The iBasso Jr Cookie Ti are in-ear monitors featuring a dynamic driver with a 10mm diameter composite diaphragm and aluminum-magnesium alloy dome. These IEMs also feature a dual Helmholtz resonance chamber to reduce distortion while improving transient response. Overall, the iBasso Jr Cookie Ti offers clear and detailed sound. Their 16-ohm impedance and 112dB sensitivity make them easy to drive. They also come with a detachable cable with interchangeable connectors: 3.5mm jack, 4.4mm balanced jack, or USB-C. The USB-C connector is equipped with a CX31993 DAC chip for immediate connection to a smartphone with high-quality digital-to-analog conversion.
| Specifications | |
| Product type | In-ear monitors |
| Driver | Dynamic |
| Coil | CCAW 0.03mm |
| Impedance | 16 ohms |
| Sensitivity | 112dB |
| Frequency response | 20Hz-22kHz |
| THD | < 1%@1kHz |
| SHell material | Alliage de titanium |
| Detachable cable | |
| Earphone connectors | CIEM 0.78mm |
| Cable termination | Interchangeable termination: 3.5mm jack 4.4mm balanced jack USB-C with CX31993 DAC |
| General | |
| Color | Matte |
| Weight | 10g/earphones |
| Package | 1x Pair of iBasso Jr. Cookie Ti earphones 1x Detachable 0.78mm CIEM cable with interchangeable termination 1x 3.5mm jack termination 1x 4.4mm balanced jack termination 1x USB-C termination |
| Color | Silver |
| Impedance (Ω) | 16 |
| Efficiency / Sensitivity (dB) | 112.0 |
| Wireless | No |
| Cable termination | USB-C |
| Cable termination | Jack 4.4mm |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
