Bruno R.
Un autre monde
Pour essayer le R2R dont j'entendais parler. Dac précédent smls do200pro avec ses 12 puces Cirus Logic qui,...
Davor M.
Davor M.
Very fast shipping to Croatia(4 days)
Customers reviews - There are 20916 reviews.
Matt H.
Expensive but worth it
I have just replaced the moulded IEC’s on a pair of PS Audio Premier sc cables feeding my active speakers and also the IEC and mains plug on a Wireworld Electra 5.2 that feeds my balanced transformer, feeding my source equipment.
Really impressed with the build quality and solid grip the IEC has when plugged in.
Nice uplift in sound quality and quieter mains supply allowing more detail through. Timing seems to have improved along with a more 3D soundstage.
Roland L.
FOSI AUDIO V1.0G Class D Stereo Amplifier TPA3116 2x50W 4 Ohm This small Fosi Audio V1.0G integrated amplifier is an affordable, high-quality Class D stereo amplifier. It incorporates a TI TPA3116D2 amplifier chip enabling it to develop...
Fosi audio V1.0G
Étonnant ce petit ampli, il est vraiment très musical, très équilibré, il est même fourni avec son alim secteur ! Super rapport qualité prix
Roland L.
MEAN WELL LRS-150-36 SMPS Switching Mode Power Supply Module 36V 4.3A 150W This Mean Well LRS-150-36 SMPS switching power supply is capable of delivering 36V and 4.3A for a power output of 150W. Its low-profile 1U form...
Très bonne alimentation.
Liam O.
EVERSOLO DMP-A6 MASTER EDITION UPGRADE 4TO Streamer 2xES9038Q2M WiFi DLNA AirPlay 2 Roon Bluetooth aptX HD 32bit 768kHz DSD512 Eversolo presents with its DMP-A6 MASTER EDITION a streamer as powerful as it is intuitive and stylish. It will allow you to stream your music with ease while enjoying excellent...
Excellent Service.
I learned of Audiophonics while watching a Youtube video about Eversolo streamers/dacs. It was mentioned that Audiophonics, who have a comprehensive workshop, would implement upgrades to the units to customers requirements. I ordered the Eversolo DMP-A6 Master Edition with the linear power supply, 4TB SSD and external cd/writer. My order was dealt with very expeditiously and arrived safely by courier.
The Eversolo installed without problems and I am very happy indeed with the sound. The Company responds to queries by return and I would be happy to deal with them again.
Liam.
J'ai entendu parler d'Audiophonics en regardant une vidéo Youtube sur les streamers/dacs Eversolo. Il a été mentionné qu'Audiophonics, qui dispose d'un atelier complet, mettrait en œuvre des mises à niveau des unités selon les exigences des clients. J'ai commandé l'Eversolo DMP-A6 Master Edition avec l'alimentation linéaire, un SSD de 4 To et un CD/graveur externe. Ma commande a été traitée très rapidement et est arrivée en toute sécurité par courrier. L'Eversolo s'est installé sans problème et je suis vraiment très content du son. La société répond aux questions par retour et je serais heureux de les traiter à nouveau.
Liam.
Robert v.
Great value CD-player upgrade!
Audiophonics did a fantastic job again with this DigiRescue Reclocker. I have the reclocker connected to a quite 'regular' 1990s Sony cd-player that has a Toslink output, and I power it with Audiophonics' 5V linear powersupply, on which I still had an unused USB 5V out. I use the "Canare by Audiophonics" digital coax cable to connect it to my DAC's s/pdif in, and a glass-based Toslink cable between the cd-player and the DigiRecue.
Before getting the Digirescue, I was not able to hear a difference between the cd-player's internal DAC and my external DAC. I am happy to report this is no longer the case now!
This device feels very well built, with metal housing and nice sturdy RCA connections. The reclocker has not only increased clarity and precision as advertised, but I can also clearly notice better dynamics and imaging. Overall, I experience more presence and enjoy my CD's more now. One thing to note in my setup, is that the bass not only gained presence, but also somehow feels significantly louder. That could/should be just due to either perceptual change as a result from better clarity and dynamics, or perhaps my smaller room size now more prominently interacting with these frequencies from the former. Either way, it's not on a level that's disturbing me but it was unanticipated and interesting.
Toslink to Coax conversion/ port choice is fully automatic, so you can tuck this small device also in difficult to reach spaces, should you want to.
The web-shopping experience has room for improvement: it is not cool that the product suddenly increased by 6 Euros in price during shopping/looking around. I wish that the advertised product price would be what you see the first time, and the web-store leaves out the marketing trickery.
Patrick R.
Protège bien
C’est sûrement un très bon produit mais je n’avais pas compris qu’il faut absolument l’utiliser en complément du desoxidant d100 (pas gold)
Patrick R.
Belles qualités
Montée sur un TCS31avec une IEC 50 NCF. Le résultat est un câble vraiment exceptionnel, sur mon DAC. Mise en remplacement d’une shucko Charlin. Il y a une petite amélioration en terme de contrôle: grave encore mieux tenu, équilibre général.
Arnaud B.
Ces pointes sont très bien usinées.
Un conseil sur le sens de positionnement de la pointe vers le haut ou vers le bas aurait été judicieux, il faut fait des essais e faire confiance à ses oreilles ce qui n est pas plus mal .
Arnaud B.
Ce câble haut parleur transmet le signal de façon équilibrée, sans coloration.
Il est utilisé en câblage interne dans les enceintes Revival Atalante 3, enceintes.
Je conseille ce produit Van Den Hul sans restriction
Étonnant !
Essayé sur des colonnes 2,5 voies 6 ohms 92db, en simple utilisation et strap basses aigus.
C' est un excellent midrange ! Il ne se suffit pas à lui seul mais peut être dans une composition plus complexe de câble en apportant des qualités de bas, haut medium indéniables!
De la précision, dynamique, finesse et beauté du son. Excellentissime !!
Fasi I.
DAC Module MS8413 SPDIF Coaxial Optical 24bit 192kHz This small, affordable DAC module is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24bit 192kHz. On the input side, the module...
I love it
an excellent value for money small module with outstanding sound. it can even drive a Hifiman HE400se with pleasant dynamics, albeit relatively quietly :)
Hocine H.
Belle boîte
Achetez uniquement pour le caisson et les embases, j'ai retiré le filtre, bypassé l'interrupteur et le fusible à réarmement et changé tout le câblage interne.
J'ai recâblé avec du OYAIDE EE / F-S2.0 V2 de3.3mm² et intégré un fitre SCHAFFNER protégé. Le résultat est au-delà de mes espérances tant la qualité est améliorée, mais comme toujours, la qualité du son est subjective pour chacun.
Je l'avais testé stock et j'ai été très déçu par rapport à ce que j'avais avant et ne regrette pas le tweak de ce distributeur.
Il revient au final plus cher de 160 euros, ce qui monte son coup à 400 euros avec le filtre et le câble, mais surpasse largement des distributeurs plus onéreux que j'ai pu posséder. Il faut aussi avoir envie de bricoler et il n'y a rien de compliqué, la grande difficulté réside dans le retrait des cosses sur l'interrupteur et le fusible car VIBORG a eu la bonne idée de les souder. Et pour finir, en suface il parait bien fini et propre, mais une fois démonté beaucoup de surprises sur la pietre qualité des éléments utilisés apparaissent, surtout dans un distributeur secteur ; bref tout est propre maintenant et ne m'en separerais pas de sitôt.
Même sans modification il vaut son prix, sauf le filtre qui est juste bon à jeter.
Bruno C.
THINHYA JA 310
utilisé avec une sortie optique toslink sur un ampli : son impeccable. L'appareil est bien fini , il fait bien son job. Il y a un petit afficheur bien visible indiquant piste et temps écoulé, situé sous le couvercle. L'objet est compact. Le bruit de rotation est très léger. C'est du made in China ( le prix !) , avec une notice uniquement en chinois. Pour info, le bouton on est celui du volume qu'il faut enfoncer. Il faut ajouter une alimentation , mais audiophonics le précise bien.
Alain V.
Quelle claque !
Vraiment impressionné par cet ampli, quelle puissance, que de détails, magnifiques spatialisation et tout cela à un prix mini. Enorme merci à David Aubert pour le précieux conseil !
Stephane N.
XANGSANE XS-005 Cable Male USB-A to Male USB-B 2.0 Silver Plated Triple Shielding 1m The Xangsane XS-005 is a high-quality USB cable. With a length of 1m, its 4 silver-plated copper conductors with a cross-section of 0.78mm² ensure excellent conductivity...
À ce prix là….
On ne peut qu’être surpris.
C’est neutre, ça fonctionne très bien, tout de suite.
Comparé à d’autre références bien plus coûteuses que j’ai possédé, il est loin d’être en dessous.
Très satisfait de cet achat.
Stephane N.
Excellent produit qui me permet de relier un ancien DAC AUDIOMAT dépourvu d’entrée USB depuis la sortie d’un McBookPro.
Je conseille cette interface.
Wayne M.
Oil caps
These caps made such a difference to my bowers 686 crossover, after the recap they just came to live smooth and accurate and a pleasure to listen to thanks
Jean-Cedric L.
JANTZEN AUDIO SILVER Z-CAP Capacitor 800V 6.8μF Jantzen Audio Silver Z-Cap capacitors maintain perfect sound neutrality and a very nice tonal balance. They are particularly suitable for use with a tweeter or midrange in...
Stunning !
Pas simple de faire un comparatif A/B mais utilisé en remplacement sur filtre ELIPSON MELODINE 7 avec d'autres Jantzen et un Jantzen Silver, après 20min d'écoutes différentes le son semble s'être stabilisé. Très ouvert, beaucoup de détails dans les mediums et aigus. Basses droites.
Jean-Cedric L.
Tiens ses promesses
Florent P.
IKKO OH10, un IEM extrêmement fun
L'OH10 était un IEM que je souhaitais depuis un petit bout de temps, mais étant donné son "âge" il était compliqué de le trouver encore à la vente directement en France. Du coup je suis super content d'avoir pu le trouver sur ce site (qui possède d'ailleurs une sélection intéressante).
On est donc sur un IEM avec une sonorité en "V Shape" donc assez axé sur les bass mais qui restent extrêmement bien défini ailleurs également. Je possède déjà un Moondrop Dusk qui est plus "calme" en terme de sonorité et également un Ziigaat Doscinco qui fait également parti des IEM plus axé sur les basses.
Mais pour le moment je dois dire que je préfère l'OH10 comme utilisation quotidienne car il est plus "fun" à l'écoute surtout pour mon style de musique (Techno, DnB, Funk, etc.) .
Pour le packaging je passe vite en revu car cela ne m'a jamais vraiment intéressé, classique. Pour les accessoires on y retrouve également deux jeux différents d'embouts en différentes taille S/M/L et une housse de transport en cuir. Câble très standard, qui fait le boulot mais je le changerai pour quelque chose qui vrille moins.
Concernant la fabrication, il est principalement en métal avec un très joli design. Il est cependant assez lourd comparé à tout ce que j'ai pu avoir mais ce n'est absolument pas un soucis pour moi au contraire.
Niveau fit, c'est bon de mon côté par contre les nozzle sont très courts il faudra vraiment trouver les embouts adaptés à cela, surtout que cela a un impact très important sur le rendu final du son.
Perso j'opte pour des embouts en mousse mémoire de forme plutôt que du silicone.
Enfin pour le reste livraison très rapide avec un très bon suivis. Traitement de la commande très professionnel et bien détaillé chez Audiophonics. Rien à dire, je recommenderai très surement sur le site si je suis à la recherche de matériel.
Jean-paul R.
Produit au top
Installation dans une salle home cinéma, dans un fauteuil fixé sur l'ossature en bois, le résultat est vraiment très bon .Le BST 300 est alimenté par un ampli Thomann t.amp e-400 sur un seul canal. Produit à recommander, le rapport qualité prix est excellent, merci audiophonics
Angelo P.
Un sensibile miglioramento
Sostituiti ai due op-amp di serie negli ampli Fosi V3 mono, questi hanno perso una leggerissima acidità del suono, rendendolo più caldo senza perdere in precisione, levigando i timbri degli strumenti e quindi facendo aumentare sensibilmente il livello di questi amplificatori. Per me la sostituzione è obbligatoria, considerando anche il prezzo.
PIERRE P.
convaincant
ce câble coaxial de la marque audiophonics en 50 centimètres est impressionnant d'efficacité , le transfert entre un audio et un lecteur réseau.
sa rigidité est signe de très bonne qualité avoir dans le temps mais visuellement il me convient
je recommande et je valide le soin apporte a ce câble fournit avec sa petite sacoche!!
PIERRE P.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Silver The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable...
REMARQUABLE
petit mais costaud :)
AUNE MAGIC DAC porte bien son nom, un magicien du son
il vous transforme la sonorité de la musique dans tous ses détails
la scène musicale est plus ouverte , les détails sont précis ,
relier un un lecteur réseau BLUESONUD NODE X
WAOUH le couple parfait ,sa simplicité de branchement via un câble coaxial et sa facilité d'exécution est remarquable
je ne regrette pas mon choix pour cette marque AUDIOPHILE
Werner H.
very good digital xlr cable
I have several cables between 500-2000€, but I have never experienced a cable for around 50€ sounding so good, I am confused and say respect!!
Dominique D.
FX-AUDIO TUBE-03 MKII Stereo Tube Preamplifier 6K4 Bluetooth 5.0 Silver The FX--Audio Tube-03 MKII is an update of the Tube-03E. It is an affordable two-tube 6K4 preamplifier. Complete and powerful, with its own volume control and adjustments for...
Manque de dynamique, de profondeur du son,
Fonctionnellement, rien à redire. il fait le travail qu'on lui demande.
En termes 'audiophile', c'est différent. Habitué à écouter des fichiers numériques de qualité en "Pure Direct", donc sans étage de préampli, que ce soit au casque ou sur mes enceintes de salon, je trouve qu'avec le préampli à tubes le son étouffé, moins dynamique (peut-être est-ce cela que les adeptes des vinyles appellent "son plus chaud"? Il n'a donc pas ma faveur, mais en matière audiophile, tout est affaire de gouts.
CATALIN L.
Great preamp
This is a great device, with a very transparent sound. Very good quality and the price is ok.
Christophe P.
Gold Plated 3 Pins Female Mini XLR Connector Ø5mm (Unit) This Mini XLR 3-pin female connector allows the design of cables mainly used for the connection of certain headsets (AKG for example). Its gold-plated copper contacts ensure a...
Bon connecteur pour AKG
J'ai refait un câble pour un casque AKG K702 avec ce connecteur mini-XLR et un câble Mogami W3106. Ca fonctionne pas mal et le câble ne se tord pas contrairement à l'original. Il faut bien tenir la prise pour souder afin que les connecteurs ne s'enfoncent pas dans le support plastique. J'ai retiré le manchon pour faire passer le câble, pourtant prévu pour un casque mais le diamètre est trop important... Côté son, pas vraiment de différence avec l'original, ou alors il faut roder le câble... (en général : Qobuz + Audirvana, Dac Mydac et ampli casque Myzic).
Un grand merci à Audiophonics pour l'envoi rapide et en cas de rupture, pour les échanges de mail constructifs.
Zoltán T.
Fantastic sound
He replaced an Allo Digione coax. It has a fantastic sound, I didn't regret it. The price is more than good, the delivery took a week to Hungary. The only negative is the screws, I don't know how they calculated this. But her voice makes up for it!
Best regards
Zoli, Hungary
Christian M.
LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8 The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8 network players by replacing the...
Se monte très facilement, matériel top qualité, reste à juger la différence au niveau de l'écoute...
Il existe une vidéo de montage destinée au modèle DMP-A6 mais qui se transpose, bien respecter les précautions indiquées, notamment en ce qui concerne l'ouverture du capot face avant.
Xavier L.
CLOUDYX CL-BOX Audio Streamer Bit-Perfect WiFi Bluetooth 5.0 AirPlay 2 DLNA Multiroom DAC AK4430 White The CloudyX CL-Box is an extremely practical combo audio network player / WiFi and Bluetooth receiver, enabling you to transform your audio installation into a true wireless...
Très simple avec l'appli et bonne qualité avec Qobuz (HiRes), prise réseau et sortie optique bers mon DAC et chaîne
Hal G.
Great Little Amplifier
I recently purchased this amplifier based upon the rating of a similar unit (stereo as opposed to mono) in ASR using the same NCore amplification. The unit is being used between the pre-outs on an Anthem MRX 540 to drive a Kef R6 Meta with a 12-volt trigger. What can I say besides it works flawlessly, and the sound is very accurate sound production without creating an unneeded sound signature of its own, it just reproduces exactly what it is fed. It is well made and at the price point a bargain.
Angelo F.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
ifi Audio iPOWER Adaptateur secteur / Alimentation Audio faible bruit 9V 2A
Dear Sir I received the Shanling CR60 today and I thank you.May I use the Ifi Audio iPOWER Adaptateur secteur / Alimentation Audio faible bruit 9V 2A (bought from you in 2018)togheter with the Shanling CR60?
Hi,yes the device can support 9V input
Frederic D.
DD BC30XLR XLR Interconnect Cables Stereo Silver OCC Copper Gold Plated 75cm (Pair) DD HiFi's BC30XLR is a 3-pin XLR to 3-pin XLR cable that can be used for all your balanced output connections, such as, for example, a DAC to an amplifier or active drivers. The...
Comme j'aime
Entre mon Eversolo DMP-A8 et mes Topping B200; laissent tout passé, tout! Transparents! Insensibles aux interférences! Parfaits! Pas la peine de payer plus cher selon moi. Merci
Frederic D.
TOPPING Dual Trigger Cable 12V Jack 3.5mm Male to 2x Jack 3.5mm Male for Mono Amplifier 2m This Topping cable is a double trigger cable, specifically designed for use with the brand's B100/B200 mono amplifiers. It consists of a 3.5mm stereo jack connector to 2 3.5mm...
Fait le job! Dommage qu'il n'y ait pas d'autres longueurs, 1m, 0.75m, etc...
Frederic D.
Super efficaces
Permet à mon système de mieux s'exprimer notamment dans les aigus. Rapport qualité prix imbattable
Frederic D.
TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while...
Toppingssime
En remplacement de mon excellent Rotel A11 Tribute Edition, ces 2 blocs mono me permettent logiquement de gagner énormément niveau scène sonore mais également sur tous les plans et singulièrement les hautes fréquences, les détails.... C'est mon dernier achat en matière d'ampli; j'ai trouvé! Vraiment sublimes avec mon Eversolo DMP-A8 et mes enceintes Revival Atalante 3.... Il ne me reste que le caisson de basse à faire évoluer. Merci
Dominique D.
FX-AUDIO DAC-SQ6 DAC Headphone Amplifier ES9038Q2M SA9227 32bit 768kHz DSD256 The FX-Audio SQ6 is an affordable DAC and headphone amplifier combo. It benefits from a meticulous design and versatile connectivity for assured integration into the vast...
Très beau son mais ... très capricieux
Le son est excellent, d'une finesse inconstestable, mais,
- sur pc (prise USB), la déconnexion est fréquente, le son est alors coupé.
- sur TV, la reconnaisssance/reconnexion (Fiche Opt) utilisée n'est pas systématique. Ce qui contraint à relancer le décodeur pour avoir le son sur l'ampli (alors que la TV est bien réglée en PCM). La bascule en "Opt" via le commutateur du DAC ne suffit pas toujours. Dommage.
Il est vraiment très très petit et fourni sans alimentation (juste un cable usb)
Alors que sur mon Dacmagic100 de Cambridge, la reconnaissance se fait toujours sans problème sur l'un comme sur l'autre.
Essai CD Ripper
Après le Transport CD je l'ai essayé pour ripper de CD
Aucun problème il fonctionne parfaitement
Très satisfait de ce produit
AUDIOPHONICS JDC-125 Power supply cable Jack DC 2.5mm to DC 2.5mm 1m This cable has been assembled by us in the Audiophonics workshops to allow you to enjoy the quality of the Elecaudio range at a lower cost. The choice of materials has been...
fais le job
KECES P6 Ultra Low Noise Regulated Linear Power Supply 5V / 7V / 9V / 12V + 12V / 15V / 19V / 24V 6A The Keces P6 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful...
Trois fois 5*
Voila mon chalenge ; alimenter ces trois éléments:
1 préampli phono MOON 110 en 24V
2 switch CHORD en 5V
3 LIVEBOX ORANGE en 12v
Le gain sur ces trois éléments est au delà de mes espérances et ce sur tour les paramètres sonores.
En plus c'est très rentable comparé a l'achat de trois alim de qualités similaires (SBOOSTER).
Le câble SECTEUR est un RAAM AMADEUS 5 avec prise secteur VIBORG OR (je suis fan de ce câble).
Julien L.
DAYTON AUDIO EPIQUE E150HE-44 Speaker Driver Subwoofer DVC MMAG Carbon Fiber 200W 8 Ohm 83dB 30Hz - 4000Hz Ø14cm Combining excellent performance with a reasonable price, the Epique E150HE-44 Carbon Fiber Diaphragm subwoofer sets a new standard for versatility, distortion and response for...
Subwoofer epique 5"
Produit envoyé très rapidement et bien emballé.
Toujours un plaisir d'acheter sur audiophonics.
SHANLING ME600 In-Ear Monitors Dynamic IEM 16 Ohm 100dB 12Hz-40kHz Black With its ME600, Shanling unveils dynamic in-ear monitors featuring no less than 5 diaphragms per earhone. Their 16-ohm impedance and 100±3dB sensitivity make them easy to drive.
SHANLING ME600
SHANLING ME600 - you will receive a nicely made box, after opening the headphones are placed in foam padding, there is also a large number of ear reductions, a cable with a 4.4mm jack connector in a nice case, there are also sound filters. After connecting to the Cayin N3 Ultra player, which has a classic tube sound mode, the sound pleasantly surprised me, the headphones are sufficiently dynamic, from low frequencies to the highest tones. The power is more than sufficient, the headphones are very precisely made, the cable is pleasantly flexible. Even after prolonged listening, the headphones fit well, they are not tiring. For the price, a good choice.
Clement L.
SOMMERCABLE MERIDIAN SP215 FG Speaker Cable OFC Copper Shielded 2x1.5mm² Ø 8mm This Sommercable Meridian SP215 FG speaker cable offers excellent performance in terms of conductivity. It features OFC copper conductors and triple shielding in aluminum foil...
Uniquement pour installation
Gaine peu esthétique, très rigide.
Alain R.
Outil indispensable du DIYeur
J'ai plusieurs tailles de ces cloches de découpe, elles sont géniales.
Je découpe aussi bien l'acier, l'aluminium que le bois.
Il faut tourner à la bonne vitesse, ni trop vite, ni trop lentement.
Dans l'acier et l'alu, un peu de lubrification améliore grandement la coupe. Cette cloche de 50mm fera un trou à l'arrière d'une enceinte bibliothèque pour un évent de 50 mm ext.
Jean-Luc L.
Le nivarna
J’ai mis longtemps pour me décider, tellement de choix, les prix. Et à force de lire tous ces retours positifs sur ce dac, j’ai donc passé le cap.
Il a aujourd’hui 150 heures de fonctionnement et c’est une merveille, chaque écoute est une douceur musicale dans le bons sens de terme, une richesse et un respect des timbres, faut il encore avoir les éléments l’entourant qui soient à la hauteur de ce monstre d’efficacité.
Je ne peux que conseiller ce dac .
Bertrand V.
Petit DAP au son étonnant pour son prix !
Si vous voulez du son de qualité (à mes oreilles) au meilleur prix et que vous n’êtes pas rebuté par une interface rudimentaire et quelques bizarreries (classement des fichiers et parfois des titres dans les fichiers), ce DAP devrait vous satisfaire.
Son utilisation est très intuitive, les commandes se trouve facilement à l’aveugle (DAP dans la poche) et il semble plutôt solide.
Il est léger et discret, bref en nomade il est parfait pour moi.
Un conseil : télécharger le dernier firmware : https://xduoo.net/firmware-download/
Yves B.
attention à la petite gaine transparente fournie
la petite gaine transparente fournie avec la fiche jack et son capot vissable n'est pas de la gaine thermorétractable comme on aurait pu s'y attendre. Donc inutile de chauffer dessus pour enserrer vos connexion avant de visser le capot. Vous ne réussirez qu'à la ratatiner! Tout le reste est sans reproche. Bonne soudabilité, bons contacts
Christophe M.
Moyen
J'ai ce câble depuis longtemps et je n'ai pas plus l'utiliser en raison du poids des connecteurs qui sont très lourds, beaucoup trop lourds. Ils viennent faire travailler dangeureusement les prises USB des machines sur lesquelles le câble est branché...
Patrick v.
Great machine.
I ordered the CR60 to pair it with my Auralic Aries G1 to listen to and upsample my CD collection. In "ripper" mode the CR60 was immediately recognized via a USB cable and I can now upsample my CD collection to 352.8k without any problems. Together with a 12V linear power supply this is a perfect combination. And what a sound quality! Thanks Audiophonics for the fast delivery and service.
