage.
Marlies B.
TOPPING RACK HiFi Rack Aluminium Acrylic for PA3 / MX3 / VX3 / D30 / A30 The Rack is a small HiFi support proposed by Topping, in order to install your HiFi devices and in particular the Topping PA3, MX3, VX3, D30, A30.
Good looking rack, but lacking QA
The product comes in a box with soft foam to protect the pieces.
The Acrylic plates are covered in foil.
The stand it self looks good and doesn't wobble or moves easily, once it's screwed together.
Sadly some of the metallic pillars of my unit have some rather visible scratches, because of this I will my recommendation will only be a 3/5.
Seems to be lacking some QA.
Hugo S.
MATRIX X-Hi External USB 3.0 Power controller
The board does very well its function but attention only works having an external power supply.
John T.
Addendum
..in clicking away from the page, I noted that the resistors are susumu. If that is indeed the case, they have a very good reputation for noise
John T.
Looks good
I have yet to wire the device in, but it seems to have a good build quality. I brought it in order to connect to a pi. It isn't going to be just a plug in, but equally a pretty simple lash up of power and i2c. I found The documentation less than clear, but in reality all those connectors are just pass through, so 4 / 5 wires should do it. A true audiophile would reject those SMD resistors, but for me a better that 100db signal to noise ratio is more than acceptable. I note the other advice here on popping when changing levels. This is a general problem with switched ladders, but I note that the Dutchman whose design is almost identical to this one has an algorithm for reducing the intrusiveness .... All I need to do now is compare his solution with that used for this board
Christophe A.
Cela fait une semaine que j'ai remplacé mes connecteurs Supra en laiton par ces connecteurs Yarbo en pur cuivre et le résultat est très bon. Un son plus live avec plus de présence dans les voix. De plus, elles rentrent très bien dans les borniers avec un excellent maintien. La qualité d'usinage est au rendez-vous. Une bonne vingtaine d'heures de rodage est conseillée si vous souhaitez avoir le résultat escompté...
cyril f.
un bon materiel
Rapide et courtois, bon suivi de commande.
PATRICK P.
avis
bonjour ,site produits electronique serieux,reactif,aucun probleme de livraison,longue vie a vous ,merci.
Herbert E.
Je vais le tester...
Je trouve très amusant ce lien entre l'ancienne génération de la radiotechnique et la nouvelle.
Roland S.
FX-AUDIO M160E Class D Amplifier TDA7498E Bluetooth 4.0 2x100W 4 Ohm The FX-Audio M160E is an amplifier capable of developing 2x125W under 4 Ohm. In addition, its Class D design allows it to benefit from high efficiency and therefore to be...
Utilisé pour une télé
Parfait, livraison rapide, bien emballé, bon fonctionnement.
Un petit préampli dans le même esprit avec réglage grave et aigu
serais plus que parfais.
Roland Singer.
Joao d.
tres bon produit
fonctionne parfaitement,envois rapide et parfaitement emballé.
site sérieux, .
ANTONIO M.
Good
Good wire for cheap really short braided interconnect
Gerard M.
Vintage mais pas totalement.
J'ai acheté ces fourches pour mon McIntosh MC452 mais elles sont bien trop
J'ai acheté ces fourches pour mon McIntosh MC452 mais l'entraxe est bien trop petit..... donc inutiles les fourches qui peuvent accepter un câble de 6 mm et encore mais en aucun cas un poste de 6 mm.
belle douceur ,musical
Cable acheté avec des rca viablue or , le resultat une belle douceur ,aeration,un haut medium jamais stressant ,bien articulé, chaleureux , je recommande ce cable vivement ,merci occ.
beauté des timbres extraordinaires
Je viens de mettre le elecaudio a la place de mes dnm sur mes enceintes , une grande douceur apparait , le timbre est suave ,chaud ,riche, belle ampleur ,grave rapide ,rond, aeration , les instruments sont vrais , honnetement le meilleur cable hp que j ai pu ecouté . A recommander vivement .
sebastien g.
Hmmmmmmmmmmmmmmmmm!!!!!!
Ayant hésité avant d'acheter et surtout après avoir lu divers infos, je suis passé à l'attaque.
Commande effectuée et livraison deux jours après.
Installation facile et là...............................
Ca marche fort et la qualité est au RDV.
Cet ampli est en harmonie avec mes eltax monitors 3.
Merci aux interlocuteurs de chez audiophonics.
rapport qualité prix défiant toute concurrence.
soignez vos câbles (et enceintes)...
A la lecture des forums et autres "avis" concernant les amplificateurs FDA (quelle que soit leur marque), je ne suis pas étonné par d'assez nombreuses critiques ou déceptions. Et, sans orgueil de ma part, je crois avoir mis le doigt sur l'origine de ces frustrations. Je m'explique: tout système HIFI est limité par l'un au moins de ses maillons: cela peut être les haut-parleurs ou/et les câbles. En effet, pour l'avoir expérimenté, je ne constate aucune amélioration sonore entre mon ampli analogique et mon FDA lorsque j'utilise, par exemple, un câble numérique coaxial Qed! par contre en le substituant par un câble num coax Canare, j'entre dans un autre monde qui permet alors à mon FX audio D820 d'exprimer toutes ses qualités. On ne le dira jamais assez, un système musical est constitué de plusieurs maillons et le résultat final est toujours limité par le maillon le plus faible, d'où ces frustrations et déceptions. Alors ... soignez vos câbles numériques, vos câbles d'enceinte et vos haut-parleurs et votre avis changera ... très probablement.
József K.
Great product
I'm wondering what the voice will be after burning
József K.
AC adapter 100-240V AC to 12-24V DC + 8 Jack adapters If you find it difficult to find a power supply that matches your device, or if it is no longer available on the market, this power supply with a universal adapter will make...
Low price, low quality, but it works.
the poles can not be replaced because the size of the two needles is not the same.
Must be a force of a gorilla to assemble
József K.
it's durable seem
The product is quality, but a lilte stiff
Arnaud D.
Je complète mon avis du 11 novembre dernier:
J'utilisais initialement des HP Proac Signature. Petites enceintes de très bonne qualité.
Au cas où.... j'ai essayé ma vieille paire de Cabasse Galion (40 ans tout de même et pas une rayure), que je trouvais toujours poussives, empatées. J'avais essayé avec un quad 405, un gros Harman Kardon AVR 7000, un Yamaha RX 3020,..., rien à faire aucune présence. Et la c'est une véritable naissance. Elles n'ont fait que dormir pendant toutes ces années en attendant cet accord avec ce Master 1 et 3. Tout est clair, les enceintes disparaissent dans un tableau de musiciens. L'orchestre symphonique si exigeant est parfaitement restitué, chaque instrument positionné, chaque vibration retransmise, chaque envolée restituée avec une clarté émouvante. Dans un tout autre style, le titre "Thorn in my Heart" (Lisa Ekhal) est maintenant d'une délicatesse émouvante. Elle nous soufle à l'oreil des paroles retranscrites avec une sensualité epoustouflante!
Je n'aurais jamais imaginé pouvoir disposer chez moi d'une restitution sonore aussi authentique!!!
Merci aux ingénieurs et à Audiophonics de nous faciliter l'accès à ce niveau de qualité avec des prix contenus.
Nassim H.
SHANLING M0 HiFi DAP Compact Music Player DAC ES9218P 32bit 384kHz DSD Black Shanling offers with its M0 a digital player high fidelity extremely compact with original aesthetics. But the Shanling M0 is also a concentrate of technologies and features to...
Génial !
Un mini lecteur qui a tout d'un grand : une qualité sonore excellente dans un format aussi réduit, s'en ai presque magique. Et a un prix sommes toute très contenu. Un excellent pas dans le monde de l'audiophile, avant de partir sur des DAP plus haut de gamme et entrainer notre oreille :)
Thierry Z.
AUDIO-GD MASTER 1 Pure Class A RCA XLR ACSS Balanced Preamplifier With this Master-1, Audio-GD offers one of the best preamplifiers in the world, integrating the quintessence of audio technolohy KEY POINTS: Symmetrical design Class...
Eine ausgezeichnete Vorstufe mit ausserordentlichem Preis / Leistung Verhältnis
Ich habe schon viele Vorstufen gehabt und versuche hier eine Historie aufzulisten.
Quad, Cabre AS-101, Audio Research SP9, SP14, SP25Mk2, Audio Note L3 kit Version.
Die Audio Note L3 hatte ich von allen am längsten in meiner Anlage. Sie wurde mehrmals mit besseren Bauteilen und Potentiometern verbessert und klingt auch sehr gut. Als ich nun die AUDIO-GD MASTER 1, etwa 40 Stunden eingespielt hatte, konnte ich sie endlich anhören und den Klang mit meiner Audio Note vergleichen. Was zuerst auffiel war das der Bass Bereich tiefer und besser abgebildet wurde mit Audio-GD, das tatsächlich noch mehr Details auf den abgespielten Aufnahmen zu hören sind, Stimmen kommen aber über die Audio Note noch etwas ansprechender als über die Audio-GD obschon beide Vorstufen die Stimmen sehr natürlich und musikalisch darbieten. In der Summe der klanglichen Eigenschaften ziehe ich aber die Audio-GD vor, sie ist eine excelente Vorstufe mit sehr hohem Klanglichen Niveau und dies unabhängig vom Preis, denn für diesen Preis gab es eine so gute Vorstufe in der Vergangenheit nicht.
Anlage:
Naim Music Server
Chord Hugo TT Wandler
Audio-GD Master 1
McIntosh MC 7270
Tannoy System 1200
Simon C.
Mr Simon Coleman
Purchased this unit to power my QUETEST DAC, which I had previously being powering with an ANKER PowerCore 20100 Power Bank, 4.8amp output. I plugged in the cable to the socket at the rear of the Audiophonics power supply and attached to the Quetest - no problems. The power supply ran warm after a couple of hours use but nothing I did not expect to experience. The following day I plugged the ANKER Power Bank into the power supply socket from the front of the unit to charge it up, this whilst simaltaneously using the rear socket to power the DAC. After a couple hours the battery was nearly fully charged. I felt the power supply unit - WOW - HOT !!!! . I immediately turned off the power to the unit and disconnected both charging cables and let the power supply unit cool down. It still appears to function ok, powering the DAC from both socket outlets when trialled. So, beware - the unit may have two 5v power outlets but I would strongly recommend only using one outlet at a time. Perhaps a note from the manufacturer would have been useful here ?
Arnaud D.
Acheté avec du cable HP Elecaudio 25OCC. Vissé et soudé.
Belle pièce parfaitement usinée et adaptée au câble ci-dessus.
Résultat assuré.
Arnaud D.
Excellent!
Acheté sur les conseils de David Aubert avec des cables RCA Canare Star Quad utilisés entre mon Dac et le pré-ampli AGD.
Le gain est évident et même étonnant avec une Image plus précise, plus nuancée, des aigus plus doux et des basses plus présentes.
Le titre "Thorn in my Heart" (Lisa Ekhal) est maintenant d'une délicatesse émouvante. Elle nous soufle à l'oreil des paroles retranscrites avec une sensualité epoustouflante!
Hautement recommandable à ce prix!
Quoc Quan T.
La claque aux câbles 3 x plus cher
Suite à un changement de Dac qui a envoyé le Dac Audio GD à la cave, j’ai voulu mettre à niveau les câbles en remplaçant les 1877phono par des Nordost blue heaven... 3 x le prix des 1877phono cela a duré 48h je suis revenu au 1877phono à cause des médiums et de l’air qui circule dans le musique. Il n’y a plus de doute pour moi ces câbles sont des merveilles sur mon ensemble Piega/Devialet.
Merci pour cette trouvaille. Bravo à Audiophonics et les autres foncez si vous manquez de 3D dans les voix!
Guy L.
Guy 13
même avis que le schuko
Guy L.
Guy 13
connecteur facile à monter très musical le cuivre pur aucune agressivité la aussi bon rapport qualité/ prix
