Jean-François L.
Superbe choix
Le challenge n'était pas gagné d'avance : Alimenter mes Martin Logan Sequel II.
Après de nombreuses recherches sur...
Arnaud M.
TOP
Aucun souci sur cette commande, ce câble, surgainé par mes soins (finition en thermo rétractable), a pris place entre un...
Frederic L.
gaine thermo rétractable...
Qualité parfaite.
Service parait. Merci à l'équipe technique.
Customers reviews - There are 19292 reviews.
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz) that can be noticed from a 0.5-1m distance (or more) in silent environment (esp. from behind) ; the sound is different when the amp is off and when it is on (NC252M-based amps don't do this)
- if you plan to use the RCA inputs, expect sensitivity to ground-loops, esp. if you have a more complex sound system; if it includes a USB device (e.g. a DAC), you may need a proper USB isolator (a cheap one based on Adum3165 is just good enough)
- actually, I have been getting a slight humming sound from the RCA inputs all the time, until I connected the unbalanced source directly to the balanced input (shorting the SIG- to the ground pin); now it's finally completely silent!
- it is a pity that the XLR and RCA inputs cannot be switched remotely via some extension or upgrade; just some connector/header bypassing the mechanical switch would be very useful for a DIY implementation using relays; but considering my issues with the RCA inputs, it's probably better not using them at all anyway
Rob B.
NEOTECH NEP-3001G Power Cable Copper G-UPOCC Graphene 3x5.2mm² Ø16mm Neotech's NEP-3001G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both...
No brainer
Think this is one of the best cables for the money at the moment. Together with NEOTECH NC-P312G MKII Schuko + NEOTECH NC-P303II Connector IEC C13. It gave my NAD M23 a great boost. The graphene in the cable and the connectors will make the difference here I think. In my opinion it is not inferior to the Furutech dps-4.1. Highly recommended.
Luca C.
AUDIO-GD DI-25HE Digital Interface Amanero Accusilicon 32Bit 384kHz DSD512 The Audio-GD DI-25HE digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is designed to offer a plethora...
A highly recommended product!
Audiphonics is, as usual, a top website for purchasing high-quality products!
Immediate shipping!
Thanks and see you soon.
Enrico N.
INCREDIBILE!
Amplificatore veramente potente e con un suono decisamente soilfisticato! Pilota anche i sassi! Se usato in mono è addirittura spaventoso! Qualità sonica HI END!
Tutto questo a casa per 200 euro... Incredibile ma vero!
FRANCOIS D.
AUDIOPHONICS GREYHOUND Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically connecting your HiFi equipment,...
Félicitations !
Une fois de plus un super produit ! Magnifique qualité de fabrication. Ce câble respire la robustesse et améliore grandement les performances de mon installation.
FRANCOIS D.
Bravo AUDIOPHONICS
Bravo à vous pour la conception de ce produit de très belle qualité !
Fabrice C.
J'ai acheté cet ampli dans l'espoir de mieux alimenter mes enceintes Magnepan MG1.6 QR actuellement sur un Denon PMA 2000.
Si vous avez la même idée, oubliez! Le grave est étriqué, il est dépourvu du beau "moelleux" procuré avec le Denon. Le haut médium est outrageusement mis en avant au point de rendre l'écoute très fatigante sur certains titres. Les timbres sont dénaturés dans cette gamme de fréquence. D'une manière générale, la musique est désincarnée. Après deux mois d'essais, il m'apparait que cet appareil se marie très mal avec les Magnepan.
J'ai donc décidé de le tester sur mes vielles enceintes Rogers LS7T qui fonctionnent très bien avec mon ampli Onkio A 8500 (2 X 100 watts), et là, ça a été la très bonne surprise! Je l'ai associé à un DAC pré-ampli Silkline Zuki I acquis récemment. Eh bien, mes Rogers n'ont jamais aussi bien sonné! Le grave est charpenté, moelleux et soyeux à souhaits. Les timbres sont justes et équilibrés, l'aigu à sa place sans excès. L'écoute, légèrement flatteuse est vivante et extrêmement agréable.
En conclusion, selon mon expérience, cet ampli est capable du meilleur comme du pire en fonction des enceintes qui lui sont raccordées... Le mariage avec des Magnepan est désastreux mais, au contraire, il fait merveille avec des Rogers...
bruno j.
J'ai longuement réfléchi avant l 'achat pour upgrader mon wiim pro plus ,foncé car cette alimentation vaut vraiment le coup .Un câble neotech nep 3003 G lui convient a merveille et MERCI a audiophonics de leur livraison rapide
rodrigue Y.
Connecteur RCA
Très bonne qualité de fabrication, donne une impression de robustesse au touché. Par contre il faut utiliser un câble avec le diamètre extérieur adapté pour que la tresse de masse soit en contact fiable avec la vis de blocage, ou dénuder sur une bonne longueur pour pouvoir enrouler soigneusement la tresse de masse autour de la gaine du câble de façon à augmenter le diamètre extérieur. J'ai utilisé un peu de soudure pour fixer la tresse enroulée. Pour mon deuxième câble,j'ai soudé la masse directement sur le connecteur côté intérieur. Si vous soudez côté extérieur impossible de refermer le connecteur, ou il faut une soudure d'1mm d’épaisseur. Ouais pas simple. Malgré tout, j’aime bien la solidité et l’aspect de ces connecteurs . Rodrigue
Franck M.
Franck M.
SHANLING Protective Leather Case for Onix Alpha XI1 Portable DAC This leather protective case from Shanling is specially designed for the Onix Alpha XI1 portable DAC. Aesthetically pleasing, it also provides effective protection for the...
excellentissime
petit dac très bien construit, tout en métal avec des boutons physique, design rétro magnifique et dac très performant, très puissant et le son est irréprochable, facile à utiliser, sur PC reconnu instantanément ainsi que sur smartphone ou il faut installer une application pour avoir plus d'options du contrôle du dac : application sur le store de Google ; Eddict Player. je recommande ce produit pour ceux qui ne veulent pas trop investir et avoir un dac d'excellente qualité utilisable partout .
Vincent B.
Bof
Le caoutchouc n est pas assemblé. C est une sorte de joint torique qui a du mal a resté a en place. Il aurait mieux value qu il ait une rainure et se clipse sur l alu.
Decu je m attendaia a autre chose
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo piano performances, where you can see the sound hanging in space, fading away without any blur.
The treble is never harsh, and the overall sound is truly flat and stress-free. Despite this, even the lowest frequencies are clearly separated and dynamic without being overbearing. For acoustic music, this is exactly the sound I was looking for.
However, one point requires attention.
This amplifier also supports RCA input via a switch. But since the Purifi module is designed for a fully balanced configuration, using RCA results in a severe degradation in sound quality. Specifically, issues such as smearing, distortion, and poor imaging become noticeable—to the point where (to exaggerate slightly) it starts to resemble a sub-€100 Chinese digital amp.
Therefore, if your upstream equipment only has unbalanced RCA output, or a pseudo-XLR connection that only uses pin 2, simply using an adapter plug for conversion is not sufficient. The unbalanced-to-balanced conversion must be performed via active circuitry within the preamplifier!
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with older CD players or DACs that only have RCA outputs, an unbalanced-to-balanced conversion via electrical circuitry is necessary. In that regard, this device is essential for bringing out the full performance of the Purifi module and offers outstanding cost-performance.
The sound quality is warm, with the high frequencies extending naturally into the air range. The MUSES electronic volume control is also truly excellent!
However, for those who especially prefer a tight and direct sound, directly connecting a source device with built-in preamp functionality to the power amp via XLR may be more in line with their preferences.
Hans V.
Zeer fijn
Het is altijd afwachten met wat je krijgt....prijs/kwaliteitverhouding.
Maar ik vindt deze met deze pluggen zeer goed.
Het zilver geeft ook een mooi frisse geluidsbeeld.
Erg blij mee en zal.deze vaker bestellen mocht dit nodig zijn.
Ik ben tot deze pluggen gekomen omdat ze mooi kort zijn wat past in infinity kappa luidsprekers
Thierry C.
SHANLING ONIX ZENITH XST20 CD / SACD / MQA CD Transport Sanyo HD870 With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a...
L'adresse du site Head Fi
Introducing ONIX Zenith XST20 - High-End SACD Transport with true DSD output | Page 10 | Headphone Reviews and Discussion - Head-Fi.org https://share.google/JOatlSESuj2O2cFiM
Thierry C.
Un drive à un doigt de la perfection
La construction est remarquable, massive et pourtant l'esthétique estraffinée, l'opération sans problème et le fonctionnement presque parfaitement silencieux même à faible distance.
La qualité sonore est exceptionnelle, avec une dynamique une ampleur de restitution de l'espace remarquable et l'apport du DSD parfaitement tangible en utilisant la sortie I2S.
Le seul défaut en l'état actuel du Firmware est que le Gapless ne l'est pas parfaitement
On suivra avec profit la résolution de ce défaut apparemment bien connu de la communauté sur le site Head Fi où intervient un staff de Shanling
Laurent G.
AUDIOPHONICS HPA-DM500NIL Power Amplifier Class D Dual Mono Nilai500DIY 2x500W 4 Ohm Hand-assembled in our workshop in France, the Audiophonics HPA-DM500NIL power amplifier is a high-performance Class D dual-mono model, based on the new Hypex Nilai500DIY...
Ampli nilai
Tenue de grave impressionnante , spatialisation excellente , rapport qualité prix incroyable fonctionne avec un ampli préamplificateur moonriver 404 référence sur des grosses enceintes elipson Legacy 3230
Joseph C.
VEZZOSO X36 Balanced DAC ES9039PRO HDMI I2S SPDIF USB XMOS AES 32bit 768kHz DSD512 This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology ES9039PRO DAC chip and a Qualcomm...
Retour d’expérience
Retour d’expérience après dix jours d’utilisation. Malgré ses qualités de bande passante, je trouvais la sonorité « sèche « , une « trop grande «  séparation des instruments qui donnait la sensation d’écouter plusieurs chansons en même temps et un manque de fluidité..
J’ai vérifié la phase secteur et celle-ci était inversée. Après changement de la phase, le rendu c’est grandement amélioré sauf pour l’aspect fluidité. J’ai donc acquis une multiprise en aluminium schuko filtré. Cette dernière à résolu le soucis de fluidité :)
Pour résumer, ce dac est particulièrement sensible à la phase et qualité du secteur.
Jusqu’à présent tous mes précédents appareils n’ont révélé aucune différence sonore quand à la phase du secteur, c’est donc une première pour moi.
Cette vérification est de plus gratuite.
Si cela peut aider les utilisateurs du dac
PSVANE KT88-TII MARK II Tubes HiFi Serie (Matched Quad) These high-end PSVane T-Series Mark II matched tubes offer exceptional performance. These tubes have a superb design quality and will easily find their place in your audio...
PSVane KT88-TII Mark II
I replaced the PSVane KT88-TII Mark II tubes with the original Cayin KT88 and it was immediately noticeable how the dynamics, depth, delivery, clean highs, dynamic bass, noticeable mids changed, the sound suddenly got a completely different dimension, the space also changed, beautiful 3D details, which I had rarely heard before. The tubes arrived beautifully packed in boxes with foam, against damage, excellently packaged. So we'll see when they burn out after about 250 hours, I assume the sound will get even better and it will be like a symphony of tone, which I will enjoy forever :) ... Thanks to Audiophonics for the fast delivery to the Czech Republic.
Eric v.
AUDIOPHONICS STEALTH XLR Interconnect Cable XLR-XLR OCC Copper 0.3m (Pair) The Audiophonics Stealth range offers a selection of particularly high-performance, affordable cables, hand-assembled in our workshops in France. The Audiophonics Stealth XLR...
Très bon cable neutre et des détails et avec les XLR au rapport qualité/prix imbattable
Eric v.
MORNSUN LOF550-20B36 SMPS Switching Mode Power Supply Module 550W 36V 15.3A PFC This LOF550-20B36 switching-mode power supply module delivers 36V and 15.3A for 550W of power. The module features high-quality components and is...
Très bonne alimentation utilisée sur bloc mono fosi , permet en 36v de faire baisser la température des petits amplis... assure une puissance constante vu sa conception , parfais!
Eric v.
NEOTECH CU-AG-20-20 Wiring Cable OCC Copper / OCC Silver PE Insulation 0.518mm² Neotech CU-AG cabling wire ensures perfect signal transmission, using conductors made of OCC copper alloy and 20% OCC silver for optimal conductivity. Each conductor is...
Bon cable
Cable très rigide ,pratique pour cablage interne modulation mais la gaine est vraiment médiocre , fond très vite dommage sur un cable de qualité et à ce prix !
Arnaud C.
IBASSO DX180 Digital Audio Player DAP 4x CS43131 Bluetooth 5.0 Android 13 Black The DX180 from iBasso is an audiophile DAP of excellent quality. It benefits from a meticulous design incorporating four CS43131 DAC chips, delivering faithful, accurate and...
IBASSO DX180
Il n'y a pas photo entre le DX180 et mon Redmi Note 10 Pro qui est pourtant certifié HiRes. Le son est clair, les graves sont présents, les médiums bien séparer et les aigus viennent agréablement agrémenter tous styles de musique. Les instruments sont bien placés et pour profiter d'une scène sonore élargie.
Pour l'instant je le teste avec mes IEM FH3.
Je recommande surtout avec une mémoire suffisamment grande pour y loger plus de 44h de musique dont la moitié en 192khz avec qobuz.
Hâte que le baladeur soit rodé et de les essayer avec mes FH19.
Kirsch p.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Ne pas choisir la livraison par DPD
Audiophonics a été très réactif quant à la livraison mais DPD n'a pas respecté les délais nis mon colis il est arrivé dans un état abominable heureusement qu'il est bien protégé.
sinon le DAC et fantastique !
A H.
Great alternative for high end audio
I use this for my DSS mains conditioner with a Furutech cable and FI-e50 ( non-NCF) schuko on the other end. The powercon did not deteriorate the sound, it is clear, detailed but not very smooth in a high-end way. I guess this is due to the silver. But the Furutech rhodium will take care of the signal becoming smooth enough. Considering the price this powercon is a real steal.
A H.
Also with digital this is a great plug
My first c-004 was a big shock on my power amp. Stereo-image became very precise and clear, as if you listen to a master tape. What was lacking a bit was bass volume bit the increase in detail and realism… just incredible. I still wonder how this is possible with just an iec-plug.
With a Furutech FI-50 schuko I got that bass volume back and changing the iec-inlet on my amp for a Furutech gold iec-inlet also made the highs more silky and the whole thing perfectly balanced and natural.
I bought a second c-004 for my streamer+server. Now the effect wasn’t that spectacular as with the power amp, but still the c-004 gave clearly more detail and is worth every penny. Here a Furutech FI-50 NCF schuko brought some more bass detail and smoother highs.
So, the c-004 is a real bargain when you can get around the “not that strong” points like less bass with a power amp.
My cables are green and blue Furutech. This all combines very well for a reasonable price. Only the Furutech FI-50 NCF seems a bit expensive, but also is the p-004.
Jean-Baptiste A.
Acheté pour découpler mes enceintes jmlab cobalt 826 installées sur dalle granit de 3cm d'épaisseur sur 1 dalle de liège de 1cm pour la liaison sur carrelage. Elles sont couplé avec les pointes audio bastion xspike plus. Elles s'associent parfaitement dans cette composition. Comparativement les soundcare me faisaient perdre énormément de dynamique sur les basses fréquences. A l'opposé les pointes et contre pointes d'origine me permettaient de récupérer du dynamisme au détriment d'un confort d'écoute très fatiguant avec des aigus très agressif. Bref, avec ce couple audio bastion, j'ai pu récupérer avec brio le meilleur des 2 solutions précédentes. Un grave dynamique avec beaucoup plus de profondeur. Une séparation des instruments intelligible, des médiums merveilleux et des aigus presque soyeux, jamais agressif même à fort volume ! Pour ma configuration, je pense que je ne pourrai pas trouver mieux.
Jean-Baptiste A.
AUDIO BASTION SPIKE X PLUS Spike Stainless Steel M8 (Set x4) These Audio Bastion Spike X PLUS spikes effectively dampen the vibrations generated by your audio system. They are made of 304 stainless steel, both robust and durable....
Acheté pour découpler mes enceintes jmlab cobalt 826 installées sur dalle granit de 3cm d'épaisseur sur 1 dalle de liège de 1cm pour la liaison sur carrelage. Elles sont couplé avec les Contrepointes audio bastion xpad plus2. Elles s'associent parfaitement dans cette composition. Comparativement les soundcare me faisaient perdre énormément de dynamique sur les basses fréquences. A l'opposé les pointes et contre pointes d'origine me permettaient de récupérer du dynamisme au détriment d'un confort d'écoute très fatiguant avec des aigus très agressif. Bref, avec ce couple audio bastion, j'ai pu récupérer avec brio le meilleur des 2 solutions précédentes. Un grave dynamique avec beaucoup plus de profondeur. Une séparation des instruments intelligible, des médiums merveilleux et des aigus presque soyeux, jamais agressif même à fort volume ! Pour ma configuration, je pense que je ne pourrai pas trouver mieux.
Johannes R.
Fosi Audio P4 Preamp
Très approprié à mon avis. J'ai équipé les monos V3 d'Audiophonics OPA1642. Parfait pour moi ! DAC est un Soekris 1221, antérieur à Lindemann Limetree Bride.
Patrice P.
MUSICIAN PEGASUS II Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Black The Musician Pegasus II presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies,...
Haute valeur musicale ajoutée
Après plus d'un mois d'écoute, ce DAC révèle sa vraie nature très musicale et analogique. Il est aussi très précis, transparent. et silencieux. la scène sonore est large et profonde. Un vrai régal pour l'oreille. Matériel audiophile !
Mon système : Eversolo DMAP A6, amplicateur Ma252 et enceintes Sonus Faber Sonetto III.
Le rodage est un peu compliqué : au moins 250h pour qu'enfin la véritable signature sonore se stabilise. Pendant cette phase, on doute, on passe par des hauts et des bas... Puis, tout s'éclaire et là, c'est tout simplement magique.
Attention, ce DAC ne laisse rien passer. Toutes les liaisons (câbles) entre la box, la source, le DAC et l'ampli doivent être particulièrement soignées sinon on perd en précision et en fluidité.
Pour ma part il ne me reste plus qu'à changer ma source qui n'est plus au niveau de ce bijou ...
Je ne peux que recommander ce produit à tout ceux qui veulent approcher la sonorité "vinyle-like" avec de la précision, une dynamique franche, fluide et humaine.
philippe C.
FOSI AUDIO DC Power Noise Filter 12-55V 10A with DC jack doubler This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your...
Dynamique
J'ai essayé ce filtre qui m'apporte du silence, de la dynamique, des détails et un médium plus naturel. C'est une bonne solution pour améliorer les alimentations "sales" qui pullulent sur le marché actuel de la hifi.
C'est bien, c'est peu coûteux et ça marche... sensiblement.
olivier P.
Déception !!…
Matière sans doute qualitative .. mais finition très moyenne un brin corrodée et mal ébavurée… on trouve mieux à 10 fois moins cher et en inox dans le commerce .. client audiophonics régulier et ravi de l’être mais très déçu sur cet achat …
Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many numerous amplifiers in the ASR ranking.
After a few days, the unit sounds even better.
Unfortunately, this amplifier requires 13-14 volts of input voltage to deliver its full power.
Most preamplifiers deliver up to 2-2.5 volts.
It is possible to adjust the gain on the bottom of the unit using the preamplifier itself.
Unfortunately, this somewhat degrades the excellent technical values ​​(Sinad from 137 dB to 128, etc.).
These are still excellent values, and I don't hear any sonic differences on my Nuvero 140.
Audiophonics specifies the following gain values:
Bypass: 11.5 dB
19 dB
25 dB
31 dB
33 dB
The following values ​​can be set on the device:
11.5 dB
19 dB
24 dB
28 dB
I love this amplifier. I've certainly owned over 10 select and well-tested amplifiers before.
The LPA-S600NCX is my favorite.
Plenty of stage, plenty of detail, and decent dynamics.
Theodoros R.
ORACLE II 01 Discrete Single OPA DIP8 (Unit) The Oracle II 01 single OPA represents a new generation of hybrid discrete operational amplifier, specifically designed for audio applications and offering excellent performance...
NICE OPAMP
VERY NICE OPAMP FOR THE MONEY!!
Charles S.
Bravo Xangsane
A ce prix les connecteurs XS-6001 AU sont imbattables .
Timbres dynamique aération et musicalité qui fait mieux même à 10 fois le prix !
Merci Audiophonics pour cette découverte , rare aujourd'hui .
Aurelijus S.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks...
Elevating FM Radio: Integrating Teac PD-301-X with Topping E70 Velvet & B200 for Audiophile Sound
I have a Teac PD-301-x FM tuner with excellent sound but only an analog RCA output from the FM Radio. So, to have its sound in my HiFi audio system, I added PocketADC into the chain, which looks like this now: Analog FM signal from Teac PD-301-X → PocketADC → SPDIF → Topping E70 Velvet (DAC) → Topping B200 (amplifier) → Dynaudio Emit 20 speakers. PocketADC is transparent, and now I can enjoy excellent FM Radio quality from my nice Teac tuner.
I selected 48 kHz as the sampling rate because the source signal is analog FM radio, which has a limited frequency range—typically up to around 15 kHz. A 48 kHz sampling rate comfortably captures the full audio bandwidth of FM broadcasts without unnecessary overhead. I did not see any heat from pocketADC. Also, I use a linear power supply, Keces P6, which also powers my Teac FM Radio component.
FRANCOIS D.
AUDIOPHONICS STEALTH Power Cable Schuko C7 OFC Copper Shielded 3x3.5mm² 1.5m The power cable is the first element in a HiFi system, so its quality should not be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our...
Super produit !
J'utilise ce cordon sur ma SoundTouch 30 depuis plusieurs semaines et suis ravi de l'apport que procure ce câble au niveau de la restitution sonore . De plus le câble est robuste et de grande qualité. Bravo !
TUNG-SOL 6SN7GTB Dual Triode Tube (Unit) The 6SN7GTB Tung-Sol tube is a double triode tube that benefits from a beautiful design thanks to quality materials. This model has identical characteristics to the 6SN7GTA...
TUNG-SOL 6SN7GT
I bought the TUNG-SOL 6SN7 on recommendation and it worked well, they fit perfectly with my KT 88 Genalex Gold Lion power tubes, the sound is beautifully transparent and dynamic, I have a Cayin CS 88 A amplifier and it really plays great now. Thanks to Audiophonics for the fast delivery
TUNG-SOL 6SL7 Double Triode Tube (Unit) The Tung-Sol 6SL7 is a high-quality double triode tube. It has beeThe Tung-Sol 6SL7 is a high-quality double triode tube. It has been designed to amplify the low-frequency...
TUNG-SOL 6SL7GT
I bought the TUNG-SOL 6SL7 on recommendation and it worked well, they fit perfectly with my KT 88 Genalex Gold Lion power tubes, the sound is beautifully transparent and dynamic, I have a Cayin CS 88 A amplifier and it really plays great now. Thanks to Audiophonics for the fast delivery
Joseph C.
Belle acquisition
Vezzoso
J’utilise l’unité depuis 3 jours et le “plumage “ est incroyable : 6,5 kg usiné dans un bloc d’aluminium joliment teinté d’un vert olive.
Avec sa mise en place à l’aide des gants blancs en coton fournis, ont à l’impression d’avoir gagné à l’euro million. Par contre sa télécommande vous fait vite revenir à la réalité ^^
Comme décrit dans l’avis précédent, l’appareil démarre sur un compte à rebours de 66mn afin de chauffer et roder les condensateurs . Temps de chauffe bien insuffisant au vu de la première écoute qui s’en suit les oreilles grandes ouvertes : une patate sonne mieux. On repense à tous ces préjugés négatifs sur les dac asiatiques . Pas de bol dirait l’autre..
1, 2, 3 heures ah là on ne le reconnaît plus
Au bout de 5 ou 6 heures il sonne vraiment très bien
Bruno M.
Love it
I use it between Melco N100 and Chord M-Scaler that feeds Chord TT2.. According to Chord, I wasted money and it is unnecessary. To me, the improvement is substantial, as it removes stress from the music and renders it more detailed yet more relaxed at the same time. I can now listen for very long time without fatigue.
Véronique V.
Mitigé
Parfait pour une application sur des surfaces horizontales, mais l'adhésif est juste pour des surfaces verticales et carrément insuffisant pour des surfaces horizontales vers le bas, malgré un marouflage consciencieux. Tout se décolle dans les 24 heures ! Un ajoute de colle est indispensable...
Neng V.
THIEAUDIO PRESTIGE LTD In-Ear Monitors IEM Dynamic Electrostatic 22 Ohm 98dB 20Hz-80kHz With these Prestige LTD in-ear earphones, Thieaudio unveils an innovative, high-end pair of earphones that follows on from the Prestige Original model. Indeed,...
Fin du jeu
Simplement les meilleurs iem que j'ai entendu! Contrôle qualité au top les 2 unités sonne parfaitement. Un monstre de technique, de details, de fluidité, de séparation d'instruments, une scènes sonore énorme, le son est hors de la tête dans toutes des directions! Mention S+ pour audiophonics.fr pour la rapidité d'envoi, commandé la veille et reçu le lendemain le tout très bien emballé.
Nicolas B.
FOSI AUDIO ZP3 Balanced Preamplifier NE5532 The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The...
Après avoir utilisé le Fosi Audio P4 pendant plusieurs mois, j’étais curieux de découvrir ce que le nouveau ZP3 avait à offrir. Clairement pensé comme une évolution directe du P4, ce nouveau modèle apporte des améliorations sensibles à tous les niveaux.
Qualité sonore : plus de définition, plus de dynamique
Le ZP3 reprend l’approche du P4 avec ses AOP interchangeables, mais va plus loin en termes de transparence et de scène sonore. Le grave est mieux tenu, les médiums plus ouverts et les aigus plus ciselés sans devenir fatigants. On gagne en précision et en séparation des instruments, ce qui donne une écoute plus "hifi" que le P4, qui restait un peu rond ou doux selon les configurations.
Construction et design : plus sérieux
Là où le P4 semblait presque "jouet" dans sa finition, le ZP3 respire davantage la qualité. Châssis plus solide, meilleurs connecteurs, et une alimentation plus sérieuse permettent de tirer le meilleur de ses composants internes. C’est un vrai plus si vous l’intégrez dans un système audiophile.
Fonctionnalités : toujours aussi modulable
Comme le P4, le ZP3 permet le remplacement des AOP (op-amps), ce qui est un vrai bonheur pour les tweakeurs. Il est livré avec de très bons AOP d’origine (souvent des NE5532 ou dérivés), mais il prend une toute autre dimension avec des modèles comme les OPA627 ou Sparkos SS3602. De plus, il accepte sans problème des sources variées grâce à sa large plage de gain et ses entrées bien pensées.
Le Fosi Audio ZP3 est clairement une montée en gamme logique et réussie. Il conserve l’esprit DIY et audiophile du P4, mais avec un raffinement et une maturité sonore que le P4 n’atteignait pas. Si vous avez aimé le P4, vous allez adorer le ZP3. Et si vous hésitez entre les deux, le ZP3 justifie largement son tarif légèrement supérieur par une restitution bien plus maîtrisée et audiophile.
Steve D.
DAYTON AUDIO SPA300-D Class D Amplifier for Subwoofer 300W 20Hz-200Hz The Dayton Audio SPA300-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
Dayton spa300-D
Genalex
I let the tubes burn in for about 100 hours and they work great for me, the bass is dense, the mids are brilliant, the treble is excellent, clean. It's hard to find a better one. I have a Cayin CS 88 A amplifier, I also replaced the tubes in the preamp with Tung-Sol, which Audiophonics also offers, specifically Tung-Sol 6SN7GT and Tung-Sol 6SL7GT. Great combination for this amplifier. Thanks Audiophonics for the fast delivery, very well packaged :)
Theodoros R.
VERY NICE OPAMP!
Remi B.
XANGSANE XS-F02 Female XLR Plug Cap (Unit) This Xangsane XS-F02 XLR female cap is designed to protect the XLR male connectors of your audio equipment, such as a DAC or amplifier. It provides effective...
Bouchons
