Claude G.
Super !!
Remy C.
Simple et efficace
Lacking
Customers reviews - There are 19518 reviews.
Kirsch p.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Ne pas choisir la livraison par DPD
Audiophonics a été très réactif quant à la livraison mais DPD n'a pas respecté les délais nis mon colis il est arrivé dans un état abominable heureusement qu'il est bien protégé.
sinon le DAC et fantastique !
A H.
Great alternative for high end audio
I use this for my DSS mains conditioner with a Furutech cable and FI-e50 ( non-NCF) schuko on the other end. The powercon did not deteriorate the sound, it is clear, detailed but not very smooth in a high-end way. I guess this is due to the silver. But the Furutech rhodium will take care of the signal becoming smooth enough. Considering the price this powercon is a real steal.
A H.
Also with digital this is a great plug
My first c-004 was a big shock on my power amp. Stereo-image became very precise and clear, as if you listen to a master tape. What was lacking a bit was bass volume bit the increase in detail and realism… just incredible. I still wonder how this is possible with just an iec-plug.
With a Furutech FI-50 schuko I got that bass volume back and changing the iec-inlet on my amp for a Furutech gold iec-inlet also made the highs more silky and the whole thing perfectly balanced and natural.
I bought a second c-004 for my streamer+server. Now the effect wasn’t that spectacular as with the power amp, but still the c-004 gave clearly more detail and is worth every penny. Here a Furutech FI-50 NCF schuko brought some more bass detail and smoother highs.
So, the c-004 is a real bargain when you can get around the “not that strong” points like less bass with a power amp.
My cables are green and blue Furutech. This all combines very well for a reasonable price. Only the Furutech FI-50 NCF seems a bit expensive, but also is the p-004.
Jean-Baptiste A.
Acheté pour découpler mes enceintes jmlab cobalt 826 installées sur dalle granit de 3cm d'épaisseur sur 1 dalle de liège de 1cm pour la liaison sur carrelage. Elles sont couplé avec les pointes audio bastion xspike plus. Elles s'associent parfaitement dans cette composition. Comparativement les soundcare me faisaient perdre énormément de dynamique sur les basses fréquences. A l'opposé les pointes et contre pointes d'origine me permettaient de récupérer du dynamisme au détriment d'un confort d'écoute très fatiguant avec des aigus très agressif. Bref, avec ce couple audio bastion, j'ai pu récupérer avec brio le meilleur des 2 solutions précédentes. Un grave dynamique avec beaucoup plus de profondeur. Une séparation des instruments intelligible, des médiums merveilleux et des aigus presque soyeux, jamais agressif même à fort volume ! Pour ma configuration, je pense que je ne pourrai pas trouver mieux.
Jean-Baptiste A.
AUDIO BASTION SPIKE X PLUS Spike Stainless Steel M8 (Set x4) These Audio Bastion Spike X PLUS spikes effectively dampen the vibrations generated by your audio system. They are made of 304 stainless steel, both robust and durable....
Acheté pour découpler mes enceintes jmlab cobalt 826 installées sur dalle granit de 3cm d'épaisseur sur 1 dalle de liège de 1cm pour la liaison sur carrelage. Elles sont couplé avec les Contrepointes audio bastion xpad plus2. Elles s'associent parfaitement dans cette composition. Comparativement les soundcare me faisaient perdre énormément de dynamique sur les basses fréquences. A l'opposé les pointes et contre pointes d'origine me permettaient de récupérer du dynamisme au détriment d'un confort d'écoute très fatiguant avec des aigus très agressif. Bref, avec ce couple audio bastion, j'ai pu récupérer avec brio le meilleur des 2 solutions précédentes. Un grave dynamique avec beaucoup plus de profondeur. Une séparation des instruments intelligible, des médiums merveilleux et des aigus presque soyeux, jamais agressif même à fort volume ! Pour ma configuration, je pense que je ne pourrai pas trouver mieux.
Johannes R.
Fosi Audio P4 Preamp
Très approprié à mon avis. J'ai équipé les monos V3 d'Audiophonics OPA1642. Parfait pour moi ! DAC est un Soekris 1221, antérieur à Lindemann Limetree Bride.
Patrice P.
MUSICIAN PEGASUS II Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Black The Musician Pegasus II presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies,...
Haute valeur musicale ajoutée
Après plus d'un mois d'écoute, ce DAC révèle sa vraie nature très musicale et analogique. Il est aussi très précis, transparent. et silencieux. la scène sonore est large et profonde. Un vrai régal pour l'oreille. Matériel audiophile !
Mon système : Eversolo DMAP A6, amplicateur Ma252 et enceintes Sonus Faber Sonetto III.
Le rodage est un peu compliqué : au moins 250h pour qu'enfin la véritable signature sonore se stabilise. Pendant cette phase, on doute, on passe par des hauts et des bas... Puis, tout s'éclaire et là, c'est tout simplement magique.
Attention, ce DAC ne laisse rien passer. Toutes les liaisons (câbles) entre la box, la source, le DAC et l'ampli doivent être particulièrement soignées sinon on perd en précision et en fluidité.
Pour ma part il ne me reste plus qu'à changer ma source qui n'est plus au niveau de ce bijou ...
Je ne peux que recommander ce produit à tout ceux qui veulent approcher la sonorité "vinyle-like" avec de la précision, une dynamique franche, fluide et humaine.
philippe C.
FOSI AUDIO DC Power Noise Filter 12-55V 10A with DC jack doubler This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your...
Dynamique
J'ai essayé ce filtre qui m'apporte du silence, de la dynamique, des détails et un médium plus naturel. C'est une bonne solution pour améliorer les alimentations "sales" qui pullulent sur le marché actuel de la hifi.
C'est bien, c'est peu coûteux et ça marche... sensiblement.
olivier P.
Déception !!…
Matière sans doute qualitative .. mais finition très moyenne un brin corrodée et mal ébavurée… on trouve mieux à 10 fois moins cher et en inox dans le commerce .. client audiophonics régulier et ravi de l’être mais très déçu sur cet achat …
Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many numerous amplifiers in the ASR ranking.
After a few days, the unit sounds even better.
Unfortunately, this amplifier requires 13-14 volts of input voltage to deliver its full power.
Most preamplifiers deliver up to 2-2.5 volts.
It is possible to adjust the gain on the bottom of the unit using the preamplifier itself.
Unfortunately, this somewhat degrades the excellent technical values ​​(Sinad from 137 dB to 128, etc.).
These are still excellent values, and I don't hear any sonic differences on my Nuvero 140.
Audiophonics specifies the following gain values:
Bypass: 11.5 dB
19 dB
25 dB
31 dB
33 dB
The following values ​​can be set on the device:
11.5 dB
19 dB
24 dB
28 dB
I love this amplifier. I've certainly owned over 10 select and well-tested amplifiers before.
The LPA-S600NCX is my favorite.
Plenty of stage, plenty of detail, and decent dynamics.
Theodoros R.
ORACLE II 01 Discrete Single OPA DIP8 (Unit) The Oracle II 01 single OPA represents a new generation of hybrid discrete operational amplifier, specifically designed for audio applications and offering excellent performance...
NICE OPAMP
VERY NICE OPAMP FOR THE MONEY!!
Charles S.
Bravo Xangsane
A ce prix les connecteurs XS-6001 AU sont imbattables .
Timbres dynamique aération et musicalité qui fait mieux même à 10 fois le prix !
Merci Audiophonics pour cette découverte , rare aujourd'hui .
Aurelijus S.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks...
Elevating FM Radio: Integrating Teac PD-301-X with Topping E70 Velvet & B200 for Audiophile Sound
I have a Teac PD-301-x FM tuner with excellent sound but only an analog RCA output from the FM Radio. So, to have its sound in my HiFi audio system, I added PocketADC into the chain, which looks like this now: Analog FM signal from Teac PD-301-X → PocketADC → SPDIF → Topping E70 Velvet (DAC) → Topping B200 (amplifier) → Dynaudio Emit 20 speakers. PocketADC is transparent, and now I can enjoy excellent FM Radio quality from my nice Teac tuner.
I selected 48 kHz as the sampling rate because the source signal is analog FM radio, which has a limited frequency range—typically up to around 15 kHz. A 48 kHz sampling rate comfortably captures the full audio bandwidth of FM broadcasts without unnecessary overhead. I did not see any heat from pocketADC. Also, I use a linear power supply, Keces P6, which also powers my Teac FM Radio component.
FRANCOIS D.
AUDIOPHONICS STEALTH Power Cable Schuko C7 OFC Copper Shielded 3x3.5mm² 1.5m The power cable is the first element in a HiFi system, so its quality should not be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our...
Super produit !
J'utilise ce cordon sur ma SoundTouch 30 depuis plusieurs semaines et suis ravi de l'apport que procure ce câble au niveau de la restitution sonore . De plus le câble est robuste et de grande qualité. Bravo !
TUNG-SOL 6SN7GTB Dual Triode Tube (Unit) The 6SN7GTB Tung-Sol tube is a double triode tube that benefits from a beautiful design thanks to quality materials. This model has identical characteristics to the 6SN7GTA...
TUNG-SOL 6SN7GT
I bought the TUNG-SOL 6SN7 on recommendation and it worked well, they fit perfectly with my KT 88 Genalex Gold Lion power tubes, the sound is beautifully transparent and dynamic, I have a Cayin CS 88 A amplifier and it really plays great now. Thanks to Audiophonics for the fast delivery
TUNG-SOL 6SL7 Double Triode Tube (Unit) The Tung-Sol 6SL7 is a high-quality double triode tube. It has beeThe Tung-Sol 6SL7 is a high-quality double triode tube. It has been designed to amplify the low-frequency...
TUNG-SOL 6SL7GT
I bought the TUNG-SOL 6SL7 on recommendation and it worked well, they fit perfectly with my KT 88 Genalex Gold Lion power tubes, the sound is beautifully transparent and dynamic, I have a Cayin CS 88 A amplifier and it really plays great now. Thanks to Audiophonics for the fast delivery
Joseph C.
VEZZOSO X36 Balanced DAC ES9039PRO HDMI I2S SPDIF USB XMOS AES 32bit 768kHz DSD512 This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology ES9039PRO DAC chip and a Qualcomm...
Belle acquisition
Vezzoso
J’utilise l’unité depuis 3 jours et le “plumage “ est incroyable : 6,5 kg usiné dans un bloc d’aluminium joliment teinté d’un vert olive.
Avec sa mise en place à l’aide des gants blancs en coton fournis, ont à l’impression d’avoir gagné à l’euro million. Par contre sa télécommande vous fait vite revenir à la réalité ^^
Comme décrit dans l’avis précédent, l’appareil démarre sur un compte à rebours de 66mn afin de chauffer et roder les condensateurs . Temps de chauffe bien insuffisant au vu de la première écoute qui s’en suit les oreilles grandes ouvertes : une patate sonne mieux. On repense à tous ces préjugés négatifs sur les dac asiatiques . Pas de bol dirait l’autre..
1, 2, 3 heures ah là on ne le reconnaît plus
Au bout de 5 ou 6 heures il sonne vraiment très bien
Bruno M.
Love it
I use it between Melco N100 and Chord M-Scaler that feeds Chord TT2.. According to Chord, I wasted money and it is unnecessary. To me, the improvement is substantial, as it removes stress from the music and renders it more detailed yet more relaxed at the same time. I can now listen for very long time without fatigue.
Véronique V.
Mitigé
Parfait pour une application sur des surfaces horizontales, mais l'adhésif est juste pour des surfaces verticales et carrément insuffisant pour des surfaces horizontales vers le bas, malgré un marouflage consciencieux. Tout se décolle dans les 24 heures ! Un ajoute de colle est indispensable...
Neng V.
THIEAUDIO PRESTIGE LTD In-Ear Monitors IEM Dynamic Electrostatic 22 Ohm 98dB 20Hz-80kHz With these Prestige LTD in-ear earphones, Thieaudio unveils an innovative, high-end pair of earphones that follows on from the Prestige Original model. Indeed,...
Fin du jeu
Simplement les meilleurs iem que j'ai entendu! Contrôle qualité au top les 2 unités sonne parfaitement. Un monstre de technique, de details, de fluidité, de séparation d'instruments, une scènes sonore énorme, le son est hors de la tête dans toutes des directions! Mention S+ pour audiophonics.fr pour la rapidité d'envoi, commandé la veille et reçu le lendemain le tout très bien emballé.
Nicolas B.
FOSI AUDIO ZP3 Balanced Preamplifier NE5532 The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The...
Après avoir utilisé le Fosi Audio P4 pendant plusieurs mois, j’étais curieux de découvrir ce que le nouveau ZP3 avait à offrir. Clairement pensé comme une évolution directe du P4, ce nouveau modèle apporte des améliorations sensibles à tous les niveaux.
Qualité sonore : plus de définition, plus de dynamique
Le ZP3 reprend l’approche du P4 avec ses AOP interchangeables, mais va plus loin en termes de transparence et de scène sonore. Le grave est mieux tenu, les médiums plus ouverts et les aigus plus ciselés sans devenir fatigants. On gagne en précision et en séparation des instruments, ce qui donne une écoute plus "hifi" que le P4, qui restait un peu rond ou doux selon les configurations.
Construction et design : plus sérieux
Là où le P4 semblait presque "jouet" dans sa finition, le ZP3 respire davantage la qualité. Châssis plus solide, meilleurs connecteurs, et une alimentation plus sérieuse permettent de tirer le meilleur de ses composants internes. C’est un vrai plus si vous l’intégrez dans un système audiophile.
Fonctionnalités : toujours aussi modulable
Comme le P4, le ZP3 permet le remplacement des AOP (op-amps), ce qui est un vrai bonheur pour les tweakeurs. Il est livré avec de très bons AOP d’origine (souvent des NE5532 ou dérivés), mais il prend une toute autre dimension avec des modèles comme les OPA627 ou Sparkos SS3602. De plus, il accepte sans problème des sources variées grâce à sa large plage de gain et ses entrées bien pensées.
Le Fosi Audio ZP3 est clairement une montée en gamme logique et réussie. Il conserve l’esprit DIY et audiophile du P4, mais avec un raffinement et une maturité sonore que le P4 n’atteignait pas. Si vous avez aimé le P4, vous allez adorer le ZP3. Et si vous hésitez entre les deux, le ZP3 justifie largement son tarif légèrement supérieur par une restitution bien plus maîtrisée et audiophile.
Steve D.
DAYTON AUDIO SPA300-D Class D Amplifier for Subwoofer 300W 20Hz-200Hz The Dayton Audio SPA300-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
Dayton spa300-D
Genalex
I let the tubes burn in for about 100 hours and they work great for me, the bass is dense, the mids are brilliant, the treble is excellent, clean. It's hard to find a better one. I have a Cayin CS 88 A amplifier, I also replaced the tubes in the preamp with Tung-Sol, which Audiophonics also offers, specifically Tung-Sol 6SN7GT and Tung-Sol 6SL7GT. Great combination for this amplifier. Thanks Audiophonics for the fast delivery, very well packaged :)
Theodoros R.
VERY NICE OPAMP!
Remi B.
XANGSANE XS-F02 Female XLR Plug Cap (Unit) This Xangsane XS-F02 XLR female cap is designed to protect the XLR male connectors of your audio equipment, such as a DAC or amplifier. It provides effective...
Bouchons
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound from anything less then the best UP-OCC. I used to believe that OFC copper that is not cast in the Ohno Continuous casting proces and was very good quality oxygen free copper perhaps but not cast in that "special" mono crystal way, would always be less in performance then one hat was true OFC copper OCC casted. But this cable changed my opninion and my recommendations to all friends and clients, Forget about OCC and only watch for those magic three letters.... I have put WBT pure copper spades on one side and viablue banana plugs on the speaker side, The cable that it replaced was one that was 40x more expenisve 10AWG massive Lab grade OCC copper. And this 5080 humiliates that well known brand and not just by a hair, but a mile,,,,,, This Cable Is Too Good for the proce friens, Make sure you strip and mount it like it has to be done. Use the flat conductor to maximize contact surface between the conductors and connectors.... GianT killer this one
Pierre-Marin L.
1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 5m (Pair) These 1877Phono Zavfino Nova-SPK  banana speaker cables  are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to...
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba un Rotel RB-1552MkII en clase AB.. y muy bien ... hasta que pones el Purifi 9040 + Preamplificador Gustard P26 (Testado también con preamplificador Audio Research SP17 y Vincent SV-94)... no sabe uno de como puede sonar tu sistema cuando la potencia sobra. Los típicos comentarios de que la clase D no suena natural..... y que me decían algunos antes de apostar por este amplificador se disiparon una vez lo conecté a mi sistema.... al segundo día de pruebas... ya le quité la pegatina de protección frontal del Purifi 9040, puesto que tenía muy claro que me lo quedaría.
Ahora está junto con el Audio Research SP17 sonando... muy bien la verdad, pero es que la sinergia con el preamplificador Gustard P26 de mucho menor coste es aún mejor!..por increíble que parezca y para mi gusto... hacen una sinergia excelente.
Nada como probarlo en tu casa, con tu sistema... y ver de lo que es capaz esta bestia, apostaría que sí das el paso.. te lo quedas.
Saludos
Raphael A.
1MII LAVAUDIO DS200 Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Silver The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution...
Son trop cristallin et trop orienté sur les médiums
Je l'ai testé vs. mon AUDIOPHONICS LHDC Récepteur Bluetooth 5.0 LHDC SA9910 / DAC PCM5102A 24Bit / 96kHz (moins cher, acheté il y a 5 ans) et je n'ai pas aimé le son : trop plat et cristallin, ciblé sur les médiums, pas assez rond pour mon ensemble. Ou pour mon goût. Je l'ai rendu. SAV Audiophonics très réactif, nickel.
Raphael A.
Son imbattable, rond et précis. Attention switch BT complexe
Je l'ai depuis 4 ans maintenant pour l'interface entre mon PC et ma chaine hi-fi (NAD basse/moyenne gamme). Imbattable sur la qualité sonore, j'ai testé d'autres DAC de sa catégorie et je n'ai jamais obtenu un son aussi rond, complet, précis, agréable. Convient parfaitement pour une connexion BT unique et stable. Car pour switcher d'appareil, il faut hélas l'éteindre, le rallumer et établir une nouvelle connexion. Idem quand on veut remettre l'ancien. Dommage qu'il n'y ait pas au minimum un bouton de réinitialisation BT.
Raphael A.
Je l'ai acheté il y a 4 ans. Connecté entre un DAC BT sortie jack et ma chaine hi-fi (basse/moyenne gamme), la restitution sonore est très bonne et rien n'a bougé depuis 4 ans ! Esthétique, souplesse, qualité, tenue dans le temps à ce prix, rien à dire, je recommande fortement.
Eric L.
XCITE XT32-4 Speaker Driver Exciter 20W 4 Ohms 35Hz - 17kHz The XCITE XT32-4 exciter features a unique combination of large travel and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range....
Produit excellent bande passante après correction presque complète. Netteté, solidité et il tient le coup avec un amplificateur de 40Wrms .Xcite a toute une gamme de vibreurs très intéressante. Je recommande vivement ce produit.
Marc F.
Très pratique mais finition perfectible...
Placé en amont d'un ampli SMSL A-300 il remplit très bien sa fonction native et permet en sus d'alimenter soit cet ampli intégré soit un ampli casque Sennheiser.
Quelques regrets côté finition : à réception du produit les embases RCA n'étaient pas suffisamment serrées.
EIZZ EZ-507-4 Lockable Banana Plugs Pure Copper Gold Plated 5µ (Pair) These EIZZ EZ-507-4 banana plugs benefit from a high-end design thanks to their 99.99% pure copper contact and 5µ thick non-magnetic gold plating. These features give them...
Top qualité
Je cherchais des bananes en cuivre pur avec une excellente conductivité et blocage
J'ai trouvé !
Fabrice C.
SILKLINE ZUKI I Balanced preamplifier / DAC 32bit / 192kHz USB XMOS Silkline's Zuki I combines the functions of preamplifier and DAC . The preamplifier function has a balanced and unbalanced output and a v oltage gain of 12dB ....
SILKLINE ZUKI I
Voici un DAC avec contrôle de volume et quatre entrées analogiques qui mérite vraiment d'être connu! Ne vous arrêtez pas à son aspect austère car à l'usage vous comprendrez vite que vous avez fait une excellente affaire.
Il est très simple à utiliser et se révèle parfaitement transparent à l'écoute. Il suffit de regarder à l’intérieur pour comprendre. La qualité et le sérieux de la fabrication ne fait aucuns doutes. Point d'alimentation à découpage ici mais un énorme transformateur torique, l'alimentation ne risque pas de s’effondrer! Pas non plus de puces de conversion ESS dernier cri, plus réputées pour leurs performances que pour leur musicalité, non, juste de bons vieux Analogue Device, excellents, peu couteux et qui font le job jusqu'à 24 - 192Khz. Je ne vois pas pourquoi aller plus haut en HiFi audio...
Pareil pour la puce Xmos; elle fonctionne en USB sans driver jusqu'à 48 Khz sous Windows. Pour aller au delà, il faut installer le driver (on le trouve facilement avec le lien sur la fiche produit Audiophonics). L’installation est très facile, elle s'adapte automatiquement à votre version de Windows et fonctionne aussi sur Windows 11.
Toutes les entrées sont commutées par des relais électroniques, vous n'entendrez aucuns bruits de commutation. Le contrôle de volume est précis et de bonne qualité, l'affichage est un peu troublant, le chiffre affiché diminue au fur et à mesure que le volume augmente mais on s'y habitue très vite.
Petit bémol, contrairement aux sorties CINCH, le niveau de sortie en XLR est trop faible, cela oblige à pousser le volume proche du maximum quand on utilise ces sorties, cependant, la qualité du son ne semble pas altérée.
Vous l'aurez compris, je recommande ce produit à tous ceux qui ont besoin d'un bon DAC avec contrôle de volume et quelques entrées analogiques. Le rapport qualité prix me semble exceptionnel.
FRANK D.
Impressionnant.
Une fois compris le systeme et en ayant pris des precautions pourque les parties en plastique ne se desolaridesent pas cette fiche en vaut largement le coup a l'ecoute.
Son net et beaucoup plus transparant que toutes les autres connecteurs utilises auparavant. Meme de tout haut de gamme.
Le montage peut certe, etre simplifie, du moins il me semble...
Bruno R.
J’ai donc commandé le dimanche et reçu le mardi une Gold Lion de Genalex en 12AX7 / ECC83. Bravo à Audiophonics pour le service impeccable !
Je l’ai installée pour remplacer une lampe de la marque TAD du même type sur un ampli hifi hybride TAGA Harmony HTA-1000B équipé d’origine avec des 2 tubes Psvane en 12AU7 en plus de la 12AX7. Dans la configuration actuelle de l’ampli, des Tung-sol remplacent déjà les Psvane.
Pour faire court : je suis scotché par le bond qualitatif avec cette lampe Genalex, ressenti dès les premières minutes d’écoute ! C’est le jour et la nuit comparé à la TAD !!
Les graves sont justes… parfaits. Bien définis sans être envahissants. Sur les percussions de batterie, on ressent la vibration des peaux sur les fûts, la petite résonnance qu’on entendrait si la batterie était réellement devant nous. C’est bluffant.
Très beaux mediums aussi pour les guitares électriques par exemple.
C’est globalement plus aéré et l'écoute est agréable car pas fatigante.
Il n’y a que sur les voix que, si la bande passante est chargée (par exemple sur un morceau de metal) qu’elles ont tendance à rester un poil en retrait.
Mais cela tient peut-être aux autres lampes ou aux enceintes tout simplement.
Bref, je recommande cette lampe sans aucune hésitation !
Alain p.
top du top
OGUZHAN O.
SBOOSTER BOTW P&P MKII Regulated Linear Power Supply 5V 3A / 6V 1.75A / 6.5V 1.6A With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply....
With Bluesound Node N130
I use it with Bluesound Node N130 and it gave lots of sound improvements
OGUZHAN O.
Good Quality Materials but hard to make cable
1) 10 mm Neotech 3220, There is a reducer in it, without it cable a bit loose. Anyways lots of pvc shaving i manage to fit with reducer.
2) Tip of the connector, split 2 parts, you have to keep it together while soldering. After i finish 1 pair i try rca sockets, one of them bended like eliptical, because of this doesnt fit. I tear it again, use a little force and voila! Then I said to myself wish i chose to make easier version of rca like whole metal body.
OGUZHAN O.
Very Good Quality for price
Nice grip, good contact. I use it with Mogami W2497 cables no issues.
Mika N.
TOPPING PROFESSIONAL E2X2 OTG USB Audio Interface 2 Inputs 2 Outputs 24bit 192kHz Black Topping's E2x2 OTG is an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of...
Very good sound card with professional sound. Works very well in Windows 11.
All the best!!!
Gaine PTFE parfaite
Mais là je dois avouer que je suis bluffé par l'option gaine ptfe proposée par Audiophonics en option avec le fil nu argent pur élecaudio qui est tout simplement adapté a l'usage pour lequel il est conseillé et personnellement je n'ai eu aucun problème pour enfiler les 150 cm de pur argent dans la gaine même si il faut un peu de patience et de dextérité.
Merci encore Audiophonics pour cet excellent conseil.
Cela reste quand même très cher pour une gaine mais le résultat est qualitatif.
Eric S.
FX-AUDIO TUBE-02 PRO 5725 Tube Preamplifier / Headphone Amplifier Class A With the Tube-02 Pro, Fx-Audio offers a small tube preamplifier and headphone amplifier in a compact and affordable format. Its preamplifier stage uses a pair of 5725 tubes,...
Belle surprise !
Branché sur un ordinateur. Quelle amélioration, notamment sur le rendu des instruments acoustiques ! J’ai changé les tubes d’origine qui bridaient un peu les performances de ce ampli casque que je recommande…chaleureusement.
Lars Nuqa Clement B.
ET3 and Oversampling advantage ?
Has anyone taken an audio CD (16 bit /44,1 KHz) and experimented with raising the oversampling Frequency at playback over I2S outlet ? Theoretically, oversampling works as a filter and it could impact on experienced sound audio quality even if bitrate are the same. Share your experience with us here, please !
Laurent G.
Expédition rapide, produit d'origine pour ma station ZD937
Il est dommage que l'élément céramique soit introuvable et impose de changer le fer complet, car même si le fer de rechange n'est pas très cher, c'est quand même encore une forme de gâchis.
Merci.
Gorazd K.
OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 0.7m (Pair) This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us...
Top quality product. The cable is a bit stiffer, which is expected given the manufacturing method and the materials used. The connectors are really excellent quality. You can tighten them and they hold firmly, without moving. In my opinion they are sonically balanced, but here there are differences depending on personal preferences and the type of system.
