ATAUDIO AT-FR008 RCA Male Connector Ø6mm (Pair)
This ATAUDIO AT-FR008 male RCA connector has a carbon-fiber body and gold-plated pure copper contacts. Its carbon body provides insulation against interference, while the contacts offer optimum conductivity and resistance to corrosion and oxidation.
4.5 / 5
Reference : 18693
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 09-09-2025.
Photo of ATAUDIO AT-FR008 RCA connectors
This ATAUDIO AT-FR008 male RCA connector has a carbon-fiber body and gold-plated pure copper contacts. Its carbon body provides insulation against interference, while the contacts offer optimum conductivity and resistance to corrosion and oxidation. It accepts cables up to Ø6mm diameter.
Photo of ATAUDIO AT-FR008 RCA connector dimensions
Product typeMale RCA connector
Conductor materialCopper
Contacts platingGold
Max. cable diameterØ6mm
Mounting typeTo weld
Identification rings
Total dimensions37.5 x 12 x 10mm
PackageSold by pair
Max cable diameter (mm)6.0
ConnecticMale
2 reviews
Ok for the money
Good quality for the money bottom diameter is little bit smaller than on scheme so with designated cable need little force than you should be fine. For connection they are solid and tight but no sonic difference from cable direk connection.
This review has been posted for ATAUDIO AT-FR008 RCA Male Connector Ø6mm (Pair)
Rqp au top
Je conseil ces fiches RCA pour ceux qui débutent en diy. Elles sont jolies, de qualité et faciles a souder. De plus, offrent une très bonnes connexion avec les appareils hifi.
This ATAUDIO AT-FR008 male RCA connector has a carbon-fiber body and gold-plated pure copper contacts. Its carbon body provides insulation against...
