LAIV CRESCENDO CHORUS Power Amplifier Black
The LAiV Crescendo Chorus is an audiophile stereo power amplifier based on GaN (Gallium Nitride) technology, designed to deliver extremely transparent and dynamic sound reproduction in a compact format. Operating in GaN-optimized Class D, it uses ultra-fast switching GaN transistors combined with high-performance modulation and driver stages, resulting in very low distortion, wide bandwidth, and excellent energy efficiency.
By buying this product you get 107 loyalty points
Reference : 21849
1 079,00 €tax incl.
899,17 € tax excl.
Shipping date: 25-11-2026.
LAiV Crescendo Chorus GaN Class D Power Amplifier Stereo / Bridge Mono 2x80W / 1x120W 4 Ohm Black
Photo du LAIV CRESCENDO CHORUS
The amplifier offers two operating modes: a stereo mode delivering 2 x 50W into 8Ω (up to 2 x 80W into 4Ω), and a bridge mono mode providing 120W into 8Ω (also stable at 4Ω and down to 2Ω) with a fully balanced architecture. In terms of connectivity, it features balanced XLR and unbalanced RCA analog inputs, as well as speaker outputs via binding posts.
It also integrates a full protection system (DC, overcurrent, overheating) controlled by a microcontroller, a mode selector, LED indicators, and firmware update capability via microSD. Compact (approx. 1.5kg) and powered by a 160W internal power supply, it easily integrates into a modern HiFi or high-end desktop system.
LAiV Crescendo Chorus: GaN technology and optimized audio architecture
The Crescendo Chorus is based on GaN (Gallium Nitride) amplification technology, a major evolution compared to traditional MOSFETs. These transistors enable much faster switching, drastically reducing losses and distortion. It features no fewer than 4 CoolGaN™ G5 65R080D2 units from Infineon.
Result: an output signal nearly identical to the original analog signal, with more natural reproduction, improved micro-dynamics, and enhanced accuracy across the entire spectrum. This technology also minimizes heat while maintaining excellent efficiency.
Beyond technical performance, the Chorus is designed for balanced musical reproduction. It integrates high-performance signal modulators and carefully optimized driver stages, aiming to combine analytical precision with listening pleasure.
Its wide bandwidth (up to 80 kHz) and low distortion rate (< 0.005 %) allow it to faithfully reproduce details while maintaining a smooth and natural listening experience.
LAIV CRESCENDO CHORUS : technologie GaN et architecture audio optimisée
LAiV Crescendo Chorus: stereo or bridge mono mode
The Chorus stands out for its versatility thanks to its two operating modes:
  • In stereo mode, it operates as a conventional amplifier with two independent channels, delivering 50W per channel into 8Ω.
  • In bridge mono mode, it combines its two channels to produce fully differential balanced amplification, reaching 120W into 8Ω with improved dynamics and reduced noise.
This mode also enables a dual mono configuration using two units, providing complete channel separation and an even wider and more precise soundstage.
LAIV CRESCENDO CHORUS : mode stéréo ou mode bridge mono
LAiV Crescendo Chorus: advanced safety, ultra-low noise power supply, and long-term reliability
The LAiV Crescendo Chorus integrates a complete microcontroller-driven protection system, ensuring reliable and safe operation under all conditions. It continuously monitors critical parameters such as DC offset at the output, overcurrent, and operating temperature, effectively protecting both the amplifier and connected speakers.
The unit also relies on an ultra-low noise 160W internal power supply, specifically designed to provide clean, stable, and instantly available current. This power quality plays a key role in overall amplifier performance by reducing interference and ensuring precise, dynamic, and controlled sound reproduction, even during demanding passages.
At startup, a full diagnostic is performed before activating the outputs, preventing any risk to connected equipment. Finally, the presence of a microSD port under the unit for firmware updates allows the device to evolve over time, ensuring long-term durability and compatibility with future improvements.
LAIV CRESCENDO CHORUS : sécurité avancée, alimentation ultra faible bruit et fiabilité à long terme
Overview of the LAiV Crescendo Chorus
The Chorus offers simple and efficient connectivity, allowing it to integrate easily into most HiFi systems. It features a balanced XLR input ensuring excellent noise and interference immunity, as well as an unbalanced RCA input providing broad compatibility with many audio sources. Speaker outputs via binding posts ensure a reliable and secure connection to speakers.
Thanks to this versatility, the amplifier can be easily paired with a DAC or a preamplifier, whether in a high-end home system or a powerful desktop setup.
Aperçu du LAIV CRESCENDO CHORUS
1ON/OFF button
2Power LED
3Mono indicator LED
4Error LED
5Speaker binding post output (Mono on top)
6Balanced XLR input (Mono on the right)
7RCA input (Mono on the right)
8Stereo / RCA Mono / XLR Mono mode selector
9IEC power input and fuse
Technical specifications
Product typePower amplifier
TechnologyGaN
Transistors4x Infineon CoolGaN™ G5 65R080D2
Input1x RCA single-ended stereo/mono input
1x XLR balanced stereo/mono input
OutputSpeaker binding post output stereo/mono
Input impedanceRCA: approx. 94 kΩ
XLR: approx. 47 kΩ
Input sensitivity1.414Vrms (XLR stereo mode)
1.100Vrms (XLR mono mode)
0.707Vrms (RCA stereo mode)
0.550Vrms (RCA mono mode)
Gain22dB (XLR stereo mode)
28dB (XLR mono mode)
28dB (RCA stereo mode)
34dB (RCA mono mode)
Output power120W @ 8/4Ω (Mono mode)
80W/Channel @ 4Ω (Stereo mode)
50W/Channel @ 8Ω (Stereo mode)
Damping factor80 at 1kHz @ 8Ω (Stereo mode)
160 at 1kHz @ 8Ω (Mono mode)
Frequency response20Hz–80kHz, within ± 3 dB³
THD+N< 0.005% at 5W @ 8Ω
SNR≥ 100dB³
Dynamic range≥ 100dB³
Power supply100-260VAC 50/60Hz
Power consumption≤ 0.5W (Standby)
≤ 20 W (idle)
≤ 160W (max output power)
Fuse5A Slow-blow 5 x 20mm
Dimensions (WDH)168 x 180 x 60mm (+10mm with feet)
Weight1.5kg
Package contents1x LAiV Crescendo Chorus Amplifier
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipTransistors
Power (W)80.0
Power (W)120.0
Power (W)50.0
LAIV CRESCENDO CHORUS Power Amplifier GaN Class D Stereo / Bridge Mono 2x80W / 1x120W 4 Ohm Black
The LAiV Crescendo Chorus is an audiophile stereo power amplifier based on GaN (Gallium Nitride) technology, designed to deliver extremely...
