The iFi Audio Zen Air Blue 2 is an audiophile Bluetooth receiver with integrated ES9023 DAC, designed to add high-quality wireless connectivity to any HiFi system. It is based on a 3-stage internal architecture (Bluetooth, DAC, amplification) integrating a Qualcomm QCC3095 chipset, a dedicated ESS Sabre DAC, and proprietary OV Series operational amplifiers, ensuring optimized signal processing at every stage. Compatible with Bluetooth 5.4, it supports a wide range of codecs including aptX Lossless, LDAC, LHDC/HWA, aptX Adaptive, aptX HD, aptX, AAC, and SBC, allowing transmission up to 24bit 96kHz and bitrates reaching up to 1200kbps in aptX Lossless.
It features a stereo RCA analog output (2.1V RMS) with ≤51Ω impedance, a signal-to-noise ratio of 109dB, very low distortion (<0.005%), and an extended frequency response up to 40kHz. The device also includes a high-precision GMT femto clock to reduce jitter, a supplied external antenna (short and long) to improve reception, a pairing and control button, and flexible operation thanks to a 5 to 12V DC power supply (via DC Jack), enabling use both in home environments and in a car or on battery power. Compact (158 x 100 x 35mm) and lightweight (305g), it is a complete and modern solution for high-fidelity wireless audio streaming.
| 1 | Power button |
| 2 | LED indicator |
| 3 | Logo |
| 4 | Bluetooth pairing |
| 5 | RCA output |
| 6 | Bluetooth antenna |
| 7 | 5–12V DC power input via DC jack |
Technical specifications
| Specifications | |
| Product type | Bluetooth receiver |
| DAC chip | ES9023 |
| Bluetooth chip | QCC3095 |
| Input | Bluetooth |
| Output | 1x RCA output |
| Bluetooth version | Bluetooth 5.4 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX Adaptive, aptX HD, aptX Lossless, LDAC, LDHC/HWA |
| Frequency response | 10Hz-20kHz (-3dB @ 44.1kHz) 20Hz-40kHz (-3dB @ 96kHz) |
| THD | < 0.005 % |
| SNR | 109dB |
| DNR | 110dB |
| Line output level | 2.1V |
| Output impedance | ≤ 51Ω |
| General | |
| Power supply | 5-12V DC ≥0.5A (center +) |
| Dimensions | 158 x 100 x 35mm (6.2” x 3.9” x 1.4”) |
| Weight | 305g (0.67lbs) |
| Package | 1x iFi Audio Zen Air Blue 2 1x Short Bluetooth antenna 1x Long Bluetooth antenna 1x USB-A to DC jack cable (1.2m) |
| Input | Bluetooth |
| Output | RCA |
| DAC / ADC Chip | NC |
| Color | Blue |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | aptX Adaptive |
| Supported Bluetooth codecs | HWA LHDC |
| Supported Bluetooth codecs | AAC |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | LDAC |
| Supported Bluetooth codecs | aptX Lossless |
| Supported Bluetooth codecs | SBC |
| Supported Bluetooth codecs | aptX |
