marc g.
Dominique R.
Hautement recommandé
Paulo D.
VASILEIOS K.
NEOTECH NES-5001 Speaker Cable UP-OFC Copper 2x4mm² Ø15mm The Neotech NES-5000 series incorporates UP-OFC Ultra Pure Copper conductors while ensuring an affordable price. The NES-5001 consists of two conductors with a cross-section of...
Just good!
It didn't blew me away although the build quality is very impressive. You can find a better cable. I think i prefer the cheaper Jantzen 6N solid core!!!
Michel l.
INCROYABLEMENT BON
CONCERNANT LES MOGAMI W3103 JE SUIS STUPÉFAIT D'AVOIR UN résultat probant une transparence redoutable pour si peut d'argent c'est bluffant comment est ce possible ? j'avais au paravent les modèles van den hul cs 122 et cs 352 4 fois plus cher au mètre associer a des jumpers zavfino pour ma part j’étais convaincu de l'association a mes monitor audio je ne regrette pas une seul seconde d'avoir fait confiance a audiophonics merci encore
JULIUS L.
My first tube amp
I am very happy with this little amp.
There is a perfect synergy with my Grado Headphones especially the RS1X but it is also very good with Beyerdynamic dt1990pro there is plenty of power that this amp deliver (more power than I will ever need) I just love tube sound - everything sounds so natural I have not experienced this with my any of my solid state amps.
This amp sounds fantastic delivery and send was fast and reliable I will be back in the future for sure.
Highly recommended !
jacques p.
SILKLINE T8 Tuner Radio FM / DAB / DAB+ The Tonemax T8 is an FM / DAB / DAB+ tuner equipped with an RDS decoder that allows you to broadcast analog FM radio as well as DAB + digital radio, which is more recent and...
je ne lis pas le chinois mais apres de longues minutes j'ai reussi a programmer la telecommande bon achat le son est parfait manques notice en francais
Eric d.
[GRADE S] XDUOO XD05 BAL Portable Balanced Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver Refurbished product  - Grade S The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its digital/analog conversion stage has been...
Xduoo XD 05 Bal
Excellent appareil qui a transformé mon écoute casque sur un Sivga P2.
Tout est en place: précis, transparent, dynamique et timbré.
Les grosses masses orchestrales symphoniques passent comme une lettre à la poste!
L'écoute à partir du Yamaha WXC 50 utilisé comme streamer+dac vers l'ampli Audiophonics K 214 (malgré ses grandes qualités d'amplification Class A) m'avait laissé sur ma faim..
On ne peut pas réellement utiliser ce Xduoo en mode nomade (malgré sa batterie interne), vu son encombrement et son poids..
Sebastien D.
Fiches à visser, c'est du solide la connection ne laisse aucuns jeux, un peu cher mais faut se faire plaisir, le son perfect !
julien D.
Que du bon
Cette gaine est magique étant pas mal équipé en furutech genre prise NCF cable et compagnie qui donne un son méga top et je peux avoué que la gaine a encore monté un cran au dessus et ces propre je dirai méga propre utilisé sur cable enceintes et cable secteur l'effet est garantie en son Hi-Res le bonheur.
VIBORG VS702R Pure Copper Spades OFC Copper / Silver / Rhodium Plated Ø4.5mm (Set x4) The Viborg VS702R are high quality forks, ensuring optimal connection and conductivity. These models are made of pure Copper, with a triple plating of OFC Copper, Silver and...
Belles fiches de très bonnes qualité
J’ai choisi ces fiches, pour faire des straps de bonne qualité, pour des enceintes, câblées avec le câble Athom HP en diamètre 3mm. J’ai donc utilisé le même câbles avec ces fiches: un très bon résultat, fiches de belle épaisseurs , un beau plaquage bien poli, très bon rapport qualité prix.
Mon premier choix s’était porté sur des Furutech , que j’utilise souvent dans mon gros système , mais comme il m’en fallait 8, ça commençait à fair cher, pour mon système de vacances : mais je n’ai aucun regret, ces fiches sont fantastiques!!!
James S.
AUDIOPHONICS LPA-S400ET - Superb!
In my system, to my ears, this amp sounds perfect. Clear, transparent, fast, and uncolored, it sounds like whatever I put into it. When I first turned it on I was startled by the clarity and the rock-solid rendering of a wide and deep soundstage. If the music is relaxed, it sounds relaxed. If the music is punchy, it sounds punchy. You get the idea. I listen to a wide range of music - classical, jazz, rock, funk, afro-cuban, bluegrass. From top to bottom this amp renders them all with accuracy and ease. I love it.
GERASIMOS Z.
Attila R.
Cheap and good
It is relatively cheap and if great quality overall. It does the job, no complaints :)
Attila R.
Amazing sound, in-wall cable
I was expecting a less rigid cable, this is definitely not the best choice for your standard IEC cables. The copper is a SOLID CORE inside, which makes this cable extremely rigid. You bend it and it stays like that. I would definitely use this as an in-wall cable as it has the certifications you need and would do the job (if you don't bend it too much). Out of necessity however, I have built a component Schuko-IEC cable with it and it sounds mind-blowingly good! If I had to run a new power line to my Hi-Fi rig, I would probably use these now.
Francisco Javier R.
Bon, mais...
Bon dissipateur de chaleur. Je lui donne une note faible car ils sont arrivés avec des rayures
J'espère que les deux que je viens de racheter arriveront en parfait état.
Attila R.
Fantastic sleeves!!
Amazing quality, was a breeze to work with it. I use a wiha tool to crimp it and it does the job perfectly. I used it for silver plated speaker cables so far.
Philipp G.
Jack 3.5mm Stereo Socket 3 Poles Square Body This Jack 3.5mm 3-pole jack with a square body (2 beveled corners)  will allow you to create headsets for your DIY designs
robust
Everything fine. The Jack seems to be robust.
Philipp G.
Looks Nice
Was easy to assemble and the aluminium front looks nice.
Eric P.
YAMAHA MUSICCAST WXC-50 Audio Streamer ES9006 WiFi AirPlay DLNA Bluetooth 24bit 192kHz DSD128 Yamaha unveils with its WXC-50 an extremely complete network player, based on the brand's MusicCast system. The WXC-50 is a comprehensive network player based on Yamaha's...
Tres bien pour le streaming
Ce petit lecteur réseau n'est pas trop Cher et fonctionne très bien avec tidal master et audirvana studio ,un régal
Eric P.
PANGEA PREMIER Cat7 RJ45 Ethernet Cable Silver Plated Copper Triple Shielding 0.129mm² 0.6m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
Parfait pour un lecteur réseau le Yamaha.
Eric P.
PANGEA PREMIER Coaxial Cable Silver Plated OFC Copper Double Shielding 1.5m This Pangea digital coaxial cable incorporates excellent conductors, consisting of OFC copper and silver plated copper, with double shielding to drastically reduce interference....
Tres bien pour le streaming ou pour un lecteur cd
Parfait pour du matériel entre 500 et 1500euros
Eric P.
Idéal pour un petit lecteur réseau comme le Yamaha
Johny C.
Déjà très satisfait de ces PSVANE après seulement 4h d'écoute
J’ai acheté plusieurs types de tubes chez Audiophonics pour upgrader ceux de mon ampli Line Magnetic LM845 IA
- Etage d’entrée : 2x 12AX7 (upgrade : Psvane 12AX7-S Art-Series)
- Rectifier : 1x 5AR4 (upgrade : Gold Lion U77 - GZ34 Genalex – Russie)
- Drivers : 2x 6P3P (upgrade : TAD 6L6GCM-STR Redbase Premium Selected)
Ces choix ont été effectués en tenant compte des avis divers provenant des détenteurs du même ampli.
Je commence dans un premier temps par effectuer le changement des tubes d’étage d’entrée (les PSVANE 12AX7), et au bout de 4 heures d’écoute seulement je dois dire que le changement sans être radical est bien notoire. Des aigus plus fins, une dynamique plus perceptible, et surtout une musicalité bien plus évidente. Très agréable et jamais agressif. Après les 50 à 80h d’utilisation préconisées, je pense que le son ne pourrait que s’améliorer encore.
Je ne testerai les autres tubes qu’une fois la période de rodage des premiers sera terminée pour mieux cerner le réel changement au fur et à mesure des changements.
Je remercie donc Audiophonics de proposer tous ces tubes disponibles à la fois, sans avoir à les acheter dans plusieurs boutiques.
Alexandre G.
super chouette
il brule depuis peu sur mon convertisseur , franchement ce lecteur reseau vaut un tres bon drive et l'appli est super bien faite. aucun bug , facile a installer ... aucune critique! j'ai eu un auralic bien plus cher et franchement je vois pas pourquoi il l'etait!
Frederic G.
Très bon en streamer/ pas essayé en dac…
L’Eversolo a remplacé deux steamers (1600 et 2500 euros) que j’utilisais en Roon endpoint aussi bien qu’avec leurs propres applis.
J’en étais satisfait mais j’étais à la recherche d’un streamer abordable pourvu d’une sortie USB performante car les entrées spdif du Hugo Mscaler ne sont pas ses meilleures, mesures à l’appui (écoute également, chez moi et selon mes goûts)
Je me disais que quelque chose pouvait peut-être être amélioré dans ce domaine.
C’est appareil est neutre et dynamique avec beaucoup de détails parfaitement intégrés. Les timbres sonnent justes et pleins, surtout en Roon endpoint. Je n’ai remarqué aucune dureté ou brillance dans les aigus, au contraire. Il fait preuve de finesse, de douceur et de fluidité.
L’apport du Chord scaler y est sans doute pour quelque chose mais je n’avais jamais ressenti autant de nuances et de naturel auparavant.
Ce streamer est vraiment très bon dans mon système, sans même parler de son remarquable rapport qualité prix!!
Musique : jazz, classique, électro, rock, pop, métal,
Système: pc + Roon core / network acoustics Muon pro / câble ethernet Cardas clear network / Eversolo + câble secteur Shunyata delta / filtre secteur Niagara / câble usb audioquest carbon / Hugo Mscaler + Ferrum Hypsos / câble Oyaide bnc 510 / Chord TT2 + Ferrum Hypsos / câbles rca Cardas clear / Dartzeel 8550 mkii / enceintes perso.
Barrette secteur de grande qualité
Barrette secteur de grande qualité qui a pu apporter un plus indéniable à mon installation audio video.
De plus le matériau utilisé rassure sur la solidité de cette barrette.
Le prix peut paraître certes un peu élevé mais cela en vaut la peine !
Grzegorz B.
I echanged A22 to A26 and this was good step
I have Gustard A22 for over 2 years, it goes to second system and A26 exchanged it in main system. I short - the same good, natural, full and balanced sound, with little improvement of low frequency, new model is more accurate, more detailed. And has improvements like input for external clock (I will add in future) and with LAN input! Only screen is smaller than in A22, but looks more stylish. Important - new model heat-up less than A22
osman b.
FURUTECH FT-7445(R) Jack 4.4mm Connector TRRRS Copper Rodium Plated ⌀6mm (Unit) This FURUTECH FT-7445(R) 4.4mm balanced Jack connector benefits from a very nice design, with a rhodium-plated copper conductor, all Alpha treated.
super fast shipping
The product is excellent. The seller is very relevant and helpful. Very fast shipping 2 days. This is my next favorite shopping company. Thank you very much for everything.
osman b.
super fast shipping
Turkka L.
TOPPING PA5 II PLUS Class D Amplifier Balanced 2x125W 4 Ohm Silver Topping's PA5 II Plus amplifier is a compact and powerful model, adopting a totally balanced structure and an innovative Class D amplifier circuit, enabling it to develop a...
Great little amp with plenty power
I am driving Linton 85 speakers with this amp and E50 DAC. Lintons are recommended for 25-200W and I never listen beyond 50% volume setting because it gets so loud, and I can hear zero distortion.
I'm very happy with the clarity and neutrality of the amp. Amazing package for the price.
I wish it had sub out, but I am taking the sub now from the DAC.
Cris K.
Excellent build and astonishing sonic performance especially for its cost. ΅Well done ΡΑΜΜ AUDIO.
Au départ j'avais placé sous mon ampli des iso puck de la même marque supportant 9 kg ; le son s'était nettement amélioré . Cependant je n'étais pas tout à fait satisfait . J'avais constaté que l'essentiel du poids se situait sur l'arrière de l'ampli dû à la présence des transformateurs . J'ai décidé de réduire l'amortissement sur l'avant de l'ampli en installant ces indigos et gardait iso puck 9 kg à l'arrière . Super résultat son transparent et ultra naturel . Conclusion ne pas hésiter à associer différents types en fonction de la répartition du poids de vos appareils . Hautement recommandable .
philippe C.
Fantastique !
Comment peut-on dire que cet ampli casque n'est pas bon ? Non il est fantastique ! D'une droiture et d'une bande passante extraordinaire et d'une neutralité incroyable. Très puissant écouté avec des casques planars de trés haut de gamme,Que ceux qui cherchent un appareil qui "fait" de la musique avec du relief des basses comme ci des aigues comme çà passent leur chemin... C'est un ampli casque avec une connectique pléthorique, une puissance fantastique et une fabrication hors pair. Je ne lis pas les blogueurs mais quand il est bien accompagné : câbles, secteur propre, symétrique du début à la fin, DAC etc et surtout musique ... Je parle de LA MUSIQUE, il est incroyable. Ceci dit on peut aimer ou ne pas aimer Carl Bohm, Furtwamgler ou Baremboîm mais de là à dire qu'ils ne sont pas bons...
Cet appareil est si précis et exigeant que sa mise en oeuvre pour en obtenir la quintessence demande de l'exigence et il vous fera entrer au plus profond de la musique. Il ne FABRIQUE pas de musique, il JOUE LA MUSIQUE avec plénitude et rigueur.
C'est un trés bon ampli Casque pour 600€.
PS : Les critiques du web sont comme les chiens qui pissent aux pieds des lampadaires.
Eric P.
Le son est très bon avec tidal master c'est parfait et même avec les radios Internet vu le prix que demander de plus.
Eric K.
SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 The D-6 joins SMSL's wide range of DACs, offering excellent performance for a contained price. It is equipped with two AKM AK4493S conversion chips and a second generation USB...
Le D6
Excellent petit dac (chaleur/profondeur/même les graves sont mordants) ! Quelle belle surprise en ligne avec ampli de puissance (je vais essayer avec un preamp bientôt). Livraison rapide comme d'habitude. Merci.
mathieu l.
ATOHM ZEF Interconnect Cable RCA OCC Copper (Pair) 0.6m True to its high-end philosophy, Atohm has developed an uncompromising RCA interconnect cable . Thanks to its unique design and rigorous choice of materials, the Atohm ZEF...
Trop transparent
J’ai gagné en clarté, précision et surtout en transparence, malheureusement au détriment de l’articulation des médiums et des voix.
Très bon câble malgré tout.
mathieu l.
Neutre, clair et précis.
Extérieurement le câble est très bien fabriqué, souple, avec des connecteurs Cinch qui se dévissent puis se revissent très rapidement et sûrement.
Jusqu’à aujourd’hui je me contentais d’un QED Performance Audio 40i pour relier un Atoll AM100 à un
CXA81. Bien m’en à pris d’y réfléchir. Dès le branchement l’écoute à immédiatement apporter une clarté et une précision dans les médiums et les aigus. Avec du Rocket 11 pour les graves et du Viard Audio Premium HD pour les aigus qui font chanter des petites Monitor Audio Silver 50 7G, l’écoute est devenue excellente.
Davor R.
Davor
A long-time user of only class A and tube amplifiers, this is a new great experience. I couldn't believe my ears how deep, wide and clean it sounds full of the most subtle informations, uniform and connected from bottom to the top into one huge picture full of beautiful natural details. This amp sounds just like your source, cables and speakers do.No less, no more,but beautifully big...Outstanding !!!. Perfect match with Topping pre90
Francois B.
MATRIX ELEMENT S Streamer DAC USB I2S SPDIF WiFi DLNA AirPlay 2 32bit 768kHz DSD512 With the Element S, Matrix Audio unveils an excellent, versatile, practical and powerful streamer that will allow you to bring your HiFi system into the world of audio...
Très bien, mais...
Produit bien protégé par Audiophonics (toujours au Top), d’autant que le packaging du Matrix est sympa, le produit est dans une petit sac simple avec poignée, le tout dans son package.
En quelques mots, c’est un lecteur audio/réseau sans Dac (Player) avec une bonne connectique. Le produit est mini.
La mise en route se fait par un système de QR code (m’ouais, j’ai un peu galéré, il me disais non valide sans arrêt lors du Scan) via une iDevice et l’application Matrix MA.
Une fois en route, pas de soucis, mais uniquement en anglais ou… chinois.
Après plus de 15 heures d’utilisation avec SSD 2 To et fichiers Flac (avec dac Hegel HD20 + ampli Hegel H190 et enceintes Sonus Faber Venère 3/0, c’est excellent, et je trouves l’ensemble un peu plus « défini - détails qui ressortent mieux » qu’avec mon autre lecteur audio Pioneer NAE 50) sur la même configuration.
Maintenant les choses qui m’agacent : c’est la reconnaissance des Tags des fichiers, que je fais manuellement et vérifiés, c’est très sujet à l’incomprehension (pourtant je n’ai aucun soucis sur les mêmes fichiers sur Walkman Sony (pourtant pénible a ce sujet) ou Shanling)
En fait c’est un peu la panique, il m’affiches parfois des infos dans les tags (que je sais même pas d’ou cela vient, je vérifies encore et encore, je refais = rien a faire, on gère, mais le pire c’est l’affichage avec le classement par artiste (ou autres choix dans les onglets de classement aussi), certes au niveau du nom d’Artiste, ça va, autant il cherches a mettre les photos des artistes qu’ils ne trouvent pas, ou quand il en trouves c’est pas le bon !!! Bref c’est un peu ‘’naze’’. (Attention aux mêmes noms de fichier/track si artistes différents, il mélangera tout, comme chez Shanling, chinois aussi …
tiens tiens !). Par exemple, il ne met (ou trouves rien a mettre) rien pour des artistes comme Vangelis, ou Diana Krall etc… reconnaissance surement plus adapté a des artistes du continent asiatique ou carrément chinois.
Par contre pour l’affiche des pochettes d’albums c’est tout bon a 99,9 %
Ceci dit, je ne regrettes pas mon achat, c’est un très bon produit.
Todor S.
Great device!
I have a USB powered DAC and I could hear the noise from my desktop PC. To solve this problem I use iFi iDefender+ in combination with Allo Nirvana and everything works perfectly. The noise is completely gone and the sound quality has improved significantly. Highly recommended device!
Joan M.
Very solid product
This is a very solid product you can trust when building your next DIY project.
Front panel is aluminum, very elegant finish
Rear panel is steel so you will need cobalt or titanium drill bit.
Fortunately for us IEC rectangle and fuse holder are already drilled
Jean-Francois B.
Parfait!
J'utilise cet adaptateur sur mon Hugo2 et franchement c'est du solide. J'en ai pas mal d'autres de ce type mais d'autres marques et c'était faux contact sur faux contact! Avec celui là, c'est parfait.
Alain S.
E1DA POWERDAC V2.1 Headphone Amplifier FDA TAS5558 320mW 32 Ohm E1DA's FDA PowerDAC V2.1 headphone amplifier builds on the excellent foundation of its predecessor, the PowerDAC V2, while now allowing operation with both balanced and...
Le seul FDA pour casque du marché
Produit exceptionnel à de nombreux égards ...
Il a l'audace d’être à la fois moins cher et meilleur que tous ces concurrents dans le domaine (sans parler des possibilités de réglages inédites).
Si vous aimez l'écoute aux casque et intras foncez !!!
WONDOM AA-AB31471 Class D Mono Amplifier Module TPA3110 30W 4 Ohm The Wondom AA-AB31471 is a small, simple and efficient Class D mono amplifier module. It includes a TPA3110 TI chip to enable it to provide a power of 30W for an efficiency of...
Wondom AA-AB31471 review
I bought this little amplifier for my portable system with JBL Control 1 Pro speaker. It is incredible what this little amp can do, it makes declared 30W with the 19Vdc power supply. I posted a review at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/wondom-aa-ab31471-1-x-30-watt-class-d-amplifier-board-review-and-measurements.46972/
laurent A.
Discret et efficace
Merci a Audiophonics pour l'efficacité.
Dac discret, bon son naturel, son mat et flatteur avec les enregistrements de moyennes qualités.
Parfait pour le prix
Ruben B.
a well build super clean amp
It's a great clean amp, a class D amp that does not sound like one like all NCore amps, it's just gain on a wire. Build quality is good, design is basic, but so is the price compared to other builds. The only complain is that the led on the power buttom is way to bright (but modable).
Pascal B.
En remplacement de 4 patins Linn Skeet en fonte d’alu , ces contrepointes font merveille sous les pointes de mes plateaux supportant mes deux lecteurs Luxman ( D05 pour les cds et PD171 pour les vinyles)
Amélioration de la spacialisation et du réalisme de la scène sonore . Je suis ravi .
Décidément, Audio Bastion est une marque qui sait lutter contre les perturbations dues aux vibrations !
excellent raport qualité prix
Cette alimentation est vraiment silencieuse et enlève le stress sur le hautes fréquences. Précision : elle est connectée sur un boitier de filtrage du courant du secteur. Pour le prix, elle est parfaite.
ATAUDIO POLARIS Power Cable Schuko IEC C15 Shielded Silver Plated OFC Copper 1.5m The ATAudio Polaris power cable is of exceptional quality and uses extremely pure conductors. Of the six insulated conductors in the Polaris, three are made of OFC 7N copper and...
qualité
Câble bien construit avec des fiches de qualité. Utilisé entre la prise secteur et mon transformateur de filtrage de courant, il conserve la dynamique de mon système. Il est parfait pour un prix très raisonnable.
Hector S.
Banana Plugs Silver Plated Ø5mm (Pair) These low-cost banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers. The contacts are silver plated to ensure excellent signal...
Excellentes
L'efficacité du maintien est admirable, la fabrication est exemplaire. Elles s'insèrent avec douceur dans les prises des appareils.
C'est du zéro prise de tête; exactement le type de petits matériels qu'il est utile de toujours avoir en réserve.
Bastiaan v.
parfait, très content
Acheté en remplacement d'un IFI Zen V2 qui n'arrêtait pas de faire des micro coupures dans le flux. Un violon qui se coupe ce n'est pas possible.
Aussitôt branché, aussitôt trouvé par l'ordinateur. Le son est parfait, un peu plus chaud et un poil moins défini que le processeur Sabre de l'IFI Zen, mais ce sont des affaires de gout.
Pour 65 euro c'est un appareil fantastique, bien construit. Et surtout, depuis 4 heures d'écoute aucune coupure, même si j'ai traversé la pièce et donc les ondes Bluetooth des nombreuses fois. Envoi rapide, rien a dire.
Laurent B.
TRIANGLE SYMPHONIE SYS25A Speaker Cables OFHC Copper Silver Plating 2.5m (Pair) The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors...
Agréablement étonnant !
Dubitatif quant à la nécessité de changer mes bon vieux et basics câbles d'enceintes.
J'en reconnait l'utilité maintenant avec ces "câbles triangle symphonie".
Je n'ai pas changé d'enceintes (des triangles) et pourtant !
Plus de détails dans tous les registres , moins d'agressivité et plus de finesse dans les aigus, des médiums enchanteurs et des basses plus profondes et tendues.
Je redécouvre des morceaux de musique avec des détails non perçus auparavant et pensait que mes enceintes donnaient déjà leur maximum, il n'en était rien.
Câble de qualité de fabrication reçu rapidement par Audiophonics.
Rien à redire.
