André A.
Fais le job
Produit correspond à la description. Très simple d'utilisation, léger compact bref parfait pour lire ou ripper support....
Luca C.
Panos M.
Its more my personal taste
Customers reviews - There are 19586 reviews.
Jean-Marie B.
Qualité et subtilité du son
J'ai acheté un 2 em pour mettre entre la platine CD et l'ampli HG MARANZ pm8006 ..une seulle critique et un défaut a signaler au fabricant ''les slots dans lesquels rentre les tubes sont de mauvaises factures car les lampes fournient 6k4 pour les rentrer c'est du délire de fou
gilbert d.
Pour une enceinte centrale
gilbert d.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 5.6µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
gilbert d.
gilbert d.
DAYTON AUDIO RS125-4 Reference Speaker Driver Midbass 30W 4 Ohm 90dB 65Hz - 5400Hz Ø13cm Combining a sophisticated motor with 2 separate internal electrical shortcuts, and an ultra-rigid aluminum cone, the transducers in this series dethrone many more expensive...
Pour une enceinte centrale diy
gilbert d.
Ovidiu P.
MINIBOSS PLAYER PLUS Volumio Streamer DAC 32bit 384kHz Amplifier 2x50W 4 Ohm Like its big brother the Boss DAC, this Allo MiniBoss Player Plus is a high-resolution digital-to-analog (DAC) converter based on the MonoBoss DAC module equipped with a PCM5122...
Awesome little streaming combo!
If its power is enough for your speakers this is a pleasure to use and listen to. I would even say it is amazing in this price range.
I replaced the preinstalled Volumio with MoodeAudio and this little streaming amp + DAC is now giving me a lot of joy.
However my advice to potential buyers is to replace the SD card with a higher quality one. You should also use a high quality power supply for the RPI zero w and if possible disable the onboard Bluetooth as it seems to interfere with the WiFi chip.
Lionel B.
J'ai monté ce câble avec des Furutech CF-102 en liaison numérique entre Bluray et processeur en remplacement d'un câble O2A Elegance.
Bien que ce dernier me donnait pleine satisfaction il n'y a pas photo. Ce câble Furutech ramène une foule d’informations supplémentaires. La dynamique est nettement améliorée. Un rapport prix / agrément imbattable comme souvent avec Furutech (Compter une dizaine d'heures de rodage pour ôter toute agressivité)
Panos M.
Quite nice to build uppon
For its price it is really a no-brainer. Using a few of them and if you are up to it, use muses3 opamps, change the clock and use dedicated cpu's on all sections, removing the onboard regulators.
Then this baby can sing
Michel B.
Solide, bien construit avec des composants de qualité, suffisamment lourd pour ne pas être soulevé par les câbles qui y sont branchés, excellent donc.....bon ce n'est qu'une boîte noire qui n'est pas particulièrement jolie mais je suis sûr qu'il y a plus horrible sur les étagères !
Patrice J.
DIY USB type B Male Connector Gold / Nickel Plated This USB-B connector is ideal for making your own USB cable or repairing a faulty connector. The contacts are made of copper alloy with gold plating on the outside and nickel...
Connecteur USB B d'excellente qualité pour fabriquer un câble numérique. En ce qui me concerne, j'ai reçu cet article sur lequel il manquait une fiche pour souder un des conducteurs du câble numérique (en théorie au nombre de quatre).
Après avoir signaler cet incident, le SAV d'Audiophonics m'a renvoyé un connecteur conforme, montrant ainsi leur sérieux et le besoin de satisfaire sa clientèle.
Bravo Audiophonics pour votre professionnalisme !
Dragoljub Ć.
Cyberpunk
Really great with FLAC material using foobar2000 and RetroArch upsampler, and also my own electronic music in Ableton Live, going through RME Fireface UCX II at 192kHz (98kHz in Ableton Live), the original cable, and some cheap 3.5mm to 1/4" adapter. Also very good with Moondrop Dawn 4.4mm over phone and CTU-01 cable, although I didn't get it to work in higher bitrates on my phone yet. I'm not sure, but I think I need to get some app for that. It seems like it has less bass compared to listening from the RME interface. Which seems reasonable considering that RME has an external power supply.
This is my first pair of IEMs. But I've used Behringer Truth B2030A and AKG K 271 MKII.
Having two types of drivers seems very basic, at least in modern terms, but it's part of a world of miniaturized Hi-Fi sound systems which fit into your ear.
Yes, my initial assumptions were confirmed. This is the closest thing we have to a virtual reality device like some of the devices described in novels of ... ah, help... the guy who wrote Neuromancer, yes, William Gibson.
Balanced armature - who cares what it means. It screams cyberpunk.
Luc M.
CYP CPLUS-V11PE8 HDMI Audio Extractor 4K60 LPCM 7.1 with EDID Management and RS-232 Control This HDMI audio extractor can retrieve up to 8 channels of the LPCM stream from an HDMI source, allowing you to convert a high-quality HDMI audio stream into a multi-channel...
Tres Pratique
Me permet d’attaquer mon DAC en 192 Khz en provenance d'une source HDMI avec protection HDCP 2.0
Christophe G.
Très bon connecteur
J'ai commandé ce connecteur pour une alimentation externe à un préamplificateur. Le connecteur me permet de connecter le coté négatif, la masse et le coté positif. En plus, j'ai connecté la terre sur le boitier du connecteur, de façon à relier le boitier du préampli à la terre.
Marco P.
IAN CANADA DUAL MONO PLUS DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
Very Good
I built a streamer-DAC on Volumio platform and this hat was simply surprising. With transformers output and a linear supply it gives great reproduction results. Smooth and clear timber, stable scene. To me it's really good solution, better than other I implemented in the past. Cost is a bit high but you will be rewarded with good sonic performance
Jean Paul T.
Absorbant vraiment efficace
Produit très bien réalisé, facile à utiliser, diminution des résonnances internes très importante, mesure "perso" d'environ 15 dB à partir de 600 Hz , de loin largement supérieur à de la ouate en vrac. Devrait supprimer l'effet de boite, et donner un son beaucoup plus naturel.
Werner H.
NEOTECH STDCT-20 Hook-Up Wiring Multi-Strands UP-OCC Copper PTFE 0.52mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
very good product
Werner H.
NEOTECH STDCT-18 Hook-Up Wiring Multi-Strands UP-OCC PTFE 0.8mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
very good product
Werner H.
very good product
Werner H.
very expensive but very good product
Fabien C.
NEOTECH NES-5001 Speaker Cable UP-OFC Copper 2x4mm² Ø15mm The Neotech NES-5000 series incorporates UP-OFC Ultra Pure Copper conductors while ensuring an affordable price. The NES-5001 consists of two conductors with a cross-section of...
Fait le café
Un très bon câble. Pour ma part, le registre grave s'est amélioré. Beaucoup plus de matière, de profondeur et surtout mieux contrôlé. Pour le reste du registre (médium, aigu) un peu plus d'aération dans le haut du spectre (lumineux ?).
Pour la qualité du câble en lui-même : câble très souple malgré sa taille. En parlant de taille :), il faut faire attention à la découpe. La gaine extérieure est très tendre donc les gaines des conducteurs sont très vite atteints. Dans l'ensemble très content de l'achat et un rqp pas trop mal.
Quant à Audiophonics, parfait comme d'habitude.
Config : RME ADI-2 DAC FS (tu parles d'un nom... :), Simply Italy, B&W 705 Signature, source Audirvana
Chére mais efficace
Fais presque aussi bien que sa grande sœur de la même marque pour un prix moindre qui reste élevé toutefois . Restitution d' un grand naturel ou rien ne manque .
Ludovic M.
Commandé pour reparer un preampli JC concept
Identique a l’original.tres fin a l’ecoute
Jean-Michel N.
beaucoup plus de plaisir....
Amélioration dans tous les registres.vives recommandations.
Dominique L.
Un amplificateur audiophile basique
J'ai commandé le premier amplificateur Audiophonics K214 V2 le 24/11/2020, puis un deuxième qui arrive prochainement. Suite à un rodage de cent heures, le son n'était toujours pas chaud alors je l'ai gardé comme amplificateur de dépannage sans trop comprendre pourquoi le mien conservait un son froid, creux, analytique.
Je m’en suis servi de temps en temps et j'ai constaté une nette amélioration du son avec une chaleur bien venue. J'ai réalisé le test avec le casque Beyerdynamic DT 770 PRO qui m'avait servi pour le rodage de l'amplificateur à sa réception. J’ai d’ailleurs utilisé d’autres casques pour les tests. Ce casque semble être une bonne association avec cet amplificateur. J’ai utilisé mon PC et YouTube (la sortie est paraît-il en PCM 2.0). La différence entre le premier test et le deuxième est incommensurable. J’ai du mal à croire à un effet psycho-acoustique et je pense plutôt qu’il est question ici d’un vieillissement des composants utilisés car il est bien question d’un montage audiophile classique de classe A à transistor. Ce qui complique la donne, c’est que la source n’est pas stable comme avec du matériel HIFI classique en raison du fait qu’il est question d’un objet connecté supportant de nombreuses mises à jour, en l’occurrence Windows 10 puis Windows 11.
Il n’y a pas beaucoup d’amplificateur à transistor mais plutôt à AOP (Amplificateur Opérationnel), il y a également le MONOLITH LIQUID SPARK qui est à transistor mais il utilise des composants de surface plus modernes, il représente également une exception dans les amplificateurs pour casque dans sa catégorie.
Nnanna E.
FIIO KA2 LIGHTNING Portable DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 With the KA2, FiiO offers a powerful and affordable portable DAC and headphone amplifier combo, allowing you to enjoy the best possible sound quality both on the road and at...
Decent DAC for iPhone
Listening to music on this DAC is impressive and you can tell FiiO engineered a good device with quality components. It gets loud enough if you like a bit more power but doesn’t drive full size headphones to their full capacity. Distortion can be heard on certain earphones only at very high volumes but below that it is a pleasure to listen to
Maurizio B.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Silver Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Perfectly transparent Preamp
I decided to add the Pre90 plus the EXT90 to the D90SE to avoid switching my cables between my home theatre processor and the D90SE. I was not sure how to do it, but a quick email to Topping support provided a perfect solution: add a custom button to the Home Theatre setup with 00db attenuation and the other to the stereo setup. Voilà! After many years I have the perfect solution for my needs. On top of that, the Pre90 is as transparent as it gets and I did not notice any difference by adding it.
MUNDORF SUPREME SILVERGOLD OIL Capacitor 1000V 0.47μF The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and...
Le meilleur que j’ai pu écouter .un équilibre ,une douceur,aération et précision.
Excellent câble pour réaliser un câble de modulation, le mien est en fiches RCA. Le son est transparent, toutes les fréquences passent bien, c'est net et précis, merci Audiophonics !!
Jean-Pierre L.
satisfait
excellent produit. livré dans les temps. bien empaqueté
Jean-Pierre L.
satisfait
Jean-Pierre L.
satisfait
Jean-Pierre L.
satisfait
Jean-Pierre L.
satisfait
produit excellent. livré ans les temps. bien empaqueté.
Patrick D.
SMSL SU-10 DAC
J'ai longtemps possédé un AURALIC VEGA de 2016 dont je fus très satisfait: dynamique, transparence, large scène sonore (son holographique), très précis mais pas analytique donc très musical....mais le SMSL SU-10 qui a la même signature sonore va encore plus loin... et d'une façon notoire (au moins 20%).
Je remercie Audiophonics pour son honnêteté puisque m'a longtemps conseiller de rester avec mon Auralic et de ne pas en changer inutilement pour un autre... mais c'était sans compter l'arrivée sur le marché du SMSL SU-10 avec un rapport qualité/prix exceptionnel.
Bernard G.
Rapport qualité prix douteux!!!
Dans la description de ce produit,il est spécifié que l'isolation est en
téflon! Or,lors de la soudure des conducteurs,cet isolant de couleur
noire s'est mis à fondre!!!! J'ai donc un doute sur le fait que cet
isolant soit en téflon!!! D'autre part,l'emplacement pour souder le
conducteur canal gauche est très mal conçu par rapport à celui du
canal droit! À ce niveau de tarif,ce n'est pas acceptable!
Très bon câble pour fabriquer un cordon de modulation RCA.
Rémi L.
A ce prix, autant passer en actif
Après l’avoir utilisé sur des colonnes Davis (passives) avec beaucoup de satisfaction en remplacement d’un Marantz, j’ai souhaité pousser mon système plus loin. J’utilise donc désormais cet ampli sur des bibliothèques DIY 2 voies actives (deux amplis donc) équipées de hauts parleurs SB Acoustic (Design inspiré des enceintes Buschardt S400MKII/A500). Le filtrage actif / Crossover est assuré par un Mini DSP NanoDigi (fonctionnement full digital) et la source étant un PC via la sortie optique. J’utilise des cordons mini-coax / SPDIF entre le DSP et les amplis. Les deux amplis sont alimentés par une alimentation unique SMPS300RS 24V qui avec ses 300W encaisse largement les deux amplis pour un rendu et une dynamique excellente avec des grave bien tenue. Sur les amplis, le câblage interne a été remplacé par du fil cuivre plaqué argent + quelques autres modifications.
Le rapport qualité prix du système en filtration active est assez incroyable et même en version d’origine en usage passif, c’est un excellent appareil que j’ai fait acheter à bon nombre d’amis qui eux-mêmes sont conquis
Bert D.
Heel handig
Voelt betrouwbaar aan vanwege stevige afwerking en prettige bediening. Lekker veel ingangen.
Bert D.
Very diverse and good looking
It's a very handsome and diverse device and above all very good sounding.
Bert D.
Good quality
Build quality is very good for its price.
Bert D.
DYNAVOX Gold Plated Banana Plugs Ø5mm (Pair) These low-cost Dynavox banana plugs allow a simple and quick connection to the terminals of your speakers and amplifiers. The contacts are gold plated to ensure good signal...
Robust
Good connecting and installation quality for little money.
Bert D.
Alright
It does the thing it has to do, without spending much money.
Gabriel V.
TONEWINNER AT-7300HD AV Processor / Home-Theater Preamplifier Dolby Atmos 13 Channels 7.2.4 The Tonewinner AT-7300HD is a 13-channel audio/video processor and preamplifier, ideal for home theater integration in configurations up to 7.2.4. It supports all current audio...
Super content ,comme toujours audiophonics ma expédié la commande super rapidement. Le produit a un bon packaging et il respire la qualité. Je posterai un deuxième avis dans quelques temps quand j'aurais assez de recul sur sont utilisation
Claude G.
Prise shuko
Posée sur un câble secteur de qualité standard, apporte plus de matière et de poids au son... bon produit
Silvo P.
Very satisfied
Fast delivery, quality service.
Fabrice j.
very satisfied
good results against the sticky static effect when handling your vinyl and choice between a sharp dry sound on the cork side or a deeper subtle bass on the black side
M A.
nice product, exactly what I was looking for.
works perfectly with the volumio audiophonics on/off plugin.
just a question, there is a connection for an infrared sensor, how does this work? can't find anything about it.
IFI AUDIO GO BAR Portable USB DAC Headphone Amplifier XMOS 32bit 384kHz DSD256 MQA With the Go Bar, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact size, it can accompany you on all your travels...
Si petit, et pourtant....
Bien fini, encombrement mini, caractéristiques de premier plan font de ce Dac portable une alternative à beaucoup de Dac de bureau.
Du grave à l'aigu en passant par le médium, la clarté, la finesse du message sonore procure un réel plaisir d'écoute.
Assez puissant pour dans mon cas piloter un casque de 250 Ohms sans problème.
Très content de cet achat.
