Thierry W.
Andrea S.
nCore Technology rocks !
I would like to spend a couple of words about this amplifier. Being it based on a new concept and being nCore technology something really new, especially in terms of the mathematical theory behind its design that has been recently formalized. I have a real passion for audiophile devices and even if I didn't have the possibility to buy very expensive rigs I had the possibility, along the years, to test several devices passing through the complete digital audio revolution started in the 80s. I don't have the ability of the perfect pitch and I'm not the kind of audiophile that spends one million words speaking about the music planes, the perspective box or other amenities or buys a 1m mono signal cable costing 1000€. What I have to say is that this amplifier really doesn't sound.. it doesn't sound at all, it simply amplifies the signal for your speakers. This could seem a very minimal statement but it's not actually ! I always
had the impression, with ALL the amplifiers I tried before in this 40 years, that there was a kind of "alias" following the sound, something like a "noise" modulated by the main signal that was superimposed to the real sound. In some amplifiers this "coloration" was less evident in some others was more but it was ALWAYS there. I was blaming the speakers, I was blaming the digital conversion but I couldn't really tell what it was causing it. Now I know, it was the amplifier ! This amplifier really amplifies only the sound you put at its inputs and doesn't generate this distorted alias that ALL the units I tried before
were adding. This "alias" has nothing to do with harmonic distortion or intermodulation stuff since I tried amplifiers with very nice numbers in this respect and it was the same. This is the first time in my life that I find an amplifier that is completely transparent. You can easily spot this because typically the
superimposed noise of other amplifiers was masking partially or completely the very subtle ambience-related echo signals, with this amplifier the sensation of reality instead is increased a bunch. Also the voices (that typically are causing a lot of the alias signal I was mentioning in other amplifiers) here are
reproduced with a very high degree of reality and you can easily grasp any nuance. The bass is hugely deep and very precise and clean. The absence of the alias allows you also to appreciate subtle sounds in the music that with other mplifiers are inaudible. The difference in the reproduction of songs I know very very well and the absence of this distorted alias is very evident and audible with exactly the same setup of source, cables and speakers changing only the amplifier. The alias noise I'm speaking about is mainly generated in the mid-high frequencies so, its absence, could seem to make the sound "dull" if your speakers have a very linear response on the high frequencies and you're used to amplifiers producing a lot of this alias sound. Nevertheless the amplifier reproduces the high frequencies with a very high control and an impressing cleaness. The sound of the trumpets and the piano are incredibly detailed and "real". In short, this amplifier is really of another league for me respect to anything I heard before. Let's come to the two only small issues I would like to pinpoint. The first one: there is a transient noise made by the amplifier when switching OFF that is clearly audible in the speakers. It's not loud but it's audible. It's mainly mid and high frequencies (woofers are not moving at all). This happens if the amplifier, after being switched ON, is not run for at least 10-15 minutes with music. The issue is related to the amplifier board, Hypex knows about it and they're working to a solution. The second drawback is the heat produced by the unit. nCore Class D amplifiers are VERY efficient and the on-board SMPS is very efficient as well, nonetheless a certain amount of heat is
produced when the amplifier works. In this implementation of the amplifier the only heat dissipation is provided by the aluminium box since there are no external/internal heatsinks. Running the amplifier at an average volume (in an apartment) for an extended period of time with an ambient temperature of 25-26°C makes the amplifier box gets warm. I don't know what could happen to the temperature of the amplifier in hot environments if the amplifier is run near its limits. In a domestic envrionment however I don't anticipate any issue with heat dissipation. Do I recommend this amplifier ? Well I bought two !! draw your own conclusions :-)
philippe B.
DAYTON AUDIO ND16FA-6 Speaker Driver Dome Tweeter Silk Neodymium 10W 6 Ohm 88dB 3500Hz - 27kHz Ø1.9cm
WONDOM AA-AB32178 Amplifier Module TPA3116 Class D 2 x 50 Watts 4 Ohms
bien
Andrea S.
Volume Controller / Source Selector
The device is very well assembled and the feeling of quality is high. Also the aluminium box with the front panel of polished black aluminium held in place by allen screws has a very professional look. Volume potentiometer rotates very smoothly with absolutely no noise being introduced in the audio signal and the source selector has very precise rotation marks so the overall feeling is the one of a very good quality product. The balance between Left and Right stereo channels of the audio volume at very low levels is good as well confirming the quality of the logarithmic potentiometer by ALPS. Since this is a passive preamp we cannot speak about "sound quality", however I can say there is no noise or hum being picked up by using this unit even if RF devices are placed in its vicinity so its shielding is very good and the internal wiring must have been properly routed. The only real drawback of the unit is its price that, unfortunately, is not cheap, especially considering that there are no active components inside it and consindering that its form factor is not the typical "big" one with a box 43cm wide. However, if you need a passive preamp built with very good components and you don't mind about the size of the box (or maybe you even want it to be the smallest possible) I would certainly consider this small passive preamp.
Jiri G.
TINYSINE CSR USB-SPI Bluetooth CSR Chip Programmer This TinySine USB-SPI CSR card will allow you to program your CSR Bluetooth chips. This module has a much better download speed than a parallel port programmer. This programmer...
It works
No problems, I could recommend.
Laurent R.
Câble de très grande qualité à un prix imbattable. Entièrement satisfait par cette achat.
Laurent R.
Reçue rapidement, produit très bien emballé visiblement de grande qualité.
J'avais de simple câbles Monster mais la mon système est transfigurer. Satisfait de mon achat.
Didier L.
Enfin le produit que j'attendais
En sortie USB du mac avec Audirvana le résultat est parfait avec un cable RCA SPDIF CANARE en entrée de mon DAC.
La qualité de fabrication est exemplaire.
La terre est reliée en entrée USB (apparement nécessaire pour obtenir le 32bit/768khz), mais bien isolée en sortie RCA et en sortie AES/EBU.
Je n'utilise pas d'alimentation auxiliaire pour le moment ni la sortie I2S HDMI.
Didier L.
Court-circuitant
C'est bien précisé, les caches sont court-circuitants. Ne pas utiliser sur les sorties des appareils. La pin centrale se dévisse, on peut donc dans ce cas l'utiliser en entrée et sortie.
Didier L.
Dust Cover Metal for XLR Male and Female Protect your male and female XLR inputs from oxidation and dust when not in use. Ideal to limit degradation of electronic circuits.
Mise à la terre
Attention pour la prise mâle, la pin 1 est reliée au chassis. Ne pas utiliser en sortie d'un appareil.
Claude B.
Déçus
Excellent produit, son détaillé et plus, commutation d'entrées agréable. MAIS :
* livré avec les sorties en opposition de phase : câble de liaison inversé
* carte mal découpée qui est du coup montée de travers et empêche le vérouillage correct des fibres optiques.
Certe j'ai acheté ce produit en promotion, et ces petits défauts sont facile à corriger; mais est-ce une raison pour fourguer des produits défectueux ?
José L.
J'ai acheté ce d'ongle en complément d'un casque Bluetooth momentum de chez sennheiser, l'ensemble fonctionne parfaitement et la diféfence en Bluetooth ou filaire n'est pas audible.
L'aptitude rempli parfaitement son rôle.
Frederic V.
Bon petit HP
J'ai acheté ces HP's pour réaliser une paire d'enceintes 2 voies compactes à un prix raisonnable.
Le HP est de bonne facture, donne de bonne basses pour un HP de ce diamètre, ils encaissent bien a puissance !
Je recommande ce HP fortement !
Fred.
Arnaud F.
FURUTECH TF Rhodium Plated OFC Copper Fuse Type T Slow 5x20mm 0.5A With its TF range, Furutech offers exceptional semi-slow time delay fuses. Indeed, the brand integrates very high quality components to maximise the performance of the fuse and...
Plus de transparence et de précision mais...
Comme tous les fusibles audiophiles, l'apport en transparence ou précision est réel et bienvenu mais dans le cas de ce Furutech, essayé sur un lecteur CD HDG ou un ampli-préampli HDG, la musicalité est moindre qu'avec le fusible d'origine (évidemment essayé dans les deux sens !). Cela dit, je suis convaincu maintenant qu'un fusible Furutech apportera beaucoup à de très nombreux systèmes par rapport au fusible d'origine. J'hésitai donc entre trois et quatre étoiles.
antoine L.
alimentation 15 volts 4A
avant de faire l'achat d'une alim , ou autre option, l'on a toujours un doute sur le résultât final,
c'est vrai que dans les années 1970 ( il me semble) des gens comme Naim ou autres avaient adoptés cet option, cela permettait de faire évoluer leur matériels, pré amplis ou amplis,.......
si le schéma d'un ampli, d'un pré ampli, ou d'un Dac est abouti, bien construit, pourquoi en changer, plutôt que d'y adjoindre une alimentation de qualité, ( surtout si le materiel est évolutif ) disons mieux construite, mieux filtrée plus conséquentes, plutôt que des alim genre PC portable qui n'apporteraient pas le courant suffisant pour exploiter au mieux un materiel audiophile, à l'achat et déballage d'un materiel l'on croit avoir trouvé la " pépite " que l'on cherchait, et surtout dans le résultat final n'est pas toujours entièrement satisfaisant,
en faisant l'achat de cette alim régulée, et c'est ce genre de résultat auquel je souhaitais bénéficier et le résultat final à dépassé la petite amélioration auquel j'avais espoir, l’amélioration a été un résultat bien plus flagrant, avec un résultat d'écoute bien supérieure à l'origine, tout les intervenants ( chanteurs, musiciens ) gagnent en précisions, localisations, présences, transparences, recul du bruit de fond, c'est comme une monté en gamme du materiel, qui aurait coûté bien plus cher, que le simple prix d'une alim,........à ne pas négliger,......
bruno n.
Pas audiophile
Câble standard. Rca standard.
L’objectif était de remplacer une rallonge en 3 morceaux
Grado 6,35 mâle femelle
Quel adaptateur 6,35 vers 3,5
Audioquest mini jack vers rca
le tout pour attaquer un ampli depuis un preamp en jack 6,35.. Bref le câble unique de cette gamme sommer câble donne un résultat plus terne que les « morceaux » plus typés audiophile. A mon avis c est un matériel plus destiné aux branchements pro qu audiophile. Dommage qu ils ne proposent pas un tel câble sur leur base « stratos » . Celui ci ne m a rien amené. J ai gardé ma rallonge grado+audioquest.
bruno n.
Usb3 supérieur
Difficile de trouver de l usb 3 de qualité plus audiophile que les câbles de base usb proposés avec les Dac mobile.
Après avoir envisagé du wireword, celui ci m apporte un plus audible dans la transparence principalement au niveau des aigus . Je trouvait mes tannoy légèrement ternes sur ce point, et ce câble a amené quelques micros détail mais surtout un chouilla d aération et de transparence dans le haut du spectre.
bref mieux que le câble bleu d origine (dac ifi) sans etre exorbitant...
A essayer..
Jean-Patrice H.
Vraiment bluffant
Ayant disposé, il y a quelques années d'un gros ampli de puissance en classe A qui représentait le nec plus ultra en matière de reproduction sonore, je ne m'attendais pas à écouter un son aussi excellent, et ce malgré les commentaires lus, que celui de ce petit AD18. Bravo! Je recommande cet ampli à tous ceux qui veulent avoir une véritable qualité hi-fi.
j'ai entrepris la réalisation d'un cordon rca avec ce câble de modulation. Le son semble plus dynamique, plus détaillé et gagne en clarté dans le haut du spectre. Le câble est un élément de la chaine aussi, et ce n'est que mon avis, je le conseillerais avec des électroniques plutôt douces
Ces connecteurs sont de très bonne facture et assurent un serrage très fort, de plus ils sont esthétiques et ajoutent un look très chic au cordon. Seul petit souci qui doit malgré tout rebuter personne, les soudures de la tresse et de la masse ne sont pas des plus aisées.
Fichtre les fiches
Non mais vraiment, quelle galère ces fiches DIN ! Qu'est ce qu'on n'est pas allé inventer à l'époque! Un bon bornier à visser c'était plus simple quand même. Mais non. Bref, j'ai été obligé d'acheter ces fiches pour faire des cables compatibles avec un vieil ampli qui n'accepte que ça. Un peu galère pour les monter car les trous n'acceptent que du 1mm2 max. Par ailleurs, le cul des fiches n'est pas un simple trou comme sur l'image, mais une espèce de tresse plastifiée d'1cm+ environ, solidaire du corps de la fiche. Ce système est archi nul, mais les fiches sont ok, même si le plastique me semble un peu mou. Un conseil, faites des cables exprès pour ces fiches en mettant des bananes ou des fourches à l'autre extrémité.
Avis limité
Cable souple et bien construit, rien à dire là dessus. Concernant ses qualités audio, je n'ai pas encore d'avis mais je ne l'ai pas acheté pour faire la différence entre une source à 5000€ et une autre à 50000€. Non, je devais faire de nouveaux câbles et j'ai pris Mogami, comme j'aurais pu prendre Sommercable. Sa structure le rend assez compliqué pour faire des terminaisons simples, mais c'est le seul bémol.
Yarbo c'est tout bon
Fines, esthétiques, pratiques, peu encombrantes, bonne qualité, tout est bon dans Yarbo. En plus, il y a les couleurs pour ne pas se tromper. Génial, non ?
Grosse banane
Ouaip, c'est de la grosse banane et franchement ça ne se met pas partout. Si vous avez de la place derrière vos enceintes ou votre ampli, ça peut passer mais sinon, regardez ailleurs. Sinon, la qualité de construction est au rdv et l'idée de la protection est très bonne.
stephane d.
audiocast M5
bonjour, produit expedié rapidement, conforme à mon utilisation à savoir lire ma musique en airplay sur mon ampli, appareillage pas evident au premier coup sur ma livebox , aussi après maintes essais fonctionne plutot bien, je l'utilise surtout pour envoyer mes musiques depuis disque dur branché sur livebox play depuis application music streamer et la c'est que du plaisir, tous les formats sont reconnus, ras, par contre via application ieast play je ne peux avoir accès à mes fichiers sur mon serveur livebox malgré le fait qu'il soit reconnu mais n'affiche rien du tout, pourquoi je n'ai pas encore trouvé la solution mais si quelqu'un pouvait m'aider ça serait avec plaisir, voilà mes ressentis sur le produit, pour le prix je le recommande sans detour sur ce site, allez y.
Frédéric D.
Mitigé
Résultat mitigé: un médium trés riche (un peu en avant) mais une définition et dynamique un peu en retrait. Au final, cela donne un petit côté "tube".
Pour des applications spécifiques mais, en général, je préfère encore le standard NE5534 ou le LM4562.
Frédéric D.
Dynamique d'enfer, timbres raffinés, équilibre parfait et transparence absolue.
Cet ampli a avantageusement remplacé 2 Parasound Halo A23 bridgés. C'est un ampli qui rivalise avec les meilleurs amplis du marché.
Il est trés (trop) compact. Seul détail légèrement ennuyeux: pas d'entrée XLR et un promiscuité des connecteurs qui rend le raccordement des cables un peu difficile. Mais une fois que cela est fait ... Toutefois, le boîtier est de bonne qualité.
Dommage que Audiophonics ne fait pas les plus gros modèles avec entrée XLR.
Arnaud F.
Précision mais au détriment de la musicalité
Évidemment que l'apport s'entend sur la précision des sons, des timbres plus subtils donc c'est à ce titre indispensable dans un système HDG mais malheureusement on perd en musicalité, en émotion, en tension dans la musique et ce dans dans les deux sens de montage (c'est évidemment encore pire dans le "mauvais" sens) par rapport à mon bon vieux fusibles en verre bas de gamme.
Arnaud F.
Remarquable prise IEC
Après de nombreux essais croisés, je peux confirmer certains avis sur mon système THDG : grande transparence, ouverture, précision, qualité des timbres, très beau grave, ferme ce qu'il faut et aigus magnifiques etc mais surtout en préservant la musicalité (les émotions, le subtil de la musique). Très grande neutralité donc se fait complètement oublié. Très intéressant quand on ne veut pas "typer" le son. de sa chaîne et avoir un composant très haut de gamme. Je recommande chaleureusement.
Philippe N.
AUDIO-GD MASTER 10 BYPASS PREAMP 2019 EDITION Class-A Balanced Amplifier ACSS 2x 500W 4 Ohm with Preamplifier Bypass The Audio-GD Master 10 is an impressive, symmetrical Class A amplifier that delivers great power to accompany the most demanding lousdspeakers. In this version, the Master 10...
Fantastique
Sur les forums tout a été dit sur cette marque excellente au rapport qualité prix hallucinant.vous pouvez acheté les yeux fermés.la seule chose qui me chagrine ,c'est au bout de 2ans de garantie,il faut renvoyé l'appareil chez le constructeur en cas de panne ,et vu le poids,c'est surement plusieurs centaines d'euros en frais d’expédition.
Philippe N.
superbe
un câble de modulation est fait pour faire transité un signal électrique ,d'un point a vers un point b et celui la le fait très bien,sans ajouté ou retiré quelque chose.le son son est propre, limpide ,avec beaucoup de clarté et de détails.il est cependant dommage que d'autre câbles du même type ne soit plus aux catalogue audiophonics
Philippe N.
exellent
la qualité des fiches neutrik,n'est plus a démontré,solidité ,montage facile et surtout qualité a l’écoute,pas la peine de dépensé plus.j'utilise ce montage pour relié mon atoll in400se a l’excellent intégré audio gd master 10.que du bonheur,idem pour la fiche male.
Hugo V.
Elle fait la différence!
testée en remplacement d'une LJ CM6631A pour accompagner un module ESS ES9038Q2M, dès la première écoute une perception beaucoup plus fine des détail, beaucoup d'espace et une meilleure représentation spatiale.
A noter, les amplis op du module ES9038Q2M avaient été remplacés par des Muses03.
James T.
Pourquoi dépenser plus ?
Très bon produit. Puissant malgré sa petite taille. Seul bémol en ce qui me concerne, fonctionne en Bluetooth sur des normes récentes (iPhone SE) je n'ai pas réussis à me connecter depuis des appareils plus anciens (iPad 2 - iPhone 4). Sans doute une question de normes Bluetooth.
James T.
Etonnant pour sa taille !
Utilisé dans une cuisine pour regarder la TV sur un iPad (via Molotov TV) ou écouter de la musique (Via Qobuz). Fonctionne sans problème en liaison filaire comme en Bluetooth.
Suffisamment puissant pour les petites pièces.
Laurent T.
Excellent ampli
Il s'agit effectivement d'un excellent amplificateur class D à très haut rendement et suffisant pour écoute confortable avec ma paire de Magnat Supreme 2002 d'un rendement de 93 dB/W/M.,
avec encore une bonne reserve de puissance .
" Le circuit embarque deux OP Amp NE5532 interchangeables. Une propriété qui fera le bonheur des amateurs de DIY et de ceux qui souhaitent personnaliser le rendu et moduler les composants en toute simplicité. " Un sujet dédié au théme
se trouve icI : http://www.diyaudio.com/forums/class-d/315681-tpa3250-listening.html.J'ai donc remplacé les deux OP Amp NE5532 par deux LME49720NA. Le resultat est EXCELLENT ,
une meilleure résolution sur tout le spectre, un meilleur espace de la scène sonore, des graves plus fermes .Pour á peine 10 €
un réel upgrade de cet ampli, le meilleur des 4 amplis Classe D
que j'ai testé.
Alain V.
recommandable
Rodage: au moins 20 h ensuite: ouverture définition dynamique. Très beau rendu sur la voix. Pour son prix vous serez surpris!
vincent r.
bonne surprise
Je l'ai acheté avant tout pour gagner de la place en remplaçant un ampli "classique" qui servait à alimenter le caisson de basse. Je ne pensais pas gagner en qualité, mais ce fut une bonne surprise. Les basses sont plus nettes, bien maîtrisées. Sinon c'est vrai que le boitier est chaud.
Patrick J.
Étonnant
J'ai connecté Ce petit ampli à des enceintes vintage Cabasse SAMPAN et le résultat est étonnant. Je ne me rappelle pas avoir eu un son aussi clair et agréable avec de bonnes basses. Avec Spotify, pas de différence entre entrée USB et Bluetooth , c'est vraiment bon.
J'ai ensuite tenté l'association avec mes enceintes haut rendement GKF VOIX DU CONCERT. Là encore le petit ampli AD18 les drive bien, mais honnêtement il y a un gros ecart de clarté et de timbres par rapport à mon ampli à tubes AIRTIGHT, c'est normal il vaut 30 fois plus cher.
Je le conserve donc en association avec les Cabasse qui retrouvent grâce à lui une seconde jeunesse. Merci audiophonics pour cette découverte.
Sébastien V.
câble de qualité
ce produit est de très bonne facture, cependant à vérifier,sur celui que j'ai reçu, la phase n'était pas du bon côté, un détail peu être mais qui a son importance quand on ne dispose pas de prises shuko
Sébastien V.
très bon dac
ce dac répond à mes attentes, le son est très bon, les graves bien présents, pour le prix, rien à redire, de plus le sav a été réactif car j'avais reçu l'appareil sans l'aop, ils ont envoyés la pièce très vite
Stéphane n.
Vraiment excellentissime!
J'avais acheté ces modules car séduit par la bonne sonorité des modules LJM L10 (FET) montés pour un ami, à la fois doux, claires avec une très bonne tenue en puissance.
Ces modules qui sont en fait des LJM L20SE (versions bipolaires du L20) m'on fait redécouvrir le grave sur mes Dynaudio, à la fois abyssale et détaillé et le reste est tout aussi bon avec une chute en pente douce vers l'extrême aigu qui donne une douceur "vintage" à cet ampli; je pensais pourtant que seule la classe D pouvait actuellement sortir un grave correcte à prix équivalent...
Le dernier ampli à m'avoir donné cette sensation était un Bryston 3B...
Acheté à la base pour simple exercice de style dans le but de posséder un ampli pseudo-vintage à transistors bipolaire, il est devenu mon ampli de référence piétinant même mes classe D (sauf Hypex!) et FDA qui s'entassent et me lassent très rapidement!
Yannick C.
Beau mais fragile et peu pratique
Les contacts de la fiche banane sont fragiles. Après un aller-retour dans la fiche femelle deux lamelles de contact se sont cassées.
Le principe retenu pour assurer le contact entre le fil et la fiche est absurde et inesthétique. Je ne recommande pas ces fiches même si elles ont une belle finition.
Vous nous voyez navré de cette déconvenue. Nous les vendons depuis des années sans connaitre le soucis rencontré.
Yannick C.
Dimensions standards pour pose rapide dans boîtier mural Legrand
Belle finition
Yannick C.
Bonne finition
Yannick C.
hugues g.
Pas d'autres Mots ...Indispenssable couteau suisse de la Hifi !!!
j'avais pas envie d'investir dans un appareil sans savoir exactement a quoi ça correspondait au niveau sonore, par rapport a une carte son d 'ordinateur. Et la grâce a ce mini DAC je suis en mesure d'entendre ce que lit exactement mon ordi , c'est magnifique c' est vraiment de la hifi bravo les chinois. En plus je trouve ce miniDAC beau , portatif sur plusieurs station d'écoute. Très bon pour l'éducation en attendant d'acheter mieux et très honnête pour les personnes nomade sur des ordis portable qui n 'ont pas de place.(je fais passer l'info).
et je n'oublie pas de remercier l'équipe d'AUDIOPHONICS pour cette perle.
hugues g.
TRES... PUISSANT...MALGRES SON APPARENCE
VOILA , livraison Impeccable. Le Test sur mes jamo s406 avec une Impédance de 6 Ohms et 90 dB. Je lui ai adjoint le DAC FX-AUDIO FX01 et la ça a été vraiment du plaisir ,pour une somme je dirais modeste...Il a driver les 2 colonnes sans aucun problème j'ai pousser 15 et 30/100 du volume pour une pièce de 25 mètres tout l"après midi avec des grosses pointes a 60/100. Tous les niveaux de cet ampli sont vraiment excellents autant en écoutant des mp3 que du flac en 24 bit. Un seul conseil a donner si vous l'acheter , le boîtier devient très chaud au toucher.ne posez rien dessus et prévoyez de bien l"aérer et un rodage progressif en crescendo. Moi je l'ai tester tout l’après midi et il n a pas explosé (RIRE!!!) a part la dame du syndic qui est venu taper a ma porte pour le bruit (comme d habitude). Sinon encore un petit bijou et merci a toute l 'équipe d'AUDIOPHONIC pour leur sérieux.
jean louis d.
Pour la soudure il ne faut pas hésiter à faire une boucle avec le fil (Si faible section) pour avoir plus de "volume", et bien étamer la banane et le câble. Excellente tenue macanique.
Une gaine thermo termine le tout.
Damien M.
Nickel, bon son.
Je suis très content de ce dac, il pressente un son bien meilleur que mon ordi de bureau, c'était le but, parfait. Raspberry 3 et Kodi.
Freddy D.
Jb capacitor
Bon rapport Q/P , c,est de l,entrée de gamme mais bons résultats quand même !
