marc g.
Dominique R.
Hautement recommandé
Paulo D.
Bengt N.
Absolutely outstanding, BUT...
I am extremely happy with this product, the sound is excellent.
However, the display function has one major flaw. It shows the sampling rate in large characters, readable form the listening position. The sampling rate is not so interesting. The VOLUME on the other hand, is much more useful but it is displayed in so small characters that it is unreadable.
If a new version of this product would be released that displays the VOLUME in readable characters, I would buy it just for that.
Mon gros ampli home cinéma a du bluetooth mais le son était correct mais bof bof en branchant ce récepteur en numérique optique et en activant la fonction codec Ldac sur ma galaxy tab 5se c’est plus que correct c’est même bon on sent la différence elle palpable et Deezer est tellement plus agréable à écouter. pour de l’ecoute quotidienne c’est vraiment nickel, étonnant même le progrès du bluetooth en tout cas rapport qualité prix techno embarquée imbattable
Iulian O.
Works fine
Bought for HDMI ARC with an LG TV, it works well. Also tested for phone USB OTG, very good. Very good price for all functions included.
DD TC07AC USB-A to USB-C cable Pure Silver / OFC Copper OTG 50cm This DD TC07AC USB cable is a high-quality USB-A to USB-C cable. Part of the Nyx version 2.0 series, it features silver shielding and double insulation in PE NUC and PVC for...
très bon
Utilisé comme câble d'alimentation entre une alimentation régulée 5V et un récepteur Bluetooth . Le son est plus propre et net sans avoir à tendre l'oreille . Efficace .
Luka Š.
Nice presentation
I have bought for my old turntable and amplifier. For turntable I have notice that lower range is much more clear the mid and treble I didn't notice high difference, also need more time for burn out. For amplifier power cord notice difference was much higher. Immediately on lower volume output stage was much more clear, punchy and midrange was so tight that I was surprised for price to get it. Sound is more warmer but definitely for the price meets the requirements. Definitely recommend for decent power upgrade.
Micheal S.
Amazing quality
Very well built and amazing sound
Tibor P.
O-NOORUS D3 Class D Amplifier TPA3255 Bluetooth 5.0 2x130W 4 Ohm Red With its D3 class D amplifier, O-Noorus offers a compact, powerful amplifier with the essentials. The D3 features a TPA 3255 amplification chip and an output power of around...
Small masterpiece
It is much more than I expected when I ordered this amplifier for my bedroom. I use an optical cable from a streamer as an input source. The first surprise was the details coming from its built-in DAC, the second was the high power level and good dynamics. I think this setup would be enough for most of the living room installation as well.
Francois L.
Bon produit avec quelques limites
Bonne fiches assez faciles à souder, mais le controle qualité n'est pas parfait... une fiche s'est 'autodétruite' en voulant visser la partie noire, pourtant sans forcer (c'est potentiellement dû au fait que j'utilisais un cable de 6mm qui, bien que compatible est probablement trop juste pour ces connecteurs) ... les 3 autres fiches faites au même moment n'ont pas posé de problème...
Francois L.
Un boitier de selection de bonne facture (assez lourd et volumineux). La finition est correcte mais sans plus (le '0' du commutateur est un peu décalé).
Le principal défaut pour moi est que les cables à fourches ('spades' en anglais) ne sont pas compatibles avec la connectique du boitier
Peter P.
Gaine PTFE AWG11 Ø2.2mm Transparent This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 2.2mm diameter maximum. Transparent, it leaves the conductor visible.
Just perfect for my needs
I wanted to use this for isolation of Mogami W3082 speaker cable shielding wire (2.0 mm2).
The shielding wire fits inside just fine without much fiddling.
After heating it melted a little bit so the wire holds in the place.
François C.
TOPPING MX5 Amplifier Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Black The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Incomparable!
Acheté au départ pour un usage occasionnel durant mes vacances, j'ai découvert une solution idéale pour ne pas démarrer ma centrale nucléaire en classe A les jours Tempo Rouge EDF. Consommation 16VA à écoute normale!
Sur des enceintes pas trop difficiles dotées d'un rendement de 90dB ou plus, la restitution est de qualité même en bluetooth sur Qobuz ou bibliothèque locale. En USB c'est un peu meilleur sur les messages complexes.
Excellent rapport Q/P et puissance suffisante dans les conditions ci-dessus sans distorsion.
Paulo S.
Good interconnect
Very well concepted and made. Heavy weight.
Marc A.
La parfaite finition pour habiller un cable.
Marc A.
Fais le job
Impossible pour moi de dire que ce cable offre ceci ou cela de plus qu'un autre. Certains commentaires me font rire d'ailleurs avec le vocabulaire employé pour décrire le son d'un cable.
Certains auraient-ils une mémoire auditive surhumaine?... Perso, le temps de changer les cables pour comparer, j'ai oublié l'éventuelle subtilité qui pourrait les différencier.
Ce que je peux dire, est que ce cable est bien souple, la technologie "Quad" me parrait être un bon argument.
Mais en résumé et à l'écoute, je trouve que mes enceintes me donnent tout ce qu'elles savent faire et elles restent elles mêmes (pas de coloration). Les timbres sont beaux, c'est dynamique, précis et ça l'est car mon Dac et mes enceintes ont ces qualités. Ce cable respecte mon matériel.
Je n'ai pas dépensé une fortune et je ne suis pas convaincu qu'un cable 10 fois plus cher fasse mieux. De toute façon je me régale avec mon installation.
Donc je recommande
DAVID P.
les gaines n ont pas de couleur différentes
Dans mon exemplaire toutes les gaines sont noires. Ce n est pas compliqué de retrouver qui est qui mais ca oblige à une mesure de continuité et un marquage perso...
Pierre I.
Transformateur Torique sur Mesure
Commande reçue largement dans les temps, même avant.
De nombreux échanges ont permis d'avoir des caractéristiques très précises (dimensions, espace restreint) et ont été respectées.
Je recommande fortement, ne pas hésité à contacter le service technique qui est à votre écoute, très satisfait.
Alexis L.
Beau rendu, solide sur le corps.
Acheté le 24/02/2024, installé dans le cadre d'un mod sur casque Beyerdynamic DT990 (passage du casque en symétrique et cable détachable d'un seul coté du casque), je voulais me faire un cable mini XLR 4pins vers jack TRS 3.5mm, cable asymétrique donc..
Je l'utilise avec une gaine "11417 ELECAUDIO ADIACIUM GB Gaine Tressée Extensible Nylon (PET) 4-11mm" et un cable "5241 MOGAMI NEGLEX W2534 Câble Micro comportant 2 paires 0.22mm² Ø6mm".
C'est assez "fit" (voir photo), niveau montage, j'ai eu quelques péripéties: premièrement une soudure après montage total du connecteur qui avait lachée..obligé donc de tout recommencer...puis une des 2 pattes qui a cassée en l'occurence celle de gauche "L" (la petite).
J'ai quand meme réussi a souder mon fil gauche (L) sur le centre de la pièce (pas peu fier d'ailleurs), la voie droite "R" et jai mis ensemble les deux fils de masse sur la plus grosse des patte en les sertissant avec la patte qui sert a serrer le cable renforcé avec de l'étain, ca fonctionne très bien. Vérifié au multimètre.
J'ai aussi mis de la gaine thermo en 10mm avec un ratio de rétreint de 2:1 sur les contacts juste avant la partie doré, la gaine tressée est alors bien maintenue avec un résultat propre.
en résumé, tres bon connecteur qui inspire confiance. prendre son temps dans le montage est conseillé.
au moment du revissage du capuchon faites doucement quand vous passerez sur les contacts,en vissant doucement.
Gaine tressé + cable W2534 + gaine thermo on est sur 7.5-8mm...
allez si on cherche la petite bête une épaisseur plus importante des pattes serait mieux..
Le rendu est très bon. Bon connecteur !
Michel V.
.; et je vais en acheté une 3eme fois !
Malgré ma critique, comment ne pas être convaincu par le son, grandiose, équilibré, bluffant sur du jazz ou des voix.... et qui arrive a faire bouger des Infinity Kappa 7, au grand boomer, il est vrai, qui bouge enfin, avec les transfos exceptionnels du Cary .J 'imagine les résultats sur des enceintes a haut rendement. Le changement de lampes a réussi enfin à montrer ce dont ces Infinity sont capables. Enfin, à tous les acheteurs, merci audiophonics, il n' y a plus les délais d'attente de plus de 3 mois, comme pour mes deux premiers achats.
Si votre matériel vous permet de préférer le fonctionnement en triode, les lampes auront une plus longue durée de vie. Je vous recommande Les Gold Lion d' autant plus.
Michel, de Toulouse
Sébastien C.
OPA2210 Dual OPA DIP8 (Unit) This OPA2210 is a dual OPA mounted on DIP8. It is built on Texas Instrument's Super Beta precision complementary bipolar semiconductor...
Opa2210
A mon oreille en lpf de pcm1793 smsl l opa2210 sonne mieux que opa1612 opa1642 opa627 opa1656 lm4562 et muses02. L'Opa1692 sonne bien aussi. Et comparé le tout a un smsl c100 c'est comme si le c100 gommait les aspérités de la musique. Le burr brown + opa2210 est bien plus musical plus detaille meilleur rythme plus naturels les voix rendent bien aussi la basse ressort bien. Spatialisation niquelle.
Vraiment beaux
Inspirent la qualité. C' est massif, lourd, bien fini et classieux. Très bon produit pour le tarif, c' est une affaire.
Un peu cher
Bonne alimentation pour un wiim pro plus qui a tendance a "surgraver " e signal. L' ensemble devient plus précis et plus détouré. Moins onéreuse, se serait parfait.
Incroyable rqp !!
J' étais sceptique en attendant ma commande.
Reçu ce jour, je l' ai testé en stéréo et en double mono...
C' est un ampli très équilibré et qui sonne juste avec une belle image stéréo en solo et un punch et une puissance insoupçonnée en double mono.
Je voulais attendre la version plus avancée qui doit sortir cette année, mais déjà , c' est une très belle surprise. Et il n' a qu' une demi heure.... Les yeux fermés, même en solo !!
Discret
Petits tampons a la densité parfaite pour un wiim pro plus...
Matthis F.
CIEM 0.78mm Connector Gold Plated Ø3.5mm (Pair) This CIEM connector will allow you to create your own HiFi headphone cable. Beautifully made, it benefits from gold plated contacts, ensuring a very good conductivity and...
Un peu cher, mais permet de commander en france plutôt qu'en chine. Des packs de plusieurs unités seraient appréciés.
Matthis F.
ATAUDIO AT-X10 Jack 3.5mm TRS Connector Gold Plated Ø6mm Blue This ATAudio AT-X10 Jack 3.5mm TRS connector features a high quality design, ensuring both performance and durability. It features a rugged metal body and 24k gold-plated...
OK
Produit de qualité même si un peu cher.
Jean-Charles G.
Câble AES EBU 110 ohm
Inutile de dépenser plus, ce câble fait merveilleusement le travail, équilibre et neutralité.
Mon ancien câble à 400€ est revendu.
Edmond H.
MPA-125NC RCA
Commandé le dimanche et livré le mardi soir, parfait.
Ampli acheté pour driver des 'monitors' des 70's.....quelle claque !
J'ai eu une bi-amplification NAD qui ne lui arrivait pas à la cheville, que ce soit dans la faculté de gérer le HP de grave que dans la tenue des notes des medium/aigües.
Je suis maintenant dans la réécoute de mes meilleurs morceaux. De l'orgue au rock en passant par youn sun nah, rien que de l'exceptionnel.
Mes enceintes ont une impédance de 4 ohms, les 21 cms sont tenus, fermes, expressifs ( le bonheur ), alors que le reste du spectre est sensuel, précis, ciselé.
Je n'ai jamais entendu une différence telle sur un ampli.
Simple, de prix raisonnable, facilement logeable....Merci Audiophonics, vous m'avez redonné le sourire.
Raffaele V.
Digital Interface Module USB to SPDIF Coaxial Optical I2S SA9227 32bit 384kHz DSD256 AC3 DTS This module is a digital interface featuring a USB-B 2.0 input, as well as two SPDIF outputs in coaxial and Toslink optical formats and a 5-pin I2S output. The interface is...
Funziona molto bene, ottima alternativa all'Amanero
Works very well, great alternative to Amanero
Raffaele V.
Veramente Soddisfatto
Presa per prova, devo dire che ne sono rimasto estremamente soddisfatto, facile da montare, bisogna solo avere molta attenzione all'alimentazione che deve essere molto pulita.
Taken for testing, I must say that I was extremely satisfied with it, easy to assemble, you just need to pay close attention to the power supply which must be very clean.
Hocine H.
XANGSANE XS-008 24k Gold-Plated Spades Ø8mm (Set x4) These XS-008 spades from Xangsane are good quality. The copper alloy contacts are plated with 24k gold. Conductivity is therefore optimal, and the plating ensures resistance to...
Très robuste
Fourches très qualitative avec points de serrages à 4 endroits pour une très bonne fixation. Elles sont lourdes, très lourdes, on pourrait même s'en servir comme arme contendantre, je plaisante. Je n'ai pas trouvé mieux à ce prix pour un set de 4, en plus elles ont une très belle finition.
Michel V.
Durée de vie
Attention, attention : mon expérience, et j' en ai changé deux fois, c 'est la durée de vie de ces lampes .Achetées chez Audiophonics, qui ne peut être mise en cause
Montées sur un Cary Sli 80 ( en position Ultralinéaire, et pas triode), j' ai du les changer au bout d' une année d' utilisation .A 3 heures d' écoute moyenne par jour X 5 jours X 44 semaines = 660 Heures seulement . Donc, la fiabilité n 'est pas là sur mon installation. Le rendu ,les basses, la présence, la séparation des canaux sont par contre tous bien améliorés par rapport aux Sovtek installées à l' origine sur l' ampli.
Julian S.
Perfect Ethernet Cable
Better then other products. More details, more room...fully recommendation!
Marek P.
Perfect sound & DSD direct via UPnP works!
Continuing from my previous appraisal below: please do not do anything wrong as directed by some extremist forums: just downgrade to Gustarender 1.41 (when you have received 1.43) - BalenaEtcher or USBImager would do. Install USB drivers fist (for C port above ETH). Suddenly TIDAL HiRes & MQA works without any outages and you can stream DSD from your own UPnP resources instantly! I am not a user of Roon, and I will never be - no reason for it. Thank you Audiophonics for the support!
David G.
Pour le prix ces absorbeurs font le job!
Amélioration sensible de la qualité sonore mais surtout une scène sonore mieux étagée.
Jean-Michel P.
XDUOO XD05 BASIC Portable Headphone Amplifier DAC ES90108K2M XMOS 32bit 384kHz DSD256 xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means...
Dt990 Peo
Enfin un ampli qui drive autoritairement mon dr990 pro.
Bel espace sonore de la précision de l'ampleur.
Ça ne vaut pas un audio GD en classe A mais c'est plutôt étonnant.
Fantaisie militaire de Bashung bien respecté ça foisonne c'est détouré un joli aigu.
Une légère redondance dans le haut grave mais sans plus.
L'appareil est un peu gros mais il faut savoir ce qu'on veut.
Bref très bon rapport qualité prix
Jean-Pierre B.
Exceptionnel
Remplace un ifi audio Gemini (liaison séparée entre son et courant). Connecte un PC de bureau (gygabit X570 pro) avec Audirvāna et un DAC Matrix X Sabre Pro MQA. Amplificateur AUDIO-GD A1 en connexion symétrique, enceintes Nautilus 804.
Aucune comparaison possible cet Oyaide surclasse le Gemini dans tous les domaines : plus de volume, plus de transparence, plus de justesse des timbres, voix plus naturelles, plus de réalisme : impossible de revenir en arrière.
Qualité de construction Oyaide c’est pour dire.
Très bon RQP.
Clairement recommandé
Sans Soudure ?
Je ne vois pas comment ne pas souder la tresse de blindage. Il n'y a qu'une vis pour le point chaud et une pour le serre câble. J' ai essayé via le serre câble mais se n' est pas fiable. Je n'ai sûrement pas compris cette fiche !
Pierre G.
COMPLY SmartCore AP-SC Set of 3 Pairs of Memory Foam Eartips (M) (4.8-6.3mm) Get a comfortable listening experience with Comply Audio Pro memory foam ear tips. Compatible with most in-ear monitors, these patented SmartCore™ tips conform to the...
Adopté !
Description exacte ! Acheté pour remplacer les embouts silicone d'origine de mes écouteurs Sennheiser CX 300S que j'avais tendance à perdre. J'ai testé l'écoute à coté de mon lave-vaisselle qui tournait, nickel ! Ça isole bien mieux, les basses sont plus présentes, le son est de meilleur qualité globalement, le temps que la mousse s'adapte à l'oreille, et on les oublie, c'est très bien.
Jean-Philippe F.
Tubes pentodes TUNG-SOL EL34B (quad appairés)
Achetés pour remplacer un quad d'EL 34 Electro-Harmonix qui m'ont donné satisfaction depuis 12 ans... Je suis extrêmement surpris par le message musical de ces tubes. Chaque instrument est à sa place: les aigus ne sont pas agressifs, les basses sont profondes sans excès , les médiums clairs . comparés aux EH, la finesse est en plus. Pas de fatigue à l'écoute et les voix sont superbes. Les TUNG-SOL sont transparents du haut en bas, chauds avec une tonalité splendide. Pour l'instant en rodage sur un ampli de 2x35w. A recommander. Merci à l'équipe pour ce choix. Jean-Philippe.
GUSTARD N18 PRO Network Switch 5x RJ45 1x Optical Fiber Black The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz clock. The RJ45 Ethernet ports...
A suivre
Jai reçu en l'espace de moins de 24h ! ce switch Gustad , j"ai déja une horloge Gustad
je le compare a un upTone avec une alimentation special de très bonne qualité et donc signal d'horloge externe pour le deux
Pour l'instant le N18 est plus ouvert avec plus de timbres reste que l'uptone a un coté chantant qui est plus présent
Il faut savoir que le signal d'horloge doit être carré (ou est la doc ?)
Le rodage continu (combien de temps ?????)
En tout cas ce switch sonne droit
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 75cm The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Tres bon cable
Excellent câble, pourquoi payer plus cher ?
Fabrication au top
SHANLING EC3 CD Player Sanyo HD850 ES9219C Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Silver The Shanling EC3 is a CD player that stands out at first glance thanks to its compact size with measurements of only 188mm wide by 255mm deep and 68mm high. A certain...
Excellent Lecteur et drive CD
Excellent Lecteur CD ou transport.
C'est mon deuxième appareil, celui-ci en couleur alu est magnifique.
Merci Audiophonics pour l'envoi exprès avec un super emballage.
Pour 3 euros de plus...
Utilisées depuis longtemps suite a la lecture de bons avis sur ces fiches j'ai décidé d'en avoir le cœur net. Testée comparativement avec les fiches plus classiques du même fabricant ELECAUDIO RC-602 sur le même câble (occ crystal). Résultat immédiat : l'image sonore s'agrandit et ca respire beaucoup plus, avec de jolies extinctions de notes. J'ai aussi trouvé les timbres plus riches voir même un poil brillants, tout dépendra finalement de l'association avec le reste. Le retour aux RC-602 est compliqué... C'est fade, plat et l'extrême grave est en retrait.
Attention quand même au corps en plastique très fragile de ces fiches, très faciles a souder au demeurant. Le moindre coup de fer a souder de travers et hop on entame le filetage, ce qui rend impossible le vissage du corps. A part ce détail excellent produit agréable a utiliser au quotidien. Merci Elecaudio, un tel apport technologique pour un budget si faible est clairement significatif.
Florian C.
Ne correspond pas à la photo
Manchon sympa mais bien plus court que sur la photo.
Florian C.
Trop court et trop serré
Gaine de qualité bien que plus serrée que prévu. En effet j'ai commandé 7m pour un câble de 9mm de diamètre et de 6m de long mais ça s'est avéré largement trop court. Donc ne pas hésiter à prendre au minimum 30% de plus contrairement aux recommandations Audiophonics.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer...
Efficace !
Utilisé sur l'alim d'un DAC Topping E30 Lite, raccordé en usb à un Raspberry Pi4/Moode Audio.
Le Dac était auparavant alimenté par un bloc secteur Meanwell à découpage, désormais remplacé par un chargeur smartphone faible bruit (ça existe) + filtre USB à supercondensateurs.
L'aigu a perdu son côté un poil "piquant" mais reste lumineux et détaillé, et surtout mieux intégré au reste du spectre.
J'ai une alim linéaire LDOVR LT3045 qui subjectivement ne fait pas mieux, y compris sur le fameux "silence entre les notes".
Bien que le DAC soit ultra silencieux, il laissait visiblement passer des résidus HF du bloc secteur à découpage, ce que ce petit filtre nettoie de façon audible.
Edgar T.
XDUOO MX-01 Bluetooth 5.3 Transmitter aptX Adaptive xDuoo's MX-01 is a high-performance Bluetooth 5.3 transmitter. It incorporates a Qualcomm chip, a guarantee of stability and quality. The MX-01 is capable of transmitting...
Excellent product.
High quality product. The Bluetooth connections with it are very fast, without any break and with a big range. Very small form factor. It's a pity that Xduoo doesn't send the power supply, but any usb charger do the trick. I don't know why Xduoo designed this product without a remote control, it's a pity.
Edgar T.
USB-A male to USB-C male Gold Plated cable 2m This 2m USB-A male to USB-C male cable is beautifully designed, with copper conductors, a braided textile sheath and gold-plated contacts for efficient signal transmission.
Excellent product. I can't believe the inexpensive price.
Edgar T.
Excellent product.
Excellent quality that justifies the price.
Edgar T.
High quality. with a beautiful design. Recommended.
