IFI AUDIO ZEN AIR PHONO 2 Phono Preamplifier MM/MC
The iFi Audio ZEN Air Phono 2 is an audiophile phono preamplifier designed to fully exploit the potential of turntables. Compatible with MM (Moving Magnet) and MC (Moving Coil) cartridges, it features ultra-precise RIAA equalization (±0.15 dB from 20Hz to 20kHz), a proprietary intelligent subsonic filter, and a symmetrical channel architecture to reduce noise and improve stereo separation.
Reference : 21879
139,00 €tax incl.
115,83 € tax excl.
iFi Audio Zen Air Phono 2 MM/MC Phono Preamplifier
IFI AUDIO ZEN Air Phono 2
The iFi Audio Zen Air Phono 2 is an audiophile phono preamplifier designed to fully exploit the potential of turntables. Compatible with MM (Moving Magnet) and MC (Moving Coil) cartridges, it features ultra-precise RIAA equalization (±0.15 dB from 20Hz to 20kHz), a proprietary intelligent subsonic filter, and a symmetrical channel architecture to reduce noise and improve stereo separation. It stands out with an extremely low noise level (EIN down to -151dBV), revealing micro-details in analog recordings. The Zen Air Phono 2 offers gain modes adapted for MM/MC, a line output up to 6.5V RMS, and simple connectivity with an RCA input for turntable and RCA output to amplifier. Powered by 5V DC (via DC jack), it features very low power consumption (<1.8W) and an optimized design for a clean and stable signal. Compact and accessible, it is an ideal solution to significantly improve the sound quality of a vinyl setup.
iFi Audio Zen Air Phono 2: intelligent subsonic filter for preserved bass and eliminated interference
Unlike traditional filters that cut low frequencies, the Zen Air Phono 2 uses an intelligent subsonic filter developed by iFi. It removes only unwanted vibrations caused by warped records without affecting the musical content.
The result is cleaner listening without rumble, while preserving bass depth and impact.
iFi Audio Zen Air Phono 2: MM / MC compatibility
The preamplifier offers gain selection adapted to MM and MC cartridges, ensuring perfect compatibility with most turntables.
A simple switch allows you to adjust the amplification level according to the cartridge type, guaranteeing optimal operation without compromising sound quality.
Overview of the iFi Audio Zen Air Phono 2
Overview of the IFI AUDIO ZEN Air Phono 2
1RCA output
2RCA phono input
3MM/MC switch
45V power input via DC jack
Technical specifications
Product typePhono preamplifier
CompatibilityMM/MC
Input1x RCA Phono
Output1x RCA
Max output level6.5Vrms
Frequency response20Hz to 20kHz (+/- 0.15dB)
Channel separation75dB
GainMM : 40dB
MC : 64dB
Input impedanceMM : 47 kOhms
MC : 1 kOhms
Output impedance100 ohms
THDMM : -90dB/0.005%
MC : -80dB/0.036%
SNRMM(40dB ±1dB) : 86dB (A-weighted)
MC (64dB ±1dB) : 40dB (A-weighted)
Power supply5V/1A DC
Power consumption< 1.8W
Dimensions158 x 117 x 35mm
Weight323g
Package contents1x iFi Audio Zen Air Phono 2
1x USB-A to DC jack power cable
InputPhono
ColorBlue
ClassN/A
The iFi Audio ZEN Air Phono 2 is an audiophile phono preamplifier designed to fully exploit the potential of turntables. Compatible with MM (Moving...
