Eric H.
Artis R.
Good price performance
Gregory P.
Parfait pour un ensemble TAD
Aucun...
Customers reviews - There are 19427 reviews.
ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Not so practical at lest with big wires
Please see my review of the ETI Link Spade, which I find an excellent Product. Here it would be same, but opposite to the Spade version (where you have the same large opening with same, about 1cm long, diameter tube, with 2 screws to hold the wire), the tube, here you enter with the wire and it looses hal of the diameter (the tube) after the first screw. To hold a wire with one screw, just after the opening, makes it for me useless. A shame for that in theory great product.
Eric H.
Eric H.
MUNDORF MLYTIC AG Capacitor 25V 22000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Nicolas T.
AUDIOPHONICS CANARE Digital SPDIF Coaxial Cable 75 Ohm RCA-RCA 10m This SPDIF coaxial cable assembled in our workshops in France consists of an L-5CFB Canare cable and RCAP-C5F connectors of the same brand. This is a high quality 75 Ohm model...
Excellent Rapport Qualité/Prix !
Pas trop de surprise avec un câble Canare ! Et ce, même sur une distance S/PDIF de 10 mètres ! Câble relativement neutre et transparent, sans rondeur ni raideur ; et qui descend proprement dans le bas du spectre avec une belle tenue... Le plus grand avantage de ce câble est incontestablement l'excellente réjection des interférences environnantes ! Et cela, est un vrai plus et qui a guidé mon choix ici... Parfois, il ne faut pas chercher plus loin qu'un grand classique déjà bien éprouvé !
Patrice W.
Retour
J'ai refusé la livraison pour retour. Motif: ces câbles sont beaucoup trop gros et ne passent pas dans mes gaines. Je ne doute pas de leurs qualités mais je ne peux les utiliser
Erwan C.
Bluetooth 5.1 Receiver DAC Optical 24bit 96kHz / USB files Player This small Bluetooth 5.1 receiver with integrated digital / analog converter will allow you to provide your audio system with a wireless reception capacity. Thus, it becomes...
recepteur BT petit prix mais fait très bien le job
réception rapide.
correspond exactement à ce que je cherchais.
il m'a permis de transformer un vieil ampli en ampli acceptant le BT.
Qualité du son très bonne à ce que j'ai pu en juger (sur une autre chaine orientée HIFI).
Seul bémol, le niveau de son est faible par rapport à d'autres sources même quand on règle le niveau de volume au max sur le récepteur et sur la source BT. Mais ça ne détériore pas la qualité du son.
Il n'y a pas d’alimentation mais c'est indiqué dans la description.
Radu D.
FERRUM POWER SPLITTER Power Supply Splitter The Ferrum Power Splitter allows two devices to be powered from a single power supply. It has been designed to work with the Ferrum Hypsos power supply (sold separately). It is...
Ferrum power splitter
It does it's job as a splitter for people with Hypsos source, OOR and Wandla, it provides power to both accordingly, nothing fancy otherwise. Price a bit on the expensive side, but very nice metal build.
Radu D.
FERRUM OOR Balanced Preamplifier Headphone Amplifier Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the...
Ferrum OOR
I had the OOR in the past, sold it at some point and now bought it again, in combination with Hypsos and Wandla it goes sonically way beyond it's price point
Iulian M.
Verry good with minor issues.
It does not seem to have any iron in the conducting part of the connector. Just the golden cock ring has some iron and I just cut it of (seems stupid to include it, the connector looks better all black) as it could act as a small filter (like a ferrite bead). The cap is aluminium but I dont see how it could affect the sound, a better solution may have been plastic like WBT connectors. These connectors are my go to as it seems to not affect the sound (compared with just wire) and are way cheaper than WBT.
Bertrand G.
Tout a déjà été dit, la qualité d'écoute vaut bien ce petit investissement (avec des câbles USB et RCA de qualité). J'ajoute que l'amélioration de la clarté notamment sur la parole permet une écoute plus attentive des langues étrangères.
En bonus : Ce DAC est compatible avec la console de jeu PS5.
Cristian S.
100u Capacitors upgrade
I revise my initial review. After the cap upgrade with 100u quality parts the frequency response greatly improved. If you consider this board exchange of the series capacitors (signal path) is mandatory. But you will not regret it, the result is pretty impressive. Will keep me satisfied for a while ;)
Christophe G.
hallucinant !!
Je n'en crois pas mes oreilles. Au bout de 3 jours d'écoute tres attentive, et bien ...mille fois hélas , mais j'ai revendu sur ..." E...y" mon ampli actuel Denon PMA 1700 à 2000 euros, oui vous avez bien lu...2000 euros !!! je rejoins certains commentaires qui disent la même chose ! franchement , je dois vous dire que j'ai l'oreille absolue (étant musicien depuis 42 ans) et mon oreille quasi infaillible, n'a franchement pas entendu de différence notoire entre ce petit bijou et mon ampli denon 17 kilos plus lourds !!! oui il y a d'énormes progres en matière de classe D et cet ampli en est la preuve évidente . Elles sont connectées à une excellente paire de Monitor Audio Silver 100 (biblio) . ce matin encore j'écoutais des lieder de Mahler et la voix magnifique de Mildred Miller dans un enregistrement magistral de Bruno Walter (années 60) ...résultat extraordinaire. ! la cause est entendue...je le garde !
Denis S.
AIYIMA A200 Class D Amplifier TPA3255 2x180W 4 Ohm Bluetooth 5.0 Aptx-HD The Aiyima A200 is a powerful and affordable Class D stereo amplifier. It is based on a TPA3255 amplifier chip and a NE5532 AOP.
Oh My God !
Eh bien, c'est très bien... Il ne fonctionne qu'avec le Bluetooth, car c'est juste pour moi un ampli d'appoint... Mais il marche vraiment très bien, très étonné par la droiture, la puissance, le détail et la tenue des graves... Pour le prix, c'est un sans-faute, à découvrir. Grand merci à Audiophonics pour la livraison bien protégée...
Predrag S.
Very good product!
Bananas sit firmly, are solidly made and for the price there are no better ones!
Marius V.
IFI AUDIO GND DEFENDER Main Power Supply Ground Loop Filter 90-240VAC The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the...
Great
Works great, mains noise has been eliminated. Sound quality was not affected. I am very satisfied.
Maxime B.
DAYTON AUDIO PA130-8 Speaker Driver Full Range 50W 8 Ohm 88.2dB 90Hz - 15kHz Ø12.7cm The Dayton Audio PA130-8 is a good speaker at a low price, which can be used as a replacement for a defective model or for DIY speaker design. The wide covered frequency range...
Haut-parleurs de très bonne qualité
J'ai acheté ces haut-parleurs pour faire une paire d'Auratone DIY, et bien je suis bluffé du rendu. J'en ai fait plusieurs avec des caissons de taille différentes car pour copier des Auratone, le volume de la caisse est théoriquement trop petit par rapport aux spécifications constructeur. J'ai le sentiment que de respecter le volume donne un peu plus d'air, elles sonnent un peu plus vivantes.
Quand on regarde la courbe de réponse, on voit qu'elles sont très linéaires et c'est ce que je cherche. On arrive à entendre quand même du bas vers les 80Hz. Le gros + concerne toute la bande de bas et haut medium sur lesquels on a une super lisibilité, on entend les instruments avec beaucoup de détails, les effets de spécialisation ressortent très bien. Ca n'est jamais agressif.
Vraiment idéal pour trouver l'équilibre des instruments dans un mix entre le clair / obscure.
Pour le prix je suis bluffé et très content de mon investissement, je serais curieux d'entendre la différence avec des haut-parleurs de gamme supérieur.
Comme tout haut-parleur, ils ont besoin d'un temps de rodage car au début ça sonne assez dur, un peu de patience...
Jean-Christophe R.
Secteur
Câble de qualité que je raccorde à une barrette Audiphonics
Attention section importante et du coup assez rigide
Jean-Christophe R.
Barette
Fait le boulot, qualité au rendez vous
Je l'utilise pour une écoute au casque Haut de gamme et rien à redire
Super qualité, s'adapte sur plaque Dayton DBPP.
Lire mon avis sur la plaque Dayton DBPP pour passer mes Cabasse vintage en bi-câblage avec ces borniers.
Belle construction, câble hp jusqu'à 5 mm2 en serrage, fourches, fiches bananes aussi.
Livraison éclair d'Audiophonics.
Idéal pour passer mes CABASSE vintage en bi-câblage.
Souhaitant passer mes enceintes Cabasse Caravelle (les M2 : filtres avec 9 condensateurs, 7 selfs et une résistance) en bi-câblage, ces plaques sont idéales.
Elles se fixent sans aucune modification, à la place des anciens borniers en plastique marron, en position HORIZONTALE.
J'ai vissé dessus 4 borniers isolés EIZZ-304 (les borniers Jantzen Audio conviennent aussi) puis soudés les câbles internes, les 2 du bas vers les hp de graves 21NDB et les 2 borniers du haut vers les hp médiums DOM12 et tweeters DOM4 ensemble.
Cette plaque existe en simple câblage avec 2 trous mais la dimension ne convient pas (10x10 cm).
Il faut 10cm x 14 cm pour recouvrir le trou des Cabasse.
Cette plaque est suffisamment épaisse, de belle qualité.
Dernière précision, les encoches ou petites découpes horizontales autour des trous ne servent à rien, je les ai même bouché à la colle car elles laissent passer l'air.
Livraison ultra-rapide, toujours bravo à Audiophonics.
Le prix de la justesse ?
A mon tour de faire mon petit commentaire
Commandé après Noel et reçu 10 jours après malgrès une rupture de stock.
Bravo AudioPhonics
Configuration : Audirvana-CHORD hugo2-Cayin cs55a-DALI menuet-REL zéro-câblage de très bonne facture.
Ces tubes sont ni plus ni moins les plus chères dans cette référence, excepté les NOS.
Valent-ils leur prix ?
Apres la chauffe réglementaire des 30 minutes :
Il se dégage une excellent équilibre sans effet notoire. La musique fille librement sans aucune coloration.
Tout au plus une légère présence dans le haut du spectre sans aucune agressivité qui me fait penser que les PSVANES étais pas très démonstratifs dans cette zone…
Ces aigus justement donne plus de lumière aux morceaux et plus de présence aux instrument dans les passages les plus doux.
Sur la musique classique les différents groupes de violons parviennent à se détacher les uns des autres par leurs timbres spécifiques.
Dans les basses fréquences aucun bridage ; ça pousse fort !
Le combo full MULLARD (12AX7-12AU7) avec les TUNG-SOL KT120 en puissance est très équilibré tant il est transparent avec la musique. Il y a énormément de détails et le fait de monter le volume ne permet pas d’entendre plus de choses
D’autre part la dynamique me semble assez rare, j’entend par là que les passages les plus doux et les plus fort « semblent » joués à même niveau comme au concert. Particulièrement convainquant sur de la musique classique.
Je m’attend avec le rodage à gagner en ouverture et en profondeur.
En bref, c’est une toute autre esthétique que les PSVANES. Fallait essayer pour le savoir…
Je remet un commentaire plus tard.
ETI LINK SPADE Spades Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Spade offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Excellent Product!
Excellent Product, as per my opinion. Very well executed, quality and used materials. Large diameter to enter cable, screws same material as conductor. Very, shockingly, neutral, no turn to cold or warm, no smearing. Very homogeneous, e.g. in resolution, no preference for treble or low/bass. Bravo.
musicalité parfaite selon mes gouts ..sonorités impeccables ..en remplacement d'une electro harmonie 12au7..colis bien protéger et super rapide ..
Maurizio N.
Expectations confirmed.
I.m founding this preamp excellent in order quality construction and sound. It's very close and somewhat superior respect to my EC1 pre Electrocompaniet.
Quality sound improves noticeably after at least 100 hour and more burn-in (in the beginning is not too great).
I'm gonna replace output solen caps with better Janzten z cap superior.
Item arrived quickly in a few days, thanks to Audiophonics.
antoine L.
TAD EL84-M Power Tubes Pentode (Matched Pair) The TAD EL84-M pentode tubes offer a robust design and provide powerful midrange and well-defined bass. Durable, they provide up to 10,000 hours of use.
el84 tubes de puissances
je ne souhaitai pas intervenir, mais bon, Audiophonics m'a demandé d'intervenir, d'après ce que j'ai pu lire, ces tubes seraient fiables et solides avec une durée de vie importante, j'ai surtout acheté ces tubes pour les garder en secours, certaines références commencent à manquer ou à se raréfier,
Georges F.
Ces patins absorbent les vibrations sur mon parquet bois de façon très efficace, je recommande
Bernard T.
Fonctionne en continu depuis 6 ans avec un pc linux, convient parfaitement à la diffusion du son sur sur un ampli nad 302
Ralf S.
LHY AUDIO BATT-USB Regulated Linear Power Supply on Battery 5V 2A This LHY Audio BATT-USB regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (a total of 9.8Ah) and an ultra-low-noise LDO LT3042 linear...
Gute Akkuversorgung für Medienkonverter
Ich nutze das Gerät für den Betrieb eines Medienkonverters. Laufzeit mit einer vollen Ladung reicht locker für einen Betrieb über 48 Stunden. Das Problem der nicht vollständigen Trennung vom Stromnetz habe ich mit einer 2-poligen Zeitschaltuhr gelöst.
Florent c.
Branché en sortie d'un wiim pro, afin d'alimenter un ampli atoll et un ampli casque. Rien à redire, pas de perte de signal. Très satisfait.
Gorazd K.
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 3m The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Excellent cable and connectors for this price, it's hard to get a better cable of this length for this money. And as always fast shipping and safe packaging.
L'application fonctionne très bien, l'AirPlay et les radios aussi.
Il y a des mises à jour régulièrement de l'application.
L'installation est facile.
Le Dac interne est au dessus de mes attentes .
Auparavant j'avais un Dac Audio GD R1
YOSHIBUMI O.
swift delivery
I received my ordered items so fast even christmas season. So I can enjoy my time with the parts for amplifier. I thank you, Audiophonics!
Maximilian D.
Very cheap, but great cable.
Maximilian D.
Great cable , the ends are super malleable ! Good price.
Maximilian D.
Great , especially for the price!
Luc A.
J'ai une petite expérience en matière de câbles réseau et celui ci, contrairement a beaucoup d'autres cables blindés, ne bouchonne pas la musique. Bien au contraire. On y gagne en fidélité de restitution des timbres sans y perdre en definition. Top.
Flavien A.
Rapport prix calité imbatable!
Une vairitable differnce avec un cable classique!
Puggioni G.
Dayton audio
J'ai vu de nombreux avis avant de l'acheter et je dois dire que c'est un excellent produit
Nicolas J.
Silencieux mais interupteur de charge ne coupe pas du secteur
Pas de problème de fonctionnement, assez bonne autonomie. Effectivement silencieux mais pour moi, qui alimente un dac trop sensible à l’alimentation, il faut débrancher le câble de l'alimentation 9V, l’interrupteur de charge, qui est probablement unipolaire, ne suffit pas à couper la ronflette. Je bricolerai probablement quelque chose à l'occasion mais cela aurait bien de prévoir de série de couper tout lien avec le secteur avec l’interrupteur de charge.
Miguel d.
Incoparable value for money
The amp is everything you want and expect: clear, detailed, airy, neutral, but not in your face. Strong basses, tamed highs and well textured mid-range. I have it paired with a Conrad-Johnson CT-6 and Piega PL-XL4.
I observed a noticeable difference, however, when using the XLR inputs instead of RCA, even though, I am using an adaptor.
Superfast delivery, another happy customer!
Frederick R.
Etonnant
Un mois utilisation avec Tidal sans soucis.
Facile à installer et utiliser , j'ai aussi les radios que j'écoute habituellement.
Utilisé sur une chaine 'ordinaire' mais quand même avec un dac externe.
Par curiosité je l'ai branché sur ma bonne chaîne ( dac Atoll300 , pré Artera et Quad 606 ), en sortie toslink : le son est bien meilleur qu'avec mon PC dédié audio (Dell I5 20Mb mem) avec Audirvana ou Amarra Studio! ( avec une interface Armature Hecate )
Dimitar C.
EVERSOLO DMP-A6
After a month of using, my impressions are mixed.Starting with connectivity the device is ok(wi fi,bluetooth )streaming functions also good using Tidal. Most important for me is sound quality of the streamer and here is a my little disappointment,the sound is on the bright side and that is clear good middle, not deep bass and highs are not harsh.But the biggest problem of this device is that it is randomly stops the sound for about 15sec no matter what source is using, and here is my question to Audiophonics team what is the next step.
Benjamin B.
Best purchase ever and best value
I was sceptical enough to just buy 2 times 3 meter cabel without bananas because I did not want to make a bigger investment just to try the cable. That was a mistake. I imediately ordered banana plugs for the cable. I exchanged the cable for a chord company clearway which is almost exactly the same price but the performance of this Mogami is of a completeley another level.
My System is: Audio Note AN-J with a Hegel Röst as amplifier and I use the Dac of the röst with an Pro-Ject streamer.
At the beginning you notice that it is much cleaner sounding but the base was gone and the treble was to bright. After about 10 hours the base came back suddenly and the treble is also not so bright anymore and it is getting better and better now. Just listended 20 hours. Cable needs break in time! Who would belive that a cable needs break in time? Ridiculous. I would not have believed it if you told me but it does need break in time.
Together with a furutech FP-TCS31 my system is on a completely different level. If you would tell me the dac or the amplifer was exchanged for another component of double the price I would have believed it but is was just cable upgrade.
The changes were not subtle at all! Much better system now. Best value ever.
Cédric A.
Worth it !
Super conseil de l'équipe audiophonics. Installation simple, remplace un ifi zen blue sur mon vieil ampli. C'est un bon en avant en termes de qualité audio.
Michael M.
Sehr gute Qualität!
Diese Bindung Posts sind von sehr guter Qualität! Sie sehen nicht nur gut aus, sondern fühlen sich bei der Bedienung auch sehr gut an. Es macht tatsächlich s
Spaß die Dinger auf und zu zu drehen, weil das Gewinde seidenweich läuft. Das lässt auf ein hohes Maß an Präzision in der Fertigung schließen. Besonders hervorzuheben möchte ich, dass die Schraubklemmen, wenn man sie nicht braucht, sich selbst sehr angenehm arretieren. Benutzt man statt Bananas lieber Gabelstecker, so werden auch diese beim Festklemmen selbst arretiert und die Schraubklemmen lösen sich dann auch nur wenn man es will und diese wieder aufdreht.
Die innenseitige Befestigung für die Anschlussleitung ist mittels Madenschraube und Inbus schnell erledigt und auch hier hatte ich trotz mehrmaligen öffnen und schließen der Klemme keine Problem mit einem defekten Gewinde oder ähnlichem.
Die Klemmen sind ihr Geld wert!
Pascal A.
très bon
très bon rapport qualité prix. Je l'ai mis entre un smsl ao300 et des studios 3 de la maison du hp avec des 33 cms dans le grave. C'est une tuerie. L'ampli à 279 euros écrase tout ce qui est en dessous de 2500 euros. Le cable est au meme niveau.
Bart D.
Detailed Sound and Power: Fosi ZA3 Amplifier Review
Seamless Performance and Detailed Sound: Fosi ZA3 Amplifier Review
I recently purchased the Fosi ZA3 amplifier after reading glowing reviews about the V3 model. While the V3 lacked in delivering the desired subwoofer experience, I’m thrilled to report that the ZA3 performs exceptionally well, syncing flawlessly with volume adjustments. Paired with my B&W CDM-1 speakers (88dB SPL 8ohm 150w), I was amazed by the considerable enhancement in sound quality. This amplifier easily powers these speakers placed just a meter away from me.
One of the most impressive aspects is the amplifier's intricate level of detail in sound reproduction. Furthermore, it operates at a relatively low temperature, a feature I appreciate. Some users have lamented the absence of a dedicated power on/off button, but personally, the 3-second press of the volume knob isn't a hassle.
Additionally, the convenience of switching between XLR and RSA inputs is noteworthy. I did notice that the XLR connection produces significantly louder sound compared to both connections using the Topping DX5 Lite, although this discrepancy might be attributed to the Topping unit itself.
In conclusion, I highly recommend the Fosi ZA3 amplifier. The only feature I wish it had was a remote control. Also, it's worth mentioning that the transitions between XLR/RSA and powering on/off are impressively smooth, devoid of any popping sounds.
Volker R.
TOPPING MX5 Amplifier Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Black The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Volker R.
the Topping MX5 at PC just works super.
With ELAC BSU5 quit loud enough, no noise!
The Headphoneamp has enough power for every headphone fron 30Ohr till 600 Ohm.
The only bad thing... for every Change you need the remote control...not so funny!
LUDOVIC C.
Très bon produit et très bien réalisé.
Commander pour la réalisation personnelle d'un amplificateur Audio de Sonorisation de ma propre conception de 2X350W sous 8 ohms que ce soit bien clair, je possède des amplis Audio puissant réalisé avec sérieux, le transformateurs sur mesure que ma fournis Audiophonics est parfait ! C'est le moins que l'on puisse dire, il réalisé avec un grand sérieux, les tensions sont stable et correcte d'un enroulement à l'autre je le précise car c'est le principale problème que j'ai pu rencontrer sur des transformateurs d'autres marque pour lesquels j'ai du ajouter du fil rigide par tour aux enroulements pour non seulement avoir les tensions recherchés, mais quelle soit identique d'un enroulement à l'autre, ça se joue à quelques volts, parfois à 1 ou 2 volts mais pour les spécialistes lors d'un test de puissance et au bout de l'amplificateur, cette différence devient importante.
Bref produit de qualité et correctement livré si bien que j'en ai commandé un autre puisque tout ampli audio conçu sérieusement se doit d'avoir ses deux alimentation totalement séparés ;)
Pascal A.
Diabolique ce truc
Assis sur mon derrière, toutes mes références sont tombées. Je croyais que pour choisir un ampli, il fallait qu'il soit tres lourd et très cher. Ce truc de moins de 2 kilos, tout petit, enterre des amplis à 4 chiffres tranquille. Les idiophiles ont de quoi s'inquiéter les grands constructeurs aussi. Choisir des bons cables et une bonne source, ca ne pardonne rien.
