1MII LAVAUDIO DS200 Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Silver
The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution transmission like the aptX, the aptX LL, the aptX HD or the LDAC for a listening of great quality, even in wireless.
2.0 / 5
Reference : 15826
99,00 €tax incl.
82,50 € tax excl.
1Mii DS200Pro
Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018K2M Silver
Récepteur Bluetooth 5.0 CSR8675 DAC ES9018K2M 32bit 384kHz
The conversion stage is entrusted to an ESS ES9018K2M DAC chip, in charge of processing and converting digital audio data into analog. The latter supports high sampling rates, up to PCM 32bit 384kHz, and ensures excellent audio performance, with a dynamic range of 127dB and a THD+N of -120dB.
On the connectivity side, there are RCA output as well as a digital optical output for maximum compatibility with your current audio system.
Product typeBluetooth reception
Bluetooth chipQualcomm CSR8675
Bluetooth version5.0
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, aptX LL, LDAC
DAC ChipESS ES9018K2M
Outputs1x Stereo RCA
1x Optical Toslink
Dynamic range127dB
THD+N-120dB
Dimensions105 x 90 x 26mm
ColorSilver
Package1x 1Mii DS200Pro
1x Power cable
1x Female Jack 3.5mm to Male RCA cable
1x Optical cable
1x RCA Cable
4x Rubber feet
OutputOptical Toslink
DAC / ADC ChipES9018
ColorSilver
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
Son trop cristallin et trop orienté sur les médiums
Je l'ai testé vs. mon AUDIOPHONICS LHDC Récepteur Bluetooth 5.0 LHDC SA9910 / DAC PCM5102A 24Bit / 96kHz (moins cher, acheté il y a 5 ans) et je n'ai pas aimé le son : trop plat et cristallin, ciblé sur les médiums, pas assez rond pour mon ensemble. Ou pour mon goût. Je l'ai rendu. SAV Audiophonics très réactif, nickel.
This review has been posted for 1MII LAVAUDIO DS200 Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Silver
The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs...
